Inkscape Gcodetools plug-in English support forum
What function should we develope next?
Результаты голосования
Generated Gcode in EMC2 (1471966 просмотров) <a class='original' href='./download/file.php?id=508&mode=view' target=_blank>Загрузить оригинал (21.99 КБ)</a>
TypeExtension of vector
graphics editor Inkscape
DeveloperGcodetools develop team
Written inPython
OSCross-Platform (Windows, Linux, MacOS)
Version1.6.03
LicenseGNU GPL
Downloads7800+
Gcodetools
Gcodetools is a plug-in for Inkscape. It prepares and converts paths from Inkscape to Gcode, using biarc interpolation.
This article is unfinished. You can help cnc-club expanding it.
Screenshots and photos are needed. Please post them at this thread.
Features (для просмотра содержимого нажмите на ссылку)
Features
Preview of the generated Gcode in EMC (1474890 просмотров) <a class='original' href='./download/file.php?id=130&mode=view' target=_blank>Загрузить оригинал (154.76 КБ)</a>
Gcodetools area pocketing (1460993 просмотра) <a class='original' href='./download/file.php?id=772&mode=view' target=_blank>Загрузить оригинал (147.75 КБ)</a>
Gcodetools lathe (1467314 просмотров) <a class='original' href='./download/file.php?id=642&mode=view' target=_blank>Загрузить оригинал (21.98 КБ)</a>
Gcodetools lathe
Gcodetools engraving by Rene (1467479 просмотров) <a class='original' href='./download/file.php?id=631&mode=view' target=_blank>Загрузить оригинал (233.84 КБ)</a>
Bears by Durachko (1402937 просмотров) <a class='original' href='./download/file.php?id=5429&mode=view' target=_blank>Загрузить оригинал (89.93 КБ)</a>
Bears by Durachko
Export to Gcode
  • Export paths to Gcode
  • Using circular (biarc approximation) or straight line interpolation
  • Automatic path subdivision to reach defined tolerance
  • Multiply tool processing
  • Export Gcode in parametric of flat form
  • Including personal headers and footers
  • Choosing units
  • Multi-pass processing
  • Numeric suffix is added to generated files to avoid overwriting
Lathe Gcode
  • Compute trajectories for lathe
  • Fine cut
  • Define fine cut's depth
  • Define fine rounds
  • Two different computation functions for fine cut
  • Standard axis remapping
Path's area processing
  • Building area paths
  • Area paths could be modified
Engraving
  • Building trajectory according to the cutter's shape
  • Defining different cutter's shapes
Tool's library
  • Defining different tool's parameters (diameter, feed, depth step, penetration feed, personal Gcode before/after each path, cutters shape, personal tool's changing Gcode)
  • Tools can be managed by Inkscape's standard procedures (copy, delete, assigned to different layer)
  • Multiply tools processing
Orientation system
  • Applying scale along any axis
  • Apply rotate in the ХY plane
  • Apply translation along any axis
  • Apply transforms according to arbitrary points
Post-processor
  • You can create custom post-processor by writing down the commands or choose from the list of default post-processors
  • Scale and offset Gcode
  • Gcode commands remapping
  • Parameterize Gcode
  • Round floating point values to specified precision
Verifying tools for the scene
  • Select and remove small paths (area artefacts)
  • Tool's alignment check
  • Cutting order check
Plotter cutting
  • Export to Gcode for plotter with tangential knife. Forth axis A is knife's rotation.
Install (для просмотра содержимого нажмите на ссылку)
Install
Windows
Unpack and copy all the files to the following directory Program Files\Inkscape\share\extensions\ and restart inkscape
Linux
Unpack and copy all the files to the following directory /usr/share/inkscape/extensions/ and restart inkscape
Screenshots (для просмотра содержимого нажмите на ссылку)
Screenshots
Gcodetools plug-in tutorial (2600*1300 px png ~ 700Kb) (1474893 просмотра) <a class='original' href='./download/file.php?id=127&mode=view' target=_blank>Загрузить оригинал (752.7 КБ)</a>
Curve to Gcode result (1474899 просмотров) <a class='original' href='./download/file.php?id=103&mode=view' target=_blank>Загрузить оригинал (1023.52 КБ)</a>
Get latest version (для просмотра содержимого нажмите на ссылку)
Get latest versions
Latest stable version Gcodetools 1.7
gcodetools.tar.gz
Gcodetools 1.7
(75.25 КБ) 104332 скачивания
Older versions(ver 1.5)
gcodetools-1.6.tar.gz
Gcodetools 1.6
(56.6 КБ) 16564 скачивания
(ver 1.5)
gcodetools.tar.gz
Gcodetools 1.5
(21.32 КБ) 12153 скачивания
(ver 1.4)
gcodetools.tar.gz
(14.72 КБ) 29047 скачиваний
(ver 1.2)
extensions.tar.gz
(9.01 КБ) 11891 скачивание
Dev-version
You can try the newest development version by getting it from github repository https://github.com/cnc-club/gcodetools via web interface or using git clone git@github.com:cnc-club/gcodetools.git .
You'll need to run python create_inx.py to create inx files. After that install procedure is the same with the stable version.
Translations
Gcodetools is included into Inkscape v 0.49 so it will have native translations as other Inkscape's extensions. Until it is released you can use some self made translation packs:
Credits (для просмотра содержимого нажмите на ссылку)
Credits
Developers:
  • Nick Drobchenko (Nick)
  • Vladimir Kalyaev (Dormouse)
  • Henry Nicolas (Alfcnc)
Translators:
  • John Brooker (greybeard from cnczone.com)
Develop (для просмотра содержимого нажмите на ссылку)
Develop
At the moment following features are being developed:
  • Plasma cutter extension
  • Turning lathe extension
  • Plotter extension
You can help us improve Gcodetools in several ways
  • Writing a report / bug report
  • Improve help and manuals
  • Publish G-codes / SVGs / other code
  • Publish photos / videos
  • Make a bug report
  • Help develop new features
  • Suggest a new feature
Tested on (для просмотра содержимого нажмите на ссылку)
Tested on
Linux
Ubuntu 9.10 14.04 + inkscape 0.48 (older Gcodetools versions also work with 0.46, 0.47)
Windows
Windows XP, Windows Vista, Windows 7 + inkscape 0.46, inkscape 0.47
MacOS
There are some reports on successful work on MacOs.
Re: Inkscape Gcodetools plug-in English support forum
Bartelime писал(а):Dear all
I'm great fan of cnc-club and milled several projects so far. Yesterday I experienced a problem. The code seemed to be finde on EMC2 (Ubuntu 10.04). But when milling, it follows on a huge radius, when I understand the G-code, see picture and see what I mean. (I tried two fonts, Comics Sans / Tlwg Typist)
It appears that EMC2 threat G02 and G03 commands as a full circle if start and end points of the arc are closer than 0.0001 and probably if |start-end|<10-5*R.
Thanks to psha from linuxcnc.org : http://www.linuxcnc.org/component/optio ... lish/#6787 !
I've got this bug fixed at Gcodetools-dev revision 174. You can get that version throught bazaar ("bzr branch lp:gcodetools") or throught web interface from http://www.launchpad.net/gcodetools .
Once again thanks for the bug report :)!
Bartelime
Сообщение Bartelime »
Hi root
I just tested the improved engraving and I see perfect result! I appreciate your help and your time you invest in this great plugin.
Again, thanks very much !
Regards
Bartelime
You are welcome :)!
By the way do you have any photos to post in this forum?
geekinesis
Re: Inkscape Gcode tools plug-in English support forum
Сообщение geekinesis »
Hi
The code works great. The only problem I have is the scale of the output. The gcode, when imported into emc appears to be at about 20 percent of the size of the original inkscape drawing?
What units do you use in the inkscape?
Post here an svg file and generated ngc, and I'll try to get your problem solved///
roteng
Сообщение roteng »
problem with Z depth:
This morning I used inkscape .48 with your entension to generate gcode using mm and z axis parameters 5 mm safe, surface 0.0, and depth -0.01 it generated top portion shown below:
Header)
(Generated by gcodetools from Inkscape.)
(Using default header. To add your own header create file "header" in the output dir.)
M3
(Header end.)
G21 (All units in mm)
G00 Z5.000000
G00 X5.766556 Y-8.309251
G01 Z-0.010000 F100.0
G03 X5.801289 Y-7.860250 Z-0.010000 I-21.541572 J1.892197 F400.000000
G03 X5.827190 Y-7.402779 Z-0.010000 I-22.343967 J1.494543
Mach3 read file, objects egraved very well.
Then tried same object with some added objects using the same z axis parameters 5 mm safe, surface 0.0, and depth -0.01 it generated top portion shown below:
(Header)
M3
(Header end.)
G00 Z5.000000
G00 X20.257776 Y32.258771
G01 Z-10.000000 F100.0
G01 X20.201933 Y32.234045 Z-10.000000 F400.000000
G03 X20.152934 Y32.153001 Z-10.000000 I0.182507 J-0.165678
G03 X20.112459 Y31.923775 Z-10.000000 I0.625309 J-0.228600
The z won't show up as -0.01 it shows up as -10 as seen above. The text in the origin that the extension adds, shows (100.0;0.0;-0.099999) which looks like the right z depth, but why does it only create -10 as the zdepth?
Attach your svg file please. I'll got to check it.
It's a strange behavior...
roteng
Сообщение roteng »
attached is the inscape file both before the extension and after running the extension. I had to remove a few converted text elements that were paths to make it more generic, this version still generates the -10 on the Z axis.
tank_tag_no_shield_b.svg
inkscape file before running the extension
(67.82 КБ) 934 скачивания
tank_tag_no_shield_after_gcode_b.svg
after running extension inkscape svg file
(3.43 МБ) 1076 скачиваний
I thought that you've got problem with "Path to gcode". That's why svg is important :).
Now to the point.
It seems that there's something wrong with the default tool. Try go to Gcodetools->Tools Library and add an cone cutter definition. It worked for me.
By the way what cutter's bit are you planing to use to engrave it?
roteng
Сообщение roteng »
I usually use either a half round or a profile on an old 3 axis hermes vanguard 3400 on aluminum.
I admit I am unsure which tool type for the roatry engraver.
Can you explain what the difference between pressing apply from the engraver tab vs pressing apply from the gcode tab? If I add a cone as you suggest and use the gcode tab, I get the desired result, but if I use the engraver tab, the result in terms of the z depth is different.
Thanks,
Lee
Engraving makes a trajectory inside the path. And edges of machined trajectory should fit the original path. Z depth of the trajectory will be different for different parts of the path and it depends on the cutter's shape and path's "width" at that part.
Path-to-gcode converts the path into gcode trajectory. And cut it at the defined depth.
So here's a small illustration:
path to gcode vs engraving.png (7456 просмотров) <a class='original' href='./download/file.php?id=1134&mode=view' target=_blank>Загрузить оригинал (106.89 КБ)</a>
Here's an engraving example:
gcode engraving.JPG (7456 просмотров) <a class='original' href='./download/file.php?id=1135&mode=view' target=_blank>Загрузить оригинал (128.95 КБ)</a>
And Path to Gcode: Notice the letters
path to gcode.JPG (7456 просмотров) <a class='original' href='./download/file.php?id=1136&mode=view' target=_blank>Загрузить оригинал (58.69 КБ)</a>
inizul
Сообщение inizul »
First of all, thanks for your program.
It works great, it's fantastic!
I am doing a G-Code file viewer program, and I use files made with your program to check it.
NOTE:
I downloaded the file gnu.ngc on this page and do not have the GNU !! :o
only the text shown in the picture.
https://picasaweb.google.com/lh/photo/f ... directlink
Thanks again :)
OMG you are right!
The GNU is missing :o!!!
I'll fix that bug :)!
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Hi !
I'd like to have an option on the offset function that's make a new layer with the offset path create by the offset function.
This doing won some time when generate the pre-process for cutting path with multiple zone with different order of cutting...
This give the ability to d'ont have to select all the path between the offset and the original one when doing path to gcode
but just have to select all path on visible layer that were the one generate by offset function....
I hope you understand me...
Have a nice day.
Which offset function do you mean? The one from the Gcodetools (it only appears in the dev version), or Inkscape's offset functions?
Usually all paths that are made by Gcodetools are put in the separate group. You can easily push them to another layer by Ctrl+PageUp/PageDown.
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Yes i think about the Offset function of Gcodetools-dev...
For now i do it like you say Ctrl+PageUp/PageDown.
But when having many path that were offset it's long after each offset to set them to a layer...if Gcodetools have an option to done this directly i found that's were faster to work with :roll: don't you ?
Have a nice day.
alfcnc
Заслуга: Tester
Сообщение alfcnc »
alfcnc писал(а):Hi !
Ill try to test new dev release of gcodetools , first the lathe extension but nothing work.
And after just the path to gcode and same problem ??? Inkscape 0.48 on Debian.
The svg is just a spriral , Two orientation point set with gcotools dev 1.6 last rev 173.
And standard tool... and i have nothing done and no errors...if I'll set the option direct viewing and then I have :
File "gcodetools-dev.py", line 5396, in <module>
e.affect()
File "/usr/local/share/inkscape/extensions/inkex.py", line 211, in affect
self.parse()
File "/usr/local/share/inkscape/extensions/inkex.py", line 139, in parse
self.document = etree.parse(stream)
File "lxml.etree.pyx", line 2706, in lxml.etree.parse (src/lxml/lxml.etree.c:49958)
File "parser.pxi", line 1522, in lxml.etree._parseDocument (src/lxml/lxml.etree.c:72015)
File "parser.pxi", line 1552, in lxml.etree._parseFilelikeDocument (src/lxml/lxml.etree.c:72325)
File "parser.pxi", line 1435, in lxml.etree._parseDocFromFilelike (src/lxml/lxml.etree.c:71240)
File "parser.pxi", line 997, in lxml.etree._BaseParser._parseDocFromFilelike (src/lxml/lxml.etree.c:68381)
File "parser.pxi", line 539, in lxml.etree._ParserContext._handleParseResultDoc (src/lxml/lxml.etree.c:64257)
File "parser.pxi", line 625, in lxml.etree._handleParseResult (src/lxml/lxml.etree.c:65178)
File "parser.pxi", line 565, in lxml.etree._raiseParseError (src/lxml/lxml.etree.c:64521)
lxml.etree.XMLSyntaxError: Document is empty, line 1, column 1
Thanks !
I have always the problem on this computer.. I have try to update... search difference between others computer...and I found that this computer
is in utf8 not the others... the bug should probably be this one....
http://comments.gmane.org/gmane.comp.py ... devel/1852 :evil:
excuse me to reload this post but If someone have the same problem this make win some time.... when i have time i'll test to change encoding to see if this correct the problem...
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Hi !
I'll try to test the Stable version , on top of this thread... v 6.0.4 is write.
But after download and install the help tab of gcodetools says ver: 1.6.01...
Not a drama...
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Hi !
I have the path show under this was design from Qcad in dxf...
This give me on inkscape this with just stroke activate...
shape1_without_fill.png (7224 просмотра) <a class='original' href='./download/file.php?id=1184&mode=view' target=_blank>Загрузить оригинал (29.96 КБ)</a>
If setting fill the form become this....
shape1_with_fill.png (7224 просмотра) <a class='original' href='./download/file.php?id=1185&mode=view' target=_blank>Загрузить оригинал (12.44 КБ)</a>
If I do Area with Gcodetools this give me the area of the shape from the fill shape not the stroke....
bad for me....and curious results...
here the svg...
test_area.svg
(13.96 КБ) 965 скачиваний
The alone solution i have found...
Is Stroke to path Ctrl+alt+c
Union Ctrl++
Apply Close Curve to have clean curve...
And then Area...
But this give me twice path were I have one ....
And When doing Area this make Inside outside offset path were I require just the In or Out...???
Then i can do path to gcode and then take just the path in or out from path to gcode and then apply
path to gcode to the inside or outside path but very complex...
If you have a better solution....
Thanks ! nice day to you.
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Hum I reply me...for give more accurate..
Because it is possible too use the method on the tutorial of this post...with Boolean operation...
But I'd like to stay with the original path to don't have distorsion of it's size...
Because when doing Stroke to path it have the with of the Stroke adding to the size...
Вернуться в «English forum»
