Ну так это не я постпроцессор сделал, Вот постпроцессор из Vectric Aspire под Mach со сменой инструментаNick писал(а):ЗЫ дочего же не удобно, когда все коды пишутся слитно, да еще и никому не нужные N12312 вставляются
+ Mach2/3 - Vectric machine output configuration file
+ History
+ Who When What
+ Tony 15/11/2005 Written for metric
+ Tony 06/01/2006 Added ATC option
+ Tony 14/05/2006 Fixed G21 mm in header
+ Tony 24/07/2006 Added G2 & G3 Arc support + removed (( ))
+ Mark 14/08/2008 Added G1 to Feed moves, added New_Segment
+ Mark 28/08/2009 Added G91.1 to force use of incremental arcs
+ Added Substitution, File & Toolpath Notes.
+ Mark 30/11/2009 Added TOOLPATHS_OUTPUT.
+ Brian 15/12/2009 Remove M05 from NEW_SEGMENT
POST_NAME = "Mach2/3 ATC Arcs (mm) (*.txt)"
FILE_EXTENSION = "txt"
UNITS = "MM"
DIRECT_OUTPUT = "Mach|Mach4.Document"
SUBSTITUTE = "({)}"
+ Line terminating characters
LINE_ENDING = "[13][10]"
+ Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+ Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|A|X|1.3]
VAR Y_POSITION = [Y|A|Y|1.3]
VAR Z_POSITION = [Z|A|Z|1.3]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
VAR SAFE_Z_HEIGHT = [SAFEZ|A|Z|1.3]
+ Block definitions for toolpath output
+ Commands output at the start of the file
begin HEADER
"( [TP_FILENAME] )"
"( File created: [DATE] - [TIME])"
"( for Mach2/3 from Vectric )"
"( Material Size)"
"( X= [XLENGTH], Y= [YLENGTH] ,Z= [ZLENGTH])"
"([FILE_NOTES])"
"(Toolpaths used in this file:)"
"([TOOLPATHS_OUTPUT])"
"(Tools used in this file: )"
"([TOOLS_USED])"
"[N]G00G21G17G90G40G49G80"
"[N]G71G91.1"
"[N]T[T]M06"
"[N] ([TOOLNAME])"
"[N]G00G43[ZH]H[T]"
"[N][S]M03"
"[N](Toolpath:- [TOOLPATH_NAME])"
"[N]([TOOLPATH_NOTES])"
"[N]G94"
"[N][XH][YH][F]"
+ Commands output for rapid moves
begin RAPID_MOVE
"[N]G00[X][Y][Z]"
+ Commands output for the first feed rate move
begin FIRST_FEED_MOVE
"[N]G1[X][Y][Z][F]"
+ Commands output for feed rate moves
begin FEED_MOVE
"[N]G1[X][Y][Z]"
+ Commands output for the first clockwise arc move
begin FIRST_CW_ARC_MOVE
"[N]G2[X][Y][I][J][F]"
+ Commands output for clockwise arc move
begin CW_ARC_MOVE
"[N]G2[X][Y][I][J]"
+ Commands output for the first counterclockwise arc move
begin FIRST_CCW_ARC_MOVE
"[N]G3[X][Y][I][J][F]"
+ Commands output for counterclockwise arc move
begin CCW_ARC_MOVE
"[N]G3[X][Y][I][J]"
+ Commands output at toolchange
begin TOOLCHANGE
"[N]T[T]M6"
"[N] ([TOOLNAME])"
"[N]G43H[T]"
+ Commands output for a new segment - toolpath
+ with same toolnumber but maybe different feedrates
begin NEW_SEGMENT
"[N][S]M03"
"([TOOLPATH_NAME])"
"([TOOLPATH_NOTES])"
+ Commands output at the end of the file
begin FOOTER
"[N]G00[ZH]"
"[N]G00[XH][YH]"
"[N]M09"
"[N]M30"
+ Emc2 - Vectric machine output configuration file
+ History
+ Who When What
+ Tony 02/08/2005 Written
+ Pieter 20/06/2008 adapted for EMC2, begin + end
+ it uses M7 to start coolant/vacu-cleaner
+ Mark 28/06/2008 Added Arcs and new segment section.
POST_NAME = "EMC2 Arcs(mm)(*.ngc)"
FILE_EXTENSION = "ngc"
UNITS = "MM"
+ Block numbering
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
begin HEADER
"G21 G40 G49 M6 T1"
"G17"
"M7"
"G0[ZH]"
"G0[XH][YH][S]M3"
begin RAPID_MOVE
"G0[X][Y][Z]"
"G1[X][Y][Z][F]"
begin FEED_MOVE
"G1[X][Y][Z]"
"G2[X][Y][I][J][F]"
begin CW_ARC_MOVE
"G2[X][Y][I][J]"
"G3[X][Y][I][J][F]"
begin CCW_ARC_MOVE
"G3[X][Y][I][J]"
begin NEW_SEGMENT
"[S]M03"
begin FOOTER
"G0[ZH]"
"G0[XH][YH]"
"M2"
+ G Code ATC - Vectric machine output configuration file
+ History
+ Who When What
+ Tony 12/03/2006 Added ATC option for Tommy Coates
+ Tony 02/08/2006 Added H offset for ATC
+ Tony 07/08/2006 Created mm version
POST_NAME = "G Code ATC (mm) (*.tap)"
FILE_EXTENSION = "tap"
UNITS = "MM"
+ Block numbering
begin HEADER
"T[T]M6"
"G17"
"G0[ZH]H[T]"
"G0[XH][YH][S]M3"
begin TOOLCHANGE
"M0"
"M06T[T]"
"G43H[T]"
"[S]M03"
begin RAPID_MOVE
"G0[X][Y][Z]"
"G1[X][Y][Z][F]"
begin FEED_MOVE
"[X][Y][Z]"
begin FOOTER
"G0[ZH]"
"G0[XH][YH]"
"M30"
