Leadshine 57HS серия
- sergey27rus
- Почётный участник
- Настоящее имя: Сергей
Re: Leadshine 57HS серия
http://www.leadshine.com/
Вот что пишет Leadshine в мануале на драйвера с питанием переменного и постоянного напряжения
7. Power Supply Selection
The DM drive can match medium and small size stepping motors (from NEMA frame size 14 to 34) made by Leadshine or other motor
manufactures around the world. To achieve good driving performances, it is important to select supply voltage and output current
properly. Generally speaking, supply voltage determines the high speed performance of the motor, while output current determines the
output torque of the driven motor (particularly at lower speed). Higher supply voltage will allow higher motor speed to be achieved, at
the price of more noise and heating. If the motion speed requirement is low, it’s better to use lower supply voltage to decrease noise,
heating and improve reliability.
Regulated or Unregulated Power Supply
Both regulated and unregulated power supplies can be used to supply the drive. However, unregulated power supplies are preferred due
to their ability to withstand current surge. If regulated power supplies (such as most switching supplies.) are indeed used, it is important
to have large current output rating to avoid problems like current clamp, for example using 4A supply for 3A motor-drive operation. On
the other hand, if unregulated supply is used, one may use a power supply of lower current rating than that of motor (typically 50%~
70% of motor current). The reason is that the drive draws current from the power supply capacitor of the unregulated supply only during
the ON duration of the PWM cycle, but not during the OFF duration. Therefore, the average current withdrawn from power supply is
considerably less than motor current. For example, two 3A motors can be well supplied by one power supply of 4A rating.
Multiple Drives
It is recommended to have multiple drives to share one power supply to reduce cost, if the supply has enough capacity. To avoid cross
interference, DO NOT daisy-chain the power supply input pins of the drives. Instead, please connect them to power supply separately.
Selecting Supply Voltage
The power MOSFETS inside the DM drive can actually operate with wider voltage range than the input specificaton. Higher supply
voltage can increase motor torque at higher speeds, thus helpful for avoiding losing steps. However, higher voltage may cause bigger
motor vibration at lower speed, and it may also cause over-voltage protection or even drive damage. Therefore, it is suggested to choose
only sufficiently high supply voltage for intended applications, and it is suggested to use power supplies with theoretical output voltage
of drive’s minimum + 10% to drive’s maximum – 10%, leaving room for power fluctuation and back-EMF.
Перевод гуглом
7. выборе блока питания
DM привод может сравниться средних и малых размеров шаговых двигателей (от размера NEMA кадров 14 к 34), сделанное Leadshine или другого двигателя
производит во всем мире. Для достижения хороших вождения спектакли, важно, чтобы выбрать напряжение питания и выходной ток
должным образом. Вообще говоря, напряжение питания определяет высокую скорость двигателя, в то время как выходной ток определяется
выходной крутящий момент на ведомый двигателем (в частности, при более низкой скорости). Более высокое напряжение питания позволит более высокую скорость двигателя должна быть достигнута, по крайней
цена больше шума и нагрева. Если требование к скорости движения является низкой, то лучше использовать более низкое напряжение питания, чтобы уменьшить шум,
нагревание и повысить надежность.
Регулируемых или нерегулируемых питания
Оба регулируемых и нерегулируемых источников питания может быть использован для питания электропривода. Тем не менее, нерегулируемые блоки питания являются предпочтительными из-за
их способности выдерживать бросок тока. Если регулируемые источники питания (например, большинство поставок переключения.) Действительно используется, он имеет важное значение
чтобы иметь большую номинального тока, чтобы избежать таких проблем, как тока зажима, например, с использованием питания 4A для работы 3A двигателя привода. На
С другой стороны, если используется нерегулируемого источника, можно использовать блок питания с более низким номинальным током, чем у двигателя (обычно 50% ~
70% от тока двигателя). Причина в том, что привод обращает ток от источника питания конденсатор нерегулируемого питания только во время
продолжительность на цикла ШИМ, но не в течение продолжительности выключения. Таким образом, средний ток выведены из источника питания
значительно меньше, чем ток двигателя. Например, два 3A двигатели могут быть также подается на один питания 4A рейтингу.
Несколько диски
Рекомендуется иметь несколько дисков для совместного использования одного источника питания, чтобы уменьшить стоимость, если питания обладает достаточной мощностью. Чтобы избежать крест
помех не подключайте последовательно входные выводы питания приводов. Вместо этого, подключите их к источнику питания отдельно.
Выбор Напряжение питания
МОП-транзисторы мощность внутри DM диск фактически может работать с более широким диапазоном напряжения, чем входной Specificaton. Высшее питания
Напряжение может увеличить крутящий момент двигателя на высоких скоростях, таким образом, помогают избежать действия проигрышные. Тем не менее, более высокое напряжение может вызвать больше
вибрация двигателя на низкой скорости, а также может привести к защитой от перенапряжения или даже ездить ущерб. Таким образом, предлагается выбирать
только достаточно высокое напряжение питания для предполагаемых применений, и он предложил использовать источники питания с теоретической выходного напряжения
из накопителя минимум + 10% до привода максимум - 10%, оставляя место для колебаний питания и противо-ЭДС.
Multiple Drives
Перевод гуглом
Несколько диски
- Вложения
- DMShm_P.pdf
- (3.03 МБ) 563 скачивания
- cncmybox
- Настоящее имя: Алексей
Вот есть такая инструкция на "синий ТВ6560", ею и руководствуюсь:michael-yurov писал(а):У ТВ6560 в процентах обозначается режим спада тока,
и уровень тока относительно номинального.
Только вот нет там такого режима тока в 25%.![]()
Есть 100%, 75%, 50% и 20%.
Бди! (с) Козьма Прутков
- michael-yurov
- Почётный участник
Видимо в инструкции неправда написана.cncmybox писал(а): Вот есть такая инструкция на "синий ТВ6560", ею и руководствуюсь:
Я лишь обратил внимание на официальную документацию от производителя микросхем.
пум-пурум
- Настоящее имя: слава
всем привет! купил шд. как без подключения к драйверу, проверить их работоспособность!??
- Predator
Покрути за вал рукой, должны двигаться ступенчато. Также можешь подцепить к батарейке.пум-пурум писал(а):как без подключения к драйверу, проверить их работоспособность!?
- michael-yurov
- Почётный участник
Должны вращаться ровно.Predator писал(а):Покрути за вал рукой, должны двигаться ступенчато.
А если замкнуть выводы какой-нибудь обмотки - будут вращаться ступенчато.
- Predator
Ну да, я это и хотел написать, но дети тут отвлекают постоянно, вот и ошибся
пум-пурум
какой? у меня есть под рукой 3,7в Li-Ion. подойдёт? и к каким концам подсоединять?Predator писал(а):Также можешь подцепить к батарейке
valb
Хотите посадить батарейку? Крутиться всёравно не будет. Проверьте только закорачиванием обмоток.пум-пурум писал(а): подойдёт?
пум-пурум
я туплю наверно страшно!?))
так они должны быть под напряжением что бы их закоротить!?valb писал(а):Проверьте только закорачиванием обмоток.
- Сергей Саныч
Нет, ШД сам себе генератор.пум-пурум писал(а):так они должны быть под напряжением что бы их закоротить!?
Должно быть так:
- обе обмотки разомкнуты - ощущается небольшое сопротивление вращению с маленькими "шажками". Мощные ШД иногда трудно провернуть пальцами за вал.
- одна замкнута - ощущаются четкие "рывки"
- обе замкнуты - сильное и плавное сопротивление вращению. Чем быстрее крутишь, тем больше сопротивляется.
Особое внимание надо обратить, чтобы не было подклиниваний при повороте.
- Predator
У меня на моторах аж четыре обмотки, при «коротком» движок ощутимо сопротивлялся
пум-пурум
проверил! всё работает как описали. если замкнуть все провода то практически не прокрутишь пальцами! мощь!)))
- Predator
Ну, что-то вроде того и должно бытьпум-пурум писал(а):если замкнуть все провода то практически не прокрутишь пальцами
пум-пурум
вопрос по двигателю: FL86STH65-2808 . купил 3шт таких движков. в описании к этому ШД пишут что для работы надо всего 48в и 100ват.
а я планирую приобрести драйвер DMA860H (до 80в и 7,2А в пике), и трансформатор (0,63кВА-70-80в) плюс ещё диодный мост городить!)))
вопрос!: надо ли такой запас мощности по драйверам???
П.С. и соответственно можно будет обойтись обычным (доступным по цене) блоком питания! если дело только в будущем усовершенствовании станка, то и то что я делаю: http://www.cnc-club.ru/forum/viewtopic. ... 8&start=80 в разы больше чем мне надо!)))
- michael-yurov
- Почётный участник
Так и есть.пум-пурум писал(а):купил 3шт таких движков. в описании к этому ШД пишут что для работы надо всего 48в и 100ват
Нет.пум-пурум писал(а):надо ли такой запас мощности по драйверам???
Да.пум-пурум писал(а):и соответственно можно будет обойтись обычным (доступным по цене) блоком питания!
пум-пурум
а с амперами что! сколько должно быть? для трёх таких шд и трёх драйверов Leadshine M542.
- michael-yurov
- Почётный участник
Каждому мотору нужно около 100 Вт. Т.е. на три мотора будет достаточно блока питания на 350 Вт.пум-пурум писал(а):а с амперами что! сколько должно быть? для трёх таких шд и трёх драйверов Leadshine M542.
пум-пурум
от 350ват и 48в??
- michael-yurov
- Почётный участник
Почему "от"? 350 Вт будет достаточно.пум-пурум писал(а):от 350ват и 48в??
Ну и 48 В - это даже слишком много, если речь про M542, т.к. драйвер при напряжении выше 50 В может сгореть.
Поэтому желательно выкрутить регулятор блока питания на минимум, и поставить конденсаторы на несколько тысяч микрофарад параллельно выходу блока питания,
или поставить дампер - тогда можно и не выкручивать на минимум.
