Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/red/linuxcnc/configs/test'
Machine configuration file is 'test.ini'
INIFILE=/home/red/linuxcnc/configs/test/test.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./test.hal
Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=5391
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
./test.hal:9: parameter or pin 'hm2_5i25.0.pwmgen.pwm_frequency' not found
5391
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e6000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001dfc0000 (usable)
[ 0.000000] BIOS-e820: 000000001dfc0000 - 000000001dfce000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001dfce000 - 000000001dff0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000001dff0000 - 000000001e000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: ECS P4M800PRO-M2/P4M800PRO-M2, BIOS 080012 10/04/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x1dfc0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FF0000000 write-back
[ 0.000000] 1 base 010000000 mask FF8000000 write-back
[ 0.000000] 2 base 018000000 mask FFC000000 write-back
[ 0.000000] 3 base 01C000000 mask FFE000000 write-back
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00ff780] ff780
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-000000001dfc0000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001dc00000 page 2M
[ 0.000000] 001dc00000 - 001dfc0000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x1dfbffff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 1c9e7000 - 1d749000
[ 0.000000] ACPI: RSDP 000f8730 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 1dfc0000 00030 (v01 A M I OEMRSDT 10000604 MSFT 00000097)
[ 0.000000] ACPI: FACP 1dfc0200 00084 (v02 A M I OEMFACP 10000604 MSFT 00000097)
[ 0.000000] ACPI: DSDT 1dfc0400 03CA3 (v01 12345 12345123 00000123 INTL 20051117)
[ 0.000000] ACPI: FACS 1dfce000 00040
[ 0.000000] ACPI: APIC 1dfc0390 0006C (v01 A M I OEMAPIC 10000604 MSFT 00000097)
[ 0.000000] ACPI: OEMB 1dfce040 00060 (v01 A M I AMI_OEM 10000604 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 479MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1dfc0000
[ 0.000000] low ram: 0 - 1dfc0000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001dfc0
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001dfc0
[ 0.000000] On node 0 totalpages: 122703
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map ddbff200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 928 pages used for memmap
[ 0.000000] Normal zone: 117792 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x81] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e6000
[ 0.000000] PM: Registered nosave memory: 00000000000e6000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 1e000000 (gap: 1e000000:e0c00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ddbb7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121743
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=e28b9af0-e06f-4382-bb3b-b55d20b47cc6 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 982400 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 465752k/491264k available (3495k kernel code, 25060k reserved, 1237k data, 416k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xde7c0000 - 0xff7fe000 ( 528 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xddfc0000 ( 479 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=dc408000 soft=dc40a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2666.556 MHz processor.
[ 0.004005] Calibrating delay loop (skipped), value calculated using timer frequency.. 5333.11 BogoMIPS (lpj=10666224)
[ 0.004015] pid_max: default: 32768 minimum: 301
[ 0.004124] Security Framework initialized
[ 0.004136] AppArmor: AppArmor disabled by boot time parameter
[ 0.004175] Mount-cache hash table entries: 512
[ 0.004581] Initializing cgroup subsys cpuacct
[ 0.004588] Initializing cgroup subsys memory
[ 0.004608] Initializing cgroup subsys devices
[ 0.004613] Initializing cgroup subsys freezer
[ 0.004617] Initializing cgroup subsys net_cls
[ 0.004621] Initializing cgroup subsys blkio
[ 0.004638] Initializing cgroup subsys perf_event
[ 0.004710] CPU0: Hyper-Threading is disabled
[ 0.004718] mce: CPU supports 4 MCE banks
[ 0.004735] CPU0: Thermal monitoring enabled (TM1)
[ 0.008079] SMP alternatives: switching to UP code
[ 0.014256] ACPI: Core revision 20120320
[ 0.020138] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.021396] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.061483] CPU0: Intel(R) Celeron(R) CPU 2.66GHz stepping 09
[ 0.064003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.064003] ... version: 0
[ 0.064003] ... bit width: 40
[ 0.064003] ... generic registers: 18
[ 0.064003] ... value mask: 000000ffffffffff
[ 0.064003] ... max period: 0000007fffffffff
[ 0.064003] ... fixed-purpose events: 0
[ 0.064003] ... event mask: 000000000003ffff
[ 0.072050] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.072140] Brought up 1 CPUs
[ 0.072147] Total of 1 processors activated (5333.11 BogoMIPS).
[ 0.073092] devtmpfs: initialized
[ 0.073628] PM: Registering ACPI NVS region [mem 0x1dfce000-0x1dfeffff] (139264 bytes)
[ 0.073873] dummy:
[ 0.074012] NET: Registered protocol family 16
[ 0.074290] ACPI: bus type pci registered
[ 0.074671] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=1
[ 0.074677] PCI: Using configuration type 1 for base access
[ 0.075964] bio: create slab <bio-0> at 0
[ 0.076234] ACPI: Added _OSI(Module Device)
[ 0.076241] ACPI: Added _OSI(Processor Device)
[ 0.076246] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.076251] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.078562] ACPI: EC: Look up EC in DSDT
[ 0.084190] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.092450] ACPI: Interpreter enabled
[ 0.092464] ACPI: (supports S0 S3 S4 S5)
[ 0.092524] ACPI: Using IOAPIC for interrupt routing
[ 0.115836] ACPI: No dock devices found.
[ 0.115852] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.116097] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.116386] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.116393] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.116398] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.116403] pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff] (ignored)
[ 0.116408] pci_root PNP0A03:00: host bridge window [mem 0x1e000000-0xff37ffff] (ignored)
[ 0.116414] PCI: root bus 00: using default resources
[ 0.116501] PCI host bridge to bus 0000:00
[ 0.116508] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.116513] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.116543] pci 0000:00:00.0: [1106:0314] type 00 class 0x060000
[ 0.116563] pci 0000:00:00.0: reg 10: [mem 0xf8000000-0xfbffffff pref]
[ 0.116663] pci 0000:00:00.1: [1106:1314] type 00 class 0x060000
[ 0.116732] pci 0000:00:00.2: [1106:2314] type 00 class 0x060000
[ 0.116802] pci 0000:00:00.3: [1106:3208] type 00 class 0x060000
[ 0.116871] pci 0000:00:00.4: [1106:4314] type 00 class 0x060000
[ 0.116948] pci 0000:00:00.7: [1106:7314] type 00 class 0x060000
[ 0.117023] pci 0000:00:01.0: [1106:b198] type 01 class 0x060400
[ 0.117093] pci 0000:00:01.0: supports D1
[ 0.117127] pci 0000:00:08.0: [2718:5125] type 00 class 0x110000
[ 0.117150] pci 0000:00:08.0: reg 10: [mem 0xfebf0000-0xfebfffff]
[ 0.117259] pci 0000:00:0f.0: [1106:3149] type 00 class 0x01018f
[ 0.117287] pci 0000:00:0f.0: reg 10: [io 0xec00-0xec07]
[ 0.117303] pci 0000:00:0f.0: reg 14: [io 0xe880-0xe883]
[ 0.117319] pci 0000:00:0f.0: reg 18: [io 0xe800-0xe807]
[ 0.117335] pci 0000:00:0f.0: reg 1c: [io 0xe480-0xe483]
[ 0.117351] pci 0000:00:0f.0: reg 20: [io 0xe400-0xe40f]
[ 0.117367] pci 0000:00:0f.0: reg 24: [io 0xe000-0xe0ff]
[ 0.117436] pci 0000:00:0f.1: [1106:0571] type 00 class 0x01018a
[ 0.117509] pci 0000:00:0f.1: reg 20: [io 0xfc00-0xfc0f]
[ 0.117597] pci 0000:00:10.0: [1106:3038] type 00 class 0x0c0300
[ 0.117668] pci 0000:00:10.0: reg 20: [io 0xdc00-0xdc1f]
[ 0.117719] pci 0000:00:10.0: supports D1 D2
[ 0.117723] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.117756] pci 0000:00:10.1: [1106:3038] type 00 class 0x0c0300
[ 0.117827] pci 0000:00:10.1: reg 20: [io 0xd880-0xd89f]
[ 0.117878] pci 0000:00:10.1: supports D1 D2
[ 0.117882] pci 0000:00:10.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.117912] pci 0000:00:10.2: [1106:3038] type 00 class 0x0c0300
[ 0.117983] pci 0000:00:10.2: reg 20: [io 0xd800-0xd81f]
[ 0.118033] pci 0000:00:10.2: supports D1 D2
[ 0.118038] pci 0000:00:10.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.118070] pci 0000:00:10.3: [1106:3038] type 00 class 0x0c0300
[ 0.118140] pci 0000:00:10.3: reg 20: [io 0xd480-0xd49f]
[ 0.118191] pci 0000:00:10.3: supports D1 D2
[ 0.118195] pci 0000:00:10.3: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.118225] pci 0000:00:10.4: [1106:3104] type 00 class 0x0c0320
[ 0.118252] pci 0000:00:10.4: reg 10: [mem 0xfebefc00-0xfebefcff]
[ 0.118347] pci 0000:00:10.4: supports D1 D2
[ 0.118351] pci 0000:00:10.4: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.118389] pci 0000:00:11.0: [1106:3227] type 00 class 0x060100
[ 0.118486] HPET not enabled in BIOS. You might try hpet=force boot option
[ 0.118545] pci 0000:00:11.5: [1106:3059] type 00 class 0x040100
[ 0.118573] pci 0000:00:11.5: reg 10: [io 0xd000-0xd0ff]
[ 0.118671] pci 0000:00:11.5: supports D1 D2
[ 0.118705] pci 0000:00:12.0: [1106:3065] type 00 class 0x020000
[ 0.118732] pci 0000:00:12.0: reg 10: [io 0xee00-0xeeff]
[ 0.118748] pci 0000:00:12.0: reg 14: [mem 0xfebef800-0xfebef8ff]
[ 0.118833] pci 0000:00:12.0: supports D1 D2
[ 0.118838] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.118928] pci 0000:01:00.0: [1106:3344] type 00 class 0x030000
[ 0.118955] pci 0000:01:00.0: reg 10: [mem 0xf0000000-0xf3ffffff pref]
[ 0.118969] pci 0000:01:00.0: reg 14: [mem 0xfd000000-0xfdffffff]
[ 0.119019] pci 0000:01:00.0: reg 30: [mem 0xfeaf0000-0xfeafffff pref]
[ 0.119050] pci 0000:01:00.0: supports D1 D2
[ 0.119108] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.119119] pci 0000:00:01.0: bridge window [mem 0xfca00000-0xfeafffff]
[ 0.119127] pci 0000:00:01.0: bridge window [mem 0xeff00000-0xf7efffff pref]
[ 0.119140] pci_bus 0000:00: on NUMA node 0
[ 0.119149] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.119772] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.120027] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.141233] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.141385] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.141527] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.141667] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.141812] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.141957] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.142101] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.142244] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.142502] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.142508] vgaarb: loaded
[ 0.142512] vgaarb: bridge control possible 0000:01:00.0
[ 0.142580] PCI: Using ACPI for IRQ routing
[ 0.142588] PCI: pci_cache_line_size set to 64 bytes
[ 0.142715] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.142721] reserve RAM buffer: 000000001dfc0000 - 000000001fffffff
[ 0.143163] pnp: PnP ACPI init
[ 0.143194] ACPI: bus type pnp registered
[ 0.143419] pnp 00:00: [bus 00-ff]
[ 0.143426] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.143432] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.143437] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.143442] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.143447] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.143452] pnp 00:00: [mem 0x1e000000-0xff37ffff window]
[ 0.143581] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.143657] pnp 00:01: [dma 4]
[ 0.143663] pnp 00:01: [io 0x0000-0x000f]
[ 0.143667] pnp 00:01: [io 0x0081-0x0083]
[ 0.143671] pnp 00:01: [io 0x0087]
[ 0.143675] pnp 00:01: [io 0x0089-0x008b]
[ 0.143679] pnp 00:01: [io 0x008f]
[ 0.143683] pnp 00:01: [io 0x00c0-0x00df]
[ 0.143743] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.143783] pnp 00:02: [io 0x0070-0x0071]
[ 0.143808] pnp 00:02: [irq 8]
[ 0.143869] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.143974] pnp 00:03: [io 0x0060]
[ 0.143980] pnp 00:03: [io 0x0064]
[ 0.143994] pnp 00:03: [irq 1]
[ 0.144102] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.144218] pnp 00:04: [irq 12]
[ 0.144291] pnp 00:04: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.144319] pnp 00:05: [io 0x0061]
[ 0.144376] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.144410] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.144423] pnp 00:06: [irq 13]
[ 0.144491] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.146479] pnp 00:07: [io 0x03f8-0x03ff]
[ 0.146495] pnp 00:07: [irq 4]
[ 0.146501] pnp 00:07: [dma 0 disabled]
[ 0.146725] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.148726] pnp 00:08: [io 0x02f8-0x02ff]
[ 0.148743] pnp 00:08: [irq 3]
[ 0.148748] pnp 00:08: [dma 0 disabled]
[ 0.148958] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.153744] pnp 00:09: [io 0x0378-0x037f]
[ 0.153752] pnp 00:09: [io 0x0778-0x077f]
[ 0.153768] pnp 00:09: [irq 7]
[ 0.153773] pnp 00:09: [dma 3]
[ 0.154806] pnp 00:09: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.155219] pnp 00:0a: [io 0x0000-0xffffffff disabled]
[ 0.155226] pnp 00:0a: [io 0x0a00-0x0a0f]
[ 0.155230] pnp 00:0a: [io 0x0290-0x029f]
[ 0.155235] pnp 00:0a: [io 0x0a20-0x0a2f]
[ 0.155239] pnp 00:0a: [io 0x0a30-0x0a3f]
[ 0.155369] system 00:0a: [io 0x0a00-0x0a0f] has been reserved
[ 0.155377] system 00:0a: [io 0x0290-0x029f] has been reserved
[ 0.155382] system 00:0a: [io 0x0a20-0x0a2f] has been reserved
[ 0.155387] system 00:0a: [io 0x0a30-0x0a3f] has been reserved
[ 0.155394] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.155629] pnp 00:0b: [io 0x0010-0x001f]
[ 0.155635] pnp 00:0b: [io 0x0022-0x003f]
[ 0.155639] pnp 00:0b: [io 0x0044-0x005f]
[ 0.155643] pnp 00:0b: [io 0x0062-0x0063]
[ 0.155648] pnp 00:0b: [io 0x0065-0x006f]
[ 0.155652] pnp 00:0b: [io 0x0072-0x007f]
[ 0.155656] pnp 00:0b: [io 0x0080]
[ 0.155660] pnp 00:0b: [io 0x0084-0x0086]
[ 0.155664] pnp 00:0b: [io 0x0088]
[ 0.155668] pnp 00:0b: [io 0x008c-0x008e]
[ 0.155672] pnp 00:0b: [io 0x0090-0x009f]
[ 0.155676] pnp 00:0b: [io 0x00a2-0x00bf]
[ 0.155680] pnp 00:0b: [io 0x00e0-0x00ef]
[ 0.155685] pnp 00:0b: [io 0x03e0-0x03e7]
[ 0.155689] pnp 00:0b: [io 0x04d0-0x04d1]
[ 0.155693] pnp 00:0b: [io 0x0800-0x087f]
[ 0.155697] pnp 00:0b: [io 0x0400-0x041f]
[ 0.155702] pnp 00:0b: [io 0x0000-0xffffffff disabled]
[ 0.155833] system 00:0b: [io 0x03e0-0x03e7] has been reserved
[ 0.155840] system 00:0b: [io 0x04d0-0x04d1] has been reserved
[ 0.155845] system 00:0b: [io 0x0800-0x087f] has been reserved
[ 0.155851] system 00:0b: [io 0x0400-0x041f] has been reserved
[ 0.155857] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.156037] pnp 00:0c: [mem 0xfec00000-0xfec00fff]
[ 0.156044] pnp 00:0c: [mem 0xfee00000-0xfee00fff]
[ 0.156179] system 00:0c: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.156188] system 00:0c: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.156194] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.156761] pnp 00:0d: [mem 0x00000000-0x0009ffff]
[ 0.156768] pnp 00:0d: [mem 0x000c0000-0x000cffff]
[ 0.156773] pnp 00:0d: [mem 0x000e0000-0x000fffff]
[ 0.156781] pnp 00:0d: [mem 0x00100000-0x1dffffff]
[ 0.156785] pnp 00:0d: [mem 0xff380000-0xffffffff]
[ 0.156939] system 00:0d: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.156947] system 00:0d: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.156953] system 00:0d: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.156959] system 00:0d: [mem 0x00100000-0x1dffffff] could not be reserved
[ 0.156965] system 00:0d: [mem 0xff380000-0xffffffff] has been reserved
[ 0.156972] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.157385] pnp: PnP ACPI: found 14 devices
[ 0.157390] ACPI: ACPI bus type pnp unregistered
[ 0.157398] PnPBIOS: Disabled by ACPI PNP
[ 0.195878] Switching to clocksource acpi_pm
[ 0.195963] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.195976] pci 0000:00:01.0: bridge window [mem 0xfca00000-0xfeafffff]
[ 0.195984] pci 0000:00:01.0: bridge window [mem 0xeff00000-0xf7efffff pref]
[ 0.195984] pci 0000:00:01.0: setting latency timer to 64
[ 0.195984] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.195984] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.195984] pci_bus 0000:01: resource 1 [mem 0xfca00000-0xfeafffff]
[ 0.195984] pci_bus 0000:01: resource 2 [mem 0xeff00000-0xf7efffff pref]
[ 0.195984] NET: Registered protocol family 2
[ 0.195984] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.195984] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.195984] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.195984] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.195984] TCP: reno registered
[ 0.195984] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.195984] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.195984] NET: Registered protocol family 1
[ 0.195984] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.195984] pci 0000:00:11.0: Bypassing VIA 8237 APIC De-Assert Message
[ 0.195984] pci 0000:01:00.0: Boot video device
[ 0.195984] PCI: CLS 32 bytes, default 64
[ 0.195984] Unpacking initramfs...
[ 0.699638] Freeing initrd memory: 13704k freed
[ 0.720842] audit: initializing netlink socket (disabled)
[ 0.720883] type=2000 audit(1481277186.720:1): initialized
[ 0.738145] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.738464] VFS: Disk quotas dquot_6.5.2
[ 0.738517] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.738674] msgmni has been set to 936
[ 0.739051] alg: No test for stdrng (krng)
[ 0.739135] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.739143] io scheduler noop registered
[ 0.739147] io scheduler deadline registered
[ 0.739176] io scheduler cfq registered (default)
[ 0.739372] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.739410] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.739415] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.740287] GHES: HEST is not enabled!
[ 0.740316] isapnp: Scanning for PnP cards...
[ 1.094717] isapnp: No Plug & Play device found
[ 1.094840] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.115264] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.135721] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.156578] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.177120] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.177470] Linux agpgart interface v0.103
[ 1.177662] agpgart: Detected VIA VT3314 chipset
[ 1.182774] agpgart-via 0000:00:00.0: AGP aperture is 64M @ 0xf8000000
[ 1.182980] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.183570] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.183640] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.183847] mousedev: PS/2 mouse device common for all mice
[ 1.183950] rtc_cmos 00:02: RTC can wake from S4
[ 1.184268] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 1.184337] rtc0: alarms up to one year, y3k, 114 bytes nvram
[ 1.184576] TCP: cubic registered
[ 1.184664] NET: Registered protocol family 10
[ 1.185082] Mobile IPv6
[ 1.185091] NET: Registered protocol family 17
[ 1.185104] Registering the dns_resolver key type
[ 1.185213] Using IPI No-Shortcut mode
[ 1.185444] PM: Hibernation image not present or could not be loaded.
[ 1.185482] registered taskstats version 1
[ 1.186161] rtc_cmos 00:02: setting system clock to 2016-12-09 09:53:07 UTC (1481277187)
[ 1.186349] Freeing unused kernel memory: 416k freed
[ 1.187004] Write protecting the kernel text: 3496k
[ 1.187033] Write protecting the kernel read-only data: 984k
[ 1.203278] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.224488] udevd[45]: starting version 175
[ 1.491211] usbcore: registered new interface driver usbfs
[ 1.491288] usbcore: registered new interface driver hub
[ 1.512254] usbcore: registered new device driver usb
[ 1.519947] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.520146] ehci_hcd 0000:00:10.4: EHCI Host Controller
[ 1.520225] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1
[ 1.520331] ehci_hcd 0000:00:10.4: irq 21, io mem 0xfebefc00
[ 1.522958] via_rhine: v1.10-LK1.5.0 2010-10-09 Written by Donald Becker
[ 1.523427] SCSI subsystem initialized
[ 1.529791] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.532083] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00
[ 1.532201] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.532207] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.532213] usb usb1: Product: EHCI Host Controller
[ 1.532217] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.532221] usb usb1: SerialNumber: 0000:00:10.4
[ 1.532517] hub 1-0:1.0: USB hub found
[ 1.532530] hub 1-0:1.0: 8 ports detected
[ 1.535487] libata version 3.00 loaded.
[ 1.550516] via-rhine 0000:00:12.0: eth0: VIA Rhine II at 0x1ee00, 00:19:21:4d:37:e6, IRQ 23
[ 1.551323] via-rhine 0000:00:12.0: eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link cde1
[ 1.554361] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 1.554394] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 1.554441] uhci_hcd 0000:00:10.0: irq 21, io base 0x0000dc00
[ 1.554524] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.554531] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.554536] usb usb2: Product: UHCI Host Controller
[ 1.554540] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.554544] usb usb2: SerialNumber: 0000:00:10.0
[ 1.554821] hub 2-0:1.0: USB hub found
[ 1.554838] hub 2-0:1.0: 2 ports detected
[ 1.555082] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 1.555106] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
[ 1.555154] uhci_hcd 0000:00:10.1: irq 21, io base 0x0000d880
[ 1.555230] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.555237] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.555241] usb usb3: Product: UHCI Host Controller
[ 1.555245] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.555250] usb usb3: SerialNumber: 0000:00:10.1
[ 1.555531] hub 3-0:1.0: USB hub found
[ 1.555543] hub 3-0:1.0: 2 ports detected
[ 1.555730] sata_via 0000:00:0f.0: version 2.6
[ 1.555862] sata_via 0000:00:0f.0: routed to hard irq line 11
[ 1.559791] scsi0 : sata_via
[ 1.564134] scsi1 : sata_via
[ 1.575406] ata1: SATA max UDMA/133 cmd 0xec00 ctl 0xe880 bmdma 0xe400 irq 20
[ 1.575415] ata2: SATA max UDMA/133 cmd 0xe800 ctl 0xe480 bmdma 0xe408 irq 20
[ 1.580116] pata_via 0000:00:0f.1: version 0.3.4
[ 1.582865] microcode: CPU0 sig=0xf49, pf=0x10, revision=0x3
[ 1.584317] scsi2 : pata_via
[ 1.587940] scsi3 : pata_via
[ 1.597025] ata3: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[ 1.597033] ata4: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xfc08 irq 15
[ 1.602664] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 1.602710] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
[ 1.602761] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d800
[ 1.602845] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.602851] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.602856] usb usb4: Product: UHCI Host Controller
[ 1.602860] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.602863] usb usb4: SerialNumber: 0000:00:10.2
[ 1.603245] hub 4-0:1.0: USB hub found
[ 1.603258] hub 4-0:1.0: 2 ports detected
[ 1.603446] uhci_hcd 0000:00:10.3: UHCI Host Controller
[ 1.603470] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5
[ 1.603516] uhci_hcd 0000:00:10.3: irq 21, io base 0x0000d480
[ 1.603594] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.603600] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.603605] usb usb5: Product: UHCI Host Controller
[ 1.603608] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.603612] usb usb5: SerialNumber: 0000:00:10.3
[ 1.603883] hub 5-0:1.0: USB hub found
[ 1.603895] hub 5-0:1.0: 2 ports detected
[ 1.705110] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.728042] Refined TSC clocksource calibration: 2666.666 MHz.
[ 1.728056] Switching to clocksource tsc
[ 1.776032] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.981757] ata1.00: ATA-7: ST3500630AS, 3.AAE, max UDMA/133
[ 1.981765] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.028033] usb 2-2: new low-speed USB device number 2 using uhci_hcd
[ 2.048389] ata1.00: configured for UDMA/133
[ 2.048651] scsi 0:0:0:0: Direct-Access ATA ST3500630AS 3.AA PQ: 0 ANSI: 5
[ 2.211529] usb 2-2: New USB device found, idVendor=0518, idProduct=0001
[ 2.211538] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.211543] usb 2-2: Product: USB-compliant keyboard
[ 2.211547] usb 2-2: Manufacturer: Plus More Enterprise LTD.
[ 2.252036] ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[ 2.499198] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.499356] sd 0:0:0:0: [sda] Write Protect is off
[ 2.499363] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.499430] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.518526] input: Plus More Enterprise LTD. USB-compliant keyboard as /devices/pci0000:00/0000:00:10.0/usb2/2-2/2-2:1.0/input/input1
[ 2.520354] generic-usb 0003:0518:0001.0001: input,hidraw0: USB HID v1.10 Keyboard [Plus More Enterprise LTD. USB-compliant keyboard] on usb-0000:00:10.0-2/input0
[ 2.533455] sda: sda1 sda2 < sda5 >
[ 2.534304] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.538998] input: Plus More Enterprise LTD. USB-compliant keyboard as /devices/pci0000:00/0000:00:10.0/usb2/2-2/2-2:1.1/input/input2
[ 2.539555] generic-usb 0003:0518:0001.0002: input,hidraw1: USB HID v1.10 Mouse [Plus More Enterprise LTD. USB-compliant keyboard] on usb-0000:00:10.0-2/input1
[ 2.540255] usbcore: registered new interface driver usbhid
[ 2.540263] usbhid: USB HID core driver
[ 2.553921] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 7.872906] PM: Starting manual resume from disk
[ 7.872916] PM: Hibernation image partition 8:5 present
[ 7.872920] PM: Looking for hibernation image.
[ 7.873339] PM: Image not found (code -22)
[ 7.873346] PM: Hibernation image not present or could not be loaded.
[ 7.996674] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.818174] udevd[333]: starting version 175
[ 10.244738] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 10.319762] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
[ 10.319779] ACPI: Sleep Button [SLPB]
[ 10.322368] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
[ 10.322385] ACPI: Power Button [PWRB]
[ 10.322512] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 10.322522] ACPI: Power Button [PWRF]
[ 10.391334] parport_pc 00:09: reported by Plug and Play ACPI
[ 10.391448] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 11.371378] snd_via82xx 0000:00:11.5: setting latency timer to 64
[ 11.484358] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input6
[ 13.399324] Adding 978940k swap on /dev/sda5. Priority:-1 extents:1 across:978940k
[ 13.436744] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 13.728283] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.890360] loop: module loaded
[ 16.571819] RPC: Registered named UNIX socket transport module.
[ 16.571827] RPC: Registered udp transport module.
[ 16.571831] RPC: Registered tcp transport module.
[ 16.571835] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 16.605738] FS-Cache: Loaded
[ 16.651655] NFS: Registering the id_resolver key type
[ 16.651707] FS-Cache: Netfs 'nfs' registered for caching
[ 16.663328] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 19.224794] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input7
[ 20.388249] Bluetooth: Core ver 2.16
[ 20.389088] NET: Registered protocol family 31
[ 20.389096] Bluetooth: HCI device and connection manager initialized
[ 20.389102] Bluetooth: HCI socket layer initialized
[ 20.389106] Bluetooth: L2CAP socket layer initialized
[ 20.389126] Bluetooth: SCO socket layer initialized
[ 20.414207] Bluetooth: RFCOMM TTY layer initialized
[ 20.414222] Bluetooth: RFCOMM socket layer initialized
[ 20.414228] Bluetooth: RFCOMM ver 1.11
[ 20.448640] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.448649] Bluetooth: BNEP filters: protocol multicast
[ 20.530352] lp0: using parport0 (interrupt-driven).
[ 20.637160] ppdev: user-space parallel port driver
[ 25.070597] [drm] Initialized drm 1.1.0 20060810
[ 25.107046] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 25.107056] [drm] No driver support for vblank timestamp query.
[ 25.107064] [drm] Initialized via 2.11.1 20070202 for 0000:01:00.0 on minor 0
[ 25.142153] agpgart-via 0000:00:00.0: AGP 3.5 bridge
[ 25.142198] agpgart-via 0000:00:00.0: putting AGP V3 device into 8x mode
[ 25.142314] pci 0000:01:00.0: putting AGP V3 device into 8x mode
[ 80.966380] I-pipe: head domain RTAI registered.
[ 80.966396] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 80.966409] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 80.966415] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333299, CLK_FREQ 2666556000, CPU_FREQ 2666556000
[ 80.966420] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 80.966427] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333299, 8333299, 6199000
[ 81.142597] insmod: page allocation failure: order:7, mode:0xd0
[ 81.142608] Pid: 3526, comm: insmod Tainted: G O 3.4-9-rtai-686-pae #1
[ 81.142613] Call Trace:
[ 81.142632] [<c10ae360>] ? warn_alloc_failed+0xc0/0x100
[ 81.142640] [<c10b108f>] ? __alloc_pages_nodemask+0x56f/0x7d0
[ 81.142651] [<c1024ae0>] ? set_memory_rw+0x40/0x40
[ 81.142658] [<c10b1354>] ? __get_free_pages+0x14/0x30
[ 81.142686] [<deb919e7>] ? alloc_extent+0x37/0xb0 [rtai_sched]
[ 81.142706] [<deb91e17>] ? rtheap_init+0x1b7/0x1d0 [rtai_sched]
[ 81.142728] [<deb78afa>] ? __rtai_lxrt_init+0x3a/0x5c0 [rtai_sched]
[ 81.142736] [<c1001112>] ? do_one_initcall+0x32/0x190
[ 81.142743] [<c1024a11>] ? set_memory_ro+0x31/0x40
[ 81.142764] [<deb78ac0>] ? lxrt_handle_trap+0xf0/0xf0 [rtai_sched]
[ 81.142772] [<c1075bbd>] ? sys_init_module+0x8bd/0x1ad0
[ 81.142819] [<c1368c28>] ? sysenter_do_call+0x12/0x16
[ 81.142824] Mem-Info:
[ 81.142828] DMA per-cpu:
[ 81.142832] CPU 0: hi: 0, btch: 1 usd: 0
[ 81.142836] Normal per-cpu:
[ 81.142839] CPU 0: hi: 186, btch: 31 usd: 0
[ 81.142847] active_anon:21303 inactive_anon:21337 isolated_anon:5
[ 81.142849] active_file:12229 inactive_file:48941 isolated_file:24
[ 81.142851] unevictable:0 dirty:109 writeback:0 unstable:0
[ 81.142852] free:1575 slab_reclaimable:1523 slab_unreclaimable:1986
[ 81.142854] mapped:17887 shmem:523 pagetables:571 bounce:0
[ 81.142864] DMA free:1948kB min:88kB low:108kB high:132kB active_anon:4892kB inactive_anon:4976kB active_file:1128kB inactive_file:2772kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15804kB mlocked:0kB dirty:248kB writeback:0kB mapped:88kB shmem:0kB slab_reclaimable:84kB slab_unreclaimable:44kB kernel_stack:48kB pagetables:20kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 81.142873] lowmem_reserve[]: 0 460 460 460
[ 81.142890] Normal free:4352kB min:2696kB low:3368kB high:4044kB active_anon:80320kB inactive_anon:80372kB active_file:47788kB inactive_file:192992kB unevictable:0kB isolated(anon):20kB isolated(file):96kB present:471168kB mlocked:0kB dirty:188kB writeback:0kB mapped:71460kB shmem:2092kB slab_reclaimable:6008kB slab_unreclaimable:7900kB kernel_stack:2024kB pagetables:2264kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 81.142899] lowmem_reserve[]: 0 0 0 0
[ 81.142909] DMA: 1*4kB 1*8kB 1*16kB 0*32kB 0*64kB 1*128kB 1*256kB 1*512kB 1*1024kB 0*2048kB 0*4096kB = 1948kB
[ 81.142934] Normal: 44*4kB 40*8kB 21*16kB 14*32kB 12*64kB 12*128kB 3*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 4352kB
[ 81.142959] 61727 total pagecache pages
[ 81.142964] 9 pages in swap cache
[ 81.142969] Swap cache stats: add 37, delete 28, find 0/1
[ 81.142973] Free swap = 978824kB
[ 81.142976] Total swap = 978940kB
[ 81.157239] 122800 pages RAM
[ 81.157246] 0 pages HighMem
[ 81.157249] 2848 pages reserved
[ 81.157252] 73616 pages shared
[ 81.157255] 85461 pages non-shared
[ 81.174330] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 81.174424] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 81.174436] RTAI[sched]: hard timer type/freq = APIC/8333299(Hz); default timing: oneshot; linear timed lists.
[ 81.174443] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666556000 hz.
[ 81.174447] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 81.282566] RTAI[math]: loaded.
[ 82.695055] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 82.695060] This Message will only display once per session.
[ 82.695062] Run the Latency Test and resolve before continuing.
[ 102.173205] spurious APIC interrupt on CPU#0, should never happen.
[ 102.200112] RTAI[math]: unloaded.
[ 102.216165] SCHED releases registered named ALIEN PEDV$D
[ 102.244251] RTAI[malloc]: unloaded.
[ 102.344074] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 102.359683] I-pipe: head domain RTAI unregistered.
[ 102.359704] RTAI[hal]: unmounted.
[ 118.762576] I-pipe: head domain RTAI registered.
[ 118.762590] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 118.762604] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 118.762610] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333299, CLK_FREQ 2666556000, CPU_FREQ 2666556000
[ 118.762615] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 118.762621] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333299, 8333299, 3227500
[ 118.787554] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 118.787677] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 118.787689] RTAI[sched]: hard timer type/freq = APIC/8333299(Hz); default timing: oneshot; linear timed lists.
[ 118.787696] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666556000 hz.
[ 118.787700] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 118.816929] RTAI[math]: loaded.
[ 119.102808] hm2: loading Mesa HostMot2 driver version 0.15
[ 119.115187] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 119.115270] hm2_pci: discovered 5i25 at 0000:00:08.0
[ 119.117930] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 119.175606] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 119.175617] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 119.175621] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 119.175625] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 119.175629] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 119.175633] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 119.175637] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 119.175641] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 119.175646] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 119.175652] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 119.175657] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 119.175662] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 119.175667] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 119.175672] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 119.175677] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 119.175682] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 119.175686] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 119.175691] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 119.175696] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 119.175700] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 119.175704] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 119.175707] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 119.175711] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 119.175715] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 119.175719] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 119.175724] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #6, pin Mux Select 0 (Output)
[ 119.175729] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #3, pin Muxed A (Input)
[ 119.175734] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #3, pin Muxed B (Input)
[ 119.175738] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #3, pin Muxed Index (Input)
[ 119.175743] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 119.175747] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 119.175751] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 119.175754] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 119.175758] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 119.175762] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 119.177159] hm2/hm2_5i25.0: registered
[ 119.177170] hm2_5i25.0: initialized AnyIO board at 0000:00:08.0
[ 120.090210] hm2_5i25.0: dropping AnyIO board at 0000:00:08.0
[ 120.090226] hm2/hm2_5i25.0: unregistered
[ 120.091166] hm2_pci: driver unloaded
[ 120.096847] hm2: unloading
[ 122.376661] RTAI[math]: unloaded.
[ 122.382502] SCHED releases registered named ALIEN PEDV$D
[ 122.396676] RTAI[malloc]: unloaded.
[ 122.496034] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 122.501838] I-pipe: head domain RTAI unregistered.
[ 122.501874] RTAI[hal]: unmounted.
[ 163.513626] I-pipe: head domain RTAI registered.
[ 163.513643] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 163.513654] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 163.513661] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333299, CLK_FREQ 2666556000, CPU_FREQ 2666556000
[ 163.513666] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 163.513672] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333299, 8333299, 5778500
[ 163.541941] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 163.542064] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 163.542075] RTAI[sched]: hard timer type/freq = APIC/8333299(Hz); default timing: oneshot; linear timed lists.
[ 163.542082] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666556000 hz.
[ 163.542086] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 163.571536] RTAI[math]: loaded.
[ 163.816584] hm2: loading Mesa HostMot2 driver version 0.15
[ 163.823372] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 163.823454] hm2_pci: discovered 5i25 at 0000:00:08.0
[ 163.824106] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 163.881800] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 163.881810] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 163.881815] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 163.881819] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 163.881823] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 163.881827] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 163.881831] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 163.881835] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 163.881841] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 163.881846] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 163.881851] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 163.881856] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 163.881861] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 163.881865] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 163.881869] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 163.881873] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 163.881877] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 163.881881] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 163.881884] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 163.881888] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 163.881892] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 163.881896] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 163.881900] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 163.881904] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 163.881908] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 163.881912] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 163.881916] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 163.881920] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 163.881924] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 163.881927] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 163.881931] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 163.881935] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 163.881939] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 163.881943] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 163.881947] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 163.882130] hm2/hm2_5i25.0: registered
[ 163.882137] hm2_5i25.0: initialized AnyIO board at 0000:00:08.0
[ 164.473028] hm2_5i25.0: dropping AnyIO board at 0000:00:08.0
[ 164.473046] hm2/hm2_5i25.0: unregistered
[ 164.473963] hm2_pci: driver unloaded
[ 164.479707] hm2: unloading
[ 166.734652] RTAI[math]: unloaded.
[ 166.740442] SCHED releases registered named ALIEN PEDV$D
[ 166.753026] RTAI[malloc]: unloaded.
[ 166.852049] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 166.857781] I-pipe: head domain RTAI unregistered.
[ 166.857803] RTAI[hal]: unmounted.
[ 216.656591] I-pipe: head domain RTAI registered.
[ 216.656607] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 216.656619] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 216.656625] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333299, CLK_FREQ 2666556000, CPU_FREQ 2666556000
[ 216.656630] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 216.656637] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333299, 8333299, 3064500
[ 216.684988] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 216.685108] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 216.685119] RTAI[sched]: hard timer type/freq = APIC/8333299(Hz); default timing: oneshot; linear timed lists.
[ 216.685125] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666556000 hz.
[ 216.685130] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 216.715881] RTAI[math]: loaded.
[ 216.954339] hm2: loading Mesa HostMot2 driver version 0.15
[ 216.960845] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 216.960927] hm2_pci: discovered 5i25 at 0000:00:08.0
[ 216.962989] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 217.020929] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 217.020940] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 217.020944] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 217.020948] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 217.020952] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 217.020956] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 217.020960] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 217.020963] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 217.020969] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 217.020975] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 217.020979] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 217.020985] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 217.020990] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 217.020994] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 217.020999] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 217.021004] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 217.021009] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 217.021014] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 217.021018] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 217.021022] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 217.021026] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 217.021030] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 217.021034] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 217.021038] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 217.021042] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 217.021045] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 217.021049] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 217.021053] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 217.021057] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 217.021061] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 217.021065] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 217.021068] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 217.021072] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 217.021076] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 217.021080] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 217.021297] hm2/hm2_5i25.0: registered
[ 217.021303] hm2_5i25.0: initialized AnyIO board at 0000:00:08.0
[ 217.643377] hm2_5i25.0: dropping AnyIO board at 0000:00:08.0
[ 217.643393] hm2/hm2_5i25.0: unregistered
[ 217.644257] hm2_pci: driver unloaded
[ 217.650218] hm2: unloading
[ 219.905864] RTAI[math]: unloaded.
[ 219.911595] SCHED releases registered named ALIEN PEDV$D
[ 219.924534] RTAI[malloc]: unloaded.
[ 220.024037] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 220.029832] I-pipe: head domain RTAI unregistered.
[ 220.029853] RTAI[hal]: unmounted.
[ 269.918959] I-pipe: head domain RTAI registered.
[ 269.918974] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 269.918985] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 269.918992] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333299, CLK_FREQ 2666556000, CPU_FREQ 2666556000
[ 269.918997] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 269.919004] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333299, 8333299, 6895500
[ 269.946663] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 269.946780] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 269.946790] RTAI[sched]: hard timer type/freq = APIC/8333299(Hz); default timing: oneshot; linear timed lists.
[ 269.946797] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666556000 hz.
[ 269.946801] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 269.976323] RTAI[math]: loaded.
[ 270.202076] hm2: loading Mesa HostMot2 driver version 0.15
[ 270.208551] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 270.208633] hm2_pci: discovered 5i25 at 0000:00:08.0
[ 270.209775] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 270.267035] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 270.267047] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 270.267051] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 270.267055] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 270.267059] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 270.267063] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 270.267067] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 270.267071] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 270.267077] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 270.267082] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 270.267087] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 270.267093] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 270.267097] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 270.267101] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 270.267105] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 270.267109] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 270.267113] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 270.267117] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 270.267121] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 270.267125] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 270.267129] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 270.267133] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 270.267137] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 270.267141] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 270.267145] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 270.267149] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 270.267153] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 270.267157] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 270.267161] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 270.267165] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 270.267168] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 270.267172] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 270.267176] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 270.267180] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 270.267184] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 270.267390] hm2/hm2_5i25.0: registered
[ 270.267396] hm2_5i25.0: initialized AnyIO board at 0000:00:08.0
[ 270.839625] hm2_5i25.0: dropping AnyIO board at 0000:00:08.0
[ 270.839640] hm2/hm2_5i25.0: unregistered
[ 270.840522] hm2_pci: driver unloaded
[ 270.846354] hm2: unloading
[ 273.101417] RTAI[math]: unloaded.
[ 273.107289] SCHED releases registered named ALIEN PEDV$D
[ 273.119814] RTAI[malloc]: unloaded.
[ 273.216032] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 273.221709] I-pipe: head domain RTAI unregistered.
[ 273.221730] RTAI[hal]: unmounted.
[ 408.766950] I-pipe: head domain RTAI registered.
[ 408.766966] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 408.766978] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 408.766985] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333299, CLK_FREQ 2666556000, CPU_FREQ 2666556000
[ 408.766990] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 408.766996] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333299, 8333299, 8229750
[ 408.839100] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 408.839226] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 408.839237] RTAI[sched]: hard timer type/freq = APIC/8333299(Hz); default timing: oneshot; linear timed lists.
[ 408.839243] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666556000 hz.
[ 408.839248] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 408.869782] RTAI[math]: loaded.
[ 409.114955] hm2: loading Mesa HostMot2 driver version 0.15
[ 409.121498] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 409.121578] hm2_pci: discovered 5i25 at 0000:00:08.0
[ 409.122223] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 409.179595] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 409.179607] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 409.179611] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 409.179615] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 409.179619] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 409.179623] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 409.179627] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 409.179631] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 409.179636] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 409.179642] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 409.179647] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 409.179652] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 409.179657] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 409.179661] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 409.179665] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 409.179668] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 409.179672] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 409.179676] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 409.179680] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 409.179684] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 409.179688] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 409.179692] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 409.179696] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 409.179700] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 409.179704] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 409.179707] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 409.179711] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 409.179715] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 409.179719] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 409.179723] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 409.179727] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 409.179731] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 409.179735] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 409.179739] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 409.179743] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 409.179928] hm2/hm2_5i25.0: registered
[ 409.179933] hm2_5i25.0: initialized AnyIO board at 0000:00:08.0
[ 409.780054] hm2_5i25.0: dropping AnyIO board at 0000:00:08.0
[ 409.780069] hm2/hm2_5i25.0: unregistered
[ 409.781419] hm2_pci: driver unloaded
[ 409.787047] hm2: unloading
[ 412.042372] RTAI[math]: unloaded.
[ 412.048345] SCHED releases registered named ALIEN PEDV$D
[ 412.062646] RTAI[malloc]: unloaded.
[ 412.160034] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 412.165701] I-pipe: head domain RTAI unregistered.
[ 412.165722] RTAI[hal]: unmounted.
[ 451.010880] I-pipe: head domain RTAI registered.
[ 451.010897] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 451.010909] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 451.010916] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333299, CLK_FREQ 2666556000, CPU_FREQ 2666556000
[ 451.010921] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 451.010927] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333299, 8333299, 8278000
[ 451.039081] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 451.039204] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 451.039216] RTAI[sched]: hard timer type/freq = APIC/8333299(Hz); default timing: oneshot; linear timed lists.
[ 451.039223] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666556000 hz.
[ 451.039227] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 451.063648] RTAI[math]: loaded.
[ 451.308796] hm2: loading Mesa HostMot2 driver version 0.15
[ 451.315274] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 451.315356] hm2_pci: discovered 5i25 at 0000:00:08.0
[ 451.315992] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 451.373365] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 451.373377] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 451.373381] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 451.373385] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 451.373389] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 451.373393] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 451.373397] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 451.373401] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 451.373406] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 451.373412] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 451.373417] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 451.373422] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 451.373426] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 451.373430] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 451.373434] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 451.373438] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 451.373442] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 451.373446] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 451.373450] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 451.373454] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 451.373458] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 451.373462] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 451.373466] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 451.373470] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 451.373474] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 451.373477] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 451.373481] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 451.373485] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 451.373489] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 451.373493] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 451.373497] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 451.373501] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 451.373505] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 451.373509] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 451.373513] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 451.373709] hm2/hm2_5i25.0: registered
[ 451.373716] hm2_5i25.0: initialized AnyIO board at 0000:00:08.0
[ 451.949949] hm2_5i25.0: dropping AnyIO board at 0000:00:08.0
[ 451.949966] hm2/hm2_5i25.0: unregistered
[ 451.950949] hm2_pci: driver unloaded
[ 451.956626] hm2: unloading
[ 454.211630] RTAI[math]: unloaded.
[ 454.217591] SCHED releases registered named ALIEN PEDV$D
[ 454.230994] RTAI[malloc]: unloaded.
[ 454.328036] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 454.333845] I-pipe: head domain RTAI unregistered.
[ 454.333866] RTAI[hal]: unmounted.
