Проблемы с установкой 3D Max 2013
Остальные вопросы по работе с операционной системой Windows
Романов Семен
Сообщение Романов Семен »
Кто то вдруг сталкивался. Спрошу на всякий случай:
2013/3/19:21:18:15	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/19:21:18:15	user	USER-ПК	Launch
2013/3/19:21:18:20	user	USER-ПК	=== Setup ended ===
2013/3/19:21:18:16	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/19:21:18:16	user	USER-ПК	Launch
2013/3/19:21:18:20	user	USER-ПК	PageOpen	LaunchDialog
2013/3/19:21:18:30	user	USER-ПК	PageOpen	LicenseDialog
2013/3/19:21:18:34	user	USER-ПК	PageOpen	ProductInfoDialog
2013/3/19:21:19:11	user	USER-ПК	PageOpen	ProductSelectionDialog2
2013/3/19:21:19:16	user	USER-ПК	PageOpen	FullProgressDialog
2013/3/19:21:19:16	user	USER-ПК	Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/3/19:21:19:43	user	USER-ПК	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Succeeded
2013/3/19:21:19:43	user	USER-ПК	Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/3/19:21:20:12	user	USER-ПК	Install	Microsoft Visual C++ 2005 Redistributable (x64)	Succeeded
2013/3/19:21:20:12	user	USER-ПК	Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/3/19:21:20:41	user	USER-ПК	Install	Microsoft Visual C++ 2008 SP1 Redistributable (x86)	Succeeded
2013/3/19:21:20:41	user	USER-ПК	Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/3/19:21:21:11	user	USER-ПК	Install	Microsoft Visual C++ 2008 SP1 Redistributable (x64)	Succeeded
2013/3/19:21:21:11	user	USER-ПК	Installing .NET Framework Runtime 4.0: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/19:21:22:58	user	USER-ПК	Install	.NET Framework Runtime 4.0	Succeeded
2013/3/19:21:22:58	user	USER-ПК	Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/3/19:21:26:52	user	USER-ПК	Install	.NET Framework Runtime 4.0 KB2468871	Succeeded
2013/3/19:21:26:52	user	USER-ПК	Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:21:28:19	user	USER-ПК	Install	DirectX® Runtime	Succeeded
2013/3/19:21:28:19	user	USER-ПК	Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:28:42	user	USER-ПК	Install	Autodesk Material Library 2013	Succeeded
2013/3/19:21:28:42	user	USER-ПК	Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:29:31	user	USER-ПК	Install	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:21:29:31	user	USER-ПК	Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:30:28	user	USER-ПК	Install	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:21:30:30	user	USER-ПК	Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI401B.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:30:44	user	USER-ПК	Install	Autodesk® 3ds Max 2013	Failed	Installation aborted, Result=1603
2013/3/19:21:30:53	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:21:31:03	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:21:31:19	user	USER-ПК	Rollback	Autodesk Material Library 2013	Succeeded
2013/3/19:21:31:19	user	USER-ПК	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2013/3/19:21:31:19	user	USER-ПК	Rollback	.NET Framework Runtime 4.0 KB2468871	Failed	Installation aborted, Result=1619
2013/3/19:21:31:20	user	USER-ПК	Rollback	.NET Framework Runtime 4.0	Failed	Failure is ignored, Result=1619
2013/3/19:21:31:20	user	USER-ПК	Rollback	Microsoft Visual C++ 2008 SP1 Redistributable (x64)	Failed	Installation aborted, Result=1619
2013/3/19:21:31:20	user	USER-ПК	Rollback	Microsoft Visual C++ 2008 SP1 Redistributable (x86)	Failed	Installation aborted, Result=1619
2013/3/19:21:31:20	user	USER-ПК	Rollback	Microsoft Visual C++ 2005 Redistributable (x64)	Failed	Installation aborted, Result=1619
2013/3/19:21:31:20	user	USER-ПК	Rollback	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1619
2013/3/19:21:31:20	user	USER-ПК	PageOpen	InstallCompleteDialog
2013/3/19:21:32:27	user	USER-ПК	=== Setup ended ===
2013/3/19:21:32:42	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/19:21:32:42	user	USER-ПК	Launch
2013/3/19:21:32:44	user	USER-ПК	=== Setup ended ===
2013/3/19:21:32:43	user	USER-ПК	PageOpen	LaunchDialog
2013/3/19:21:34:40	user	USER-ПК	PageOpen	LicenseDialog
2013/3/19:21:34:42	user	USER-ПК	PageOpen	ProductInfoDialog
2013/3/19:21:35:09	user	USER-ПК	PageOpen	ProductSelectionDialog2
2013/3/19:21:35:24	user	USER-ПК	PageOpen	FullProgressDialog
2013/3/19:21:35:24	user	USER-ПК	Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:21:36:33	user	USER-ПК	Install	DirectX® Runtime	Succeeded
2013/3/19:21:36:33	user	USER-ПК	Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:36:44	user	USER-ПК	Install	Autodesk Material Library 2013	Succeeded
2013/3/19:21:36:44	user	USER-ПК	Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:37:27	user	USER-ПК	Install	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:21:37:27	user	USER-ПК	Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:38:21	user	USER-ПК	Install	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:21:38:24	user	USER-ПК	Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI78C8.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:38:40	user	USER-ПК	Install	Autodesk® 3ds Max 2013	Failed	Installation aborted, Result=1603
2013/3/19:21:38:49	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:21:38:58	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:21:39:10	user	USER-ПК	Rollback	Autodesk Material Library 2013	Succeeded
2013/3/19:21:39:10	user	USER-ПК	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2013/3/19:21:39:11	user	USER-ПК	PageOpen	InstallCompleteDialog
2013/3/19:21:43:05	user	USER-ПК	=== Setup ended ===
2013/3/19:21:43:09	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/19:21:43:09	user	USER-ПК	Launch
2013/3/19:21:43:18	user	USER-ПК	=== Setup ended ===
2013/3/19:21:43:17	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/19:21:43:17	user	USER-ПК	Launch
2013/3/19:21:43:18	user	USER-ПК	PageOpen	LaunchDialog
2013/3/19:21:43:20	user	USER-ПК	PageOpen	LicenseDialog
2013/3/19:21:43:23	user	USER-ПК	PageOpen	ProductInfoDialog
2013/3/19:21:43:49	user	USER-ПК	PageOpen	ProductSelectionDialog2
2013/3/19:21:44:17	user	USER-ПК	PageOpen	FullProgressDialog
2013/3/19:21:44:17	user	USER-ПК	Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:21:44:59	user	USER-ПК	Install	DirectX® Runtime	Succeeded
2013/3/19:21:44:59	user	USER-ПК	Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:45:06	user	USER-ПК	Install	Autodesk Material Library 2013	Succeeded
2013/3/19:21:45:06	user	USER-ПК	Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:45:11	user	USER-ПК	Install	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:21:45:11	user	USER-ПК	Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:45:32	user	USER-ПК	Install	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:21:45:32	user	USER-ПК	Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI177.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:45:45	user	USER-ПК	Install	Autodesk® 3ds Max 2013	Failed	Installation aborted, Result=1603
2013/3/19:21:45:54	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:21:46:02	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:21:46:13	user	USER-ПК	Rollback	Autodesk Material Library 2013	Succeeded
2013/3/19:21:46:13	user	USER-ПК	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2013/3/19:21:46:14	user	USER-ПК	PageOpen	InstallCompleteDialog
2013/3/19:21:46:55	user	USER-ПК	=== Setup ended ===
2013/3/19:21:54:29	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/19:21:54:29	user	USER-ПК	Launch
2013/3/19:21:54:31	user	USER-ПК	=== Setup ended ===
2013/3/19:21:54:30	user	USER-ПК	PageOpen	LaunchDialog
2013/3/19:21:54:34	user	USER-ПК	PageOpen	LicenseDialog
2013/3/19:21:54:36	user	USER-ПК	PageOpen	ProductInfoDialog
2013/3/19:21:55:03	user	USER-ПК	PageOpen	ProductSelectionDialog2
2013/3/19:21:55:52	user	USER-ПК	PageOpen	FullProgressDialog
2013/3/19:21:55:52	user	USER-ПК	Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:21:56:42	user	USER-ПК	Install	DirectX® Runtime	Succeeded
2013/3/19:21:56:42	user	USER-ПК	Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:56:49	user	USER-ПК	Install	Autodesk Material Library 2013	Succeeded
2013/3/19:21:56:49	user	USER-ПК	Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:56:54	user	USER-ПК	Install	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:21:56:54	user	USER-ПК	Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:57:22	user	USER-ПК	Install	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:21:57:24	user	USER-ПК	Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI6A09.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:21:57:35	user	USER-ПК	Install	Autodesk® 3ds Max 2013	Failed	Installation aborted, Result=1603
2013/3/19:21:57:43	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:21:57:51	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:21:58:03	user	USER-ПК	Rollback	Autodesk Material Library 2013	Succeeded
2013/3/19:21:58:03	user	USER-ПК	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2013/3/19:21:58:04	user	USER-ПК	PageOpen	InstallCompleteDialog
2013/3/19:21:58:08	user	USER-ПК	=== Setup ended ===
2013/3/19:21:59:48	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/19:21:59:48	user	USER-ПК	Launch
2013/3/19:21:59:49	user	USER-ПК	=== Setup ended ===
2013/3/19:21:59:49	user	USER-ПК	PageOpen	LaunchDialog
2013/3/19:21:59:51	user	USER-ПК	PageOpen	LicenseDialog
2013/3/19:21:59:53	user	USER-ПК	PageOpen	ProductInfoDialog
2013/3/19:22:00:21	user	USER-ПК	PageOpen	ProductSelectionDialog2
2013/3/19:22:00:50	user	USER-ПК	PageOpen	FullProgressDialog
2013/3/19:22:00:50	user	USER-ПК	Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/19:22:01:46	user	USER-ПК	Install	DirectX® Runtime	Succeeded
2013/3/19:22:01:46	user	USER-ПК	Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:22:01:53	user	USER-ПК	Install	Autodesk Material Library 2013	Succeeded
2013/3/19:22:01:53	user	USER-ПК	Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:22:01:58	user	USER-ПК	Install	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:22:01:58	user	USER-ПК	Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:22:02:15	user	USER-ПК	Install	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:22:02:16	user	USER-ПК	Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI478B.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/19:22:02:29	user	USER-ПК	Install	Autodesk® 3ds Max 2013	Failed	Installation aborted, Result=1603
2013/3/19:22:02:37	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/19:22:02:44	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/19:22:02:56	user	USER-ПК	Rollback	Autodesk Material Library 2013	Succeeded
2013/3/19:22:02:57	user	USER-ПК	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2013/3/19:22:02:57	user	USER-ПК	PageOpen	InstallCompleteDialog
2013/3/19:22:03:12	user	USER-ПК	=== Setup ended ===
2013/3/21:20:34:05	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/21:20:34:05	user	USER-ПК	Launch
2013/3/21:20:34:11	user	USER-ПК	=== Setup ended ===
2013/3/21:20:34:07	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/21:20:34:07	user	USER-ПК	Launch
2013/3/21:20:34:11	user	USER-ПК	PageOpen	LaunchDialog
2013/3/21:20:34:14	user	USER-ПК	PageOpen	LicenseDialog
2013/3/21:20:34:16	user	USER-ПК	PageOpen	ProductInfoDialog
2013/3/21:20:36:19	user	USER-ПК	PageOpen	ProductSelectionDialog2
2013/3/21:20:37:05	user	USER-ПК	PageOpen	FullProgressDialog
2013/3/21:20:37:06	user	USER-ПК	Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/21:20:42:00	user	USER-ПК	Install	DirectX® Runtime	Succeeded
2013/3/21:20:42:00	user	USER-ПК	Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/21:20:44:26	user	USER-ПК	Install	Autodesk Material Library 2013	Succeeded
2013/3/21:20:44:26	user	USER-ПК	Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/21:20:45:29	user	USER-ПК	Install	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/21:20:45:29	user	USER-ПК	Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/21:20:47:06	user	USER-ПК	Install	Autodesk Material Library 2013 - Medium Resolution Library	Succeeded
2013/3/21:20:47:08	user	USER-ПК	Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI6DCF.tmp\x86\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_32bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/21:20:47:39	user	USER-ПК	Install	Autodesk® 3ds Max 2013	Failed	Installation aborted, Result=1603
2013/3/21:20:47:43	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Medium Resolution Library	Failed	Installation aborted, Result=1603
2013/3/21:20:47:56	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/21:20:48:09	user	USER-ПК	Rollback	Autodesk Material Library 2013	Failed	Installation aborted, Result=1603
2013/3/21:20:48:09	user	USER-ПК	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
Win 7 x64 .7600 (не сборка, чистая) - единственное что, это она щас справа снизу кажет: Тестовый режим. Появилось после того как мне ставили ArtCAM.
Характеристики компа - явно потянули бы макса, ибо на старенький комп с ХР поставился с этого дистриба =)
Прошу помощи. :blush:
tooshka
Re: Проблемы с установкой 3D Max 2013
Сообщение tooshka »
Если комп не очень мощный попробуй поставь более раннюю версию макса.
Милая, ты услышь меня
Романов Семен
Комп весьма мощный, а вот на более слабый пробовал ставить - поставилось там, но все жутко тормозит.
Я так думаю проблемы с ОС, но вот какие понять не могу. поставил уже SP1 - не помогло, NET 4 поставил. сейчас попробую directx обновить и видео драйвер
upd
пробовал обновить directx - говорит самая последняя версия.
качаю драйвера на видео - но думаю что вряд ли поможет - на старом компе вряд ли были последние драйвера =(
Видно что-то еще =(
Романов Семен
Обновил драйвера видео, directx обновлен как писал выше.
Удалил NET 4, NET 4 Client, все редистрибы с++, что бы установка шла с нуля.
Выключил Тестовый режим винды.
Ставлю 3ds max все равно ошибка.
уже не знаю что и делать..
2013/3/22:14:34:58	user	USER-ПК	=== Setup started on USER-ПК by user ===
2013/3/22:14:34:58	user	USER-ПК	Launch
2013/3/22:14:35:00	user	USER-ПК	=== Setup ended ===
2013/3/22:14:35:00	user	USER-ПК	PageOpen	LaunchDialog
2013/3/22:14:35:01	user	USER-ПК	PageOpen	LicenseDialog
2013/3/22:14:35:07	user	USER-ПК	PageOpen	ProductInfoDialog
2013/3/22:14:35:30	user	USER-ПК	PageOpen	ProductSelectionDialog2
2013/3/22:14:35:42	user	USER-ПК	PageOpen	FullProgressDialog
2013/3/22:14:35:42	user	USER-ПК	Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/3/22:14:36:02	user	USER-ПК	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Succeeded
2013/3/22:14:36:02	user	USER-ПК	Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/3/22:14:36:13	user	USER-ПК	Install	Microsoft Visual C++ 2005 Redistributable (x64)	Succeeded
2013/3/22:14:36:13	user	USER-ПК	Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/3/22:14:36:22	user	USER-ПК	Install	Microsoft Visual C++ 2008 SP1 Redistributable (x86)	Succeeded
2013/3/22:14:36:22	user	USER-ПК	Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/3/22:14:36:32	user	USER-ПК	Install	Microsoft Visual C++ 2008 SP1 Redistributable (x64)	Succeeded
2013/3/22:14:36:32	user	USER-ПК	Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/3/22:14:36:38	user	USER-ПК	Install	Microsoft Visual C++ 2010 SP1 Redistributable (x86)	Succeeded
2013/3/22:14:36:38	user	USER-ПК	Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/3/22:14:36:45	user	USER-ПК	Install	Microsoft Visual C++ 2010 SP1 Redistributable (x64)	Succeeded
2013/3/22:14:36:45	user	USER-ПК	Installing .NET Framework Runtime 4.0: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/22:14:40:10	user	USER-ПК	Install	.NET Framework Runtime 4.0	Succeeded
2013/3/22:14:40:10	user	USER-ПК	Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/3/22:14:42:36	user	USER-ПК	Install	.NET Framework Runtime 4.0 KB2468871	Succeeded
2013/3/22:14:42:36	user	USER-ПК	Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/22:14:43:37	user	USER-ПК	Install	DirectX® Runtime	Succeeded
2013/3/22:14:43:37	user	USER-ПК	Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:14:43:45	user	USER-ПК	Install	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/22:14:43:45	user	USER-ПК	Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI643E.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:14:43:58	user	USER-ПК	Install	Autodesk® 3ds Max 2013	Failed	Installation aborted, Result=1603
2013/3/22:14:44:05	user	USER-ПК	Rollback	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/3/22:14:44:05	user	USER-ПК	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2013/3/22:14:44:05	user	USER-ПК	Rollback	.NET Framework Runtime 4.0 KB2468871	Failed	Installation aborted, Result=1619
2013/3/22:14:44:05	user	USER-ПК	Rollback	.NET Framework Runtime 4.0	Failed	Failure is ignored, Result=1619
2013/3/22:14:44:05	user	USER-ПК	Rollback	Microsoft Visual C++ 2010 SP1 Redistributable (x64)	Failed	Installation aborted, Result=1619
2013/3/22:14:44:05	user	USER-ПК	Rollback	Microsoft Visual C++ 2010 SP1 Redistributable (x86)	Failed	Installation aborted, Result=1619
2013/3/22:14:44:05	user	USER-ПК	Rollback	Microsoft Visual C++ 2008 SP1 Redistributable (x64)	Failed	Installation aborted, Result=1619
2013/3/22:14:44:06	user	USER-ПК	Rollback	Microsoft Visual C++ 2008 SP1 Redistributable (x86)	Failed	Installation aborted, Result=1619
2013/3/22:14:44:06	user	USER-ПК	Rollback	Microsoft Visual C++ 2005 Redistributable (x64)	Failed	Installation aborted, Result=1619
2013/3/22:14:44:06	user	USER-ПК	Rollback	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1619
2013/3/22:14:44:08	user	USER-ПК	PageOpen	InstallCompleteDialog
2013/3/22:14:45:01	user	USER-ПК	=== Setup ended ===
где-то читал что бывают проблемы с правами доступа, как это узнать или еще что то?
Запускал установочник от имени администратора, антивирус был выключен!
Отключи контроль учетных записей
Без-имени-1.png (21082 просмотра) <a class='original' href='./download/file.php?id=13098&mode=view' target=_blank>Загрузить оригинал (46.61 КБ)</a>
И еще - если у тебя антивирус касперского, или какой-нибудь Avast или Avira, то шансы на успех будут довольно низки, особенно - с применением лекарства.
А, собственно, в чем проблема то заключается?
Я понял, что проблемы с установкой, но какие именно?
Если вообще не находит, куда он что установил - может быть проблемы с директорией установки, или с русскими буквами в названии дирректории.
Романов Семен
michael-yurov писал(а):Отключи контроль учетных записей
отключено
michael-yurov писал(а):И еще - если у тебя антивирус касперского, или какой-нибудь Avast или Avira, то шансы на успех будут довольно низки, особенно - с применением лекарства.
касперский стоит =(
michael-yurov писал(а):А, собственно, в чем проблема то заключается?
установка идет, идет и прерывается.
ничего не устанавливается
michael-yurov писал(а):Если вообще не находит, куда он что установил - может быть проблемы с директорией установки, или с русскими буквами в названии дирректории.
не то что бы не находит, просто не устанавливает, нет пытаюсь установить тупо в программ файлз
Вообще - основное подозрение на касперского.
Если лицензия на касперского за деньги куплена - не знаю, что посоветовать.
А если не покупалась - очень рекомендую использовать Nod32 (просто антивирус, а не смарт секьюрити).
Знакомый долгое время работал в 3dsMax 2008 просто потому что не мог установить более новую версию из за касперского.
tooshka
Сообщение tooshka »
Романов Семен писал(а):касперский стоит =(
Мочить систему теперь. Фиг его до конца удалишь.
Романов Семен
michael-yurov писал(а):Если лицензия на касперского за деньги куплена - не знаю, что посоветовать.
покупалась за деньги.
снес винду, поставил макс!
Романов Семен писал(а):снес винду, поставил макс!
:shock: О, как!... однако...
Романов Семен
registerf
Сообщение registerf »
3d max решение проблемы с установкой
100% решение проблемы!
1. Запускаем "Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm.sfx.exe" например
2. Как доходит до установки Framework получаем ошибку.
3. Все закрываем.
4. Во время установки на диске С создается папка с распакованными установочными файлами, туда и заходим
5. Заходим на диск C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm
6. Если система 64 битная заходим в папку x64
(C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\x64)
там список папок
- Cp
- DirectConnect
- ESM
- Inventor_Server
- max
- PDATA
- Revit
- Tools
7. Спокойно устанавливаем Макс из папки "max"
8. И все остальное из папок внутри папки "x64"
9. Регистрация ни чем не отличается не забываем про права администратора. (запускаем ярлык с рабочего стола и таблетку с правами админа, патчим, генерируем)
тоже долго парился с Framework. Тоже винду сносил (проблема решалась)
но вот на очередном компе добил и решил проблему обойдя установку Framework.
система w7 64 бит SP1
На многих форумах люди мучаются.
Пользуйтесь, копируйте способ чтоб народу помочь.
Вернуться в «Прочие вопросы Windows»
