ошибка linuxcnc
j4zzur1
Настоящее имя: Николай
ошибка linuxcnc
Сообщение j4zzur1 »
Добрый день, уважаемые формучане. После настройки gantry через trivkins столкнулся с такой проблемой. После закрытия linuxcnc вылетает ошибка
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0-pre0-373-gb0b2758
Machine configuration directory is '/home/mdrives/linuxcnc/configs/BVR'
Machine configuration file is 'BVR.ini'
INIFILE=/home/mdrives/linuxcnc/configs/BVR/BVR.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Y Z
KINEMATICS=trivkins coordinates=xyyz
Starting LinuxCNC...
Found file(REL): ./BVR.hal
Found file(REL): ./custom.hal
Starting TASK program: milltask
Starting DISPLAY program: axis
Warning: Forward kinematics must handle duplicate coordinate letters:yy
Note:
Individual axis homing is not currently supported for
KINEMATICS_IDENTITY with duplicate axis letter <Y>
task: 664 cycles, min=0.000018, max=0.015740, avg=0.009890, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
note: MAXV max: 100.000 units/sec 6000.000 units/min
note: LJOG max: 100.000 units/sec 6000.000 units/min
note: LJOG default: 10.000 units/sec 600.000 units/min
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1437, in __call__
return self.func(*args)
File "/usr/bin/axis", line 1442, in jogspeed_listbox_change
if isinstance(value, str): value = value.encode('utf-8', 'replace')
UnicodeDecodeError: 'ascii' codec can't decode byte 0xd0 in position 0: ordinal not in range(128)
note: jog_order='XYZ'
note: jog_invert=set([])
python: emc/rs274ngc/interp_setup.cc:189: setup::~setup(): Assertion `!pythis || Py_IsInitialized()' failed.
/usr/bin/linuxcnc: line 896: 7277 Аварийный останов $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
7231
7273
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001f000000 (usable)
[ 0.000000] BIOS-e820: 000000001f000000 - 000000001f100000 (reserved)
[ 0.000000] BIOS-e820: 000000001f100000 - 0000000020000000 (usable)
[ 0.000000] BIOS-e820: 0000000020000000 - 0000000020100000 (reserved)
[ 0.000000] BIOS-e820: 0000000020100000 - 000000007853e000 (usable)
[ 0.000000] BIOS-e820: 000000007853e000 - 000000007856e000 (reserved)
[ 0.000000] BIOS-e820: 000000007856e000 - 000000007857f000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007857f000 - 000000007869c000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007869c000 - 0000000078ac3000 (reserved)
[ 0.000000] BIOS-e820: 0000000078ac3000 - 0000000078ac4000 (usable)
[ 0.000000] BIOS-e820: 0000000078ac4000 - 0000000078b06000 (reserved)
[ 0.000000] BIOS-e820: 0000000078b06000 - 0000000078c7c000 (usable)
[ 0.000000] BIOS-e820: 0000000078c7c000 - 0000000078ffa000 (reserved)
[ 0.000000] BIOS-e820: 0000000078ffa000 - 0000000079000000 (usable)
[ 0.000000] BIOS-e820: 00000000e00f8000 - 00000000e00f9000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed01000 - 00000000fed02000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed08000 - 00000000fed09000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff800000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000180000000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: ASUS All Series/J1800I-C, BIOS 0808 11/26/2015
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x79000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-E7FFF write-through
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 079000000 mask FFF000000 uncachable
[ 0.000000] 2 base 07A000000 mask FFE000000 uncachable
[ 0.000000] 3 base 07C000000 mask FFC000000 uncachable
[ 0.000000] 4 base 100000000 mask F80000000 write-back
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000079000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd680] fd680
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36412000 - 37201000
[ 0.000000] ACPI: RSDP 000f04a0 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 78575080 0007C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 7857d6b8 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 78575198 0851C (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.000000] ACPI: FACS 7869bf80 00040
[ 0.000000] ACPI: APIC 7857d7c8 00068 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 7857d830 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG 7857d878 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: LPIT 7857d8b8 00104 (v01 ALASKA A M I 00000003 VLV2 0100000D)
[ 0.000000] ACPI: HPET 7857d9c0 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 7857d9f8 00763 (v01 PmRef CpuPm 00003000 INTL 20061109)
[ 0.000000] ACPI: SSDT 7857e160 00290 (v01 PmRef Cpu0Tst 00003000 INTL 20061109)
[ 0.000000] ACPI: SSDT 7857e3f0 0017A (v01 PmRef ApTst 00003000 INTL 20061109)
[ 0.000000] ACPI: UEFI 7857e570 00042 (v01 ALASKA A M I 00000000 00000000)
[ 0.000000] ACPI: BGRT 7857e610 00038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1048MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x00079000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x0001f000
[ 0.000000] 0: 0x0001f100 -> 0x00020000
[ 0.000000] 0: 0x00020100 -> 0x0007853e
[ 0.000000] 0: 0x00078ac3 -> 0x00078ac4
[ 0.000000] 0: 0x00078b06 -> 0x00078c7c
[ 0.000000] 0: 0x00078ffa -> 0x00079000
[ 0.000000] On node 0 totalpages: 492616
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f54f2200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 220974 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2097 pages used for memmap
[ 0.000000] HighMem zone: 263820 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-86
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 103
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 000000001f000000 - 000000001f100000
[ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020100000
[ 0.000000] Allocating PCI resources starting at 79000000 (gap: 79000000:670f8000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77cf000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 488743
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=fae57a38-964c-4954-8a4f-597d9ea98343 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 3964800 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:00079000)
[ 0.000000] Memory: 1929988k/1982464k available (3495k kernel code, 40476k reserved, 1237k data, 416k init, 1063668k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f5008000 soft=f500a000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration failed
[ 0.004000] TSC: PIT calibration matches HPET. 1 loops
[ 0.004000] Detected 2416.676 MHz processor.
[ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 4833.35 BogoMIPS (lpj=9666704)
[ 0.000008] pid_max: default: 32768 minimum: 301
[ 0.000075] Security Framework initialized
[ 0.000081] AppArmor: AppArmor disabled by boot time parameter
[ 0.000107] Mount-cache hash table entries: 512
[ 0.000351] Initializing cgroup subsys cpuacct
[ 0.000355] Initializing cgroup subsys memory
[ 0.000365] Initializing cgroup subsys devices
[ 0.000369] Initializing cgroup subsys freezer
[ 0.000372] Initializing cgroup subsys net_cls
[ 0.000375] Initializing cgroup subsys blkio
[ 0.000384] Initializing cgroup subsys perf_event
[ 0.000418] CPU: Physical Processor ID: 0
[ 0.000421] CPU: Processor Core ID: 0
[ 0.000426] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000427] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.010402] mce: CPU supports 6 MCE banks
[ 0.010412] CPU0: Thermal monitoring enabled (TM1)
[ 0.010485] ACPI: Core revision 20120320
[ 0.023100] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.023818] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.063440] CPU0: Intel(R) Celeron(R) CPU J1800 @ 2.41GHz stepping 08
[ 0.168264] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver.
[ 0.168276] ... version: 3
[ 0.168279] ... bit width: 40
[ 0.168281] ... generic registers: 2
[ 0.168284] ... value mask: 000000ffffffffff
[ 0.168287] ... max period: 000000007fffffff
[ 0.168290] ... fixed-purpose events: 3
[ 0.168293] ... event mask: 0000000700000003
[ 0.180305] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.192254] CPU 1 irqstacks, hard=f50d2000 soft=f50d4000
[ 0.192258] Booting Node 0, Processors #1 Ok.
[ 0.202270] Initializing CPU#1
[ 0.214670] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.214736] Brought up 2 CPUs
[ 0.214740] Total of 2 processors activated (9666.70 BogoMIPS).
[ 0.215275] devtmpfs: initialized
[ 0.215629] PM: Registering ACPI NVS region [mem 0x7857f000-0x7869bfff] (1167360 bytes)
[ 0.215842] dummy:
[ 0.215935] NET: Registered protocol family 16
[ 0.216109] ACPI: bus type pci registered
[ 0.216198] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.216203] PCI: not using MMCONFIG
[ 0.216610] PCI: Using configuration type 1 for base access
[ 0.217594] bio: create slab <bio-0> at 0
[ 0.217749] ACPI: Added _OSI(Module Device)
[ 0.217754] ACPI: Added _OSI(Processor Device)
[ 0.217759] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.217763] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.221779] ACPI: EC: Look up EC in DSDT
[ 0.234206] ACPI: SSDT 78566598 00506 (v01 PmRef Cpu0Ist 00003000 INTL 20061109)
[ 0.235228] ACPI: Dynamic OEM Table Load:
[ 0.235235] ACPI: SSDT (null) 00506 (v01 PmRef Cpu0Ist 00003000 INTL 20061109)
[ 0.235511] ACPI: SSDT 78565918 00433 (v01 PmRef Cpu0Cst 00003001 INTL 20061109)
[ 0.236509] ACPI: Dynamic OEM Table Load:
[ 0.236515] ACPI: SSDT (null) 00433 (v01 PmRef Cpu0Cst 00003001 INTL 20061109)
[ 0.237211] ACPI: SSDT 78567e18 0015F (v01 PmRef ApIst 00003000 INTL 20061109)
[ 0.238276] ACPI: Dynamic OEM Table Load:
[ 0.238282] ACPI: SSDT (null) 0015F (v01 PmRef ApIst 00003000 INTL 20061109)
[ 0.238556] ACPI: SSDT 78568f18 0008D (v01 PmRef ApCst 00003000 INTL 20061109)
[ 0.239569] ACPI: Dynamic OEM Table Load:
[ 0.239575] ACPI: SSDT (null) 0008D (v01 PmRef ApCst 00003000 INTL 20061109)
[ 0.240427] ACPI: Interpreter enabled
[ 0.240438] ACPI: (supports S0 S3 S4 S5)
[ 0.240484] ACPI: Using IOAPIC for interrupt routing
[ 0.240526] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.242099] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.242104] PCI: Using MMCONFIG for extended config space
[ 0.650607] ACPI: Power Resource [USBC] (on)
[ 0.651064] ACPI: Power Resource [FN00] (off)
[ 0.652248] ACPI: No dock devices found.
[ 0.652258] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.652771] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.653285] pci_root PNP0A08:00: host bridge window [io 0x0000-0x006f]
[ 0.653291] pci_root PNP0A08:00: host bridge window [io 0x0078-0x0cf7]
[ 0.653295] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.653299] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.653303] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff]
[ 0.653307] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000fffff]
[ 0.653312] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0x90716fff]
[ 0.653367] PCI host bridge to bus 0000:00
[ 0.653372] pci_bus 0000:00: root bus resource [io 0x0000-0x006f]
[ 0.653376] pci_bus 0000:00: root bus resource [io 0x0078-0x0cf7]
[ 0.653380] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.653384] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.653389] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff]
[ 0.653393] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff]
[ 0.653397] pci_bus 0000:00: root bus resource [mem 0x80000000-0x90716fff]
[ 0.653412] pci 0000:00:00.0: [8086:0f00] type 00 class 0x060000
[ 0.653465] pci 0000:00:02.0: [8086:0f31] type 00 class 0x030000
[ 0.653482] pci 0000:00:02.0: reg 10: [mem 0x90000000-0x903fffff]
[ 0.653497] pci 0000:00:02.0: reg 18: [mem 0x80000000-0x8fffffff pref]
[ 0.653511] pci 0000:00:02.0: reg 20: [io 0xf080-0xf087]
[ 0.653580] pci 0000:00:13.0: [8086:0f23] type 00 class 0x010601
[ 0.653603] pci 0000:00:13.0: reg 10: [io 0xf070-0xf077]
[ 0.653615] pci 0000:00:13.0: reg 14: [io 0xf060-0xf063]
[ 0.653627] pci 0000:00:13.0: reg 18: [io 0xf050-0xf057]
[ 0.653639] pci 0000:00:13.0: reg 1c: [io 0xf040-0xf043]
[ 0.653651] pci 0000:00:13.0: reg 20: [io 0xf020-0xf03f]
[ 0.653663] pci 0000:00:13.0: reg 24: [mem 0x90716000-0x907167ff]
[ 0.653702] pci 0000:00:13.0: PME# supported from D3hot
[ 0.653729] pci 0000:00:14.0: [8086:0f35] type 00 class 0x0c0330
[ 0.653753] pci 0000:00:14.0: reg 10: [mem 0x90700000-0x9070ffff 64bit]
[ 0.653809] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.653845] pci 0000:00:1a.0: [8086:0f18] type 00 class 0x108000
[ 0.653875] pci 0000:00:1a.0: reg 10: [mem 0x90500000-0x905fffff]
[ 0.653897] pci 0000:00:1a.0: reg 14: [mem 0x90400000-0x904fffff]
[ 0.653990] pci 0000:00:1a.0: PME# supported from D0 D3hot
[ 0.654020] pci 0000:00:1b.0: [8086:0f04] type 00 class 0x040300
[ 0.654047] pci 0000:00:1b.0: reg 10: [mem 0x90710000-0x90713fff 64bit]
[ 0.654113] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.654139] pci 0000:00:1c.0: [8086:0f48] type 01 class 0x060400
[ 0.654195] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.654222] pci 0000:00:1c.1: [8086:0f4a] type 01 class 0x060400
[ 0.654278] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.654306] pci 0000:00:1c.2: [8086:0f4c] type 01 class 0x060400
[ 0.654362] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.654387] pci 0000:00:1c.3: [8086:0f4e] type 01 class 0x060400
[ 0.654443] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.654484] pci 0000:00:1d.0: [8086:0f34] type 00 class 0x0c0320
[ 0.654515] pci 0000:00:1d.0: reg 10: [mem 0x90715000-0x907153ff]
[ 0.654621] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.654652] pci 0000:00:1f.0: [8086:0f1c] type 00 class 0x060100
[ 0.654752] pci 0000:00:1f.3: [8086:0f12] type 00 class 0x0c0500
[ 0.654790] pci 0000:00:1f.3: reg 10: [mem 0x90714000-0x9071401f]
[ 0.654867] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f]
[ 0.654995] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.655061] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.655081] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.655113] pci 0000:02:00.0: reg 18: [mem 0x90604000-0x90604fff 64bit]
[ 0.655134] pci 0000:02:00.0: reg 20: [mem 0x90600000-0x90603fff 64bit pref]
[ 0.655188] pci 0000:02:00.0: supports D1 D2
[ 0.655191] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.661882] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.661889] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.661894] pci 0000:00:1c.1: bridge window [mem 0x90600000-0x906fffff]
[ 0.661942] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.661989] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[ 0.662016] pci_bus 0000:00: on NUMA node 0
[ 0.662022] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.662407] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.662502] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.662608] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.662701] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.662997] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 3.258381] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 3.258507] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 3.258631] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 3.258755] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 3.258878] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 3.259002] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 3.259127] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 3.259251] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 3.259391] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 3.259404] vgaarb: loaded
[ 3.259407] vgaarb: bridge control possible 0000:00:02.0
[ 3.259456] PCI: Using ACPI for IRQ routing
[ 3.265633] PCI: pci_cache_line_size set to 64 bytes
[ 3.265703] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 3.265707] reserve RAM buffer: 000000001f000000 - 000000001fffffff
[ 3.265712] reserve RAM buffer: 000000007853e000 - 000000007bffffff
[ 3.265716] reserve RAM buffer: 0000000078ac4000 - 000000007bffffff
[ 3.265720] reserve RAM buffer: 0000000078c7c000 - 000000007bffffff
[ 3.265724] reserve RAM buffer: 0000000079000000 - 000000007bffffff
[ 3.265923] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 3.265933] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 3.267952] Switching to clocksource hpet
[ 3.268044] pnp: PnP ACPI init
[ 3.268062] ACPI: bus type pnp registered
[ 3.268092] pnp 00:00: [io 0x0070-0x0077]
[ 3.268129] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 3.268192] pnp 00:01: [mem 0xfed00000-0xfed003ff]
[ 3.268198] pnp 00:01: IRQ 8 override to edge, high
[ 3.268210] pnp 00:01: [irq 8]
[ 3.268249] pnp 00:01: Plug and Play ACPI device, IDs PNP0103 (active)
[ 3.268526] pnp 00:02: [bus 00-ff]
[ 3.268531] pnp 00:02: [io 0x0070-0x0077]
[ 3.268535] pnp 00:02: [io 0x0cf8-0x0cff]
[ 3.268539] pnp 00:02: [io 0x0000-0x006f window]
[ 3.268543] pnp 00:02: [io 0x0078-0x0cf7 window]
[ 3.268547] pnp 00:02: [io 0x0d00-0xffff window]
[ 3.268551] pnp 00:02: [mem 0x000a0000-0x000bffff window]
[ 3.268556] pnp 00:02: [mem 0x000c0000-0x000dffff window]
[ 3.268560] pnp 00:02: [mem 0x000e0000-0x000fffff window]
[ 3.268564] pnp 00:02: [mem 0x00000000 window]
[ 3.268568] pnp 00:02: [mem 0x00000000-0xffffffff window]
[ 3.268572] pnp 00:02: [mem 0x80000000-0x90716fff window]
[ 3.268647] pnp 00:02: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 3.268777] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 3.268820] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 3.268847] pnp 00:04: [io 0x002e-0x002f]
[ 3.268851] pnp 00:04: [io 0x004e-0x004f]
[ 3.268855] pnp 00:04: [io 0x0061]
[ 3.268858] pnp 00:04: [io 0x0063]
[ 3.268862] pnp 00:04: [io 0x0065]
[ 3.268865] pnp 00:04: [io 0x0067]
[ 3.268869] pnp 00:04: [io 0x0070]
[ 3.268872] pnp 00:04: [io 0x0080-0x008f]
[ 3.268876] pnp 00:04: [io 0x0092]
[ 3.268879] pnp 00:04: [io 0x00b2-0x00b3]
[ 3.268883] pnp 00:04: [io 0x0680-0x069f]
[ 3.268887] pnp 00:04: [io 0x0400-0x047f]
[ 3.268891] pnp 00:04: [io 0x0500-0x05fe]
[ 3.268894] pnp 00:04: [io 0x0600-0x061f]
[ 3.268962] system 00:04: [io 0x0680-0x069f] has been reserved
[ 3.268968] system 00:04: [io 0x0400-0x047f] has been reserved
[ 3.268972] system 00:04: [io 0x0500-0x05fe] has been reserved
[ 3.268977] system 00:04: [io 0x0600-0x061f] has been reserved
[ 3.268983] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 3.269279] pnp 00:05: [io 0x0000-0xffffffff disabled]
[ 3.269285] pnp 00:05: [io 0x0a00-0x0a0f]
[ 3.269289] pnp 00:05: [io 0x0290-0x029f]
[ 3.269292] pnp 00:05: [io 0x0a20-0x0a2f]
[ 3.269354] system 00:05: [io 0x0a00-0x0a0f] has been reserved
[ 3.269359] system 00:05: [io 0x0290-0x029f] has been reserved
[ 3.269364] system 00:05: [io 0x0a20-0x0a2f] has been reserved
[ 3.269369] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 3.270085] pnp 00:06: [io 0x0378-0x037f]
[ 3.270095] pnp 00:06: [irq 5]
[ 3.270099] pnp 00:06: [dma 0 disabled]
[ 3.270373] pnp 00:06: Plug and Play ACPI device, IDs PNP0400 (active)
[ 3.270986] pnp 00:07: [io 0x03f8-0x03ff]
[ 3.270998] pnp 00:07: [irq 4]
[ 3.271002] pnp 00:07: [dma 0 disabled]
[ 3.271101] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 3.271616] pnp 00:08: [io 0x02f8-0x02ff]
[ 3.271625] pnp 00:08: [irq 3]
[ 3.271630] pnp 00:08: [dma 0 disabled]
[ 3.271726] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 3.471864] pnp 00:09: [mem 0xe0000000-0xefffffff]
[ 3.471869] pnp 00:09: [mem 0xfed01000-0xfed01fff]
[ 3.471873] pnp 00:09: [mem 0xfed03000-0xfed03fff]
[ 3.471877] pnp 00:09: [mem 0xfed04000-0xfed04fff]
[ 3.471881] pnp 00:09: [mem 0xfed0c000-0xfed0ffff]
[ 3.471885] pnp 00:09: [mem 0xfed08000-0xfed08fff]
[ 3.471889] pnp 00:09: [mem 0xfed1c000-0xfed1cfff]
[ 3.471893] pnp 00:09: [mem 0xfee00000-0xfeefffff]
[ 3.471896] pnp 00:09: [mem 0xfef00000-0xfeffffff]
[ 3.471984] system 00:09: [mem 0xe0000000-0xefffffff] could not be reserved
[ 3.471990] system 00:09: [mem 0xfed01000-0xfed01fff] has been reserved
[ 3.471995] system 00:09: [mem 0xfed03000-0xfed03fff] has been reserved
[ 3.472000] system 00:09: [mem 0xfed04000-0xfed04fff] has been reserved
[ 3.472005] system 00:09: [mem 0xfed0c000-0xfed0ffff] has been reserved
[ 3.472010] system 00:09: [mem 0xfed08000-0xfed08fff] has been reserved
[ 3.472015] system 00:09: [mem 0xfed1c000-0xfed1cfff] has been reserved
[ 3.472020] system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved
[ 3.472025] system 00:09: [mem 0xfef00000-0xfeffffff] has been reserved
[ 3.472030] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 3.472496] pnp: PnP ACPI: found 10 devices
[ 3.472500] ACPI: ACPI bus type pnp unregistered
[ 3.472504] PnPBIOS: Disabled by ACPI PNP
[ 3.510961] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01-01] add_size 1000
[ 3.510969] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01-01] add_size 200000
[ 3.510975] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01-01] add_size 200000
[ 3.510987] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 3.510998] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 3.511003] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 3.511009] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff] to [bus 03-03] add_size 200000
[ 3.511019] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 04-04] add_size 1000
[ 3.511025] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04-04] add_size 200000
[ 3.511030] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 04-04] add_size 200000
[ 3.511043] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 3.511048] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 3.511053] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 3.511058] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 3.511063] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 3.511067] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 3.511072] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 3.511077] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 3.511081] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 3.511086] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 3.511094] pci 0000:00:1c.0: BAR 14: can't assign mem (size 0x200000)
[ 3.511101] pci 0000:00:1c.0: BAR 15: can't assign mem pref (size 0x200000)
[ 3.511107] pci 0000:00:1c.1: BAR 15: can't assign mem pref (size 0x200000)
[ 3.511112] pci 0000:00:1c.2: BAR 14: can't assign mem (size 0x200000)
[ 3.511118] pci 0000:00:1c.2: BAR 15: can't assign mem pref (size 0x200000)
[ 3.511124] pci 0000:00:1c.3: BAR 14: can't assign mem (size 0x200000)
[ 3.511129] pci 0000:00:1c.3: BAR 15: can't assign mem pref (size 0x200000)
[ 3.511135] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 3.511141] pci 0000:00:1c.2: BAR 13: assigned [io 0x2000-0x2fff]
[ 3.511146] pci 0000:00:1c.3: BAR 13: assigned [io 0x3000-0x3fff]
[ 3.511156] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 3.511161] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 3.511173] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 3.511178] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 3.511185] pci 0000:00:1c.1: bridge window [mem 0x90600000-0x906fffff]
[ 3.511195] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 3.511199] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff]
[ 3.511211] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[ 3.511216] pci 0000:00:1c.3: bridge window [io 0x3000-0x3fff]
[ 3.511279] pci_bus 0000:00: resource 4 [io 0x0000-0x006f]
[ 3.511284] pci_bus 0000:00: resource 5 [io 0x0078-0x0cf7]
[ 3.511288] pci_bus 0000:00: resource 6 [io 0x0d00-0xffff]
[ 3.511292] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff]
[ 3.511296] pci_bus 0000:00: resource 8 [mem 0x000c0000-0x000dffff]
[ 3.511300] pci_bus 0000:00: resource 9 [mem 0x000e0000-0x000fffff]
[ 3.511305] pci_bus 0000:00: resource 10 [mem 0x80000000-0x90716fff]
[ 3.511309] pci_bus 0000:01: resource 0 [io 0x1000-0x1fff]
[ 3.511313] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 3.511317] pci_bus 0000:02: resource 1 [mem 0x90600000-0x906fffff]
[ 3.511321] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 3.511325] pci_bus 0000:04: resource 0 [io 0x3000-0x3fff]
[ 3.511443] NET: Registered protocol family 2
[ 3.511532] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 3.511772] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 3.512277] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 3.512529] TCP: Hash tables configured (established 131072 bind 65536)
[ 3.512534] TCP: reno registered
[ 3.512539] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.512549] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.512693] NET: Registered protocol family 1
[ 3.512720] pci 0000:00:02.0: Boot video device
[ 5.108641] pci 0000:00:1d.0: EHCI: BIOS handoff failed (BIOS bug?) 01010001
[ 5.108874] PCI: CLS 64 bytes, default 64
[ 5.108951] Unpacking initramfs...
[ 5.466494] Freeing initrd memory: 14268k freed
[ 5.472516] audit: initializing netlink socket (disabled)
[ 5.472540] type=2000 audit(1564671772.376:1): initialized
[ 5.485526] highmem bounce pool size: 64 pages
[ 5.485534] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 5.485833] VFS: Disk quotas dquot_6.5.2
[ 5.485871] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 5.485975] msgmni has been set to 1719
[ 5.486220] alg: No test for stdrng (krng)
[ 5.486265] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 5.486271] io scheduler noop registered
[ 5.486274] io scheduler deadline registered
[ 5.486304] io scheduler cfq registered (default)
[ 5.486562] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 5.486591] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 5.486595] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 5.487484] GHES: HEST is not enabled!
[ 5.487503] isapnp: Scanning for PnP cards...
[ 5.841724] isapnp: No Plug & Play device found
[ 5.841804] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 5.862327] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 5.882881] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 5.903757] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 5.924390] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 5.924812] Linux agpgart interface v0.103
[ 5.925044] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 5.927191] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 5.927253] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 5.927419] mousedev: PS/2 mouse device common for all mice
[ 5.927500] rtc_cmos 00:00: RTC can wake from S4
[ 5.927660] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[ 5.927691] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 5.927873] TCP: cubic registered
[ 5.927955] NET: Registered protocol family 10
[ 5.928249] Mobile IPv6
[ 5.928254] NET: Registered protocol family 17
[ 5.928262] Registering the dns_resolver key type
[ 5.928326] Using IPI No-Shortcut mode
[ 5.928501] PM: Hibernation image not present or could not be loaded.
[ 5.928523] registered taskstats version 1
[ 5.929035] rtc_cmos 00:00: setting system clock to 2019-08-01 15:02:53 UTC (1564671773)
[ 5.929237] Freeing unused kernel memory: 416k freed
[ 5.929444] Write protecting the kernel text: 3496k
[ 5.929473] Write protecting the kernel read-only data: 984k
[ 5.945157] udevd[49]: starting version 175
[ 5.967927] SCSI subsystem initialized
[ 5.978949] usbcore: registered new interface driver usbfs
[ 5.978982] usbcore: registered new interface driver hub
[ 5.985952] libata version 3.00 loaded.
[ 5.986871] ahci 0000:00:13.0: version 3.0
[ 5.992836] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 5.992894] r8169 0000:02:00.0: (unregistered net_device): unknown MAC, using family default
[ 5.993181] r8169 0000:02:00.0: eth0: RTL8168b/8111b at 0xf8012000, 04:92:26:59:e1:de, XID 0c000800 IRQ 17
[ 5.993187] r8169 0000:02:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 5.995242] usbcore: registered new device driver usb
[ 5.999336] ahci 0000:00:13.0: AHCI 0001.0300 32 slots 2 ports 3 Gbps 0x2 impl SATA mode
[ 5.999344] ahci 0000:00:13.0: flags: 64bit ncq pm led clo pio slum part
[ 5.999351] ahci 0000:00:13.0: setting latency timer to 64
[ 6.003190] scsi0 : ahci
[ 6.006165] scsi1 : ahci
[ 6.006455] ata1: DUMMY
[ 6.006461] ata2: SATA max UDMA/133 abar m2048@0x90716000 port 0x90716180 irq 19
[ 6.006642] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 6.006648] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 6.006688] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 6.007105] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 6.007177] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.007182] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.007186] usb usb1: Product: xHCI Host Controller
[ 6.007190] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 6.007194] usb usb1: SerialNumber: 0000:00:14.0
[ 6.009611] xHCI xhci_add_endpoint called for root hub
[ 6.009616] xHCI xhci_check_bandwidth called for root hub
[ 6.009670] hub 1-0:1.0: USB hub found
[ 6.009687] hub 1-0:1.0: 6 ports detected
[ 6.009805] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 6.009818] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 6.009855] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 6.009860] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.009864] usb usb2: Product: xHCI Host Controller
[ 6.009867] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 6.009871] usb usb2: SerialNumber: 0000:00:14.0
[ 6.014659] xHCI xhci_add_endpoint called for root hub
[ 6.014664] xHCI xhci_check_bandwidth called for root hub
[ 6.014717] hub 2-0:1.0: USB hub found
[ 6.014730] hub 2-0:1.0: 1 port detected
[ 6.015058] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 6.027258] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 6.027266] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 6.027283] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 3
[ 6.027321] ehci_hcd 0000:00:1d.0: debug port 2
[ 6.034147] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 6.034183] ehci_hcd 0000:00:1d.0: irq 23, io mem 0x90715000
[ 6.036910] microcode: CPU0 sig=0x30678, pf=0x4, revision=0x831
[ 6.043061] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 6.043103] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.043108] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.043112] usb usb3: Product: EHCI Host Controller
[ 6.043116] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 6.043120] usb usb3: SerialNumber: 0000:00:1d.0
[ 6.043292] hub 3-0:1.0: USB hub found
[ 6.043303] hub 3-0:1.0: 8 ports detected
[ 6.067797] microcode: CPU1 sig=0x30678, pf=0x4, revision=0x831
[ 6.070824] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 6.330560] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 6.330737] ata2.00: ATA-11: SPCC Solid State Disk, SBFM81.1, max UDMA/133
[ 6.330742] ata2.00: 117231408 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 6.330934] ata2.00: configured for UDMA/133
[ 6.331113] scsi 1:0:0:0: Direct-Access ATA SPCC Solid State SBFM PQ: 0 ANSI: 5
[ 6.332391] ACPI: Fan [FAN0] (off)
[ 6.338914] sd 1:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.8 GiB)
[ 6.339073] sd 1:0:0:0: [sda] Write Protect is off
[ 6.339079] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 6.339129] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 6.339923] sda: sda1 sda2 < sda5 >
[ 6.340511] sd 1:0:0:0: [sda] Attached SCSI disk
[ 6.343022] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 6.354532] usb 3-1: new high-speed USB device number 2 using ehci_hcd
[ 6.466318] Refined TSC clocksource calibration: 2416.666 MHz.
[ 6.466327] Switching to clocksource tsc
[ 6.486594] usb 3-1: New USB device found, idVendor=8087, idProduct=07e6
[ 6.486599] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 6.486892] hub 3-1:1.0: USB hub found
[ 6.486964] hub 3-1:1.0: 4 ports detected
[ 6.757883] usb 3-1.4: new high-speed USB device number 3 using ehci_hcd
[ 6.851345] usb 3-1.4: New USB device found, idVendor=05e3, idProduct=0610
[ 6.851350] usb 3-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.851354] usb 3-1.4: Product: USB2.0 Hub
[ 6.851905] hub 3-1.4:1.0: USB hub found
[ 6.852218] hub 3-1.4:1.0: 4 ports detected
[ 7.125504] usb 3-1.4.1: new full-speed USB device number 4 using ehci_hcd
[ 7.220962] usb 3-1.4.1: New USB device found, idVendor=046d, idProduct=c52b
[ 7.220967] usb 3-1.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.220971] usb 3-1.4.1: Product: USB Receiver
[ 7.220975] usb 3-1.4.1: Manufacturer: Logitech
[ 7.228815] usbcore: registered new interface driver usbhid
[ 7.228820] usbhid: USB HID core driver
[ 7.236011] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.0-1.4.1/input2
[ 7.239967] input: Logitech Unifying Device. Wireless PID:404d as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.4/3-1.4.1/3-1.4.1:1.2/0003:046D:C52B.0003/input/input0
[ 7.240113] logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:404d] on usb-0000:00:1d.0-1.4.1:1
[ 11.525778] PM: Starting manual resume from disk
[ 11.525785] PM: Hibernation image partition 8:5 present
[ 11.525788] PM: Looking for hibernation image.
[ 11.526030] PM: Image not found (code -22)
[ 11.526034] PM: Hibernation image not present or could not be loaded.
[ 11.542052] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.807916] udevd[351]: starting version 175
[ 11.941355] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 11.941367] ACPI: Power Button [PWRB]
[ 11.941452] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 11.941458] ACPI: Sleep Button [SLPB]
[ 11.941539] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 11.941546] ACPI: Power Button [PWRF]
[ 11.980235] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 12.012228] parport_pc 00:06: reported by Plug and Play ACPI
[ 12.012292] parport0: PC-style at 0x378, irq 5 [PCSPP]
[ 12.114603] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
[ 12.114726] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 12.114843] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 12.114943] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 12.115052] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 12.501112] Adding 2421756k swap on /dev/sda5. Priority:-1 extents:1 across:2421756k SS
[ 12.520202] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 12.584235] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 12.619522] loop: module loaded
[ 13.489816] RPC: Registered named UNIX socket transport module.
[ 13.489821] RPC: Registered udp transport module.
[ 13.489824] RPC: Registered tcp transport module.
[ 13.489827] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 13.496109] FS-Cache: Loaded
[ 13.504210] NFS: Registering the id_resolver key type
[ 13.504247] FS-Cache: Netfs 'nfs' registered for caching
[ 13.510361] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 14.343674] Bluetooth: Core ver 2.16
[ 14.343701] NET: Registered protocol family 31
[ 14.343705] Bluetooth: HCI device and connection manager initialized
[ 14.343709] Bluetooth: HCI socket layer initialized
[ 14.343712] Bluetooth: L2CAP socket layer initialized
[ 14.343721] Bluetooth: SCO socket layer initialized
[ 14.361032] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.361037] Bluetooth: BNEP filters: protocol multicast
[ 14.368148] Bluetooth: RFCOMM TTY layer initialized
[ 14.368158] Bluetooth: RFCOMM socket layer initialized
[ 14.368162] Bluetooth: RFCOMM ver 1.11
[ 14.626031] lp0: using parport0 (interrupt-driven).
[ 14.638742] ppdev: user-space parallel port driver
[ 14.896525] r8169 0000:02:00.0: eth0: link down
[ 14.896729] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.038877] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input9
[ 36.268170] I-pipe: head domain RTAI registered.
[ 36.268178] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 36.268223] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 36.268228] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207884, CLK_FREQ 2416676000, CPU_FREQ 2416676000
[ 36.268233] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 36.268237] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207884, 5207884, 5188500
[ 36.284362] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 36.284411] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 36.284418] RTAI[sched]: hard timer type/freq = APIC/5207884(Hz); default timing: oneshot; linear timed lists.
[ 36.284424] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416676000 hz.
[ 36.284427] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 36.299764] RTAI[math]: loaded.
[ 36.469270] config string '0x378 out'
[ 65.766058] RTAI[math]: unloaded.
[ 65.768510] SCHED releases registered named ALIEN PEDV$D
[ 65.776410] RTAI[malloc]: unloaded.
[ 65.872600] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 65.874961] I-pipe: head domain RTAI unregistered.
[ 65.875017] RTAI[hal]: unmounted.
[ 267.788806] I-pipe: head domain RTAI registered.
[ 267.788815] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 267.789147] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 267.789153] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207884, CLK_FREQ 2416676000, CPU_FREQ 2416676000
[ 267.789158] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 267.789163] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207884, 5207884, 5192000
[ 267.800399] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 267.800446] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 267.800454] RTAI[sched]: hard timer type/freq = APIC/5207884(Hz); default timing: oneshot; linear timed lists.
[ 267.800459] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416676000 hz.
[ 267.800462] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 267.814049] RTAI[math]: loaded.
[ 267.966065] config string '0x378 out'
[ 279.684318] RTAI[math]: unloaded.
[ 279.686781] SCHED releases registered named ALIEN PEDV$D
[ 279.693033] RTAI[malloc]: unloaded.
[ 279.790338] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 279.792697] I-pipe: head domain RTAI unregistered.
[ 279.792752] RTAI[hal]: unmounted.
[ 640.843637] I-pipe: head domain RTAI registered.
[ 640.843645] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 640.843690] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 640.843696] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207884, CLK_FREQ 2416676000, CPU_FREQ 2416676000
[ 640.843700] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 640.843705] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207884, 5207884, 4645500
[ 640.852403] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 640.852451] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 640.852459] RTAI[sched]: hard timer type/freq = APIC/5207884(Hz); default timing: oneshot; linear timed lists.
[ 640.852464] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416676000 hz.
[ 640.852468] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 640.859093] RTAI[math]: loaded.
[ 641.010461] config string '0x378 out'
[ 648.545217] RTAI[math]: unloaded.
[ 648.547702] SCHED releases registered named ALIEN PEDV$D
[ 648.555316] RTAI[malloc]: unloaded.
[ 648.654784] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 648.657151] I-pipe: head domain RTAI unregistered.
[ 648.657207] RTAI[hal]: unmounted.
[ 1120.752677] I-pipe: head domain RTAI registered.
[ 1120.752686] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1120.752735] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1120.752740] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207884, CLK_FREQ 2416676000, CPU_FREQ 2416676000
[ 1120.752744] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1120.752749] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207884, 5207884, 5192500
[ 1120.763777] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1120.763824] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1120.763831] RTAI[sched]: hard timer type/freq = APIC/5207884(Hz); default timing: oneshot; linear timed lists.
[ 1120.763836] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416676000 hz.
[ 1120.763839] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1120.770531] RTAI[math]: loaded.
[ 1120.931926] config string '0x378 out'
[ 1127.726406] RTAI[math]: unloaded.
[ 1127.729139] SCHED releases registered named ALIEN PEDV$D
[ 1127.736579] RTAI[malloc]: unloaded.
[ 1127.834351] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1127.836748] I-pipe: head domain RTAI unregistered.
[ 1127.836803] RTAI[hal]: unmounted.
[ 1168.191567] I-pipe: head domain RTAI registered.
[ 1168.191576] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1168.191622] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1168.191628] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207884, CLK_FREQ 2416676000, CPU_FREQ 2416676000
[ 1168.191632] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1168.191637] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207884, 5207884, 5193000
[ 1168.200193] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1168.200237] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1168.200244] RTAI[sched]: hard timer type/freq = APIC/5207884(Hz); default timing: oneshot; linear timed lists.
[ 1168.200249] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416676000 hz.
[ 1168.200253] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1168.207569] RTAI[math]: loaded.
[ 1168.359152] config string '0x378 out'
[ 1276.852094] RTAI[math]: unloaded.
[ 1276.854553] SCHED releases registered named ALIEN PEDV$D
[ 1276.860079] RTAI[malloc]: unloaded.
[ 1276.959033] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1276.961402] I-pipe: head domain RTAI unregistered.
[ 1276.961458] RTAI[hal]: unmounted.
[ 1339.766566] I-pipe: head domain RTAI registered.
[ 1339.766851] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1339.766901] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1339.766907] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207884, CLK_FREQ 2416676000, CPU_FREQ 2416676000
[ 1339.766911] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1339.766916] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207884, 5207884, 4905000
[ 1339.775538] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1339.775584] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1339.775591] RTAI[sched]: hard timer type/freq = APIC/5207884(Hz); default timing: oneshot; linear timed lists.
[ 1339.775597] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416676000 hz.
[ 1339.775600] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1339.783699] RTAI[math]: loaded.
[ 1339.933274] config string '0x378 out'
[ 2420.224502] RTAI[math]: unloaded.
[ 2420.229395] SCHED releases registered named ALIEN PEDV$D
[ 2420.235855] RTAI[malloc]: unloaded.
[ 2420.333394] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2420.335775] I-pipe: head domain RTAI unregistered.
[ 2420.335830] RTAI[hal]: unmounted.
[ 2441.414354] I-pipe: head domain RTAI registered.
[ 2441.414363] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 2441.414410] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2441.414415] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207884, CLK_FREQ 2416676000, CPU_FREQ 2416676000
[ 2441.414420] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 2441.414425] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207884, 5207884, 5184250
[ 2441.422950] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2441.422996] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 2441.423003] RTAI[sched]: hard timer type/freq = APIC/5207884(Hz); default timing: oneshot; linear timed lists.
[ 2441.423009] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416676000 hz.
[ 2441.423012] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 2441.429462] RTAI[math]: loaded.
[ 2441.581356] config string '0x378 out'
[ 2448.966490] RTAI[math]: unloaded.
[ 2448.968987] SCHED releases registered named ALIEN PEDV$D
[ 2448.974891] RTAI[malloc]: unloaded.
[ 2449.072182] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2449.074537] I-pipe: head domain RTAI unregistered.
[ 2449.074593] RTAI[hal]: unmounted.
[ 2624.983095] usb 3-1.3: new high-speed USB device number 5 using ehci_hcd
[ 2625.076553] usb 3-1.3: New USB device found, idVendor=0bda, idProduct=8178
[ 2625.076558] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2625.076563] usb 3-1.3: Product: USB WLAN
[ 2625.076566] usb 3-1.3: Manufacturer: 802.11n
[ 2625.076569] usb 3-1.3: SerialNumber: 00e04c000001
[ 2625.100178] cfg80211: Calling CRDA to update world regulatory domain
[ 2625.115358] rtl8192cu: Chip version 0x11
[ 2625.117908] cfg80211: World regulatory domain updated:
[ 2625.117914] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 2625.117919] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 2625.117923] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 2625.117927] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 2625.117931] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 2625.117934] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 2625.117938] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 2625.117942] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 2625.117946] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 2625.195353] rtl8192cu: MAC address: 7c:8b:ca:1a:9d:9c
[ 2625.195361] rtl8192cu: Board Type 0
[ 2625.195597] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 2625.195652] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
[ 2625.195760] usbcore: registered new interface driver rtl8192cu
[ 2625.215396] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 2625.215939] rtlwifi: wireless switch is on
[ 2625.254948] udevd[4711]: renamed network interface wlan0 to wlan1
[ 2625.260232] rtl8192cu: MAC auto ON okay!
[ 2625.292934] rtl8192cu: Tx queue select: 0x05
[ 2625.658656] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 2642.418119] usb 3-1.3: USB disconnect, device number 5
[ 2642.418444] rtlwifi: reg 0x102, usbctrl_vendorreq TimeOut! status:0xffffffed value=0xba217e1
[ 2642.418460] rtlwifi: reg 0x422, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x5a0b8e
[ 2642.418475] rtlwifi: reg 0x542, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x55
[ 2642.418492] rtlwifi: reg 0x608, usbctrl_vendorreq TimeOut! status:0xffffffed value=0xd38000
[ 2645.683655] usb 3-1.2: new high-speed USB device number 6 using ehci_hcd
[ 2645.777113] usb 3-1.2: New USB device found, idVendor=0bda, idProduct=8178
[ 2645.777119] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2645.777123] usb 3-1.2: Product: USB WLAN
[ 2645.777126] usb 3-1.2: Manufacturer: 802.11n
[ 2645.777130] usb 3-1.2: SerialNumber: 00e04c000001
[ 2645.777736] rtl8192cu: Chip version 0x11
[ 2645.854109] rtl8192cu: MAC address: 7c:8b:ca:1a:9d:9c
[ 2645.854116] rtl8192cu: Board Type 0
[ 2645.854354] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 2645.854413] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
[ 2645.859406] ieee80211 phy1: Selected rate control algorithm 'rtl_rc'
[ 2645.859974] rtlwifi: wireless switch is on
[ 2645.885549] udevd[5134]: renamed network interface wlan0 to wlan1
[ 2645.894290] rtl8192cu: MAC auto ON okay!
[ 2645.929109] rtl8192cu: Tx queue select: 0x05
[ 2646.304969] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 2653.350530] usb 3-1.3: new high-speed USB device number 7 using ehci_hcd
[ 2653.459089] usb 3-1.3: New USB device found, idVendor=0cf3, idProduct=9271
[ 2653.459094] usb 3-1.3: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[ 2653.459099] usb 3-1.3: Product: USB2.0 WLAN
[ 2653.459102] usb 3-1.3: Manufacturer: ATHEROS
[ 2653.459105] usb 3-1.3: SerialNumber: 12345
[ 2653.479460] usb 3-1.3: ath9k_htc: Firmware htc_9271.fw requested
[ 2653.479776] usbcore: registered new interface driver ath9k_htc
[ 2653.771683] usb 3-1.3: ath9k_htc: Transferred FW: htc_9271.fw, size: 51272
[ 2654.006273] ath9k_htc 3-1.3:1.0: ath9k_htc: HTC initialized with 33 credits
[ 2654.194204] ath9k_htc 3-1.3:1.0: ath9k_htc: FW Version: 1.3
[ 2654.194209] ath: EEPROM regdomain: 0x809c
[ 2654.194212] ath: EEPROM indicates we should expect a country code
[ 2654.194215] ath: doing EEPROM country->regdmn map search
[ 2654.194218] ath: country maps to regdmn code: 0x52
[ 2654.194221] ath: Country alpha2 being used: CN
[ 2654.194224] ath: Regpair used: 0x52
[ 2654.195709] ieee80211 phy2: Atheros AR9271 Rev:1
[ 2654.195758] cfg80211: Calling CRDA for country: CN
[ 2654.197317] Registered led device: ath9k_htc-phy2
[ 2654.209656] cfg80211: Regulatory domain changed to country: CN
[ 2654.209662] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 2654.209667] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 2654.209671] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 2654.209689] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 2654.209693] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 2654.209696] cfg80211: (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm)
[ 2654.209700] cfg80211: (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm)
[ 2654.209704] cfg80211: (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm)
[ 2654.350237] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 2660.307492] usb 3-1.2: USB disconnect, device number 6
[ 2665.106408] usb 3-1.2: new high-speed USB device number 8 using ehci_hcd
[ 2665.199868] usb 3-1.2: New USB device found, idVendor=0bda, idProduct=8178
[ 2665.199873] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2665.199877] usb 3-1.2: Product: USB WLAN
[ 2665.199881] usb 3-1.2: Manufacturer: 802.11n
[ 2665.199884] usb 3-1.2: SerialNumber: 00e04c000001
[ 2665.200486] rtl8192cu: Chip version 0x11
[ 2665.276980] rtl8192cu: MAC address: 7c:8b:ca:1a:9d:9c
[ 2665.276988] rtl8192cu: Board Type 0
[ 2665.277229] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 2665.277290] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
[ 2665.284512] ieee80211 phy3: Selected rate control algorithm 'rtl_rc'
[ 2665.285393] rtlwifi: wireless switch is on
[ 2665.307550] rtl8192cu: MAC auto ON okay!
[ 2665.342006] rtl8192cu: Tx queue select: 0x05
[ 2665.715991] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 2667.207682] usb 3-1.3: USB disconnect, device number 7
[ 2667.217925] ath: phy2: Failed to wakeup in 500us
[ 2667.227984] ath: phy2: Failed to wakeup in 500us
[ 2667.237993] ath: phy2: Failed to wakeup in 500us
[ 2667.269469] usb 3-1.3: ath9k_htc: USB layer deinitialized
[ 2675.130118] usb 3-1.2: USB disconnect, device number 8
[ 2676.862281] usb 3-1.2: new high-speed USB device number 9 using ehci_hcd
[ 2676.970841] usb 3-1.2: New USB device found, idVendor=0cf3, idProduct=9271
[ 2676.970846] usb 3-1.2: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[ 2676.970850] usb 3-1.2: Product: USB2.0 WLAN
[ 2676.970854] usb 3-1.2: Manufacturer: ATHEROS
[ 2676.970857] usb 3-1.2: SerialNumber: 12345
[ 2676.971264] usb 3-1.2: ath9k_htc: Firmware htc_9271.fw requested
[ 2677.258848] usb 3-1.2: ath9k_htc: Transferred FW: htc_9271.fw, size: 51272
[ 2677.493441] ath9k_htc 3-1.2:1.0: ath9k_htc: HTC initialized with 33 credits
[ 2677.681248] ath9k_htc 3-1.2:1.0: ath9k_htc: FW Version: 1.3
[ 2677.681253] ath: EEPROM regdomain: 0x809c
[ 2677.681256] ath: EEPROM indicates we should expect a country code
[ 2677.681259] ath: doing EEPROM country->regdmn map search
[ 2677.681262] ath: country maps to regdmn code: 0x52
[ 2677.681265] ath: Country alpha2 being used: CN
[ 2677.681268] ath: Regpair used: 0x52
[ 2677.682059] ieee80211 phy4: Atheros AR9271 Rev:1
[ 2677.683047] Registered led device: ath9k_htc-phy4
[ 2677.837759] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 2688.898283] wlan0: authenticate with ec:43:f6:d2:d2:d8
[ 2688.989039] wlan0: send auth to ec:43:f6:d2:d2:d8 (try 1/3)
[ 2688.990793] wlan0: authenticated
[ 2689.037330] wlan0: associate with ec:43:f6:d2:d2:d8 (try 1/3)
[ 2689.041069] wlan0: RX AssocResp from ec:43:f6:d2:d2:d8 (capab=0x411 status=0 aid=2)
[ 2689.093500] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 2689.093616] wlan0: associated
[ 2689.093689] cfg80211: Calling CRDA for country: RU
[ 2689.099997] cfg80211: Regulatory domain changed to country: RU
[ 2689.100004] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 2689.100008] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 2689.100012] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 2689.100016] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 2689.100020] cfg80211: (5650000 KHz - 5730000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 2689.100023] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 2689.100027] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 2699.623188] wlan0: no IPv6 routers present
[ 2754.396133] udevd[6658]: starting version 175
[ 2946.424023] I-pipe: head domain RTAI registered.
[ 2946.424032] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 2946.424079] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2946.424084] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207884, CLK_FREQ 2416676000, CPU_FREQ 2416676000
[ 2946.424088] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 2946.424093] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207884, 5207884, 5174750
[ 2946.436551] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2946.436670] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 2946.436679] RTAI[sched]: hard timer type/freq = APIC/5207884(Hz); default timing: oneshot; linear timed lists.
[ 2946.436833] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416676000 hz.
[ 2946.436836] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 2946.450975] RTAI[math]: loaded.
[ 2946.614534] config string '0x378 out'
[ 2960.516814] RTAI[math]: unloaded.
[ 2960.520377] SCHED releases registered named ALIEN PEDV$D
[ 2960.533750] RTAI[malloc]: unloaded.
[ 2960.632357] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2960.634831] I-pipe: head domain RTAI unregistered.
[ 2960.634883] RTAI[hal]: unmounted.
[ 2985.030033] I-pipe: head domain RTAI registered.
[ 2985.030042] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 2985.030087] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2985.030092] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207884, CLK_FREQ 2416676000, CPU_FREQ 2416676000
[ 2985.030097] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 2985.030101] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207884, 5207884, 4823750
[ 2985.042921] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2985.042965] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 2985.042973] RTAI[sched]: hard timer type/freq = APIC/5207884(Hz); default timing: oneshot; linear timed lists.
[ 2985.042978] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416676000 hz.
[ 2985.042981] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 2985.080923] RTAI[math]: loaded.
[ 2985.135752] config string '0x378 out'
[ 2994.290256] RTAI[math]: unloaded.
[ 2994.297431] SCHED releases registered named ALIEN PEDV$D
[ 2994.311691] RTAI[malloc]: unloaded.
[ 2994.410487] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2994.413925] I-pipe: head domain RTAI unregistered.
[ 2994.413976] RTAI[hal]: unmounted.
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Чтв Авг 1 19:02:43 MSK 2019
UTC Date: Чтв Авг 1 16:02:43 UTC 2019
this program: /usr/bin/linuxcnc_info
uptime: 19:02:43 up 59 min, 1 user, load average: 1,35, 0,83, 0,50
lsb_release -sa: Debian Debian GNU/Linux 7.11 (wheezy) 7.11 wheezy
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/mdrives/linuxcnc/configs/BVR
USER: mdrives
LOGNAME: mdrives
HOME: /home/mdrives
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1024x768 pixels (302x232 millimeters)
PATH: /usr/bin:/home/mdrives/linuxcnc/configs/BVR/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: mdrives
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
machine -m: i686
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=fae57a38-964c-4954-8a4f-597d9ea98343 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
model name: Intel(R) Celeron(R) CPU J1800 @ 2.41GHz
cores: 2
cpu MHz: 2416.676
parport: 0378-037a : parport0
serial: 02f8-02ff : serial 03f8-03ff : serial
Versions:
gcc: gcc (Debian 4.7.2-5) 4.7.2
python: Python 2.7.3
git: git version 1.7.10.4
git commit: NA
tcl: 8.5
tk: 8.5
glade: not_in_PATH
glade-gtk2: glade3 3.8.0
linuxcnc_var all:
LINUXCNCVERSION: 2.9.0-pre0-373-gb0b2758
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: /usr/realtime-3.4-9-rtai-686-pae/bin/rtai-config
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Желаемый=неизвестно/установить/удалить[r]/вычистить[p]/зафиксировать[h]
| Состояние=не[n]/установлен/настроен[c]/распакован/частично настроен[F]/
частично установлен[H]/trig-aWait/Trig-pend
|/ Ошибка?=(нет)/требуется переустановка[R] (верхний регистр
в полях состояния и ошибки указывает на ненормальную ситуацию)
||/ Имя Версия Архите Описание
ii linuxcnc 1:2.9.0~pre0.373.gb0b2758 i386 motion controller for CNC machines and robots
un linuxcnc-doc <нет> (описание недоступно)
ii linuxcnc-doc-en 1:2.9.0~pre0.373.gb0b2758 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <нет> (описание недоступно)
un linuxcnc-uspace <нет> (описание недоступно)
забавно то, что на соседнем станке с так же настроенной системой gantry никакой ошибки не выдает (правда там версия 2.8). На работоспособность строки про повторяемые YY никак не влияет, да и ведь это просто предупреждения.
Заранее спасибо за помощь)
j4zzur1
Настоящее имя: Николай
Re: ошибка linuxcnc
Сообщение j4zzur1 »
возможно, есть способ отключить появление этой ошибки? скриптом или ещё как..
vala
Re: ошибка linuxcnc
Сообщение vala »
Я не спец, но в какую сторону копать сказано тут
Debug file information:
note: MAXV max: 100.000 units/sec 6000.000 units/min
note: LJOG max: 100.000 units/sec 6000.000 units/min
note: LJOG default: 10.000 units/sec 600.000 units/min
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1437, in __call__
return self.func(*args)
File "/usr/bin/axis", line 1442, in jogspeed_listbox_change
if isinstance(value, str): value = value.encode('utf-8', 'replace')
UnicodeDecodeError: 'ascii' codec can't decode byte 0xd0 in position 0: ordinal not in range(128)
note: jog_order='XYZ'
note: jog_invert=set([])
python: emc/rs274ngc/interp_setup.cc:189: setup::~setup(): Assertion `!pythis || Py_IsInitialized()' failed.
/usr/bin/linuxcnc: line 896: 7277 Аварийный останов $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
7231
7273
Stopping realtime threads
Unloading hal components
j4zzur1
Re: ошибка linuxcnc
Сообщение j4zzur1 »
"но в какую сторону копать сказано тут"
а можно поподробнее? для меня вообще не очевидно, куда именно копать. эти же "ошибки" возникают и при обычном запуске без всяких изменений в хал или ини файлах вручную. если запустить лцнц из под терминала, те же строчки будут.
R6MF49T2
Re: ошибка linuxcnc
Сообщение R6MF49T2 »
проверьте файл /usr/bin/axis, не используйте кириллицу даже в комментариях
j4zzur1
Re: ошибка linuxcnc
Сообщение j4zzur1 »
R6MF49T2 писал(а):проверьте файл /usr/bin/axis, не используйте кириллицу даже в комментариях
Проверил. Кириллицы там не было.
IMG_20190806_095957.jpg (3600 просмотров) <a class='original' href='./download/file.php?id=167281&mode=view' target=_blank>Загрузить оригинал (4.11 МБ)</a>
Убрал (uft-8), теперь ошибка с этим файлом не появляется. Но все еще появляется с другими..
IMG_20190806_100849.jpg (3600 просмотров) <a class='original' href='./download/file.php?id=167282&mode=view' target=_blank>Загрузить оригинал (2.11 МБ)</a>
я так понимаю, проблема именно в файле /usr/bin/linuxcnc. Но понятия не имею, что там править ;(
p.s. на vfd не обращайте внимания, без него то же самое.
R6MF49T2
Re: ошибка linuxcnc
j4zzur1 писал(а):Убрал (uft-8)
Зачем? Просто взяли и выкинули часть алгоритма...
Верните обратно, перед строкой "if isinstance(value, str): value = value.encode('utf-8', 'replace')" добавьте "print(value)" с тем же самым отступом. После этого в консоль будут выводится все строки которые попадают в эту функцию, в последней выведенной строке перед ошибкой ищите в чём дело.
j4zzur1
Re: ошибка linuxcnc
Сообщение j4zzur1 »
R6MF49T2 писал(а):Верните обратно, перед строкой "if isinstance(value, str): value = value.encode('utf-8', 'replace')" добавьте "print(value)" с тем же самым отступом. После этого в консоль будут выводится все строки которые попадают в эту функцию, в последней выведенной строке перед ошибкой ищите в чём дело.
Сделал, как вы сказали.. а где смотреть результат? через терминал запускаю - ошибка та же, что и выше была.
R6MF49T2
Re: ошибка linuxcnc
Покажите вывод консоли перед ошибкой
