GladeVCP и PyVCP для начинающих
Re: GladeVCP и PyVCP для начинающих
Сообщение nkp »
Попробовал-думаю наверно придется разбивать программу на несколько отдельных.
(кнопка пробы неактивна)
Виталий
Сообщение Виталий »
nkp писал(а):(кнопка пробы неактивна)
да правда.думаю может коректировать постпроцессор (арткамовский)
Виталий
Сообщение Виталий »
вот как он выглядит (постпроцессор)
; Mach3 PostP file arc moves in MM with ATC
;GW 3/14/08 created for Arc(MM) with toolchange
;GW 4/6/09 Revised formatting and sequence
;GW 4/6/09 Added tool description & tool length offset to tool change
;GW 10/25/09 Added toolnumber and tool description for Start & New Segment
;GW 10/25/09 Added New Segment to allow forced RPM change on same tool #
DESCRIPTION = "Mach3gb-MM-Arcs-ATC(*.TAP)"
FILE_EXTENSION = "TAP"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.0]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.4]
FORMAT = [Y|#|Y|1.4]
FORMAT = [Z|#|Z|1.4]
; Arc Center Coords
FORMAT = [I|@|I|1.4]
FORMAT = [J|@|J|1.4]
; Home tool positions
FORMAT = [XH|@|X|1.4]
FORMAT = [YH|@|Y|1.4]
FORMAT = [ZH|@|Z|1.4]
; Tool Number
FORMAT = [T|@||1.0]
; Set up program header
START = "([FILENAME])"
START = "G90G80G21G49"
START = "M6 T[T]"
START = "(Tool Number:[T]) ([TOOLDESC])"
START = "G43 H[T] G0[ZH]"
START = "M3 [S]"
; Program moves
FIRST_RAPID_RATE_MOVE  = "G0 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE   = "G1 [X] [Y] [Z] [F]"
FEED_RATE_MOVE         = "[X] [Y] [Z]"
FIRST_CW_ARC_MOVE      = "G2 [X] [Y] [I] [J] [F]"
CW_ARC_MOVE            = "G2 [X] [Y] [I] [J]"
FIRST_CCW_ARC_MOVE     = "G3 [X] [Y] [I] [J] [F]"
CCW_ARC_MOVE           = "G3 [X] [Y] [I] [J]"
NEW_SEGMENT_POST_TOOLCHANGE="(Tool Number:[T]) ([TOOLDESC])"
NEW_SEGMENT_POST_TOOLCHANGE= "M3 [S]"
;Setup Toolchange Commands
TOOLCHANGE = "G0[ZH]"
TOOLCHANGE = "M5"
TOOLCHANGE = "G49"
TOOLCHANGE = "M6 T[T]"
TOOLCHANGE = "G43 H[T] G0[ZH]"
; End of file
END = "G0[ZH]"
END = "G0[XH][YH]"
END = "M5"
END = "M30"
; M30 = program end and rewind
Сообщение nkp »
тут вопрос в другом-в неудобстве загрузки нескольких частей-программ.
попробую все таки с ладдером решить
(кстати,можешь ссылочку дать-где ты решение с ладдером надыбал?)
Виталий
Сообщение Виталий »
минутку
Сообщение nkp »
спасибо,поштудирую
А вариант в Gкод вставить o<touchoff> call чем не устраивает?
Виталий
Сообщение Виталий »
гдето читал что можна менять ,переназначать команды. например при команде M6 от выполняет указаный заведома ж код ,или это бред сивой кобылы?
Виталий
Сообщение Виталий »
для меня понять это не реально,остается ждать мастер класс, в очередной раз
Сообщение nkp »
А какой код вместо М6 должен выполнятся ?
А может (как советовал Ник) так :
G90 G80 G21 G49
M6 T2
o<touchoff> call
G43 H2 G0 Z5.0000
M3 S15000
G0 X29.9702 Y49.9998 Z5.0000
G1   Z-2.5000 F3000
G2 X50.0105 Y70.0283 I20.0297 J-0.0011 F4560
G2 X70.0296 Y49.9785 I-0.0106 J-20.0297
G2 X49.9893 Y29.9747 I-20.0297 J0.0259
G2 X29.9702 Y49.9998 I0.0106 J20.0297
G1   Z-5.0000 F3000
G1   Z-7.5000 F3000
G1   Z-10.0000 F3000
G0   Z5.0000
M5
G49
M6 T1
o<touchoff> call
G43 H1 G0 Z5.0000
M3 S15000
G0 X30.6250 Y20.6250 Z5.0000
G1   Z-10.0000 F780
G2 X21.6250 Y29.6250 I0.0000 J9.0000 F2520
G1  Y70.3750
G2 X30.6250 Y79.3750 I9.0000 J-0.0000
G1 X69.3750
G2 X78.3750 Y70.3750 I0.0000 J-9.0000
G1  Y29.6250
G2 X69.3750 Y20.6250 I-9.0000 J-0.0000
G1 X30.6250 Y20.6250
G0   Z5.0000
G0 X0.0000 Y0.0000
G0 Z5.0000
G0 X0.0000 Y0.0000
M5
M30
Виталий
Сообщение Виталий »
nkp писал(а):А может (как советовал Ник) так :
прикольно уже ближе,надо думать как сделать так чтобы не редактировать ж код в ручную.
Сообщение nkp »
проще всего подправить постпроцессор (это и есть его предназначение :) )
может как то так:
START = "M6 T[T]
o<touchoff> call "
потому как так:
START = "M6 T[T]  o<touchoff> call "
не работает
в общем надо чтоб он добавлял к коду М6 строку o<touchoff> call
(У меня полетел винт с виндой - "сгорела" сама железяка.Поэтому сам проверить пока не могу)
Виталий
Сообщение Виталий »
вопрос,где можна почитать о таблице инструментов,реально ли настроить сам инструмент чтобы он отображался так,как в визуализации уп арткама
Сообщение nkp »
Виталий писал(а):вопрос,где можна почитать о таблице инструментов,
http://www.linuxcnc.org/docs/2.5/html/g ... -Specifics
http://wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolTable
Последний раз редактировалось nkp 08 июл 2012, 12:26, всего редактировалось 1 раз.
Виталий
Сообщение Виталий »
спасибо
Виталий
Сообщение Виталий »
реально ли изменить форму инструмента ?допустим на v оброзную фрезу.если да то как прописать
Сообщение nkp »
есть скрин или другая картинка того инструмента ,который хочешь ?
Виталий
Сообщение Виталий »
да есть
Снимок-3.png (2923 просмотра) <a class='original' href='./download/file.php?id=6358&mode=view' target=_blank>Загрузить оригинал (363.28 КБ)</a>
