Breakout Board (Помогите разобраться)
Leonov-x
Настоящее имя: Леонов Игорь
Сообщение Leonov-x »
Доброго времени суток!
Помогите разобраться с подключением платы: 6 Axis CNC MACH3 Engraving Machine Interface Breakout Board USB PWM Spindle
Возможная модель:A932A
XFW4Wg8g6fQ.jpg (5099 просмотров) <a class='original' href='./download/file.php?id=46259&mode=view' target=_blank>Загрузить оригинал (92.91 КБ)</a>
Разбираюсь в:
Плата.jpg (5099 просмотров) <a class='original' href='./download/file.php?id=46260&mode=view' target=_blank>Загрузить оригинал (4.72 МБ)</a>
Оригинальное описание платы: (для просмотра содержимого нажмите на ссылку)
Usage:
The CNC control board is designed for MACH3 software used in computer with line print terminal.The CNC control board is extensively used in the CNC machining,such as: CNC engraving machine,CNC lathes,
CNC Plasma cutting machine,CNC laser engraving machine,CNC milling machine,CNC Machining center and so on.It can be the most cost-effective method using the CNC control board with mach3 software in the computer.
Features:
1. High integration;high reliability
2.Absolute voltage isolation. The CNC control board is powered by computer USB port used as digital power that disgned as common cathode and common ancode
which is connecticed to motor dirver’s common port,and another power is DC 12V to DC 24V which is used as analog power.It’s much more safe and stable by isolating the digital power from analog power.
3.Five signal ports are isolated by optocouplers which can be used as limitting position,finding origin points,starting and Estopping. There is no interruption with isolation of optocouplers.
4.Twelve output ports can control six motors simultaneously,and they are also can be used for some ports as you like.Some ports are communally designed for two functions,choice should be made if you
want to use them.
5.Three relays are put on the board that can be programmed in the mach3 software,and there are three leds used for pilot lamp.The relays can be used to control external equipments such as solenoid valve, cooling pump and so on.
6.Programmed analog voltage from zero to ten volt can be set.The analog voltage can control the speed of spindle motor.
7. The CNC control board can control step motor diver with common cathode or common anode.It also can control servo motor with digital signal.
8.The analog power can be from nine volt to thrity volt.
$_10.JPG (5099 просмотров) <a class='original' href='./download/file.php?id=46258&mode=view' target=_blank>Загрузить оригинал (165.68 КБ)</a>
Вот собственно в чем вопросы:
1. Зачем нужны джамперы (?1, ?2)?
2. На драйвере шаговом двигателе (Wantai dq542ma) есть вход ENBL+(+5V) для разрешения работы шд, куда подключать его?
3. Есть две пары "Common anode DC5V"(?6, ?8) и "Common cathode"(?5, ?7), для каких целей они?
Re: Breakout Board (Помогите разобраться)
Leonov-x писал(а):2. На драйвере шаговом двигателе (Wantai dq542ma) есть вход ENBL+(+5V) для разрешения работы шд, куда подключать его?
никуда - он нафик не нужен ;)
Leonov-x писал(а):1. Зачем нужны джамперы (?1, ?2)?
мануал найти и там почитать ;)
megagad
Сообщение megagad »
1) джампер 2 скорее всего "включает" релюшки. Ибо 6 осей плюс 3 реле физически не поместятся на одном ЛПТ ;) Джампер 1 скорее весго отвечат за вывод ШИМ/0-10в для управления шпинеделем.
2) никуда - просто оставить не подключённым
3) так как это "обычаня" плата без оптики на выход - это или "общий +5в", или общая "земля" - зависит от того, к чему вы будете подключать и каким сигналом(высокого или низкого уровня) будете рулить драйверами.
И да - хотите вас обрадую? У вас конденсатор у джампера1 физически пробит :)
Leonov-x
megagad писал(а):джампер 2 скорее всего "включает" релюшки. Ибо 6 осей плюс 3 реле физически не поместятся на одном ЛПТ
Получается джампером можно выбирать либо реле, либо выход. Правильно понимаю?
megagad писал(а):Джампер 1 скорее весго отвечат за вывод ШИМ/0-10в для управления шпинеделем
Под этим джампером написано "P1", как и под первым выходом, получается джампером можно переключать либо работает выход либо ШИМ?
megagad писал(а):И да - хотите вас обрадую? У вас конденсатор у джампера1 физически пробит :)
Да знаю, Там стоит 50В100мкФ, у меня есть конденсаторы 63В100мкФ. По идее если больше вольтаж при той же емкости, то можно заменить?
P.S. Есть еще парочка таких:
20150323_195617.jpg (5081 просмотр) <a class='original' href='./download/file.php?id=46271&mode=view' target=_blank>Загрузить оригинал (1.61 МБ)</a>
Где-то вроде видел на форуме про нее. По сути это тоже самое, только без релюшек? Если не учитывать возможность управления доп оборудованием релюшками, то они работать будут одинаково, или какая-то понадежнее?
megagad
Сообщение megagad »
Leonov-x писал(а):Если не учитывать возможность управления доп оборудованием релюшками, то они работать будут одинаково, или какая-то понадежнее?
Первая надёжней - там оптики нет на выходах(дешевые китайские 817-е оптроны любят "шалить", инагда просто при нагреве "дохнут").
По релюшкам - сигнал идёт или только на выводную планку. или на неё плюс релюшку(судя по фото - просто подаётся сигнал на оптрон).
там скорее всего либо выход прямой(в маче можно настроить, чтоб выходил ШИМ). Либо через преобразователь ШИМ->0-10В Опять-же нужно курить инструкцию к платке что там и как описано.
Leonov-x
aftaev писал(а):мануал найти и там почитать
megagad писал(а):Опять-же нужно курить инструкцию к платке что там и как описано.
В том то и проблема что нет мануала к ней, был бы наверное все вопросы отпали бы.
Leonov-x писал(а): В том то и проблема что нет мануала к ней, был бы наверное все вопросы отпали бы.
Складывается ощущение, что все эти комплектующие вам кто-то дарит со словами "На, держи, эта штука все равно без документации, так что мне нафиг не нужна!".
И на форумах ооочень мнго таких обладателей, кому разная электроника с неба свалилась, и они теперь не знают, что с ней делать.
Leonov-x
michael-yurov писал(а):Складывается ощущение, что все эти комплектующие вам кто-то дарит со словами "На, держи, эта штука все равно без документации, так что мне нафиг не нужна!".
Мануал который идет с данной платой в первом посте, вот оригинал:
A932A-25816.doc
(1.05 МБ) 726 скачиваний
Ответов на мои вопросы я в нем не нашел. По запросу у продавца высылает тот же что и идет с платой.
megagad
Сообщение megagad »
Leonov-x писал(а):По запросу у продавца высылает тот же что и идет с платой.
Тогда отправляйте обратно. Ибо в "мануале" ни пинов. ни описания самой платы. Похоже - "перепродаван" просто сам не знает что да как. Нужно искать "первоисточник" - производителя платы.
megagad писал(а):Ибо в "мануале" ни пинов. ни описания самой платы.
Пины расписаны на самой плате. Правда, частично по китайски, но это мелочи :)
Leonov-x
megagad писал(а):Тогда отправляйте обратно. Ибо в "мануале" ни пинов. ни описания самой платы. Похоже - "перепродаван" просто сам не знает что да как. Нужно искать "первоисточник" - производителя платы.
да отправка обратно стоить будет как плата (цена платы 350-400р 2014 год.) да и времени много прошло уже ))
Сергей Саныч писал(а):частично по китайски
Ну нечего уже разобрался ))
wagman
Настоящее имя: Petrich
Сообщение wagman »
Уважаемые буду некромансером. Заказал плату что в первом посте , помогите с тем что прописать в конфигураторах LinuxCNC и MACH по поводу что на каком пине LPT находиться.
wagman писал(а):помогите с тем что прописать в конфигураторах LinuxCNC и MACH по поводу что на каком пине LPT находиться.
А откуда мы можем знать что там на каком пине у тебя подключено?
wagman
Сообщение wagman »
не понял. Мог написать что не знаешь или нет инструкции
wagman писал(а):не понял.
Чаво не понятного. Есть какая то плата у которой есть входы и выходы. И на эти входы выходы можно вешать сервы, шаговики, концевики как нравится. Что куда подключено - прописывается потом в настройках.
wagman писал(а):Мог написать что не знаешь или нет инструкции
1. Мог бы написать подробнее что за станок и что нужно подключить к плате. Не понятно что вообще ты собрался подключать к этой плате. Дайте схему, а что я собрался подключать - догадайтесь ;)
2. На второй фотке Leonov-x, подписал что куды подключается. На плате есть циферки - номера пинов LPT, которые потом прописываются в настройках Mach3.
3. Если набить в поисковике инета название платы + Manual то находится на нее мануал за пару минут :roll:
A932A -01.doc
(1.05 МБ) 507 скачиваний
A932A-2.doc
(995 КБ) 499 скачиваний
