Inkscape Gcodetools plug-in English support forum
What function should we develope next?
Результаты голосования
Generated Gcode in EMC2 (1471322 просмотра) <a class='original' href='./download/file.php?id=508&mode=view' target=_blank>Загрузить оригинал (21.99 КБ)</a>
TypeExtension of vector
graphics editor Inkscape
DeveloperGcodetools develop team
Written inPython
OSCross-Platform (Windows, Linux, MacOS)
Version1.6.03
LicenseGNU GPL
Downloads7800+
Gcodetools
Gcodetools is a plug-in for Inkscape. It prepares and converts paths from Inkscape to Gcode, using biarc interpolation.
This article is unfinished. You can help cnc-club expanding it.
Screenshots and photos are needed. Please post them at this thread.
Features (для просмотра содержимого нажмите на ссылку)
Features
Preview of the generated Gcode in EMC (1474246 просмотров) <a class='original' href='./download/file.php?id=130&mode=view' target=_blank>Загрузить оригинал (154.76 КБ)</a>
Gcodetools area pocketing (1460349 просмотров) <a class='original' href='./download/file.php?id=772&mode=view' target=_blank>Загрузить оригинал (147.75 КБ)</a>
Gcodetools lathe (1466670 просмотров) <a class='original' href='./download/file.php?id=642&mode=view' target=_blank>Загрузить оригинал (21.98 КБ)</a>
Gcodetools lathe
Gcodetools engraving by Rene (1466835 просмотров) <a class='original' href='./download/file.php?id=631&mode=view' target=_blank>Загрузить оригинал (233.84 КБ)</a>
Bears by Durachko (1402293 просмотра) <a class='original' href='./download/file.php?id=5429&mode=view' target=_blank>Загрузить оригинал (89.93 КБ)</a>
Bears by Durachko
Export to Gcode
  • Export paths to Gcode
  • Using circular (biarc approximation) or straight line interpolation
  • Automatic path subdivision to reach defined tolerance
  • Multiply tool processing
  • Export Gcode in parametric of flat form
  • Including personal headers and footers
  • Choosing units
  • Multi-pass processing
  • Numeric suffix is added to generated files to avoid overwriting
Lathe Gcode
  • Compute trajectories for lathe
  • Fine cut
  • Define fine cut's depth
  • Define fine rounds
  • Two different computation functions for fine cut
  • Standard axis remapping
Path's area processing
  • Building area paths
  • Area paths could be modified
Engraving
  • Building trajectory according to the cutter's shape
  • Defining different cutter's shapes
Tool's library
  • Defining different tool's parameters (diameter, feed, depth step, penetration feed, personal Gcode before/after each path, cutters shape, personal tool's changing Gcode)
  • Tools can be managed by Inkscape's standard procedures (copy, delete, assigned to different layer)
  • Multiply tools processing
Orientation system
  • Applying scale along any axis
  • Apply rotate in the ХY plane
  • Apply translation along any axis
  • Apply transforms according to arbitrary points
Post-processor
  • You can create custom post-processor by writing down the commands or choose from the list of default post-processors
  • Scale and offset Gcode
  • Gcode commands remapping
  • Parameterize Gcode
  • Round floating point values to specified precision
Verifying tools for the scene
  • Select and remove small paths (area artefacts)
  • Tool's alignment check
  • Cutting order check
Plotter cutting
  • Export to Gcode for plotter with tangential knife. Forth axis A is knife's rotation.
Install (для просмотра содержимого нажмите на ссылку)
Install
Windows
Unpack and copy all the files to the following directory Program Files\Inkscape\share\extensions\ and restart inkscape
Linux
Unpack and copy all the files to the following directory /usr/share/inkscape/extensions/ and restart inkscape
Screenshots (для просмотра содержимого нажмите на ссылку)
Screenshots
Gcodetools plug-in tutorial (2600*1300 px png ~ 700Kb) (1474249 просмотров) <a class='original' href='./download/file.php?id=127&mode=view' target=_blank>Загрузить оригинал (752.7 КБ)</a>
Curve to Gcode result (1474255 просмотров) <a class='original' href='./download/file.php?id=103&mode=view' target=_blank>Загрузить оригинал (1023.52 КБ)</a>
Get latest version (для просмотра содержимого нажмите на ссылку)
Get latest versions
Latest stable version Gcodetools 1.7
gcodetools.tar.gz
Gcodetools 1.7
(75.25 КБ) 104330 скачиваний
Older versions(ver 1.5)
gcodetools-1.6.tar.gz
Gcodetools 1.6
(56.6 КБ) 16562 скачивания
(ver 1.5)
gcodetools.tar.gz
Gcodetools 1.5
(21.32 КБ) 12151 скачивание
(ver 1.4)
gcodetools.tar.gz
(14.72 КБ) 29044 скачивания
(ver 1.2)
extensions.tar.gz
(9.01 КБ) 11887 скачиваний
Dev-version
You can try the newest development version by getting it from github repository https://github.com/cnc-club/gcodetools via web interface or using git clone git@github.com:cnc-club/gcodetools.git .
You'll need to run python create_inx.py to create inx files. After that install procedure is the same with the stable version.
Translations
Gcodetools is included into Inkscape v 0.49 so it will have native translations as other Inkscape's extensions. Until it is released you can use some self made translation packs:
Credits (для просмотра содержимого нажмите на ссылку)
Credits
Developers:
  • Nick Drobchenko (Nick)
  • Vladimir Kalyaev (Dormouse)
  • Henry Nicolas (Alfcnc)
Translators:
  • John Brooker (greybeard from cnczone.com)
Develop (для просмотра содержимого нажмите на ссылку)
Develop
At the moment following features are being developed:
  • Plasma cutter extension
  • Turning lathe extension
  • Plotter extension
You can help us improve Gcodetools in several ways
  • Writing a report / bug report
  • Improve help and manuals
  • Publish G-codes / SVGs / other code
  • Publish photos / videos
  • Make a bug report
  • Help develop new features
  • Suggest a new feature
Tested on (для просмотра содержимого нажмите на ссылку)
Tested on
Linux
Ubuntu 9.10 14.04 + inkscape 0.48 (older Gcodetools versions also work with 0.46, 0.47)
Windows
Windows XP, Windows Vista, Windows 7 + inkscape 0.46, inkscape 0.47
MacOS
There are some reports on successful work on MacOs.
Re: Inkscape Gcodetools plug-in English support forum
Ok, now change units at top right to mm instead of px ;)
rubyred
Сообщение rubyred »
Nick писал(а):Ok, now change units at top right to mm instead of px ;)
in inkscape ? if change the units to mm and draw a 300mm X 100mm rectangle and than convert the output is 3000mm X 1000mm. Where did i do something wrong :cry:
The sheet size in your svg is A4 - it is 297x210mm, how do you thing how big should be your rectangle? :)
Note px (pixels) as units at the right of highlighted area on the screenshot
1.png (11848 просмотров) <a class='original' href='./download/file.php?id=36482&mode=view' target=_blank>Загрузить оригинал (108.17 КБ)</a>
rubyred писал(а):in inkscape ? if change the units to mm and draw a 300mm X 100mm rectangle and than convert the output is 3000mm X 1000mm. Where did i do something wrong
Attach your new svg and ngc...
rubyred
Сообщение rubyred »
Here, 300mm X 100mm rectangle and the ngc output is 3000mm X 1000mm :( it's not evet exactly multipled by 10. it is now a 299.9mm x 99.97mm rectangle :(
30x10.svg
(1.72 КБ) 1057 скачиваний
30x10.ngc
(666 байт) 1397 скачиваний
hmmm.
What I did:
open your file
move your rect to origin (y,x 0,0)
changed size to 300x100
path to Gcode
And got
G01 X299.999966 Y99.999988 Z-0.125000 F400.000000 which is almost exact 300x100
(LASER Header)
(Generated by gcodetools from Inkscape.)
(Header end.)
G21 (All units in mm)
(Start cutting path id: rect2985)
(Change tool to Default tool)
G00 Z5.000000
G00 X-0.000006 Y99.999988
G01 Z-0.125000 F100.0(Penetrate)
G01 X299.999966 Y-0.000027 Z-0.125000
G01 X-0.000006 Y-0.000027 Z-0.125000
G01 X-0.000006 Y99.999988 Z-0.125000
G00 Z5.000000
(End cutting path id: rect2985)
(Footer)
M5
G00 X0.0000 Y0.0000
M2
(Using default footer. To add your own footer create file "footer" in the output dir.)
(end)
30x10.svg
(29.4 КБ) 1141 скачивание
rubyred
Сообщение rubyred »
Nick, you changed the size in mm right ? if i open this gcode in grbl controller machine wants to go 300cm not mm.Can you tell me "path to gcode" settings step by step ? maybe im doing something wrong.
P.s.I want to use gcodes for 2D cutting via GRBL.
rubyred писал(а):grbl controller
Does grbl controller use cm as standard units?
Are you sure that there no option to change them to mm?
Anyway you can edit Right Orientation point to be not (100,0,...) but (10,0,...)
rubyred
Сообщение rubyred »
Hi Nick, its me again. How are you ?
I have some questions again if you dont mind.
First is there an option to generate gcode without Z axis, maybe you remember i told you i'm trying to use gcodes for 2D styrofoam cutting.
Second question is what is the feed rate for, i try to cut some drawings with previous settings but when the machine comes to a some detailed figure it goes step by step and thats not good for styrofoam cutting. Because every moment between steps the hot wire (that machine cuts sytrofoam) melting the sytrofoam and ruining the figure. It has to be fluid cut to not melt the sytrofoam
dormouse
Сообщение dormouse »
To: rubyred
I am writing to you to ask you to attach two different NC files: a) correct (your own, without pauses) and b) incorrect (gcodetools-generated one)
So we are going to compare them and understand the difference.
P.S. Better if a) is corrected b).
rubyred
Сообщение rubyred »
dormouse писал(а):To: rubyred
Hi, i don't have correct nc file because i'm running the styrofoam cutting machine with another program called winpcNC and it uses plt files. I'm trying to abandon this program thats why I want to use GRBL Controller and gcodes.
dormouse
Do you have a valid ("no-pause") GRBL Controller g-code example? Is this GRBL Controller able to make no-pause movement over lines?
narvf
Сообщение narvf »
So gcodetools is now included in inkscape 0.91. Congratulations! :)
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Yes very nice that's it's include in 0.91.
But i try the version of Debian experimental repository :
https://packages.debian.org/experimental/inkscape
And the include gcodetools done always errors....
I add orientation point it's OK.
I want adds any tools always this...
File "gcodetools.py", line 6753, in <module>
gcodetools.affect()
File "/usr/share/inkscape/extensions/inkex.py", line 268, in affect
self.effect()
File "gcodetools.py", line 6665, in effect
self.get_info()
File "gcodetools.py", line 4287, in get_info
recursive_search(self.document.getroot(),self.document.getroot())
File "gcodetools.py", line 4242, in recursive_search
recursive_search(i,i)
File "gcodetools.py", line 4245, in recursive_search
points = self.get_orientation_points(i)
File "gcodetools.py", line 4332, in get_orientation_points
point[1] = [float(r.group(1)),float(r.group(2)),float(r.group(3))]
AttributeError: 'NoneType' object has no attribute 'group'
So i have install the last dev version from git and try with this debian inkscape and this work for :
Add orientation points.
Add tools.
perform a path to gcode..
But when want engraving always the errors :
File "gcodetools-dev.py", line 7805, in <module>
gcodetools.affect()
self.effect()
File "gcodetools-dev.py", line 7735, in effect
self.engraving()
File "gcodetools-dev.py", line 6666, in engraving
print_([ [ [p[0]]*3, [p[0][0]+p[1][0]*de10,p[0][1]+p[1][1]*10]*3] ])
NameError: global name 'de10' is not defined
Do you think this come just from problem of Debian version ? or this could be gcodetools errors ?
Thanks
alfcnc
Заслуга: Tester
Сообщение alfcnc »
After some research i just come from to see that when put orientation point on the sheet the z depht point was set to -2.35921990392e-15
So i have effectively not set the Z in the orientation point dialog but just keep it to zero.
If i edit the orientation point that have been set to the sheet and set it manually to 0 or -5 or others all stuff work...
After that i try to set the z to -5 on the orientation point dialog and add orientation point to the sheet and then the orientation point is good set with -5.
If i reset Z to 0 in dialog and perform a new orientation point all is perform good now ???
So i don't know why when have first start of 0.91 when put the orieantation point this one set the Z to -2.35921990392e-15 on the sheet.. perhaps
a bad var init somewhere ? So i don't arrive to reproduce the problem after have set the Z in the dialog orientation point windows one time.
alfcnc писал(а):-2.35921990392e-15
probably this form does not covered by regular expression which defines Orientation points.
hmmm got to fix that....
alfcnc писал(а):Do you think this come just from problem of Debian version ? or this could be gcodetools errors ?
this should be gcodetools error. I'm not sure what exact version is included into inkscape 0.91...
alfcnc
Заслуга: Tester
Сообщение alfcnc »
In my inkscape Inkscape 0.91 r13725 Gcodetools says about ver. 1.7
And if i set the z value manually to this -2.35921990392e-15 the same problem is reproducible.
narvf писал(а):So gcodetools is now included in inkscape 0.91. Congratulations!
WOW!! good news! Nick, my congratulations! :)
AAronvb
Настоящее имя: AAron
Сообщение AAronvb »
Very Nice, Nick and team..
I have been using inkscape for a few years and never knew I could do this with it. I Have.. This is easier, https://www.facebook.com/groups/AAronsVAWTCNCproject/ . This is where I am at with this. I'm going to spend a lot of time reading and trying things before I start asking questions. The learning curve is going to be steep, I have no former experience with CNC/CAD or the like and this machine. All new to me. I'm in the process of d-loading the programs I need to make this work properly for me. Thanks for doing this!
Moving forward through positive action.
markjacks
Настоящее имя: mark jackson
Сообщение markjacks »
I was wondering if anyone knows a way to move the Inkscape canvas to -Y. I do all of my milling in +X and -Y because it moves the gantry out of the way when it is at home-zero. If I could have Inkscape default to there it would eliminate a step. Now X0, Y0 is in the bottom left. I would love it if it could be in the upper left. Then when I process it in Gcode_Tools it would be in the right place. -Thanks
Вернуться в «English forum»
