С чем может быть связано сжатие картинки на мониторе? На 17' монике картинка занимает2/3 экрана. При этом  изображение нормальное.
Моник samcyng 720N.
[     8.914]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[     8.915] X Protocol Version 11, Revision 0
[     8.915] Build Operating System: Linux 4.9.0-4-amd64 i686 Debian
[     8.915] Current Operating System: Linux cnc 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686
[     8.915] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=db17af95-c6af-4359-ade4-51f2e3160baa ro initrd=/install/gtk/initrd.gz quiet lapic isolcpus=1 apm=off nmi_watchdog=0
[     8.915] Build Date: 22 November 2017  08:20:30PM
[     8.915] xorg-server 2:1.12.4-6+deb7u8 (Emilio Pozuelo Monfort <pochu@debian.org>)
[     8.915] Current version of pixman: 0.26.0
[     8.915] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[     8.915] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[     8.915] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun 27 11:49:58 2019
[     8.922] (==) Using config file: "/etc/X11/xorg.conf"
[     8.922] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     8.929] (==) ServerLayout "X.org Configured"
[     8.929] (**) |-->Screen "Screen0" (0)
[     8.929] (**) |   |-->Monitor "Monitor0"
[     8.931] (**) |   |-->Device "Card0"
[     8.931] (**) |-->Screen "Screen1" (1)
[     8.931] (**) |   |-->Monitor "Monitor1"
[     8.931] (**) |   |-->Device "Card1"
[     8.931] (**) |-->Input Device "Mouse0"
[     8.931] (**) |-->Input Device "Keyboard0"
[     8.932] (==) Automatically adding devices
[     8.932] (==) Automatically enabling devices
[     8.940] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[     8.940] 	Entry deleted from font path.
[     8.942] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[     8.942] 	Entry deleted from font path.
[     8.942] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[     8.942] (**) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/100dpi/:unscaled,
	/usr/share/fonts/X11/75dpi/:unscaled,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins,
	built-ins
[     8.942] (**) ModulePath set to "/usr/lib/xorg/modules"
[     8.942] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[     8.942] (WW) Disabling Mouse0
[     8.942] (WW) Disabling Keyboard0
[     8.943] (II) Loader magic: 0xb773f5a0
[     8.943] (II) Module ABI versions:
[     8.943] 	X.Org ANSI C Emulation: 0.4
[     8.943] 	X.Org Video Driver: 12.1
[     8.943] 	X.Org XInput driver : 16.0
[     8.943] 	X.Org Server Extension : 6.0
[     8.945] (--) PCI:*(0:0:2:0) 8086:a001:1458:d000 rev 0, Mem @ 0xfdf00000/524288, 0xd0000000/268435456, 0xfdd00000/1048576, I/O @ 0x0000ff00/8
[     8.945] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     8.945] (II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
[     8.945] (II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
[     8.945] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[     8.945] (II) "record" will be loaded. This was enabled by default and also specified in the config file.
[     8.945] (II) "dri" will be loaded. This was enabled by default and also specified in the config file.
[     8.945] (II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
[     8.945] (II) LoadModule: "glx"
[     8.951] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     8.956] (II) Module glx: vendor="X.Org Foundation"
[     8.957] 	compiled for 1.12.4, module version = 1.0.0
[     8.957] 	ABI class: X.Org Server Extension, version 6.0
[     8.957] (==) AIGLX enabled
[     8.957] (II) Loading extension GLX
[     8.957] (II) LoadModule: "extmod"
[     8.958] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[     8.965] (II) Module extmod: vendor="X.Org Foundation"
[     8.965] 	compiled for 1.12.4, module version = 1.0.0
[     8.965] 	Module class: X.Org Server Extension
[     8.965] 	ABI class: X.Org Server Extension, version 6.0
[     8.965] (II) Loading extension SELinux
[     8.965] (II) Loading extension MIT-SCREEN-SAVER
[     8.965] (II) Loading extension XFree86-VidModeExtension
[     8.965] (II) Loading extension XFree86-DGA
[     8.965] (II) Loading extension DPMS
[     8.965] (II) Loading extension XVideo
[     8.965] (II) Loading extension XVideo-MotionCompensation
[     8.965] (II) Loading extension X-Resource
[     8.965] (II) LoadModule: "dbe"
[     8.965] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[     8.967] (II) Module dbe: vendor="X.Org Foundation"
[     8.967] 	compiled for 1.12.4, module version = 1.0.0
[     8.967] 	Module class: X.Org Server Extension
[     8.967] 	ABI class: X.Org Server Extension, version 6.0
[     8.967] (II) Loading extension DOUBLE-BUFFER
[     8.967] (II) LoadModule: "dri2"
[     8.967] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[     8.971] (II) Module dri2: vendor="X.Org Foundation"
[     8.971] 	compiled for 1.12.4, module version = 1.2.0
[     8.971] 	ABI class: X.Org Server Extension, version 6.0
[     8.971] (II) Loading extension DRI2
[     8.971] (II) LoadModule: "dri"
[     8.972] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[     8.973] (II) Module dri: vendor="X.Org Foundation"
[     8.973] 	compiled for 1.12.4, module version = 1.0.0
[     8.973] 	ABI class: X.Org Server Extension, version 6.0
[     8.974] (II) Loading extension XFree86-DRI
[     8.974] (II) LoadModule: "record"
[     8.974] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[     8.976] (II) Module record: vendor="X.Org Foundation"
[     8.976] 	compiled for 1.12.4, module version = 1.13.0
[     8.976] 	Module class: X.Org Server Extension
[     8.976] 	ABI class: X.Org Server Extension, version 6.0
[     8.976] (II) Loading extension RECORD
[     8.976] (II) LoadModule: "vesa"
[     8.980] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[     8.981] (II) Module vesa: vendor="X.Org Foundation"
[     8.981] 	compiled for 1.12.1, module version = 2.3.1
[     8.981] 	Module class: X.Org Video Driver
[     8.981] 	ABI class: X.Org Video Driver, version 12.0
[     8.981] (II) LoadModule: "fbdev"
[     8.982] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[     8.985] (II) Module fbdev: vendor="X.Org Foundation"
[     8.985] 	compiled for 1.12.1, module version = 0.4.2
[     8.985] 	ABI class: X.Org Video Driver, version 12.0
[     8.985] (II) VESA: driver for VESA chipsets: vesa
[     8.985] (II) FBDEV: driver for framebuffer: fbdev
[     8.985] (++) using VT number 7
[     8.986] vesa: Ignoring device with a bound kernel driver
[     8.986] (WW) Falling back to old probe method for vesa
[     8.986] (II) Loading sub module "fbdevhw"
[     8.986] (II) LoadModule: "fbdevhw"
[     8.986] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[     8.987] (II) Module fbdevhw: vendor="X.Org Foundation"
[     8.987] 	compiled for 1.12.4, module version = 0.0.2
[     8.987] 	ABI class: X.Org Video Driver, version 12.1
[     8.988] (**) FBDEV(1): claimed PCI slot 0@0:2:0
[     8.988] (II) FBDEV(1): using default device
[     8.988] (==) FBDEV(1): Depth 24, (==) framebuffer bpp 32
[     8.988] (==) FBDEV(1): RGB weight 888
[     8.988] (==) FBDEV(1): Default visual is TrueColor
[     8.988] (==) FBDEV(1): Using gamma correction (1.0, 1.0, 1.0)
[     8.988] (II) FBDEV(1): hardware: inteldrmfb (video memory: 5120kB)
[     8.988] (II) FBDEV(1): checking modes against framebuffer device...
[     8.988] (II) FBDEV(1): checking modes against monitor...
[     8.988] (--) FBDEV(1): Virtual size is 1024x768 (pitch 1024)
[     8.988] (**) FBDEV(1):  Built-in mode "current"
[     8.988] (==) FBDEV(1): DPI set to (96, 96)
[     8.988] (II) Loading sub module "fb"
[     8.988] (II) LoadModule: "fb"
[     8.989] (II) Loading /usr/lib/xorg/modules/libfb.so
[     8.991] (II) Module fb: vendor="X.Org Foundation"
[     8.991] 	compiled for 1.12.4, module version = 1.0.0
[     8.991] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.991] (**) FBDEV(1): using shadow framebuffer
[     8.991] (II) Loading sub module "shadow"
[     8.991] (II) LoadModule: "shadow"
[     8.991] (II) Loading /usr/lib/xorg/modules/libshadow.so
[     8.993] (II) Module shadow: vendor="X.Org Foundation"
[     8.993] 	compiled for 1.12.4, module version = 1.1.0
[     8.993] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.993] (II) UnloadModule: "vesa"
[     8.993] (==) Depth 24 pixmap format is 32 bpp
[     9.149] (==) FBDEV(0): Backing store disabled
[     9.151] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.152] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.153] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.154] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.155] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.158] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.159] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.160] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.161] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.162] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[     9.162] (==) FBDEV(0): DPMS enabled
[     9.162] (==) RandR enabled
[     9.162] (II) Initializing built-in extension Generic Event Extension
[     9.162] (II) Initializing built-in extension SHAPE
[     9.162] (II) Initializing built-in extension MIT-SHM
[     9.162] (II) Initializing built-in extension XInputExtension
[     9.162] (II) Initializing built-in extension XTEST
[     9.162] (II) Initializing built-in extension BIG-REQUESTS
[     9.163] (II) Initializing built-in extension SYNC
[     9.163] (II) Initializing built-in extension XKEYBOARD
[     9.163] (II) Initializing built-in extension XC-MISC
[     9.163] (II) Initializing built-in extension SECURITY
[     9.163] (II) Initializing built-in extension XINERAMA
[     9.163] (II) Initializing built-in extension XFIXES
[     9.163] (II) Initializing built-in extension RENDER
[     9.163] (II) Initializing built-in extension RANDR
[     9.163] (II) Initializing built-in extension COMPOSITE
[     9.163] (II) Initializing built-in extension DAMAGE
[     9.163] (II) SELinux: Disabled on system
[     9.271] (II) AIGLX: Screen 0 is not DRI2 capable
[     9.271] (II) AIGLX: Screen 0 is not DRI capable
[     9.367] (II) AIGLX: Loaded and initialized swrast
[     9.367] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[     9.724] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[     9.724] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     9.724] (II) LoadModule: "evdev"
[     9.725] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[     9.732] (II) Module evdev: vendor="X.Org Foundation"
[     9.732] 	compiled for 1.12.1, module version = 2.7.0
[     9.732] 	Module class: X.Org XInput Driver
[     9.732] 	ABI class: X.Org XInput driver, version 16.0
[     9.732] (II) Using input driver 'evdev' for 'Power Button'
[     9.733] (**) Power Button: always reports core events
[     9.733] (**) evdev: Power Button: Device: "/dev/input/event4"
[     9.733] (--) evdev: Power Button: Vendor 0 Product 0x1
[     9.733] (--) evdev: Power Button: Found keys
[     9.733] (II) evdev: Power Button: Configuring as keyboard
[     9.733] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event4"
[     9.733] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     9.733] (**) Option "xkb_rules" "evdev"
[     9.733] (**) Option "xkb_model" "pc105"
[     9.733] (**) Option "xkb_layout" "us"
[     9.735] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[     9.735] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     9.735] (II) Using input driver 'evdev' for 'Power Button'
[     9.735] (**) Power Button: always reports core events
[     9.735] (**) evdev: Power Button: Device: "/dev/input/event3"
[     9.735] (--) evdev: Power Button: Vendor 0 Product 0x1
[     9.735] (--) evdev: Power Button: Found keys
[     9.735] (II) evdev: Power Button: Configuring as keyboard
[     9.735] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3/event3"
[     9.735] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     9.735] (**) Option "xkb_rules" "evdev"
[     9.735] (**) Option "xkb_model" "pc105"
[     9.735] (**) Option "xkb_layout" "us"
[     9.737] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event0)
[     9.737] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     9.737] (II) Using input driver 'evdev' for '  USB Keyboard'
[     9.737] (**)   USB Keyboard: always reports core events
[     9.737] (**) evdev:   USB Keyboard: Device: "/dev/input/event0"
[     9.737] (--) evdev:   USB Keyboard: Vendor 0x4d9 Product 0x1603
[     9.737] (--) evdev:   USB Keyboard: Found keys
[     9.737] (II) evdev:   USB Keyboard: Configuring as keyboard
[     9.737] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input0/event0"
[     9.737] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 8)
[     9.737] (**) Option "xkb_rules" "evdev"
[     9.737] (**) Option "xkb_model" "pc105"
[     9.738] (**) Option "xkb_layout" "us"
[     9.739] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event1)
[     9.739] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     9.739] (II) Using input driver 'evdev' for '  USB Keyboard'
[     9.739] (**)   USB Keyboard: always reports core events
[     9.739] (**) evdev:   USB Keyboard: Device: "/dev/input/event1"
[     9.739] (--) evdev:   USB Keyboard: Vendor 0x4d9 Product 0x1603
[     9.739] (--) evdev:   USB Keyboard: Found keys
[     9.739] (II) evdev:   USB Keyboard: Configuring as keyboard
[     9.744] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.1/input/input1/event1"
[     9.744] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 9)
[     9.744] (**) Option "xkb_rules" "evdev"
[     9.744] (**) Option "xkb_model" "pc105"
[     9.744] (**) Option "xkb_layout" "us"
[     9.746] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/event2)
[     9.746] (**) PixArt USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[     9.746] (II) Using input driver 'evdev' for 'PixArt USB Optical Mouse'
[     9.746] (**) PixArt USB Optical Mouse: always reports core events
[     9.746] (**) evdev: PixArt USB Optical Mouse: Device: "/dev/input/event2"
[     9.746] (--) evdev: PixArt USB Optical Mouse: Vendor 0x93a Product 0x2510
[     9.746] (--) evdev: PixArt USB Optical Mouse: Found 3 mouse buttons
[     9.746] (--) evdev: PixArt USB Optical Mouse: Found scroll wheel(s)
[     9.746] (--) evdev: PixArt USB Optical Mouse: Found relative axes
[     9.746] (--) evdev: PixArt USB Optical Mouse: Found x and y relative axes
[     9.746] (II) evdev: PixArt USB Optical Mouse: Configuring as mouse
[     9.746] (II) evdev: PixArt USB Optical Mouse: Adding scrollwheel support
[     9.746] (**) evdev: PixArt USB Optical Mouse: YAxisMapping: buttons 4 and 5
[     9.746] (**) evdev: PixArt USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[     9.747] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.0/input/input2/event2"
[     9.747] (II) XINPUT: Adding extended input device "PixArt USB Optical Mouse" (type: MOUSE, id 10)
[     9.747] (II) evdev: PixArt USB Optical Mouse: initialized for relative axes.
[     9.747] (**) PixArt USB Optical Mouse: (accel) keeping acceleration scheme 1
[     9.747] (**) PixArt USB Optical Mouse: (accel) acceleration profile 0
[     9.747] (**) PixArt USB Optical Mouse: (accel) acceleration factor: 2.000
[     9.747] (**) PixArt USB Optical Mouse: (accel) acceleration threshold: 4
[     9.748] (II) config/udev: Adding input device PixArt USB Optical Mouse (/dev/input/mouse0)
[     9.748] (II) No input driver specified, ignoring this device.
[     9.748] (II) This device may have been added with another device file.
