Страница 1 из 4
Ошибка Круговая интерполяция
Добавлено: 10 дек 2019, 12:08
dinkata
Странно и для меня непонятно .
Инструмент уходит вне заданой контур !!
20191210_2.jpg (3667 просмотров) <a class='original' href='./download/file.php?id=173070&mode=view' target=_blank>Загрузить оригинал (865.71 КБ)</a>
20191210_1.jpg (3667 просмотров) <a class='original' href='./download/file.php?id=173071&mode=view' target=_blank>Загрузить оригинал (2.6 МБ)</a>
УП:
G21 G40 G49
G17
G10L2P2 Z-472.872
G55
G0X0.000Y0.000S600M3
G0X0.000Y44.100Z80.000
G0Z3.000
M8
G1Z-0.250F15.0
G2X44.100Y0.000I0.000J-44.100F150.0
G2X0.000Y-44.100I-44.100J0.000
G2X-44.100Y0.000I0.000J44.100
G2X0.000Y44.100I44.100J0.000
G1Z-0.500F3.0
G1Z-0.750F3.0
G1Z-1.000F3.0
G1Z-1.250F3.0
G1Z-1.500F3.0
G1Z-1.750F3.0
G1Z-2.000F3.0
G1Z-2.250F3.0
G1Z-2.500F3.0
G1Z-2.750F3.0
G1Z-3.000F3.0
G1Z-3.250F3.0
G1Z-3.500F3.0
G1Z-3.750F3.0
G1Z-4.000F3.0
G1Z-4.250F3.0
G1Z-4.500F3.0
G1Z-4.750F3.0
G1Z-5.000F3.0
G1Z-5.250F3.0
G1Z-5.500F3.0
G1Z-5.750F3.0
G1Z-6.000F3.0
G1Z-6.250F3.0
G1Z-6.500F3.0
G1Z-6.750F3.0
G1Z-7.000F3.0
G1Z-7.250F3.0
G1Z-7.500F3.0
G1Z-7.750F3.0
G1Z-8.000F3.0
G1Z-8.250F3.0
G1Z-8.500F3.0
G1Z-8.750F3.0
G1Z-9.000F3.0
G1Z-9.250F3.0
G1Z-9.500F3.0
G1Z-9.750F3.0
G1Z-10.000F3.0
G1Z-10.250F3.0
G1Z-10.500F3.0
G1Z-10.750F3.0
G1Z-11.000F3.0
G1Z-11.250F3.0
G1Z-11.500F3.0
G1Z-11.750F3.0
G1Z-12.000F3.0
G1Z-12.250F3.0
G1Z-12.500F3.0
G1Z-12.750F3.0
G1Z-13.000F3.0
G1Z-13.250F3.0
G1Z-13.500F3.0
G1Z-13.750F3.0
G1Z-14.000F3.0
G1Z-14.250F3.0
G1Z-14.500F3.0
G1Z-14.750F3.0
G1Z-15.000F3.0
G1Z-15.250F3.0
G1Z-15.500F3.0
G1Z-15.750F3.0
G1Z-16.000F3.0
G1Z-16.250F3.0
G1Z-16.500F3.0
G1Z-16.750F3.0
G1Z-17.000F3.0
G1Z-17.250F3.0
G1Z-17.500F3.0
G1Z-17.750F3.0
G1Z-18.000F3.0
G1Z-18.250F3.0
G1Z-18.500F3.0
G1Z-18.750F3.0
G1Z-19.000F3.0
G1Z-19.250F3.0
G1Z-19.500F3.0
G1Z-19.750F3.0
G1Z-20.000F3.0
G1Z-20.250F3.0
G1Z-20.500F3.0
G1Z-20.750F3.0
G1Z-21.000F3.0
G1Z-21.250F3.0
G1Z-21.500F3.0
G1Z-21.750F3.0
G1Z-22.000F3.0
G0Z8.000M9
G0Z280.000
M5
G0X0.000Y0.000
M2
идет несколько круга правильно и вдруг уходит ...!!??
https://www.youtube.com/watch?v=9Z1x1iWjohs
оператор генерирует УП с ASPIRE 3 , как ему помоч ?
Re: Ошибка Круговая интерполяция
Добавлено: 10 дек 2019, 12:37
lkbyysq
Станок рабочий? Не сломан?
Добавлено: 10 дек 2019, 13:33
dinkata
lkbyysq писал(а):Станок рабочий? Не сломан?
хе :hehehe: , сломается инструмент фреза , станок трудно сломаеш .
http://www.cnc-club.ru/forum/viewtopic.php?f=146&t=5697
Добавлено: 10 дек 2019, 13:51
Какая версия LinuxCNC? :)
Добавлено: 10 дек 2019, 13:54
dinkata
MX_Master писал(а):Какая версия LinuxCNC
PathPilot 2
Добавлено: 10 дек 2019, 16:15
dinkata писал(а):PathPilot 2
вот именно :)
Я, кстати, до сих пор не понимаю за что так любят PathPilot. Только из-за пары мастеров для токарки?
Добавлено: 10 дек 2019, 16:40
dinkata
вот именно
что именно ??
давно работает без проблем.
Добавлено: 10 дек 2019, 16:45
Если работает без проблем, значит, PathPilot не виноват (:
Добавлено: 10 дек 2019, 18:27
dinkata
MX_Master писал(а):за что так любят PathPilot
интерфейс , интерфейс , интерфейс ....... на мой взгляд конечно !
Посколько я знаю тьй занимаешся с интерфейс к Linuxcnc ...
и если так , то покажи пожалуйста лучший интерфейс .
Добавлено: 10 дек 2019, 18:28
а если "по воздуху" отработать?
(без фрезы например)
Добавлено: 10 дек 2019, 18:30
ну или по совсем мягкому материалу...
dinkata
nkp писал(а):а если "по воздуху" отработать?
цельй день отработьйвали по воздух , до обед с ошибка та же ,
послеобед ни раз не ошибся , пока сомнения в температура в цех , но нет еще увереност !
Добавлено: 10 дек 2019, 18:32
А какая у тебя температура до обеда в помещении была?
Добавлено: 10 дек 2019, 18:34
dinkata писал(а): температура
дайте ему вискаря ...
это немного согревает :) :)
dinkata
MX_Master писал(а):А какая у тебя температура до обеда в помещении была?
ну нет термометр , но в пределах 5 -10 гр.С
Добавлено: 10 дек 2019, 18:56
Для точных работ на точных станках в помещении должно быть градусов 20 :) у меня станок по дереву, дык я его при температуре ниже 10 градусов даже не включаю. А ещё при низкой температуре и быстром нагреве можно запросто схватить конденсат на электронике.
Добавлено: 10 дек 2019, 19:44
dinkata писал(а):но в пределах 5 -10 гр.С
Работали и в -10, что подогретая СОЖ на стенках станка свисала как сосульки и уходов таких не было.
Похоже на проскальзывание муфты.
Я бы пробовал:
1. установить ноль
2. запустить программу, как только уйдет = пауза. Смотреть координаты осей. Эти координаты за пределами контура?
3. Гоним станок в ноль. Возвращается или нет?
Добавлено: 10 дек 2019, 19:49
calabr
MX_Master писал(а):А ещё при низкой температуре и быстром нагреве можно запросто схватить конденсат на электронике.
Конденсат так точно не схватиш - если греется плата, то она всегда сухая будет, если воздух в помещении, то он тоакже становится суше - влаги-то в нем не добавилось.
Это если начать что-то охлаждать на нем роса появиться.
Судя по фотке - глючит только 1 ось - вертикальная(на фотке). С ней и нужно искать проблемы - может механика, может драйвер или контакты/наводки... Там до обеда случайно сварщики мимо не проходили?
NikolayUa24
nkp писал(а):дайте ему вискаря ...
У них популярная ракия (40%)фруктовый самогон и мастика анисовая настойка 45% согревает :good:
Добавлено: 10 дек 2019, 20:37
calabr писал(а):Конденсат так точно не схватиш - если греется плата, то она всегда сухая будет
Если ящик станка был выключен во время быстрого нагрева, конденсат схватить дело нехитрое :)
Ну и для проверки, надо на том же компе кроме PathPilot иметь установленную LinuxCNC. Тогда половина вопросов к софту может отпасть.
