Как работать с такой фрезой ?
Rasul
Сообщение Rasul »
Добрый день!
Вопрос такой: Как работать с такой фрезой?
Тип фрезы HN IL 6616 D=10 (20768 просмотров) <a class='original' href='./download/file.php?id=18728&mode=view' target=_blank>Загрузить оригинал (4.04 МБ)</a>
Делаю звездочку:
O0004;
(ZVEZDA)
N1G90G54X-174.23Y-2.71; N2S800M3;
N3M8;
N4G01Z-24.0F500;
N5G41G01D01X-128.47Y-2.71F20;
N6G01X-111.75Y5.03;
N7G03X-104.7Y14.04R11.5;
N8G01X-104.41Y16.02;
N9G03X-108.64Y26.66R11.5;
N10G01X-122.5Y38.79;
N11G02X-109.54Y67.18R128.5;
N12G01X-91.29Y64.65;
N13G03X-80.49Y68.42R11.5;
N14G01X-79.18Y69.93;
N15G03X-76.98Y81.16R11.5;
N16G01X-82.09Y98.86;
N17G02X-55.83Y115.74R128.5;
N18G01X-41.85Y103.74;
N19G03X-30.72Y101.07R11.5;
N20G01X-28.8Y101.63;
N21G03X-20.88Y109.9R11.5;
N22G01X-15.6Y127.55;
N23G02X15.6E127.55R128.5;
N24G01X20.88Y109.9;
N25G3X28.88Y101.63R11.5;
N26G01X30.72Y101.07;
N27G03X41.85Y103.74R11.5;
N28G01X55.83Y115.74;
N29G02X82.09Y98.86R128.5;
N30G01X76.98Y81.16;
N31G03X79.18Y69.93R11.5;
N32G01X80.49Y68.42;
N33G03X91.29Y64.65R11.5;
N34G01X109.54Y67.18;
N35G02X122.5Y38.79R128.5;
N36G01X108.64Y26.66;
N37G03X104.41Y16.02R11.5;
N38G01X104.7Y14.04;
N39G03X111.75Y5.03R11.5;
N40G01X128.47Y-2.71;
N41G02X124.03Y-33.59R128.5;
N42G01X105.81Y-36.31;
N43G03X96.5Y-42.97R11.5;
N44G01X95.67Y-44.79;
N45G03X96.73Y-56.19R11.5;
N46G01X106.61Y-71.73;
N47G02X86.18Y-95.32R128.5;
N48G01X69.38Y-87.75;
N49G03X57.95Y-88.32R11.5;
N50G01X56.27Y-89.4;
N51G03X50.99Y-99.56R11.5;
N52G01X50.91Y-117.99;
N53G02X20.96Y-126.78R128.5;
N54G01X10.93Y-111.33;
N55G03X1Y-105.63R11.5;
N56G01X-1Y-105.63;
N57G03X-10.92Y-111.32R11.5;
N58G01X-20.96Y-126.78;
N59G02X-50.91Y-117.99R128.5;
N60G01X-50.99Y-99.56;
N61G03X-56.27Y-89.4R11.5;
N62G01X-57.95Y-88.32;
N63G03X-69.38Y-87.75R11.5;
N64G01X-86.18Y-95.32;
N65G02X-106.61Y-71.73R128.5;
N66G01X-96.73Y-56.19;
N67G03X-95.67Y-44.79R11.5;
N68G01X-96.5Y-42.97;
N69G03X-105.81Y-36.31R11.5;
N70G01X-124.03Y-33.6;
N71G02X-128.47Y-2.71R128.5;
N72G00G40X-174.23Y-2.71F500;
N73M9;
N74M5;
N75M2;
Тип метала: Сталь 20, толщина 22 мм. При такой обработки фрезы хватает на две - три звездочки.
Подскажите пожалуйста как правельно работать с ней?
Спасибо!
Трудиться - Удел Бога! Халява - Удел Крысы!
rustech
Re: Как работать с такой фрезой ?
Сообщение rustech »
400-500 оборотов, подачу 100 ставь. Послойкой можешь.
Смотря ещё какой съём. Возможно из-за вибраций ломается.
Rasul писал(а):При такой обработки фрезы хватает на две - три звездочки
Gcode мало чем здесь поможет
Свои режимы напиши.
Rasul писал(а):Z-24.0
:wtf: нифигаСе
горит фреза, уменьшай обороты
Rasul
Сообщение Rasul »
aftaev писал(а):Gcode мало чем здесь поможетСвои режимы напиши.
Вы о чем, Я новечек в этом деле
:wtf: нифигаСе
Вот деталь, заготовку готовыя токаря, фрезеровка только по конруру (20743 просмотра) <a class='original' href='./download/file.php?id=18740&mode=view' target=_blank>Загрузить оригинал (4.96 МБ)</a>
evgenyjp
Сообщение evgenyjp »
Rasul, обработку ведеш торцом или только боковое фрезерование ??
напиши точно:
1. обороты шпинедля ??
2. подачи (F500 судя по Г-кодам)
3. заглубление (по Z - 24мм судя по Г-кодам)
и желательно бы фото станка на котором ето все происходит.
Если ето настоящяя ханита, то ето очень хорошие фрезы и и негоже их так переводить...
Rasul
Сообщение Rasul »
evgenyjp писал(а):обработку ведеш торцом или только боковое фрезерование ??
Торцом за один проход.
evgenyjp писал(а): обороты шпинедля ??
s 800;
evgenyjp писал(а):подачи (F500 судя по Г-кодам)
Смотрите ниже там F20;
evgenyjp писал(а):заглубление (по Z - 24мм судя по Г-кодам)
Сверху в заготовку я не вризаюсь, просто опустился по Z и поехал фрезировать....
SAM_1543.JPG (20724 просмотра) <a class='original' href='./download/file.php?id=18745&mode=view' target=_blank>Загрузить оригинал (4.58 МБ)</a>
evgenyjp
Rasul писал(а): Торцом за один проход.
ниче не понял :)
если сверху не врезаешся тогда ето боковое фрезерование, а выше ты говориш что торцом...
какой шаг прохода(stepover) ???
Rasul
Сообщение Rasul »
evgenyjp писал(а):если сверху не врезаешся тогда ето боковое фрезерование, а выше ты говориш что торцом...
Так точно ! :lol:
evgenyjp писал(а):шаг прохода(stepover)
А это что ?
Rasul писал(а): Я новечек в этом деле
evgenyjp
Rasul писал(а):
А это что ?
Rasul
Сообщение Rasul »
Всеровно не понел)))) у меня фреза а не резец,
evgenyjp
Rasul писал(а):Всеровно не понел)))) у меня фреза а не резец,
ето для наглядности, неважно фреза или нет.
с боку по сколько мм фрезой сдираеш ? или на весь диаметр хреначиш ? :hehehe:
Rasul
Сообщение Rasul »
полностью врезаюсь в зуб (звездочки), на выходе отподает кусочек метала,
evgenyjp
Rasul писал(а):полностью врезаюсь в зуб (звездочки), на выходе отподает кусочек метала,
жесть !
вобщем так,
обороты шпинделя 2500-3000
подача ~ 1500мм\мин (плюс-минус)
боком снимать по 0,3 - 0,5мм не более на этой конкретной фрезе (0,03 диаметра старнартная рекомендация)
по Z можно хоть на всю высоту при боковом фрезеровании (45мм вроде на этой фрезе)
тоесть отстрой траекторию в CAMе так, чтоб фигурку звездочки вырезало послойно, со съемом 0,3мм за слой боком.
и есть у меня подозрение что ето не ханита а подделка, ибо несмог найти рекомендованых производителем параметров.
сколько стоили ети фрезы ??? настоящяя стоит порядка 100 баксов.
Rasul
Сообщение Rasul »
В САМе к сожалению еще не научился работать, А фрезы мы покупали у Альтаир Плюс есть каталог и там есть параметры с них я и вычислил S800 F20, покупали их если меня не обманули за 200 американских...
Rasul, если фрезеруешь на всю глубину то нужно смотреть на стружку, какого размера получается.
20мм сталь кроил подобными фрезами(кукурузой) за 1проход на всю глубину. Обороты 1500 подача 15-20мм/мин. Обязательно нужна СОЖ.
evgenyjp
Rasul писал(а):В САМе к сожалению еще не научился работать, А фрезы мы покупали у Альтаир Плюс есть каталог и там есть параметры с них я и вычислил S800 F20, покупали их если меня не обманули за 200 американских...
ссылка есть на рекомендованные параметры ?
на весь диаметр врезатся ето тоже там было ? :hehehe:
evgenyjp
aftaev писал(а):Rasul, если фрезеруешь на всю глубину то нужно смотреть на стружку, какого размера получается.
ждем вторую сломаную фрезу за 200 баксов :thinking:
evgenyjp писал(а):ждем вторую сломаную фрезу за 200 баксов
Мож лучше тренироваться на "наших" совковых
Rasul
Сообщение Rasul »
aftaev писал(а):если фрезеруешь на всю глубину то нужно смотреть на стружку, какого размера получается. 20мм сталь кроил подобными фрезами(кукурузой) за 1проход на всю глубину. Обороты 1500 подача 15-20мм/мин. Обязательно нужна СОЖ.
Стружка была мелкой почти порошок, а какая она должна быть?
evgenyjp писал(а):ссылка есть на рекомендованные параметры ?
нет у меня каталог на руках
evgenyjp писал(а):на весь диаметр врезатся ето тоже там было ?
этого небыло, это я сам
Вернуться в «Инструмент»
