Роботы среди нас
- Зачётный участник
Re: Роботы среди нас
нужна глюкоза поверь - микологуFisher писал(а):ну слово Sugar слышно на протяжении всего видео
Bioengineers have been steadily advancing toward the goal of building lab-grown organs out of a patient's own cells, but a few major challenges remain. One of them is making vasculature, the blood vessel plumbing system that delivers nutrients and remove waste from the cells on the inside of a mass of tissue. Without these blood vessels, interior cells quickly suffocate and die.
Scientists can already grow thin layers of cells, so one proposed solution to the vasculature problem is to "print" the cells layer by layer, leaving openings for blood vessels as necessary. But this method leaves seams, and when blood is pumped through the vessels, it pushes those seams apart.
Bioengineers from the University of Pennsylvania have turned the problem inside out by using a 3D printer called a RepRap to make templates of blood vessel networks out of sugar. Once the networks are encased in a block of cells, the sugar can be dissolved, leaving a functional vascular network behind.
"I got the first hint of this solution when I visited a Body Worlds exhibit, where you can see plastic casts of free-standing, whole organ vasculature," says Bioengineering postdoc Jordan Miller.
Miller, along with Christopher Chen, the Skirkanich Professor of Innovation in the Department of Bioengineering, other members of Chen's lab, and colleagues from MIT, set out to show that this method of developing sugar vascular networks helps keep interior cells alive and functioning.
After the researchers design the network architecture on a computer, they feed the design to the RepRap. The printer begins building the walls of a stabilizing mold. Then it then draws filaments across the mold, pulling the sugar at different speeds to achieve the desired thickness of what will become the blood vessels.
After the sugar has hardened, the researchers add liver cells suspended in a gel to the mold. The gel surrounds the filaments, encasing the blood vessel template. After the gel sets it can be removed from the mold with the template still inside. The block of gel is then washed in water, dissolving the remaining sugar inside. The liquid sugar flows out of the vessels it has created without harming the growing cells.
"This new technology, from the cell's perspective, makes tissue formation a gentle and quick journey," says Chen.
The researchers have successfully pumped nutrient-rich media, and even blood, through these gels blocks' vascular systems. They also have experimentally shown that more of the liver cells survive and produce more metabolites in gels that have these networks.
The RepRap makes testing new vascular architectures quick and inexpensive, and the sugar is stable enough to ship the finished networks to labs that don't have 3D printers of their own. The researchers hope to eventually use this method to make implantable organs for animal studies.
Text by Evan Lerner
Video by Kurtis Sensenig
Биоинженеры неуклонно продвигается к цели создания лаборатории выращенных органов из собственных клеток пациента, но некоторые основные проблемы остаются нерешенными. Один из них делает сосуды, сантехника кровеносных сосудов, что система поставляет питательные вещества и удаление отходов из клеток на внутренней массы тканей. Без этих кровеносных сосудов, внутренние клетки быстро задыхаются и погибают.
Ученые уже могут расти тонкие слои клеток, так что предлагаемое решение сосудистой проблема заключается в "печати" клетки слой за слоем, оставляя отверстия для кровеносных сосудов по мере необходимости. Но этот метод оставляет швов, и, когда кровь прокачивается через сосуды, он толкает эти пласты друг от друга.
Биоинженеры из Университета Пенсильвании превратили проблемы изнутри с помощью 3D-принтера называется RepRap, чтобы шаблоны сети кровеносных сосудов из сахара. После того, сети помещены в блок ячеек, сахар может быть расторгнут, в результате чего функциональный сосудистой сети позади.
"Я получил первый намек на это решение, когда я посетил выставку тела миров, где можно увидеть пластиковые муляжи свободно стоящие, целые сосудистой орган", говорит биоинженерии постдок Иордания Миллер.
Миллер, а также Кристофер Чен, профессор Skirkanich инноваций в Факультет биоинженерии, другие члены лаборатории Чэнь и его коллеги из Массачусетского технологического института, установить, чтобы показать, что этот метод развивается сахарный сосудистой сети помогает сохранить клетки живыми интерьера и функционирования.
После того, как исследователи разработать архитектуру сети на компьютере, они питаются дизайн RepRap. Принтер начинает строить стены стабилизации формы. Тогда это то привлекает нитей по форме, потянув за сахаром с разной скоростью для достижения желаемой толщины, что будет кровеносных сосудов.
После того, как сахар затвердеет, исследователи добавляют клетки печени, взвешенных в гель формы. Гель окружает нити, тэгов шаблона кровеносных сосудов. После того, как гель наборов она может быть удалена из формы с шаблоном по-прежнему внутри. Блок гель затем промывают в воде, растворение оставшихся в сахар. Жидкий сахар вытекает из суда он создал без ущерба для растущих клеток.
"Эта новая технология, с точки зрения клетки, делает ткань формирования нежный и быстрый путь", говорит Чен.
Исследователи успешно закачивается богатых питательными веществами СМИ, и даже кровь, при сосудистой системы этих гелей блоков. Они экспериментально показали, что больше клеток печени выживают и производят больше метаболитов в гель, что эти сети.
RepRap делает тестирование новой архитектуры сосудистой быстро и недорого, и сахар достаточно стабильны, чтобы отправить готовую сеть в лаборатории, которые не имеют 3D принтеры своих собственных. Исследователи надеются, что в конечном счете, использовать этот метод, чтобы сделать имплантируемый органы животных.
Текст Эван Лернер
Видео по Куртис Сенсениг
- Зачётный участник
Общаясь частенько с учеными микробиологами они грят, да и в среду добавляем сахара, а сахара могут быть разные глюкоза, фруктоза, лактоза и тд... А когда спрашиваешь что конкретно добавляется уточняют. Думаю и в фильме грят печатаем из САХАРОВ2cme писал(а):По тексту получается что сахар (sugar).
http://ru.wikipedia.org/wiki/%D0%93%D0% ... 0%B7%D0%B0
Глюко́за (греч. γλυκόζη, от γλυκύς сладкий) (C6H12O6), или виноградный сахар, или декстроза встречается в соке многих фруктов и ягод, в том числе и винограда, отчего и произошло название этого вида сахара. Является шестиатомным сахаром (гексозой). Глюкозное звено в состав ряда ди- (мальтозы, сахарозы и лактозы) и полисахаридов (целлюлоза, крахмал).
Если коротко питание расщепляется до глюкозы, глюкозаэто энергия клетки. Клетка хавает глюкозу расщепляя ее до СО2(что собственно выдахается) и воды. Например высшие базидомицеты тобишь грибы целлюлозу(вата) расщепляют до глюкозы, а потом потребляют ее растут и выделают СО2.
Вот как то так
А если они печатают чистым сахаром, то интересно как они справились с осматическим давлением, так как оно разорвет клетку как тузик грелку
Я так и предпологал что aftaev будет себя пяткой в грудь бить, и трясти справкой что не верблюд...
aftaev распишите какую функциональную нагрузку несет sugar в технологии предствленной на видео, будет более полезно.
- Зачётный участник
Как вырасти клетки на концентрированном сахаре иль глюкозе я не представляю. Проблемы:2cme писал(а):aftaev распишите какую функциональную нагрузку несет sugar в технологии предствленной на видео, будет более полезно.
1. раствориться пока что либо вырастить. Это как пить чай из кружки напечатанной из сахара
2. на концентрированном расти не будет из-за осмотического давления. Это также как пить чай из напечатанной из сахара - будет очень приторно.
3D печать органов посредством печати каркаса специальными волокнами, а потом выращивание на них стволовых клеток уже давно ведется.
https://www.youtube.com/watch?v=LXfnITzeceI
- Зачётный участник
Печать органов
https://www.youtube.com/watch?v=tQnJAMsV1g8
https://www.youtube.com/watch?v=80DhBLEhdzk
- Nick
- Заслуга: Developer
Насколько я понял, они печатают тонкие ниточки из сахара висящие на более толстых основаниях. Потом заливают все это гелем, и растворяют сахар. В итоге получают сеть из тоненьких "сосудов" соединяющих два толстых сосуда.
Т.е. сахар - это основа литейной формы
- Fisher
- Почётный участник
Вроде так. Мне тоже такое навеяло.
- Зачётный участник
тогда это все объясняетNick писал(а):Т.е. сахар - это основа литейной формы .
- Nick
Он второй раз дверь открыл еще до того как чувак мелодию достучал
Намного важнее то насколько вандалоустойчивый будет данный замок. Автор данного замка не предусмотрел никакой защиты, электрошокер и ...
- PKM
- Почётный участник
- Настоящее имя: Андрей
Great
- Nick
Блин сколько же можно было станочков на этих приводах собрать
Эх надо идти в рекламу, делать такие прикольные штуки, а тебе за это еще и деньги платят
- PKM
- Почётный участник
Вроде бы ничего особенного... цена, дружелюбие и легкая настройка
https://www.youtube.com/watch?v=rjPFqkFyrOY
- Nick
Интересно, что проще обучить этого робота перекладывать детальки со стола на конвейер или обучить тому же узбека
Надо такое же видео сделать с Uzbaxter
