user@ggg:~$ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
OpenGL vendor string: nouveau
OpenGL renderer string: Gallium 0.4 on NVA8
OpenGL core profile version string: 3.3 (Core Profile) Mesa 10.4.2
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,
GL_AMD_shader_trinary_minmax, GL_ARB_ES2_compatibility,
GL_ARB_ES3_compatibility, GL_ARB_base_instance,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clip_control,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_derivative_control, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_instanced, GL_ARB_explicit_attrib_location,
GL_ARB_explicit_uniform_location, GL_ARB_fragment_coord_conventions,
GL_ARB_fragment_layer_viewport, GL_ARB_fragment_shader,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_half_float_pixel,
GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_invalidate_subdata,
GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
GL_ARB_occlusion_query2, GL_ARB_pixel_buffer_object, GL_ARB_point_sprite,
GL_ARB_provoking_vertex, GL_ARB_robustness, GL_ARB_sample_shading,
GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_separate_shader_objects, GL_ARB_shader_bit_encoding,
GL_ARB_shader_objects, GL_ARB_shader_texture_lod,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_texture_barrier,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_range,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map_array,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_multisample,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_shader, GL_ARB_vertex_type_10f_11f_11f_rev,
GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_viewport_array,
GL_ATI_blend_equation_separate, GL_ATI_texture_compression_3dc,
GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr,
GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2,
GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_sRGB, GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
GL_EXT_pixel_buffer_object, GL_EXT_provoking_vertex,
GL_EXT_shader_integer_mix, GL_EXT_texture_array,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_KHR_context_flush_control, GL_KHR_debug,
GL_MESA_pack_invert, GL_MESA_texture_signed_rgba,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_packed_depth_stencil,
GL_NV_texture_barrier, GL_NV_vdpau_interop, GL_OES_EGL_image,
GL_OES_read_format
OpenGL version string: 3.0 Mesa 10.4.2
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
GL_AMD_shader_trinary_minmax, GL_APPLE_packed_pixels,
GL_APPLE_vertex_array_object, GL_ARB_ES2_compatibility,
GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_provoking_vertex,
GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_separate_shader_objects,
GL_ARB_shader_bit_encoding, GL_ARB_shader_objects,
GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
GL_ARB_shadow, GL_ARB_stencil_texturing, GL_ARB_sync,
GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,
GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
GL_ARB_transform_feedback_instanced, GL_ARB_transpose_matrix,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc,
GL_ATI_texture_env_combine3, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_copy_texture, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_provoking_vertex, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shader_integer_mix, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_compression_latc,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
GL_EXT_transform_feedback, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_KHR_context_flush_control, GL_KHR_debug, GL_MESA_pack_invert,
GL_MESA_texture_signed_rgba, GL_MESA_window_pos, GL_NV_blend_square,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_NV_vdpau_interop,
GL_OES_EGL_image, GL_OES_read_format, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 10.4.2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.0
OpenGL ES profile extensions:
GL_APPLE_texture_max_level, GL_EXT_blend_minmax,
GL_EXT_color_buffer_float, GL_EXT_discard_framebuffer,
GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
GL_EXT_read_format_bgra, GL_EXT_separate_shader_objects,
GL_EXT_shader_integer_mix, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_format_BGRA8888, GL_EXT_texture_rg,
GL_EXT_texture_type_2_10_10_10_REV, GL_EXT_unpack_subimage,
GL_KHR_context_flush_control, GL_NV_draw_buffers,
GL_NV_fbo_color_attachments, GL_NV_read_buffer, GL_OES_EGL_image,
GL_OES_EGL_image_external, GL_OES_compressed_ETC1_RGB8_texture,
GL_OES_depth24, GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_get_program_binary, GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
GL_OES_rgb8_rgba8, GL_OES_standard_derivatives, GL_OES_stencil8,
GL_OES_surfaceless_context, GL_OES_texture_3D, GL_OES_texture_npot,
GL_OES_vertex_array_object
240 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x022 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x1ef 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1f0 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x1f1 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1f2 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x1f3 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1f4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x1f5 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1f6 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x1f7 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1f8 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x1f9 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1fa 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x1fb 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1fc 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x1fd 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1fe 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x1ff 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x200 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x201 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x202 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x203 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x204 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x205 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x206 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x207 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x208 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x209 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x20a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x20b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x20c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x20d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x20e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x20f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x210 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x211 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x212 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x213 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x214 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x215 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x216 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x217 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x218 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x219 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x21a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x21b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x21c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x21d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x21e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x21f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x220 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x221 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x222 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x223 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x224 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x225 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x226 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x227 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x228 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x229 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x22a 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x22b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x22c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x22d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x22e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x22f 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x230 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x231 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x232 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x233 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x234 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x235 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x236 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x237 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x238 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x239 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x23a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x23b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x23c 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x23d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x23e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x23f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x240 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x241 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x242 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x243 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x244 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x245 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x246 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x247 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x248 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x249 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x24a 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x24b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x24c 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x24d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x24e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x24f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x250 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x251 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x252 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x253 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x254 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x255 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x256 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x257 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x258 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x259 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x25a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x25b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x25c 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x25d 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x25e 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x25f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x260 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x261 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x262 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x263 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x264 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x265 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x266 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x267 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x268 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x269 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x26a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x26b 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x26c 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x26d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x26e 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x26f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x270 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x271 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x272 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x273 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x274 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x275 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x276 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x277 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x278 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x279 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x27a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x27b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x27c 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x27d 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x27e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x27f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x280 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x281 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x282 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x283 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x284 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x285 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x286 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x287 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x288 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x289 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x28a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x28b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x28c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x28d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x28e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x28f 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x290 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x291 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x292 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x293 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x294 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x295 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x296 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x297 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x298 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x299 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x29a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x29b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x29c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x29d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x29e 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x29f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x2a0 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x2a1 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x2a2 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x2a3 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x2a4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x2a5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x2a6 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x2a7 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x2a8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x2a9 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x2aa 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x2ab 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x2ac 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x2ad 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x2ae 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x2af 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x2b0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x2b1 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x2b2 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x2b3 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x2b4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x2b5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x2b6 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x2b7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x2b8 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x2b9 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x2ba 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x2bb 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x2bc 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x2bd 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x2be 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x2bf 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x2c0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x2c1 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x2c2 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x2c3 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x2c4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x2c5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x2c6 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x2c7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x2c8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x2c9 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x2ca 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x2cb 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x2cc 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x2cd 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x2ce 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x2cf 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x2d0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x2d1 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x2d2 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x2d3 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x2d4 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x2d5 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x2d6 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x2d7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x2d8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x2d9 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x2da 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x2db 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x086 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
360 GLXFBConfigs:
0x087 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x088 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x089 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x08a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x08b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x08c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x08d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x08e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x08f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x090 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x091 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x092 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x093 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x094 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x095 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x096 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x097 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x098 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x099 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x09a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x09b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x09c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x09d 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x09e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x09f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x0a0 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x0a1 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x0a2 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x0a3 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x0a4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x0a5 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x0a6 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x0a7 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x0a8 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x0a9 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x0aa 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x0ab 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x0ac 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x0ad 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x0ae 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x0af 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x0b0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x0b1 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x0b2 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x0b3 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x0b4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x0b5 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x0b6 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x0b7 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x0b8 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x0b9 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x0ba 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x0bb 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x0bc 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x0bd 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x0be 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x0bf 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x0c0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x0c1 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x0c2 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x0c3 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0c4 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0c5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0c6 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0c7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0c8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0c9 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x0ca 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0cb 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x0cc 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0cd 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x0ce 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0cf 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0d0 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0d1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0d2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0d3 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0d4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0d5 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0d6 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0d7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0d8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0d9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0da 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0db 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x0dc 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x0dd 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x0de 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x0df 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x0e0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x0e1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x0e2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x0e3 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x0e4 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x0e5 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x0e6 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x0e7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x0e8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x0e9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x0ea 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x0eb 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x0ec 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x0ed 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x0ee 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x0ef 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x0f0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x0f1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x0f2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x0f3 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x0f4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x0f5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x0f6 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x0f7 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x0f8 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x0f9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x0fa 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x0fb 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x0fc 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x0fd 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x0fe 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x0ff 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x100 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x101 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x102 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x103 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x104 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x105 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x106 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x107 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x108 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x109 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x10a 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x10b 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x10c 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x10d 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x10e 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x10f 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x110 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x111 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x112 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x113 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x114 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x115 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x116 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x117 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x118 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x119 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 8 1 None
0x11a 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x11b 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x11c 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 8 1 None
0x11d 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x11e 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x11f 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 8 1 None
0x120 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x121 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x122 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 8 1 None
0x123 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x124 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x125 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 8 1 None
0x126 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x127 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x128 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 8 1 None
0x129 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x12a 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x12b 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 8 1 None
0x12c 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x12d 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x12e 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 8 1 None
0x12f 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x130 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x131 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 8 1 None
0x132 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x133 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x134 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 8 1 None
0x135 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x136 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x137 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 8 1 None
0x138 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x139 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x13a 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 8 1 None
0x13b 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x13c 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x13d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x13e 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x13f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x140 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x141 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x142 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x143 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x144 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x145 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x146 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x147 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x148 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x149 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x14a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x14b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x14c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x14d 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x14e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x14f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x150 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x151 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x152 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x153 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x154 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x155 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x156 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x157 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x158 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x159 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x15a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x15b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x15c 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x15d 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x15e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x15f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x160 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x161 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x162 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x163 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x164 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x165 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x166 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x167 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x168 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x169 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x16a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x16b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x16c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x16d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x16e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x16f 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x170 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x171 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x172 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x173 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x174 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x175 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x176 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x177 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x178 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x179 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x17a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x17b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x17c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x17d 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x17e 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x17f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x180 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x181 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x182 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x183 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x184 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x185 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x186 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x187 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x188 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x189 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x18a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x18b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x18c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x18d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x18e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x18f 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x190 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x191 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x192 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x193 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x194 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x195 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x196 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x197 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 8 1 None
0x198 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x199 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x19a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x19b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x19c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x19d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x19e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x19f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x1a0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 8 1 None
0x1a1 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x1a2 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x1a3 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x1a4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x1a5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x1a6 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x1a7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x1a8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x1a9 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 8 1 None
0x1aa 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x1ab 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x1ac 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x1ad 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x1ae 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x1af 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x1b0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x1b1 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x1b2 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 8 1 None
0x1b3 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x1b4 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x1b5 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x1b6 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x1b7 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x1b8 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x1b9 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x1ba 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x1bb 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x1bc 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x1bd 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x1be 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x1bf 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x1c0 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x1c1 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x1c2 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x1c3 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x1c4 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x1c5 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x1c6 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1c7 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x1c8 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1c9 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x1ca 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1cb 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x1cc 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x1cd 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 8 1 None
0x1ce 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x1cf 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x1d0 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 8 1 None
0x1d1 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x1d2 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x1d3 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 8 1 None
0x1d4 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x1d5 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x1d6 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 8 1 None
0x1d7 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x1d8 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x1d9 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 8 1 None
0x1da 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x1db 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x1dc 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 8 1 None
0x1dd 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x1de 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x1df 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 8 1 None
0x1e0 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x1e1 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x1e2 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 8 1 None
0x1e3 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x1e4 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x1e5 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 8 1 None
0x1e6 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x1e7 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x1e8 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 8 1 None
0x1e9 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x1ea 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x1eb 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 8 1 None
0x1ec 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x1ed 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x1ee 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 8 1 None
user@ggg:~$
