AG250CNC
botcman
Re: AG250CNC
Сообщение botcman »
При отключении пинов +-10В дрейф пропадает. Пробовал увеличивать Ferror до 40, никаких изменений. Что нужно подкорректировать, чтобы ошибка не вылезала?
botcman
Re: AG250CNC
Сообщение botcman »
# Generated by PNCconf at Sun May 22 23:57:42 2016
# Все изменения в этом файле будут перезаписаны
# overwritten when you run PNCconf again
[EMC]
MACHINE = mill
DEBUG = 0
[DISPLAY]
PYVCP = Panel.xml
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/q/Рабочий стол/Программы
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 5.0000
MAX_LINEAR_VELOCITY = 60.000000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
PROGRAM_EXTENSION = *,.png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i20
[HAL]
HALUI = halui
HALFILE = stanok.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
MAX_ANGULAR_VELOCITY = 360.00
DEFAULT_ANGULAR_VELOCITY = 36.00
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 8
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 40
MIN_FERROR = 1
MAX_VELOCITY = 50.0
MAX_ACCELERATION = 200.0
P = 10.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0
ENCODER_SCALE = 1000
OUTPUT_SCALE = 1.0
MIN_LIMIT = 0.0
MAX_LIMIT =400.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 15
HOME_LATCH_VEL = 0.1
HOME_FINAL_VEL = 5
HOME_USE_INDEX = yes
HOME_SEQUENCE = 1
HOME_IGNORE_LIMITS = no
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 40
MIN_FERROR = 1
MAX_VELOCITY = 50.0
P = 10.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0
OUTPUT_SCALE = 1.0
MIN_LIMIT = 0
MAX_LIMIT = 300.0
HOME_OFFSET = 0.0
HOME_FINAL_VEL = 5
HOME_SEQUENCE = 1
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 40
MIN_FERROR = 1
MAX_VELOCITY = 50
P = 8.0
I = 0.0
D = 0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0
DEADBAND = 0.0
MAX_OUTPUT = 0
OUTPUT_SCALE = 1.0
MIN_LIMIT = 0
MAX_LIMIT = 400.0
HOME_OFFSET = 0.0
HOME_FINAL_VEL = 5
HOME_SEQUENCE = 1
# Spindle
[SPINDLE]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
OUTPUT_SCALE = 1.0
botcman
Re: AG250CNC
Сообщение botcman »
Посоветуйте, куда копать, пожалуйста :wik:
MGG
Re: AG250CNC
Сообщение MGG »
Начни с того, что P снизь до 1
dtw.moscow@gmail.com
botcman
Re: AG250CNC
Сообщение botcman »
Ок. Попробую.
Re: AG250CNC
P = 50 - Пропорциональное усиление для совместного сервопривода. Это значение умножает погрешность между командой и фактическим положением в машинных единицах, что приводит к вкладу в вычисленное напряжение для усилителя двигателя. Единицы на коэффициенте усиления P являются вольтами на единицу машины, например, volts/unit
При P = 0 на выходе PID всегда будет тишина.
FF0 = 0 - Коррекция вперед 0-го порядка. Это число умножается на командную позицию, что приводит к вкладу в вычисленное напряжение для усилителя двигателя. Единицами усиления FF0 являются вольт на единицу машины, например, volts/unit
При FF0 = 1 заданная позиция на входе PID тупо подаётся на выход как скорость - видимо отсюда и дрейф.
Такие коэф. больше подходят для управления шпинделем, а не позиционирующим приводом.
P.S. Это из штатной документации, переведено гуглом без доп.коррекции.
botcman
Re: AG250CNC
Сообщение botcman »
Так это для шпинделя и есть коэффициенты. Завтра буду пробовать. Спасибо.
botcman
Re: AG250CNC
Сообщение botcman »
Не могу победить ось Y. При подключенных управлениях всех осей происходит следующее- включаю кнопку питание станка, ручное управление, те, кот. на экране, ось Y делает рывок примерно на 2мм, выскакивает ошибка Joint 1 following error и комп отрубает оси. Отсоединяю управление оси Y от платы, при включении питания станка ошибок не возникает, оси Х и Z движутся нормально. Подключение энкодера оси Y проверил сегодня еще раз- все правильно. Куда копать? Из-за этого не могу начать настройку ПИД. Прошу помощи. Так же ищу человека в Москве, который за вознограждение поможет разобраться с этим и для небольшого ликбеза.
MGG
Re: AG250CNC
Сообщение MGG »
ПИД какой установлен на У?
Вот эти параметры случайно не с разным знаком?
OUTPUT_SCALE = 1.0
Re: AG250CNC
MGG писал(а):Вот эти параметры случайно не с разным знаком?
Разность знаков не при чём.
Знак в OUTPUT_SCALE задаёт направление движения привода, это чтоб при нажатии кнопки X+ привод ехал в сторону увеличения координаты X.
Знак в ENCODER_SCALE задаёт направление изменения счётчика энкодера, знак нужно поставить такой, чтобы при движении оси в сторону увеличения координаты счётчик энкодера тоже увеличивался.
Комбинация знаков этих двух параметров зависит лишь от настроек привода и порядка подключения фаз энкодера.
MGG
Re: AG250CNC
Сообщение MGG »
UAVpilot писал(а):Разность знаков не при чём.
Но если они разнонаправленны, то сразу выйдет феррор. Проверенно на моем конфиге :)
Re: AG250CNC
MGG писал(а):Но если они разнонаправленны, то сразу выйдет феррор.
А я разве с этим спорю? :)
Направлены они должны быть одинаково, только знаки при этом могут быть разные. :)
botcman
Re: AG250CNC
Сообщение botcman »
Encoder scale и output scale с одинаковым знаком. Наверх есть инифайл
botcman
Re: AG250CNC
Сообщение botcman »
Ещё такой глупый вопрос- в каком направлении идет движение в плюс, в каком в минус у осей X Y Z?
botcman
Re: AG250CNC
Сообщение botcman »
Изменения пид У не даёт вообще результата
MGG
Re: AG250CNC
Сообщение MGG »
botcman писал(а):Ещё такой глупый вопрос- в каком направлении идет движение в плюс, в каком в минус у осей X Y Z?
В зависимости от того, какая у тебя X какая Y. Z вниз в минус идет. В кам программе посмотри как ты ноль выставляешь, и по направлению стрелок от нуля заготовки.
botcman писал(а):Изменения пид У не даёт вообще результата
А если допустим поменять Х и Y местами? И попробуй output scale -1 сделать, может у тебя энкодер в другую сторону подключен. Так же может перепетуал А+А-, или B+B-
Как вариант, поставь скорость не постоянную, а скажме 0.1 мм в ручном движении, нажми стрелку и посмотри, совпадает ли направление с циферками ахиса
botcman
Re: AG250CNC
Сообщение botcman »
Не понял вопроса про то, что какая у меня X какая Y. Менял местами управление Y и Z, безрезультатно, не работают обе оси. Подключение энкодера Y вчера проверил еще раз- все ок.
botcman
Re: AG250CNC
Сообщение botcman »
Буду пробовать output scale -1 сделать, может поможет.
botcman
Re: AG250CNC
Сообщение botcman »
Краткие вести с полей.
Пробовал output scale -1 сделать- все заработало. Ура!!! Спасибо за советы.
botcman
Re: AG250CNC
Сообщение botcman »
Подскажите, пожалуйста. Нажимаю кнопку поиск начала оси Х, ось едет до аварийного концевика, не останавливаясь на концевике Хоум и на минимальном. Сигналы в халметре проходят, нажимаю пальцем на концевики- в халметре фальс меняется на тру. Куда копать?
Еще вопрос- станок с конфигурацией осей как 676 фрезере- откуда идет отсчет осей, где минимум и максимум у каждой из осей?
