Продам электронику для станка
Simmer
Сообщение Simmer »
3 Axis Stepper motor driver DM860A - 3 шт + Интерфейсная плата - 7000р. (для просмотра содержимого нажмите на ссылку)
DM860A is a type of two-phase hybrid stepping motor driver, The drive voltage of which is from 24VDC to 80VDC. It is designed for use with 2-phase hybrid stepper motor of all kinds with 57mm to 110mm outside diameter and less than 8.0A phase current. This circuit that it adopts is similar to the circuit of servo control which enables the motor run smoothly almost without noise and vibration. Hording torque when DM860A run under high speed is also significantly higher than the other two-phase driver, what’s more, the positioning accuracy is also higher. It is widely used in middle and big size numerical control devices such as curving machine, CNC machine, and computer embroider machine, packing machines and so on.
Features:
High performance, low price
Average current control, 2-phase sinusoidal output current drive
Supply voltage from 24VDC to 80VDC
Opto-isolated signal I/O
Overvoltage, under voltage, overcorrect, phase short circuit protection
14 channels subdivision and automatic idle-current reduction
8 channels output phase current setting
Offline command input terminal
Motor torque is related with speed, but not related with step/revolution
High start speed
High hording torque under high speed
БП 48В 400Вт - 2000р. (для просмотра содержимого нажмите на ссылку)
Specifications
Output:
DC Voltage: 48V
Rated Current: 8.3A
Current Range: 0-8.3A
Rated Power: 400W
Ripple & Noise (maximun): 240mV
Voltage Adjustable Range: 41-56V
Voltage Tolerance: ±1.0%
Line Regulation: ±0.5%
Load Regulation: ±0.5%
Setup, Rise, Hold Up Time: 200ms, 50ms, 20ms at full load
Input:
Voltage Range: 90-132V AC / 180-264V AC by Switch 248-370V DC
Frequency Range: 47-63Hz
Efficiency: 83%
AC Current: 6.5A/115V 4A/230V
Inrush Current: 25A/115V 50A/230V
Leakage Current: <3.5mA/240VAC
PLZ007 (устройство плавного пуска) - 500р (для просмотра содержимого нажмите на ссылку)
Устройство плавного пуска PLZ007 (220В/5А). Рекомендуется использовать для построения систем питания с применением импульсных блоков питания и трансфоматоров.
PLZ005 (дампер, защитное устройство) - 500р. (для просмотра содержимого нажмите на ссылку)
Дампер предназначен для защиты драйверов ШД и источников питания от обратной ЭДС создаваемой ШД при резких торможениях/ускорениях. Настоятельно рекомендуется использовать модуль в любых системах с применением ШД. Модуль рассчитан на работу с источниками питания 10-80В, током до 15А. Модуль позволяет подключать 1-4 драйвера ШД.
Шпиндель 1,5 кВт + инвертр - 14000. (для просмотра содержимого нажмите на ссылку)
1.5KW WATER-COOLED SPINDLE MOTOR ENGRAVING MILLING GRIND
Specification:
Size:80x188mm(Middle body diameter:80mmxLength:188mm)
Power:1.5Kw
Voltage:220VAC
Frequency:0-400Hz
Speed:10-24000rpm
Air Cooling ER11 collet chunk
Runout off: less than 0.02mm
3pcs bearing
Grease Lubrication
1.5kw Inverter VFD
Product Feature:
1)PID control; advanced calculus PID closed-loop arithmetic, quick responding speed and high suitability;
2)Easy PLC function can realize 16 legs of speed and inverter control function;
3)RS485 communication port, adopting standard international MODBUS main circuit control;
4)With extremely strong anti-jamming capability
5)Low output ratting torque0.5HZ-150%, low speed running ability;
6)Carrier adjustable by 16KHZ, completely soundless working environment;
7)Broad voltage working area, normal running in 304V-456V;
8)Auto voltage regulation (AVR) technique, for ensuring the inverter load capability;
9)Various control technique by both synchronization and non-synchronization, dynamically realize fast starting without changing brakes;
10)With perfect error protection and short circuit starting protection capability;
Tech parameters:
1) Input Voltage: 220V(+/-15%) ,We also stock 380V(+/-15%), please contact us
for item stock.
2) Output Voltage 208Vac-240VAC
3) Input Frequency: 48-63 Hz
4) Output Frequency: 0-400 Hz
5) Input Phase: 1 or 3 phase
6) Output Phase: 3 phase
7) Warranty: 1 year from the date you purchased
Вся электроника новая. Подключал для проверки. У шпинделя общая наработка около 3-х часов по фанере.
Кнопка АвОст., USB - RS232(485), 3 индуктивных концевика (Характеристик не знаю. Заинтересованным вышлю фото) - цену предлагайте.
Доставка и способ оплаты обговариваются индивидуально.
Для связи 91ноль 4пять1 девять2три1
Последний раз редактировалось Simmer 30 сен 2014, 13:44, всего редактировалось 1 раз.
Simmer
Re: Продам электронику для станка
Сообщение Simmer »
БП 48В 400Вт - 2000р. - В резерве
или поедем в карантин
Simmer
Сообщение Simmer »
NightV писал(а):1. должны присутствовать характеристики товаров
Вроде исправился)))
Simmer
Сообщение Simmer »
Как обещал фото шпинделя.
IMG_06282013_193327.jpg (4034 просмотра) <a class='original' href='./download/file.php?id=34273&mode=view' target=_blank>Загрузить оригинал (509.73 КБ)</a>
IMG_20141002_174846.jpg (4034 просмотра) <a class='original' href='./download/file.php?id=34275&mode=view' target=_blank>Загрузить оригинал (602.42 КБ)</a>
IMG_20141002_174831.jpg (4034 просмотра) <a class='original' href='./download/file.php?id=34274&mode=view' target=_blank>Загрузить оригинал (672.89 КБ)</a>
Simmer
Сообщение Simmer »
Добавилось:
Zalman LQ315 (водяная система охлаждения для процессора. Планировал для охлаждения шпинделя. Новая в коробке. Не распакованная.) - 2500р. (для просмотра содержимого нажмите на ссылку)
Общие характеристики
Назначение для процессора
Водяное охлаждение есть
Socket S1150/1155/S1156, S1356/S1366, S2011, AM2, AM2+, AM3/AM3+/FM1, FM2/FM2+
Совместимость Intel Core i7 Extreme/i7/i5/i3 / Pentium / Celeron / AMD LIano / Trinity / Vishera / Zambezi / Phenom II / Athlon II / Opteron / Phenom / Athlon FX/X2 / Athlon / Sempron
Материал радиатора алюминий
Размеры радиатора (ШхВxГ) 153x120x57 мм
Количество вентиляторов 1
Размеры вентилятора (ДхШхВ) 120x120x25 мм
Скорость вращения 900 - 2000 об/мин
Тип подшипника скольжения
Водоблок
Материал водоблока медь
Размеры водоблока 65x65x32 мм
Масса водоблока 195 г
Дополнительно
Тип коннектора 4-pin PWM
Цвет подсветки синий
Регулятор оборотов отсутствует
Вес 575 г
Дополнительная информация возможность установки второго вентилятора
Simmer
Сообщение Simmer »
Может все таки надо кому???
Wint
Сообщение Wint »
Шпиндель с инвертором если отдаш за 12т, заберу
promokod
Настоящее имя: Дмитрий Крамов
Сообщение promokod »
Интересный агрегат. Скажи пожалуйста сколько литров нужно прокачивать для достаточного охлаждения шпинделя, конкретно для этой модели?
Simmer
Сообщение Simmer »
Wint писал(а):Шпиндель с инвертором если отдаш за 12т, заберу
Отдам. Только пересыл Ваш.
Simmer
Сообщение Simmer »
promokod писал(а):Интересный агрегат. Скажи пожалуйста сколько литров нужно прокачивать для достаточного охлаждения шпинделя, конкретно для этой модели?
Извините, мне сложно ответить. Он у меня не много работал. А то время, что работал охлаждался из 50-ти литровой канистры, просто гоняя воду (с марганцовкой) по кругу. Так она ни разу даже теплой не стала.
fara8018
Настоящее имя: Фархад Ахунбабаев
Сообщение fara8018 »
личку посмотрите пожалуйста.
Simmer
Сообщение Simmer »
Шпиндель и Zalman проданы.
Осталось:
Features:
High start speed
Specifications
Output:
DC Voltage: 48V
Rated Current: 8.3A
Rated Power: 400W
Input:
Efficiency: 83%
Варианты Combo:
1) 3 Axis Stepper motor driver DM860A - 3 шт + Интерфейсная плата + БП 48В 400Вт + PLZ005 (дампер, защитное устройство) + PLZ007 (устройство плавного пуска) = 8000
2) 3 Axis Stepper motor driver DM860A - 3 шт + Интерфейсная плата + БП 48В 400Вт + PLZ005 (дампер, защитное устройство) + PLZ007 (устройство плавного пуска) + Шаговый двигатель PL57H76-3.0-4 - 1 штука + Шаговый двигатель PL57H56-2.6-4 - 2 штуки = 11000
Simmer
Сообщение Simmer »
Все продаю и продаю....
Simmer писал(а):Все продаю и продаю...
Не нужно всё продавать, оставь что-нибудь на память :hehehe:
Ganicv0
Сообщение Ganicv0 »
Привет, меня интересуют драйвера... где и как можно оплатить/получить?
Simmer
Сообщение Simmer »
Пока отдыхал на праздниках мой товарищ подсуетился и продал все кроме двигателей.
Осталось: Если заберете все три, то ценник 2000р.
Последний раз редактировалось Simmer 05 ноя 2014, 14:56, всего редактировалось 1 раз.
sertix
Сообщение sertix »
Попутал малеха :hehehe:
2014-11-05 14-25-50 Скриншот экрана.png (3183 просмотра) <a class='original' href='./download/file.php?id=36066&mode=view' target=_blank>Загрузить оригинал (200.62 КБ)</a>
Simmer
Сообщение Simmer »
Спасибо... поправил)))
Simmer
Сообщение Simmer »
Все продано!
Вернуться в «Продам»
