tapered line endings
schoggi
Сообщение schoggi »
Hello there
what is the way to go for the machine to engrave tapered lines with inkscape??
the way that the cutting head Comes slowly out of the path, but still engraves, finer and finer until not touching material anymore.
:thinking:
I hope you understand my bad english.. my russian is even worse ;-)
thanks in advance
Re: tapered line endings
Can you attach any image... I can not imagine where it can be used...
Алексс
Заслуга: IQ32
Сообщение Алексс »
schoggi
Сообщение schoggi »
Thanks guys, will upload a pic of the thing tomorrow, I want to make an Ornament with very fine endings..
but here s already an attempt to explain..
the red dot is the maximal width of the engraving point, so you see I cannot reach the desired Corners.. only by defining the Z axis it would be
possible..
i hope it s a little more clear now.. ok .. it can seem I want too much.. and I raised the bar to high but it s really needed to make the finest engravings
pointy endings should really be pointy ;)
Screenshot (223).png (19474 просмотра) <a class='original' href='./download/file.php?id=20882&mode=view' target=_blank>Загрузить оригинал (152.87 КБ)</a>
schoggi
Сообщение schoggi »
yes Alex indeed.. something like v carve, but for metal, and much smaller
spasibo
There's Engraving function which makes path for this kind of machining.
And a tutorial on it (probably older version, but the whole meaning is the same)
http://kalyaev.com/2010/20100402/tut01/tut01.html
schoggi
Сообщение schoggi »
thanks Maestro
will have a look at it and Keep you informed.. it Looks that s alla bout i Need to know
spasobo bolschoi
schoggi
Сообщение schoggi »
here s an exemaple of what I d like to achieve with inkscape and g code one day..
the red Areas are most visible to Show where milling Point get more high than other Areas
IMG_20131113_091932.jpg (19326 просмотров) <a class='original' href='./download/file.php?id=21236&mode=view' target=_blank>Загрузить оригинал (1.02 МБ)</a>
How do you expect those areas to be cut?
Can you show original svg?
schoggi
Сообщение schoggi »
here is the original,and yes how to be cut??? that s what i ve been wondering about all the time ;-)
:thinking: thanks
Turkish ornament.svg
(101.1 КБ) 2356 скачиваний
Вернуться в «English forum»
