nkp@nkp-desktop:~/linuxcnc-reverse-run/scripts$ ./linuxcnc
LINUXCNC - 2.7.0~pre7
using image /home/nkp/linuxcnc/configs/G71/G71.gif
Machine configuration directory is '/home/nkp/linuxcnc/configs/G71'
Machine configuration file is 'G71.ini'
Starting LinuxCNC...
Found file(REL): ./core_sim.hal
/home/nkp/linuxcnc/configs/G71/G71.ini:98: executing 'import sys
sys.path.insert(0,"python")'
PythonPlugin: Python '2.7.3 (default, Oct 26 2016, 21:19:34)
[GCC 4.6.3]'
RTAPI: ERROR: Unexpected realtime delay on task 1
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
[GCC 4.6.3]'
is_callable(remap.g712) = TRUE
is_callable(__init__) = FALSE
[GCC 4.6.3]'
radeon: Acquired access to Hyper-Z.
task: main loop took 0.010889 seconds
task: main loop took 0.013789 seconds
task: main loop took 0.013829 seconds
task: main loop took 0.018516 seconds
PythonPlugin: Python '2.7.3 (default, Oct 26 2016, 21:04:23)
[GCC 4.6.3]'
is_callable(oword.taper-thread) = FALSE
task: main loop took 0.013123 seconds
task: main loop took 0.013335 seconds
[GCC 4.6.3]'
task: main loop took 0.013918 seconds
task: main loop took 0.013660 seconds
task: main loop took 0.013786 seconds
task: main loop took 0.013765 seconds
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1413, in __call__
return self.func(*args)
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 498, in callit
func(*args)
File "/home/nkp/linuxcnc-reverse-run/lib/python/vcpparse.py", line 154, in updater
a.update(pycomp)
File "/home/nkp/linuxcnc-reverse-run/lib/python/pyvcp_widgets.py", line 1494, in update
pycomp[self.halpin+"-f"]=self.get()
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 2746, in get
value = self.tk.call(self._w, 'get')
TclError: invalid command name ".176157580.176232780.176337804.176338124"
func(*args)
File "/home/nkp/linuxcnc-reverse-run/bin/axis", line 775, in update
root_window.update_idletasks()
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 919, in update_idletasks
self.tk.call('update', 'idletasks')
TclError: can't invoke "update" command: application has been destroyed
func(*args)
File "/home/nkp/linuxcnc-reverse-run/bin/axis", line 513, in actual_tkRedraw
self.tkRedraw_ortho()
File "/home/nkp/linuxcnc-reverse-run/bin/axis", line 475, in tkRedraw_ortho
self.redraw_ortho()
File "/home/nkp/linuxcnc-reverse-run/lib/python/rs274/glcanon.py", line 312, in inner
self.activate()
File "/home/nkp/linuxcnc-reverse-run/lib/python/rs274/OpenGLTk.py", line 223, in activate
self.tk.call(self._w, 'makecurrent')
TclError: invalid command name ".pane.top.right.fpreview.170406700"
can't read "data(pages)": no such variable
while executing
"foreach page $data(pages) {
Widget::destroy $path.f$page
(procedure "NoteBook::_destroy" line 5)
invoked from within
"NoteBook::_destroy .#BWidget.#Class#NoteBook"
(command bound to event)
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd9c8c>> ignored
File "/home/nkp/linuxcnc-reverse-run/bin/axis", line 1988, in reload_file
reload_file()
File "/home/nkp/linuxcnc-reverse-run/bin/axis", line 1698, in reload_file
open_file_guts(loaded_file, False, False)
File "/home/nkp/linuxcnc-reverse-run/bin/axis", line 1164, in open_file_guts
root_window.tk.call("destroy", ".info.progress")
TclError: can't invoke "destroy" command: application has been destroyed
func(*args)
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd9a2c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd982c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd962c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd942c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd922c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd902c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd2e0c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd2c0c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd288c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd250c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabd218c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabcadec>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabcaaac>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabca76c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabca42c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabca0ec>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabc3d8c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabc3a4c>> ignored
reload_file()
Exception _tkinter.TclError: 'can\'t invoke "winfo" command: application has been destroyed' in <bound method Progress.__del__ of <__main__.Progress instance at 0xabc374c>> ignored
reload_file()
reload_file()
task: 15029 cycles, min=0.000024, max=0.018516, avg=0.002067, 48 latency excursions (> 10x expected cycle time of 0.001000s)
is_callable(__delete__) = FALSE
ULAPI: WARNING: module 'HAL_classicladder' failed to delete shmem 03
ERROR CLASSICLADDER- Error intializing classicladder user module.
