Inkscape Gcodetools plug-in English support forum
What function should we develope next?
Результаты голосования
Generated Gcode in EMC2 (1471734 просмотра) <a class='original' href='./download/file.php?id=508&mode=view' target=_blank>Загрузить оригинал (21.99 КБ)</a>
TypeExtension of vector
graphics editor Inkscape
DeveloperGcodetools develop team
Written inPython
OSCross-Platform (Windows, Linux, MacOS)
Version1.6.03
LicenseGNU GPL
Downloads7800+
Gcodetools
Gcodetools is a plug-in for Inkscape. It prepares and converts paths from Inkscape to Gcode, using biarc interpolation.
This article is unfinished. You can help cnc-club expanding it.
Screenshots and photos are needed. Please post them at this thread.
Features (для просмотра содержимого нажмите на ссылку)
Features
Preview of the generated Gcode in EMC (1474658 просмотров) <a class='original' href='./download/file.php?id=130&mode=view' target=_blank>Загрузить оригинал (154.76 КБ)</a>
Gcodetools area pocketing (1460761 просмотр) <a class='original' href='./download/file.php?id=772&mode=view' target=_blank>Загрузить оригинал (147.75 КБ)</a>
Gcodetools lathe (1467082 просмотра) <a class='original' href='./download/file.php?id=642&mode=view' target=_blank>Загрузить оригинал (21.98 КБ)</a>
Gcodetools lathe
Gcodetools engraving by Rene (1467247 просмотров) <a class='original' href='./download/file.php?id=631&mode=view' target=_blank>Загрузить оригинал (233.84 КБ)</a>
Bears by Durachko (1402705 просмотров) <a class='original' href='./download/file.php?id=5429&mode=view' target=_blank>Загрузить оригинал (89.93 КБ)</a>
Bears by Durachko
Export to Gcode
  • Export paths to Gcode
  • Using circular (biarc approximation) or straight line interpolation
  • Automatic path subdivision to reach defined tolerance
  • Multiply tool processing
  • Export Gcode in parametric of flat form
  • Including personal headers and footers
  • Choosing units
  • Multi-pass processing
  • Numeric suffix is added to generated files to avoid overwriting
Lathe Gcode
  • Compute trajectories for lathe
  • Fine cut
  • Define fine cut's depth
  • Define fine rounds
  • Two different computation functions for fine cut
  • Standard axis remapping
Path's area processing
  • Building area paths
  • Area paths could be modified
Engraving
  • Building trajectory according to the cutter's shape
  • Defining different cutter's shapes
Tool's library
  • Defining different tool's parameters (diameter, feed, depth step, penetration feed, personal Gcode before/after each path, cutters shape, personal tool's changing Gcode)
  • Tools can be managed by Inkscape's standard procedures (copy, delete, assigned to different layer)
  • Multiply tools processing
Orientation system
  • Applying scale along any axis
  • Apply rotate in the ХY plane
  • Apply translation along any axis
  • Apply transforms according to arbitrary points
Post-processor
  • You can create custom post-processor by writing down the commands or choose from the list of default post-processors
  • Scale and offset Gcode
  • Gcode commands remapping
  • Parameterize Gcode
  • Round floating point values to specified precision
Verifying tools for the scene
  • Select and remove small paths (area artefacts)
  • Tool's alignment check
  • Cutting order check
Plotter cutting
  • Export to Gcode for plotter with tangential knife. Forth axis A is knife's rotation.
Install (для просмотра содержимого нажмите на ссылку)
Install
Windows
Unpack and copy all the files to the following directory Program Files\Inkscape\share\extensions\ and restart inkscape
Linux
Unpack and copy all the files to the following directory /usr/share/inkscape/extensions/ and restart inkscape
Screenshots (для просмотра содержимого нажмите на ссылку)
Screenshots
Gcodetools plug-in tutorial (2600*1300 px png ~ 700Kb) (1474661 просмотр) <a class='original' href='./download/file.php?id=127&mode=view' target=_blank>Загрузить оригинал (752.7 КБ)</a>
Curve to Gcode result (1474667 просмотров) <a class='original' href='./download/file.php?id=103&mode=view' target=_blank>Загрузить оригинал (1023.52 КБ)</a>
Get latest version (для просмотра содержимого нажмите на ссылку)
Get latest versions
Latest stable version Gcodetools 1.7
gcodetools.tar.gz
Gcodetools 1.7
(75.25 КБ) 104330 скачиваний
Older versions(ver 1.5)
gcodetools-1.6.tar.gz
Gcodetools 1.6
(56.6 КБ) 16562 скачивания
(ver 1.5)
gcodetools.tar.gz
Gcodetools 1.5
(21.32 КБ) 12151 скачивание
(ver 1.4)
gcodetools.tar.gz
(14.72 КБ) 29044 скачивания
(ver 1.2)
extensions.tar.gz
(9.01 КБ) 11887 скачиваний
Dev-version
You can try the newest development version by getting it from github repository https://github.com/cnc-club/gcodetools via web interface or using git clone git@github.com:cnc-club/gcodetools.git .
You'll need to run python create_inx.py to create inx files. After that install procedure is the same with the stable version.
Translations
Gcodetools is included into Inkscape v 0.49 so it will have native translations as other Inkscape's extensions. Until it is released you can use some self made translation packs:
Credits (для просмотра содержимого нажмите на ссылку)
Credits
Developers:
  • Nick Drobchenko (Nick)
  • Vladimir Kalyaev (Dormouse)
  • Henry Nicolas (Alfcnc)
Translators:
  • John Brooker (greybeard from cnczone.com)
Develop (для просмотра содержимого нажмите на ссылку)
Develop
At the moment following features are being developed:
  • Plasma cutter extension
  • Turning lathe extension
  • Plotter extension
You can help us improve Gcodetools in several ways
  • Writing a report / bug report
  • Improve help and manuals
  • Publish G-codes / SVGs / other code
  • Publish photos / videos
  • Make a bug report
  • Help develop new features
  • Suggest a new feature
Tested on (для просмотра содержимого нажмите на ссылку)
Tested on
Linux
Ubuntu 9.10 14.04 + inkscape 0.48 (older Gcodetools versions also work with 0.46, 0.47)
Windows
Windows XP, Windows Vista, Windows 7 + inkscape 0.46, inkscape 0.47
MacOS
There are some reports on successful work on MacOs.
tomate
Re: Inkscape Gcodetools plug-in English support forum
Сообщение tomate »
Hi Nick,
OK, I understood the lambda function stuff.
But I think that allowing the user to specify a custom depth to each path using a XML tag would add a more newbie, no-math, option.
The drawback is that it is only accessible with the XML tree editor, that is a big non-dockable window.
It would easier if these custom tags could be accessible in the "Object Properties" window.
Anyway, I made a working version of this feature.
I will try to find the time to push it today.
Tomate
tomate писал(а):It would easier if these custom tags could be accessible in the "Object Properties" window.
There was a kind of feature in Gcodetools which took Object Properties. We can try to use them.
tomate писал(а):Anyway, I made a working version of this feature.
I think the best solution will be adding another argument to that lambda function to make it able to use that defined depth.
I.e. we've got to change this two lines:
					depth_func = eval('lambda c,d,s: ' + self.options.path_to_gcode_depth_function.strip('"'))
to
					depth_func = eval('lambda c,d,s,optd: ' + self.options.path_to_gcode_depth_function.strip('"'))
and
										 	[id_, depth_func(c,zd,zs), comment],
to
										 	[id_, depth_func(c,zd,zs,optd), comment],
and define value for opt_d. Then we can just use opt_d as depth_function for your needs.
tomate
Сообщение tomate »
OK, I found the "get_path_properties" function
So I need to use it to get a "depth:something" in the desciption and affect it to "optd"
Many thanks, I will work on that.
tomate писал(а):depth:something
best way should be to use regular expressions, something like this:
r = re.match("depth\s*:\s*(\-?[0-9\.]+)",s):
if r:
  depth = float(r.group(1))
tomate
Сообщение tomate »
Wow, perfect timing : I was just working on this step !
Thanks :good:
tomate
Сообщение tomate »
Nick писал(а):I think the best solution will be adding another argument to that lambda function to make it able to use that defined depth.
The drawback of using this solution is that we cannot mix paths with "custom depth" and paths with "default depth" ( of the orientation points ) (ie : that have no "custom depth" set )
Then we can do lkie this:
if r:
else:
  depth = orientation_points_depth
or write in depth function:
optd if optd != None else : d
tomate
Сообщение tomate »
Ok, I got it working.
Ready to commit ...
Just to be sure ( I'm a bit anxious about committing this change, I wouldn't want to break everything ) :
bzr launchpad-login my-id
bzr commit -m "add possibility to specify custom depth in object description" gcodetools-dev.py
That's all ?
tomate писал(а):bzr launchpad-login my-id
this one is usualy needed only once.
tomate писал(а):bzr commit -m "add possibility to specify custom depth in object description" gcodetools-dev.py
You can use just "bzr commit", and it will generate summary and will allow you to add notes.
Then
"bzr push lp:gcodetools" to push the code.
Any way Bazaar has version control, any bad changes can be undone ;)
tomate
Сообщение tomate »
My code is commited.
I hope it worked :hehehe:
Yes, something definitely has being pushed to repository :D.
Unfortunately I can not check it right now.
tomate
Сообщение tomate »
Ahaha, yeah, ***SOMETHING*** has been pushed.
Thanks for your help.
These were the 2 things that I wanted to add to the code.
Now, I will be happy to help on other parts of the code, if you wish, as soon as it is pretty trivial things ( as you may have noticed, I am not a very experienced coder ).
Tomate
The main tast for now is prepare the code for new release. And push it to inkscape's trunk.
But I can not even imagine what is to be done to make it able :).
Another main task is to finish up offset of the biarc curve. It's almost done but there are a number of bugs which are to be fixed. Do you have any knowledge in planar geometry?
And there are some smaller but important tasks - the most main of them is to rewrite the code using new classes Biarc and CSP instead of old csp and biarc functions. This should make the code easier to read and, I think, faster to execute.
And as it was in your case make improvements based on yours (or users) needs.
tomate
Сообщение tomate »
Well ... I studied maths and physics at the university, but it was 20 years ago. And nowadays, I am not even able to do a divide operation by hand any more :oops:
Maybe I could give a try at it, but I looked at the code this afternoon, and I am not sure I will be able to help ....
I think I should first take back and read again my "Python for the newbie" book :hehehe:
Almost the same thing for me. :)
But if you'll gona need a new function, you'll now you can do it :)!
deece
Сообщение deece »
Attached is a patch which fixes a couple of spelling errors and implements the "spindle rpm" feature.
spindle_rpm.zip
(908 байт) 674 скачивания
Thanks! Will push it into the repo! :good:
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Hi ! I want try new engraving but after have update my gcodetools extension to last ver 246. I have this error, with engraving or path to gcode.
File "gcodetools-dev.py", line 8175, in <module>
gcodetools.affect()
File "/usr/share/inkscape/extensions/inkex.py", line 215, in affect
self.effect()
File "gcodetools-dev.py", line 8099, in effect
self.path_to_gcode()
File "gcodetools-dev.py", line 5986, in path_to_gcode
gcode += self.generate_gcode(curve, layer, z)
File "gcodetools-dev.py", line 5268, in generate_gcode
if "" != self.tool["spindle rpm"] :
AttributeError: Gcodetools instance has no attribute 'tool'
Fixxed that see Rev. 247, thanks for bug report :)
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Excuse me ! But have always exactly the same problem after update to 247 ?
I use Inkscape Inkscape 0.48.3.1 r9886 on Debian...
Would you want more information on it ?
Вернуться в «English forum»
