Страница 1 из 4
Как работать с такой фрезой ?
Добавлено: 18 сен 2013, 08:23
Rasul
Добрый день!
Вопрос такой: Как работать с такой фрезой?
Тип фрезы HN IL 6616 D=10 (20777 просмотров) <a class='original' href='./download/file.php?id=18728&mode=view' target=_blank>Загрузить оригинал (4.04 МБ)</a>
Делаю звездочку:
O0004;
(ZVEZDA)
N1G90G54X-174.23Y-2.71; N2S800M3;
N3M8;
N4G01Z-24.0F500;
N5G41G01D01X-128.47Y-2.71F20;
N6G01X-111.75Y5.03;
N7G03X-104.7Y14.04R11.5;
N8G01X-104.41Y16.02;
N9G03X-108.64Y26.66R11.5;
N10G01X-122.5Y38.79;
N11G02X-109.54Y67.18R128.5;
N12G01X-91.29Y64.65;
N13G03X-80.49Y68.42R11.5;
N14G01X-79.18Y69.93;
N15G03X-76.98Y81.16R11.5;
N16G01X-82.09Y98.86;
N17G02X-55.83Y115.74R128.5;
N18G01X-41.85Y103.74;
N19G03X-30.72Y101.07R11.5;
N20G01X-28.8Y101.63;
N21G03X-20.88Y109.9R11.5;
N22G01X-15.6Y127.55;
N23G02X15.6E127.55R128.5;
N24G01X20.88Y109.9;
N25G3X28.88Y101.63R11.5;
N26G01X30.72Y101.07;
N27G03X41.85Y103.74R11.5;
N28G01X55.83Y115.74;
N29G02X82.09Y98.86R128.5;
N30G01X76.98Y81.16;
N31G03X79.18Y69.93R11.5;
N32G01X80.49Y68.42;
N33G03X91.29Y64.65R11.5;
N34G01X109.54Y67.18;
N35G02X122.5Y38.79R128.5;
N36G01X108.64Y26.66;
N37G03X104.41Y16.02R11.5;
N38G01X104.7Y14.04;
N39G03X111.75Y5.03R11.5;
N40G01X128.47Y-2.71;
N41G02X124.03Y-33.59R128.5;
N42G01X105.81Y-36.31;
N43G03X96.5Y-42.97R11.5;
N44G01X95.67Y-44.79;
N45G03X96.73Y-56.19R11.5;
N46G01X106.61Y-71.73;
N47G02X86.18Y-95.32R128.5;
N48G01X69.38Y-87.75;
N49G03X57.95Y-88.32R11.5;
N50G01X56.27Y-89.4;
N51G03X50.99Y-99.56R11.5;
N52G01X50.91Y-117.99;
N53G02X20.96Y-126.78R128.5;
N54G01X10.93Y-111.33;
N55G03X1Y-105.63R11.5;
N56G01X-1Y-105.63;
N57G03X-10.92Y-111.32R11.5;
N58G01X-20.96Y-126.78;
N59G02X-50.91Y-117.99R128.5;
N60G01X-50.99Y-99.56;
N61G03X-56.27Y-89.4R11.5;
N62G01X-57.95Y-88.32;
N63G03X-69.38Y-87.75R11.5;
N64G01X-86.18Y-95.32;
N65G02X-106.61Y-71.73R128.5;
N66G01X-96.73Y-56.19;
N67G03X-95.67Y-44.79R11.5;
N68G01X-96.5Y-42.97;
N69G03X-105.81Y-36.31R11.5;
N70G01X-124.03Y-33.6;
N71G02X-128.47Y-2.71R128.5;
N72G00G40X-174.23Y-2.71F500;
N73M9;
N74M5;
N75M2;
Тип метала: Сталь 20, толщина 22 мм. При такой обработки фрезы хватает на две - три звездочки.
Подскажите пожалуйста как правельно работать с ней?
Спасибо!
Re: Как работать с такой фрезой ?
Добавлено: 18 сен 2013, 09:53
rustech
400-500 оборотов, подачу 100 ставь. Послойкой можешь.
Смотря ещё какой съём. Возможно из-за вибраций ломается.
Добавлено: 18 сен 2013, 10:02
Rasul писал(а):При такой обработки фрезы хватает на две - три звездочки
Gcode мало чем здесь поможет
Свои режимы напиши.
Добавлено: 18 сен 2013, 10:10
Rasul писал(а):Z-24.0
:wtf: нифигаСе
горит фреза, уменьшай обороты
Добавлено: 18 сен 2013, 10:35
Rasul
aftaev писал(а):Gcode мало чем здесь поможетСвои режимы напиши.
Вы о чем, Я новечек в этом деле
:wtf: нифигаСе
Вот деталь, заготовку готовыя токаря, фрезеровка только по конруру (20752 просмотра) <a class='original' href='./download/file.php?id=18740&mode=view' target=_blank>Загрузить оригинал (4.96 МБ)</a>
Добавлено: 18 сен 2013, 11:44
evgenyjp
Rasul, обработку ведеш торцом или только боковое фрезерование ??
напиши точно:
1. обороты шпинедля ??
2. подачи (F500 судя по Г-кодам)
3. заглубление (по Z - 24мм судя по Г-кодам)
и желательно бы фото станка на котором ето все происходит.
Если ето настоящяя ханита, то ето очень хорошие фрезы и и негоже их так переводить...
Добавлено: 18 сен 2013, 12:08
Rasul
evgenyjp писал(а):обработку ведеш торцом или только боковое фрезерование ??
Торцом за один проход.
evgenyjp писал(а): обороты шпинедля ??
s 800;
evgenyjp писал(а):подачи (F500 судя по Г-кодам)
Смотрите ниже там F20;
evgenyjp писал(а):заглубление (по Z - 24мм судя по Г-кодам)
Сверху в заготовку я не вризаюсь, просто опустился по Z и поехал фрезировать....
SAM_1543.JPG (20733 просмотра) <a class='original' href='./download/file.php?id=18745&mode=view' target=_blank>Загрузить оригинал (4.58 МБ)</a>
Добавлено: 18 сен 2013, 13:06
evgenyjp
Rasul писал(а): Торцом за один проход.
ниче не понял :)
если сверху не врезаешся тогда ето боковое фрезерование, а выше ты говориш что торцом...
какой шаг прохода(stepover) ???
Добавлено: 18 сен 2013, 13:14
Rasul
evgenyjp писал(а):если сверху не врезаешся тогда ето боковое фрезерование, а выше ты говориш что торцом...
Так точно ! :lol:
evgenyjp писал(а):шаг прохода(stepover)
А это что ?
Rasul писал(а): Я новечек в этом деле
Добавлено: 18 сен 2013, 13:23
evgenyjp
Rasul писал(а):
А это что ?
Добавлено: 18 сен 2013, 13:47
Rasul
Всеровно не понел)))) у меня фреза а не резец,
Добавлено: 18 сен 2013, 13:49
evgenyjp
Rasul писал(а):Всеровно не понел)))) у меня фреза а не резец,
ето для наглядности, неважно фреза или нет.
с боку по сколько мм фрезой сдираеш ? или на весь диаметр хреначиш ? :hehehe:
Добавлено: 18 сен 2013, 13:55
Rasul
полностью врезаюсь в зуб (звездочки), на выходе отподает кусочек метала,
Добавлено: 18 сен 2013, 13:58
evgenyjp
Rasul писал(а):полностью врезаюсь в зуб (звездочки), на выходе отподает кусочек метала,
жесть !
вобщем так,
обороты шпинделя 2500-3000
подача ~ 1500мм\мин (плюс-минус)
боком снимать по 0,3 - 0,5мм не более на этой конкретной фрезе (0,03 диаметра старнартная рекомендация)
по Z можно хоть на всю высоту при боковом фрезеровании (45мм вроде на этой фрезе)
тоесть отстрой траекторию в CAMе так, чтоб фигурку звездочки вырезало послойно, со съемом 0,3мм за слой боком.
и есть у меня подозрение что ето не ханита а подделка, ибо несмог найти рекомендованых производителем параметров.
сколько стоили ети фрезы ??? настоящяя стоит порядка 100 баксов.
Добавлено: 18 сен 2013, 14:11
Rasul
В САМе к сожалению еще не научился работать, А фрезы мы покупали у Альтаир Плюс есть каталог и там есть параметры с них я и вычислил S800 F20, покупали их если меня не обманули за 200 американских...
Добавлено: 18 сен 2013, 14:15
Rasul, если фрезеруешь на всю глубину то нужно смотреть на стружку, какого размера получается.
20мм сталь кроил подобными фрезами(кукурузой) за 1проход на всю глубину. Обороты 1500 подача 15-20мм/мин. Обязательно нужна СОЖ.
evgenyjp
Rasul писал(а):В САМе к сожалению еще не научился работать, А фрезы мы покупали у Альтаир Плюс есть каталог и там есть параметры с них я и вычислил S800 F20, покупали их если меня не обманули за 200 американских...
ссылка есть на рекомендованные параметры ?
на весь диаметр врезатся ето тоже там было ? :hehehe:
Добавлено: 18 сен 2013, 14:19
evgenyjp
aftaev писал(а):Rasul, если фрезеруешь на всю глубину то нужно смотреть на стружку, какого размера получается.
ждем вторую сломаную фрезу за 200 баксов :thinking:
Добавлено: 18 сен 2013, 14:20
evgenyjp писал(а):ждем вторую сломаную фрезу за 200 баксов
Мож лучше тренироваться на "наших" совковых
Добавлено: 18 сен 2013, 14:24
Rasul
aftaev писал(а):если фрезеруешь на всю глубину то нужно смотреть на стружку, какого размера получается. 20мм сталь кроил подобными фрезами(кукурузой) за 1проход на всю глубину. Обороты 1500 подача 15-20мм/мин. Обязательно нужна СОЖ.
Стружка была мелкой почти порошок, а какая она должна быть?
evgenyjp писал(а):ссылка есть на рекомендованные параметры ?
нет у меня каталог на руках
evgenyjp писал(а):на весь диаметр врезатся ето тоже там было ?
этого небыло, это я сам
