Re: ЧПУ пульты
Добавлено: 14 июн 2012, 21:36
http://dastore.ru/catalog/kompyuternoe- ... ss-silver/
ShuttleXpress
1. Description
shuttlexpress is a userspace HAL component that interfaces Contour Design’s ShuttleXpress device with LinuxCNC’s HAL. The
ShuttleXpress has five momentary buttons, a 10 counts/revolution jog wheel with detents, and a 15-position spring-loaded outer
wheel that returns to center when released.
If it is started without command-line arguments, it will probe all /dev/hidraw* device files for ShuttleXpress devices, and use all
devices found. If it is started with command-line arguments, only will only probe the devices specified.
Warning
The ShuttleXpress device has an internal 8-bit counter for the current jog-wheel position. The shuttlexpress driver can
not know this value until the ShuttleXpress device sends its first event. When the first event comes into the driver, the
driver uses the device’s reported jog-wheel position to initialize counts to 0.
This means that if the first event is generated by a jog-wheel move, that first move will be lost.
Any user interaction with the ShuttleXpress device will generate an event, informing the driver of the jog-wheel position. So if
you (for example) push one of the buttons at startup, the jog-wheel will work fine and notice the first click.
2. Setup
The shuttlexpress module needs read permission on the /dev/hidraw* device files. This can be accomplished by adding a file
/etc/udev/rules.d/99-shuttlexpress.rules, with the following contents:
SUBSYSTEM=="hidraw", ATTRS{idVendor}=="0b33", ATTRS{idProduct}=="0020", MODE="0444"
3. Pins
(bit out) shuttlexpress.0.button-0 (bit out) shuttlexpress.0.button-0-not (bit out) shuttlexpress.0.button-1 (bit out) shuttlexpress.0.button-
1-not (bit out) shuttlexpress.0.button-2 (bit out) shuttlexpress.0.button-2-not (bit out) shuttlexpress.0.button-3 (bit out) shuttlexpress.0.button-
3-not (bit out) shuttlexpress.0.button-4 (bit out) shuttlexpress.0.button-4-not
The five buttons around the outside, starting with the counter-clockwise-most one.
(s32 out) shuttlexpress.0.counts
Accumulated counts from the jog wheel (the inner wheel).
(s32 out) shuttlexpress.0.spring-wheel-s32
The current deflection of the spring-wheel (the outer wheel). It’s 0 at rest, and ranges from -7 at the counter-clockwise extreme
to +7 at the clockwise extreme.
(float out) shuttlexpress.0.spring-wheel-f
The current deflection of the spring-wheel (the outer wheel). It’s 0 at rest, -1 at the counter-clockwise extreme, and +1 at the
clockwise extreme. (The ShuttleXpress device reports the spring-wheel position quantized from -7 to +7, so this pin reports only
15 discrete values in it’s range.)
ShuttleXpress
1. Description
Warning
2. Setup
3. Pins
