TB6600 CNC Single Axis 0.2-5A Two Phase Hybrid Stepper Motor
alx41
Сообщение alx41 »
Добрый день
Дайте отзыв по этому драйверу
TB6600 CNC Single Axis 0.2-5A Two Phase Hybrid Stepper Motor Driver Controller
нужны ваши мнения стоит-ли брать такой или нет
Features: <br />High performance, cost-effective. <br />Automatic idle-current reduction. <br />Supply voltage up to 50V DC <br />Output current up to 5.0A. <br />Suitable for 2-phase and 4-phase motors. <br />High speed optoelectronic isolation signal input. <br />Single-chip PWM bipolar sinusoidal chopper ensures low vibration and high efficiency. <br />1, 2, 4 (New Mode), 8, 16 adjustable microstep control, motors run more precisely and smoothly. <br />Equipped with the 3rd generation of breakout board, display panel and control pad to control the motor manually. <br />Overload, overcurrent, overheat, overvoltage and undervoltage protection to avoid damaging your computer and devices. <br />Cooling Aluminium Box Design for Cooling, and protect the driver board from being damaged by dirt, dust or other liquids<br /><br />This item is a high performance micro-stepping driver based on the latest original TOSHIBA high-efficiency TB6600HG IC. The TB6600HG adopts single-chip PWM bipolar sinusoidal chopper to ensure the low vibration and high efficiency. Moreover, the brand new design with BiCD0.13 (50V) process technology on the chipset also ensures maximum 5.0A output current and 50V output withstand voltage. Consequently, as long as the current range of the stepper motor is within 0.2-5 amps, all the 2 Phase or 4 Phase of Nema17, Nema23, Nema24 and Nema34 stepper motors will work perfectly with this new-type TB6600HG Stepper Driver (2732 просмотра) <a class='original' href='./download/file.php?id=39834&mode=view' target=_blank>Загрузить оригинал (83.06 КБ)</a>
Features:
Последний раз редактировалось alx41 06 янв 2015, 16:41, всего редактировалось 1 раз.
ok-evgenij
Re: TB6600 CNC Single Axis 0.2-5A Two Phase Hybrid Stepper M
Сообщение ok-evgenij »
Пока не сгорит - довольно неплохо работает.
alx41
Сообщение alx41 »
в каком смысле пока не сгорит
ok-evgenij
У меня 4 штуки таких выгорело за месяц.
Правда я их эксплуатировал довольно жестко - ток 4.2 А, напряжение питания 40 V.
Дешевых приличных драйверов я не встречал.
mmg
Сообщение mmg »
ok-evgenij писал(а):У меня 4 штуки таких выгорело за месяц.
А дампера по питанию стояли?
megagad
Сообщение megagad »
mmg писал(а):А дампера по питанию стояли?
А зачем? Питалово у 6600 в районе 50в максимальное. +10в накачать будет проблематично.
И да - в них есть "овервольтажпротекшн" :) Это вам не 6560. Хотя где-то рядом валяются - всё так-же боятся проворачивания вала при удержании.
Последний раз редактировалось megagad 06 янв 2015, 17:25, всего редактировалось 1 раз.
ok-evgenij
Сначала нет. После первого сгоревшего поставил - не помогло :wik:
В целом драйвер работает нормально. Если эксплуатировать в щадящем режиме, может и стоит купить.
P.S. Сейчас на этом станке стоят драйвера BY-2HB03M. Они рассчитаны на напряжение до 40 V. Ровно столько и выставил на БП. Работают уже полгода - все живы.
dno
Сообщение dno »
у меня 3 таких, к сожалению. у них проблемы со схемой - дают 30% мощности (обсуждалось тут http://www.cnc-arena.com/en/forum/tb660 ... 86930.html). Еще - таблица на крышке говорят не соответствует истине. у меня вроде соответствует. по сравнению со сгоревшим на TB6560- вал заметно легче провернуть рукой. Кроме того, когда вскрыл 1 из них после покупки, обнаружил сопли припоя, коротящие соседние выводы. Ещё - плата в моем варианте закреплена только с одной стороны на радиаторе (винтами у TB6600) а другой висит на кожухе (который с таблицей) и зеленых разъемах. из-за этого любая выступающая над платой пайка может легко замкнуть на радиатор, т.к. зеленые разъемы чуть-чуть шатаются. Думаю, поэтому они так и горят. Разобрал все 3 драйвер, проверил всю пайку и прикрутил плату на место изолирующей пластиной. Пока прикручивал, увидел, что резисторы/конденсаторы по факту не соответствуют разметке платы. посмотрел даташит - и ему не соответствуют тоже. Пожаловался на все китайцу - он вернул деньги, про драйвер сказал - обратно не нужен...
