как сделат customhal ?
- dinkata
- Настоящее имя: Диньо
Re: как сделат customhal ?
подскажите пожалуйста как привязат входьй/вьйходьй к classicladder ,кроме ето там мне будут нужньйе
М3;М4;М5 ;М19 ; М6;Тхх и еще некоторьйе ,собираюс пользоват и къстом М 141;142;143
- dinkata
Nick писал(а):покажи, какую ошибку дает. текст целиком.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.6.3
Machine configuration directory is '/home/cnczmm/linuxcnc/configs/RV50124_1'
Machine configuration file is 'RV50124_1.ini'
INIFILE=/home/cnczmm/linuxcnc/configs/RV50124_1/RV50124_1.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting HAL User Interface program: halui
INFO CLASSICLADDER- No ladder GUI requested-Realtime runs till HAL closes.
Running HAL shutdown script
Killing task linuxcncsvr, PID=3914
Debug file information:
custom.hal:7: Pin 'hm2_5i25.0.7i64.0.2.input-00' was already linked to signal 'estop-ext'
3914
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-3linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-3linuxcnc
[ 0.000000] Disabled fast string operations
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007f28f000 (usable)
[ 0.000000] BIOS-e820: 000000007f28f000 - 000000007f316000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007f316000 - 000000007f332000 (reserved)
[ 0.000000] BIOS-e820: 000000007f332000 - 000000007f333000 (usable)
[ 0.000000] BIOS-e820: 000000007f333000 - 000000007f34b000 (reserved)
[ 0.000000] BIOS-e820: 000000007f34b000 - 000000007f352000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007f352000 - 000000007f35d000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007f35d000 - 000000007f387000 (reserved)
[ 0.000000] BIOS-e820: 000000007f387000 - 000000007f5b0000 (usable)
[ 0.000000] BIOS-e820: 000000007f5b0000 - 000000007f6e5000 (reserved)
[ 0.000000] BIOS-e820: 000000007f6e5000 - 000000007f6f0000 (usable)
[ 0.000000] BIOS-e820: 000000007f6f0000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffc00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: To be filled by O.E.M. To be filled by O.E.M./D2000 Series, BIOS 4.6.5 06/01/2012
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7f6f0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-E7FFF write-through
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07F700000 mask FFFF00000 write-through
[ 0.000000] 2 base 07F800000 mask FFF800000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fcaf0] fcaf0
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 363e0000 - 371e8000
[ 0.000000] ACPI: RSDP 000f0450 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 7f34b070 00064 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 7f350ef8 000F4 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 7f34b168 05D8F (v02 ALASKA A M I 00000000 INTL 20051117)
[ 0.000000] ACPI: FACS 7f356f80 00040
[ 0.000000] ACPI: APIC 7f350ff0 00072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG 7f351068 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET 7f3510a8 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 7f3510e0 00655 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT 7f351738 00259 (v01 PmRef Cpu0Tst 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT 7f351998 0020F (v01 PmRef ApTst 00003000 INTL 20051117)
[ 0.000000] ACPI: IFEU 7f351ba8 00042 (v01 ALASKA A M I 01072009 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1150MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007f6f0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0007f28f
[ 0.000000] 0: 0x0007f332 -> 0x0007f333
[ 0.000000] 0: 0x0007f387 -> 0x0007f5b0
[ 0.000000] 0: 0x0007f6e5 -> 0x0007f6f0
[ 0.000000] On node 0 totalpages: 521299
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f53f0200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2302 pages used for memmap
[ 0.000000] HighMem zone: 291784 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:60000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77ad000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 517221
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=c8f9640a-0bd7-48b7-8f36-d4c3f439b177 ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 4175616 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007f6f0)
[ 0.000000] Memory: 2043444k/2087872k available (3495k kernel code, 41752k reserved, 1237k data, 416k init, 1176344k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369fca - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369fca (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f4c06000 soft=f4c08000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 1861.993 MHz processor.
[ 0.000004] Calibrating delay loop (skipped), value calculated using timer frequency.. 3723.98 BogoMIPS (lpj=7447972)
[ 0.000014] pid_max: default: 32768 minimum: 301
[ 0.000125] Security Framework initialized
[ 0.000133] AppArmor: AppArmor disabled by boot time parameter
[ 0.000176] Mount-cache hash table entries: 512
[ 0.000565] Initializing cgroup subsys cpuacct
[ 0.000571] Initializing cgroup subsys memory
[ 0.000589] Initializing cgroup subsys devices
[ 0.000595] Initializing cgroup subsys freezer
[ 0.000599] Initializing cgroup subsys net_cls
[ 0.000604] Initializing cgroup subsys blkio
[ 0.000618] Initializing cgroup subsys perf_event
[ 0.000669] Disabled fast string operations
[ 0.000677] CPU: Physical Processor ID: 0
[ 0.000680] CPU: Processor Core ID: 0
[ 0.000685] mce: CPU supports 5 MCE banks
[ 0.000695] CPU0: Thermal monitoring handled by SMI
[ 0.000769] ACPI: Core revision 20120320
[ 0.012435] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.012880] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.052510] CPU0: Intel(R) Atom(TM) CPU D2550 @ 1.86GHz stepping 01
[ 0.157423] Performance Events: PEBS fmt0+, generic architected perfmon, Intel PMU driver.
[ 0.157441] ... version: 3
[ 0.157446] ... bit width: 40
[ 0.157450] ... generic registers: 2
[ 0.157455] ... value mask: 000000ffffffffff
[ 0.157459] ... max period: 000000007fffffff
[ 0.157464] ... fixed-purpose events: 3
[ 0.157468] ... event mask: 0000000700000003
[ 0.169734] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.181432] CPU 1 irqstacks, hard=f4cd4000 soft=f4cd6000
[ 0.181438] Booting Node 0, Processors #1
[ 0.191453] Initializing CPU#1
[ 0.192370] Disabled fast string operations
[ 0.192384] CPU1: Thermal monitoring handled by SMI
[ 0.194532] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.201403] CPU 2 irqstacks, hard=f4d04000 soft=f4d06000
[ 0.201409] #2
[ 0.211350] Initializing CPU#2
[ 0.212336] Disabled fast string operations
[ 0.212350] CPU2: Thermal monitoring handled by SMI
[ 0.214468] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.221364] CPU 3 irqstacks, hard=f4d16000 soft=f4d18000
[ 0.221369] #3 Ok.
[ 0.231311] Initializing CPU#3
[ 0.232296] Disabled fast string operations
[ 0.232309] CPU3: Thermal monitoring handled by SMI
[ 0.234430] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.234499] Brought up 4 CPUs
[ 0.234506] Total of 4 processors activated (14895.94 BogoMIPS).
[ 0.235617] devtmpfs: initialized
[ 0.236143] PM: Registering ACPI NVS region [mem 0x7f28f000-0x7f315fff] (552960 bytes)
[ 0.236190] PM: Registering ACPI NVS region [mem 0x7f352000-0x7f35cfff] (45056 bytes)
[ 0.236439] dummy:
[ 0.236607] NET: Registered protocol family 16
[ 0.236874] ACPI: bus type pci registered
[ 0.237013] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.237022] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.237026] PCI: Using MMCONFIG for extended config space
[ 0.237032] PCI: Using configuration type 1 for base access
[ 0.238971] bio: create slab <bio-0> at 0
[ 0.239260] ACPI: Added _OSI(Module Device)
[ 0.239269] ACPI: Added _OSI(Processor Device)
[ 0.239275] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.239281] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.243421] ACPI: EC: Look up EC in DSDT
[ 0.248967] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.255642] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.257652] ACPI: SSDT 7f316710 006D5 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.258725] ACPI: Dynamic OEM Table Load:
[ 0.258735] ACPI: SSDT (null) 006D5 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.259638] ACPI: SSDT 7f318f10 0008D (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.260673] ACPI: Dynamic OEM Table Load:
[ 0.260682] ACPI: SSDT (null) 0008D (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.263463] ACPI: Interpreter enabled
[ 0.263486] ACPI: (supports S0 S1 S4 S5)
[ 0.263551] ACPI: Using IOAPIC for interrupt routing
[ 0.282749] ACPI: Power Resource [FN00] (off)
[ 0.284448] ACPI: No dock devices found.
[ 0.284468] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.285179] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.285870] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.285878] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.285886] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.285893] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff]
[ 0.285899] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000effff]
[ 0.285905] pci_root PNP0A08:00: host bridge window [mem 0x000f0000-0x000fffff]
[ 0.285912] pci_root PNP0A08:00: host bridge window [mem 0x7f800000-0x7fffffff]
[ 0.285919] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xfebfffff]
[ 0.286022] PCI host bridge to bus 0000:00
[ 0.286029] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.286036] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.286042] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.286049] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff]
[ 0.286055] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000effff]
[ 0.286062] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff]
[ 0.286069] pci_bus 0000:00: root bus resource [mem 0x7f800000-0x7fffffff]
[ 0.286075] pci_bus 0000:00: root bus resource [mem 0x80000000-0xfebfffff]
[ 0.286096] pci 0000:00:00.0: [8086:0bf3] type 00 class 0x060000
[ 0.286171] pci 0000:00:02.0: [8086:0be2] type 00 class 0x030000
[ 0.286193] pci 0000:00:02.0: reg 10: [mem 0xdfc00000-0xdfcfffff]
[ 0.286206] pci 0000:00:02.0: reg 14: [io 0xf0f0-0xf0f7]
[ 0.286358] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.286395] pci 0000:00:1b.0: reg 10: [mem 0xdff00000-0xdff03fff 64bit]
[ 0.286514] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.286572] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.286695] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.286751] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[ 0.286875] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.286937] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.287020] pci 0000:00:1d.0: reg 20: [io 0xf080-0xf09f]
[ 0.287082] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.287164] pci 0000:00:1d.1: reg 20: [io 0xf060-0xf07f]
[ 0.287229] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.287310] pci 0000:00:1d.2: reg 20: [io 0xf040-0xf05f]
[ 0.287373] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.287453] pci 0000:00:1d.3: reg 20: [io 0xf020-0xf03f]
[ 0.287534] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.287571] pci 0000:00:1d.7: reg 10: [mem 0xdff05000-0xdff053ff]
[ 0.287698] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.287742] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[ 0.287865] pci 0000:00:1f.0: [8086:27bc] type 00 class 0x060100
[ 0.288042] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[ 0.288075] pci 0000:00:1f.2: reg 10: [io 0xf0e0-0xf0e7]
[ 0.288095] pci 0000:00:1f.2: reg 14: [io 0xf0d0-0xf0d3]
[ 0.288115] pci 0000:00:1f.2: reg 18: [io 0xf0c0-0xf0c7]
[ 0.288135] pci 0000:00:1f.2: reg 1c: [io 0xf0b0-0xf0b3]
[ 0.288155] pci 0000:00:1f.2: reg 20: [io 0xf0a0-0xf0af]
[ 0.288175] pci 0000:00:1f.2: reg 24: [mem 0xdff04000-0xdff043ff]
[ 0.288227] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.288262] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.288344] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f]
[ 0.288484] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.288673] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.288749] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.288879] pci 0000:02:00.0: reg 18: [mem 0xdfe04000-0xdfe04fff 64bit pref]
[ 0.288961] pci 0000:02:00.0: reg 20: [mem 0xdfe00000-0xdfe03fff 64bit pref]
[ 0.289186] pci 0000:02:00.0: supports D1 D2
[ 0.289193] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.289421] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.289431] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.289441] pci 0000:00:1c.1: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.289527] pci 0000:03:05.0: [2718:5125] type 00 class 0x110000
[ 0.289554] pci 0000:03:05.0: reg 10: [mem 0xdfd00000-0xdfd0ffff]
[ 0.289712] pci 0000:00:1e.0: PCI bridge to [bus 03-03] (subtractive decode)
[ 0.289726] pci 0000:00:1e.0: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.289741] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.289748] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.289755] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.289762] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000dffff] (subtractive decode)
[ 0.289769] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000effff] (subtractive decode)
[ 0.289776] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff] (subtractive decode)
[ 0.289783] pci 0000:00:1e.0: bridge window [mem 0x7f800000-0x7fffffff] (subtractive decode)
[ 0.289790] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xfebfffff] (subtractive decode)
[ 0.289824] pci_bus 0000:00: on NUMA node 0
[ 0.289833] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.290124] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P8._PRT]
[ 0.290351] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.290480] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.290893] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.302321] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.302491] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 *7 11 12 14 15)
[ 0.302654] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 *7 10 12 14 15)
[ 0.302815] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.302977] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
[ 0.303141] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
[ 0.303305] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 *10 12 14 15)
[ 0.303473] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.303706] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.303729] vgaarb: loaded
[ 0.303733] vgaarb: bridge control possible 0000:00:02.0
[ 0.303817] PCI: Using ACPI for IRQ routing
[ 0.317615] PCI: pci_cache_line_size set to 64 bytes
[ 0.317746] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.317753] reserve RAM buffer: 000000007f28f000 - 000000007fffffff
[ 0.317760] reserve RAM buffer: 000000007f333000 - 000000007fffffff
[ 0.317769] reserve RAM buffer: 000000007f5b0000 - 000000007fffffff
[ 0.317775] reserve RAM buffer: 000000007f6f0000 - 000000007fffffff
[ 0.318070] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.318085] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.320129] Switching to clocksource hpet
[ 0.320313] pnp: PnP ACPI init
[ 0.320344] ACPI: bus type pnp registered
[ 0.320754] pnp 00:00: [bus 00-ff]
[ 0.320762] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.320768] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.320774] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.320781] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.320787] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.320793] pnp 00:00: [mem 0x000e0000-0x000effff window]
[ 0.320800] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.320806] pnp 00:00: [mem 0x7f800000-0x7fffffff window]
[ 0.320812] pnp 00:00: [mem 0x80000000-0xfebfffff window]
[ 0.320957] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.321006] pnp 00:01: [io 0x0000-0x001f]
[ 0.321012] pnp 00:01: [io 0x0081-0x0091]
[ 0.321018] pnp 00:01: [io 0x0093-0x009f]
[ 0.321024] pnp 00:01: [io 0x00c0-0x00df]
[ 0.321030] pnp 00:01: [dma 4]
[ 0.321091] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.321121] pnp 00:02: [mem 0xff000000-0xffffffff]
[ 0.321198] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.321401] pnp 00:03: [mem 0xfed00000-0xfed003ff]
[ 0.321508] system 00:03: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.321518] system 00:03: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
[ 0.321554] pnp 00:04: [io 0x00f0]
[ 0.321575] pnp 00:04: [irq 13]
[ 0.321639] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.321677] pnp 00:05: [io 0x002e-0x002f]
[ 0.321683] pnp 00:05: [io 0x004e-0x004f]
[ 0.321688] pnp 00:05: [io 0x0061]
[ 0.321693] pnp 00:05: [io 0x0063]
[ 0.321699] pnp 00:05: [io 0x0065]
[ 0.321704] pnp 00:05: [io 0x0067]
[ 0.321710] pnp 00:05: [io 0x0070]
[ 0.321715] pnp 00:05: [io 0x0080]
[ 0.321720] pnp 00:05: [io 0x0092]
[ 0.321726] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.321731] pnp 00:05: [io 0x0680-0x069f]
[ 0.321737] pnp 00:05: [io 0x1000-0x1003]
[ 0.321742] pnp 00:05: [io 0x1010-0x101f]
[ 0.321748] pnp 00:05: [io 0xffff]
[ 0.321753] pnp 00:05: [io 0x0400-0x047f]
[ 0.321759] pnp 00:05: [io 0x0500-0x057f]
[ 0.321764] pnp 00:05: [io 0x0600-0x061f]
[ 0.321879] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.321887] system 00:05: [io 0x1000-0x1003] has been reserved
[ 0.321894] system 00:05: [io 0x1010-0x101f] has been reserved
[ 0.321902] system 00:05: [io 0xffff] has been reserved
[ 0.321909] system 00:05: [io 0x0400-0x047f] has been reserved
[ 0.321916] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.321923] system 00:05: [io 0x0600-0x061f] has been reserved
[ 0.321931] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.322011] pnp 00:06: [io 0x06a0-0x06af]
[ 0.322017] pnp 00:06: [io 0x06b0-0x06ef]
[ 0.322112] system 00:06: [io 0x06a0-0x06af] has been reserved
[ 0.322120] system 00:06: [io 0x06b0-0x06ef] has been reserved
[ 0.322128] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.322162] pnp 00:07: [io 0x0070-0x0077]
[ 0.322178] pnp 00:07: [irq 8]
[ 0.322245] pnp 00:07: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.322628] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.322635] pnp 00:08: [io 0x0a00-0x0a1f]
[ 0.322641] pnp 00:08: [io 0x0a20-0x0a2f]
[ 0.322646] pnp 00:08: [io 0x0a30-0x0a3f]
[ 0.322753] system 00:08: [io 0x0a00-0x0a1f] has been reserved
[ 0.322761] system 00:08: [io 0x0a20-0x0a2f] has been reserved
[ 0.322772] system 00:08: [io 0x0a30-0x0a3f] has been reserved
[ 0.322780] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.322853] pnp 00:09: [io 0x0060]
[ 0.322859] pnp 00:09: [io 0x0064]
[ 0.322874] pnp 00:09: [irq 1]
[ 0.322956] pnp 00:09: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.323069] pnp 00:0a: [irq 12]
[ 0.323170] pnp 00:0a: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.323978] pnp 00:0b: [io 0x03f8-0x03ff]
[ 0.323992] pnp 00:0b: [irq 4]
[ 0.323998] pnp 00:0b: [dma 0 disabled]
[ 0.324167] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.324976] pnp 00:0c: [io 0x02f8-0x02ff]
[ 0.324990] pnp 00:0c: [irq 3]
[ 0.324996] pnp 00:0c: [dma 0 disabled]
[ 0.325146] pnp 00:0c: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.326230] pnp 00:0d: [io 0x0378-0x037f]
[ 0.326243] pnp 00:0d: [irq 5]
[ 0.326249] pnp 00:0d: [dma 0 disabled]
[ 0.326701] pnp 00:0d: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.326774] pnp 00:0e: [io 0x0010-0x001f]
[ 0.326781] pnp 00:0e: [io 0x0022-0x003f]
[ 0.326787] pnp 00:0e: [io 0x0044-0x005f]
[ 0.326792] pnp 00:0e: [io 0x0062-0x0063]
[ 0.326798] pnp 00:0e: [io 0x0065-0x006f]
[ 0.326803] pnp 00:0e: [io 0x0072-0x007f]
[ 0.326808] pnp 00:0e: [io 0x0080]
[ 0.326814] pnp 00:0e: [io 0x0084-0x0086]
[ 0.326819] pnp 00:0e: [io 0x0088]
[ 0.326824] pnp 00:0e: [io 0x008c-0x008e]
[ 0.326830] pnp 00:0e: [io 0x0090-0x009f]
[ 0.326835] pnp 00:0e: [io 0x00a2-0x00bf]
[ 0.326841] pnp 00:0e: [io 0x00e0-0x00ef]
[ 0.326847] pnp 00:0e: [io 0x04d0-0x04d1]
[ 0.326964] system 00:0e: [io 0x04d0-0x04d1] has been reserved
[ 0.326974] system 00:0e: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.327392] pnp 00:0f: [mem 0xfed1c000-0xfed1ffff]
[ 0.327399] pnp 00:0f: [mem 0x00000000-0x00003fff]
[ 0.327405] pnp 00:0f: [mem 0x00000000-0x00000fff]
[ 0.327411] pnp 00:0f: [mem 0x00000000-0x00000fff]
[ 0.327417] pnp 00:0f: [mem 0x00000000-0xffffffff disabled]
[ 0.327423] pnp 00:0f: [mem 0xfed45000-0xfed8ffff]
[ 0.327570] system 00:0f: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.327578] system 00:0f: [mem 0x00000000-0x00003fff] could not be reserved
[ 0.327586] system 00:0f: [mem 0x00000000-0x00000fff] could not be reserved
[ 0.327594] system 00:0f: [mem 0x00000000-0x00000fff] could not be reserved
[ 0.327602] system 00:0f: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.327610] system 00:0f: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.328163] pnp 00:10: [mem 0xfed14000-0xfed19fff]
[ 0.328172] pnp 00:10: [mem 0xe0000000-0xefffffff]
[ 0.328336] system 00:10: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.328345] system 00:10: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.328355] system 00:10: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.328388] pnp 00:11: [mem 0xff000000-0xffffffff]
[ 0.328504] pnp 00:11: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.328887] pnp 00:12: [io 0x0400-0x047f]
[ 0.328895] pnp 00:12: [io 0x0500-0x053f]
[ 0.328901] pnp 00:12: [mem 0xfec00000-0xfec00fff]
[ 0.328907] pnp 00:12: [mem 0xfee00000-0xfee00fff]
[ 0.328912] pnp 00:12: [mem 0xfed1c000-0xfed1ffff]
[ 0.328918] pnp 00:12: [mem 0xfed20000-0xfed8ffff]
[ 0.328924] pnp 00:12: [mem 0xffc00000-0xffffffff]
[ 0.329081] system 00:12: [io 0x0400-0x047f] has been reserved
[ 0.329089] system 00:12: [io 0x0500-0x053f] has been reserved
[ 0.329097] system 00:12: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.329105] system 00:12: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.329113] system 00:12: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.329125] system 00:12: [mem 0xfed20000-0xfed8ffff] could not be reserved
[ 0.329132] system 00:12: [mem 0xffc00000-0xffffffff] has been reserved
[ 0.329141] system 00:12: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.329151] pnp: PnP ACPI: found 19 devices
[ 0.329156] ACPI: ACPI bus type pnp unregistered
[ 0.329164] PnPBIOS: Disabled by ACPI PNP
[ 0.370423] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01-01] add_size 1000
[ 0.370435] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01-01] add_size 200000
[ 0.370444] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01-01] add_size 200000
[ 0.370465] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 0.370501] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.370509] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.370517] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.370524] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.370539] pci 0000:00:1c.0: BAR 14: assigned [mem 0x80000000-0x801fffff]
[ 0.370549] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[ 0.370559] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80400000-0x805fffff 64bit pref]
[ 0.370570] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.370580] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.370588] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.370601] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff]
[ 0.370611] pci 0000:00:1c.0: bridge window [mem 0x80200000-0x803fffff 64bit pref]
[ 0.370626] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.370634] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.370646] pci 0000:00:1c.1: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.370657] pci 0000:00:1c.1: bridge window [mem 0x80400000-0x805fffff 64bit pref]
[ 0.370672] pci 0000:00:1e.0: PCI bridge to [bus 03-03]
[ 0.370684] pci 0000:00:1e.0: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.370763] pci 0000:00:1e.0: setting latency timer to 64
[ 0.370772] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.370779] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.370785] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.370791] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff]
[ 0.370797] pci_bus 0000:00: resource 8 [mem 0x000e0000-0x000effff]
[ 0.370804] pci_bus 0000:00: resource 9 [mem 0x000f0000-0x000fffff]
[ 0.370810] pci_bus 0000:00: resource 10 [mem 0x7f800000-0x7fffffff]
[ 0.370817] pci_bus 0000:00: resource 11 [mem 0x80000000-0xfebfffff]
[ 0.370823] pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
[ 0.370829] pci_bus 0000:01: resource 1 [mem 0x80000000-0x801fffff]
[ 0.370836] pci_bus 0000:01: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[ 0.370843] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.370849] pci_bus 0000:02: resource 1 [mem 0xdfe00000-0xdfefffff]
[ 0.370855] pci_bus 0000:02: resource 2 [mem 0x80400000-0x805fffff 64bit pref]
[ 0.370862] pci_bus 0000:03: resource 1 [mem 0xdfd00000-0xdfdfffff]
[ 0.370869] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
[ 0.370875] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
[ 0.370881] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.370887] pci_bus 0000:03: resource 7 [mem 0x000c0000-0x000dffff]
[ 0.370893] pci_bus 0000:03: resource 8 [mem 0x000e0000-0x000effff]
[ 0.370900] pci_bus 0000:03: resource 9 [mem 0x000f0000-0x000fffff]
[ 0.370906] pci_bus 0000:03: resource 10 [mem 0x7f800000-0x7fffffff]
[ 0.370913] pci_bus 0000:03: resource 11 [mem 0x80000000-0xfebfffff]
[ 0.371135] NET: Registered protocol family 2
[ 0.371287] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.371793] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.372703] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.373103] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.373110] TCP: reno registered
[ 0.373119] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.373138] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.373429] NET: Registered protocol family 1
[ 0.373467] pci 0000:00:02.0: Boot video device
[ 0.373841] PCI: CLS 64 bytes, default 64
[ 0.373960] Unpacking initramfs...
[ 0.946416] Freeing initrd memory: 14368k freed
[ 0.959973] audit: initializing netlink socket (disabled)
[ 0.959999] type=2000 audit(1411985055.852:1): initialized
[ 0.982490] highmem bounce pool size: 64 pages
[ 0.982502] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.983123] VFS: Disk quotas dquot_6.5.2
[ 0.983197] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.983389] msgmni has been set to 1721
[ 0.983851] alg: No test for stdrng (krng)
[ 0.983944] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.983952] io scheduler noop registered
[ 0.983957] io scheduler deadline registered
[ 0.984021] io scheduler cfq registered (default)
[ 0.984470] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.984523] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.984528] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.985116] acpiphp: Slot [1] registered
[ 0.985439] GHES: HEST is not enabled!
[ 0.985469] isapnp: Scanning for PnP cards...
[ 1.339117] isapnp: No Plug & Play device found
[ 1.339258] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.359828] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.380464] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.401666] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.422421] 00:0c: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.423048] Linux agpgart interface v0.103
[ 1.423529] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.424083] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.424157] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.424435] mousedev: PS/2 mouse device common for all mice
[ 1.424543] rtc_cmos 00:07: RTC can wake from S4
[ 1.424786] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 1.424833] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.425109] TCP: cubic registered
[ 1.425293] NET: Registered protocol family 10
[ 1.425788] Mobile IPv6
[ 1.425795] NET: Registered protocol family 17
[ 1.425806] Registering the dns_resolver key type
[ 1.425894] Using IPI No-Shortcut mode
[ 1.426192] PM: Hibernation image not present or could not be loaded.
[ 1.426218] registered taskstats version 1
[ 1.427039] rtc_cmos 00:07: setting system clock to 2014-09-29 10:04:16 UTC (1411985056)
[ 1.427382] Freeing unused kernel memory: 416k freed
[ 1.427787] Write protecting the kernel text: 3496k
[ 1.427847] Write protecting the kernel read-only data: 984k
[ 1.469361] udevd[63]: starting version 175
[ 1.548758] usbcore: registered new interface driver usbfs
[ 1.548829] usbcore: registered new interface driver hub
[ 1.557983] usbcore: registered new device driver usb
[ 1.559526] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.559684] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.559696] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.559774] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.559839] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.559866] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.563782] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.563858] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xdff05000
[ 1.565246] SCSI subsystem initialized
[ 1.567248] ACPI: Fan [FAN0] (off)
[ 1.574190] libata version 3.00 loaded.
[ 1.577881] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.578671] r8169 0000:02:00.0: eth0: RTL8168evl/8111evl at 0xf8022000, 00:f1:f3:19:f8:68, XID 0c900800 IRQ 17
[ 1.578686] r8169 0000:02:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.579689] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.579789] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.579801] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.579814] usb usb1: Product: EHCI Host Controller
[ 1.579823] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.579831] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.580245] hub 1-0:1.0: USB hub found
[ 1.580267] hub 1-0:1.0: 8 ports detected
[ 1.585529] ata_piix 0000:00:1f.2: version 2.13
[ 1.585572] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.586697] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.737764] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.738596] scsi0 : ata_piix
[ 1.738904] scsi1 : ata_piix
[ 1.739033] ata1: SATA max UDMA/133 cmd 0xf0e0 ctl 0xf0d0 bmdma 0xf0a0 irq 19
[ 1.739040] ata2: SATA max UDMA/133 cmd 0xf0c0 ctl 0xf0b0 bmdma 0xf0a8 irq 19
[ 1.739179] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.739199] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.739300] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.739369] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000f080
[ 1.739501] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.739511] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.739520] usb usb2: Product: UHCI Host Controller
[ 1.739528] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.739538] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.739924] hub 2-0:1.0: USB hub found
[ 1.739944] hub 2-0:1.0: 2 ports detected
[ 1.740230] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.740242] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.740271] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.740335] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000f060
[ 1.740472] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.740483] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.740493] usb usb3: Product: UHCI Host Controller
[ 1.740501] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.740509] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.740919] hub 3-0:1.0: USB hub found
[ 1.740941] hub 3-0:1.0: 2 ports detected
[ 1.741225] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.741238] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.741277] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.741377] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000f040
[ 1.741507] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.741518] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.741527] usb usb4: Product: UHCI Host Controller
[ 1.741535] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.741543] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.742049] hub 4-0:1.0: USB hub found
[ 1.742069] hub 4-0:1.0: 2 ports detected
[ 1.742373] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.742387] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.742425] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.742525] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000f020
[ 1.742650] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.742661] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.742670] usb usb5: Product: UHCI Host Controller
[ 1.742678] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.742687] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.743092] hub 5-0:1.0: USB hub found
[ 1.743112] hub 5-0:1.0: 2 ports detected
[ 1.909828] ata2.00: ATA-8: 32GB SATA Flash Drive, SFDDA01D, max UDMA/133
[ 1.909837] ata2.00: 62533296 sectors, multi 1: LBA48 NCQ (depth 0/32)
[ 1.917832] ata2.00: configured for UDMA/133
[ 1.918111] scsi 1:0:0:0: Direct-Access ATA 32GB SATA Flash SFDD PQ: 0 ANSI: 5
[ 1.930311] sd 1:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
[ 1.930609] sd 1:0:0:0: [sda] Write Protect is off
[ 1.930620] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.930730] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.932283] sda: sda1 sda2 < sda5 >
[ 1.933230] sd 1:0:0:0: [sda] Attached SCSI disk
[ 1.953421] Refined TSC clocksource calibration: 1861.999 MHz.
[ 1.953438] Switching to clocksource tsc
[ 2.049222] usb 2-1: new low-speed USB device number 2 using uhci_hcd
[ 2.052085] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.223669] usb 2-1: New USB device found, idVendor=093a, idProduct=2510
[ 2.223678] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.223685] usb 2-1: Product: USB Optical Mouse
[ 2.223691] usb 2-1: Manufacturer: PixArt
[ 2.289134] init: ureadahead main process (221) terminated with status 5
[ 2.336722] usb 2-2: new low-speed USB device number 3 using uhci_hcd
[ 2.430333] Adding 2082812k swap on /dev/sda5. Priority:-1 extents:1 across:2082812k SS
[ 2.568814] udevd[304]: starting version 175
[ 2.593057] usb 2-2: New USB device found, idVendor=09da, idProduct=0260
[ 2.593074] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.593085] usb 2-2: Product: USB Keyboard
[ 2.593093] usb 2-2: Manufacturer:
[ 3.080843] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 3.138098] lp: driver loaded but no devices found
[ 3.304132] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 3.304157] ACPI: Power Button [PWRB]
[ 3.314371] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 3.314392] ACPI: Sleep Button [SLPB]
[ 3.315097] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 3.315119] ACPI: Power Button [PWRF]
[ 3.349967] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input3
[ 3.352107] generic-usb 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1d.0-1/input0
[ 3.404965] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/input/input4
[ 3.405326] generic-usb 0003:09DA:0260.0002: input,hidraw1: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:1d.0-2/input0
[ 3.414423] udevd[409]: renamed network interface eth0 to eth1
[ 3.455394] ppdev: user-space parallel port driver
[ 3.463120] parport_pc 00:0d: reported by Plug and Play ACPI
[ 3.463169] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE,EPP]
[ 3.498151] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.1/input/input5
[ 3.498482] generic-usb 0003:09DA:0260.0003: input,hidraw2: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:1d.0-2/input1
[ 3.498659] usbcore: registered new interface driver usbhid
[ 3.499124] usbhid: USB HID core driver
[ 3.535884] Bluetooth: Core ver 2.16
[ 3.536025] NET: Registered protocol family 31
[ 3.536033] Bluetooth: HCI device and connection manager initialized
[ 3.536042] Bluetooth: HCI socket layer initialized
[ 3.536049] Bluetooth: L2CAP socket layer initialized
[ 3.536070] Bluetooth: SCO socket layer initialized
[ 3.564661] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.564673] Bluetooth: BNEP filters: protocol multicast
[ 3.565798] lp0: using parport0 (interrupt-driven).
[ 3.580698] Bluetooth: RFCOMM TTY layer initialized
[ 3.580719] Bluetooth: RFCOMM socket layer initialized
[ 3.580729] Bluetooth: RFCOMM ver 1.11
[ 3.755794] microcode: CPU0 sig=0x30661, pf=0x4, revision=0x109
[ 3.773072] coretemp coretemp.0: Unable to read TjMax from CPU 0
[ 3.773128] coretemp coretemp.0: Unable to read TjMax from CPU 2
[ 3.861546] NET: Registered protocol family 4
[ 3.872930] NET: Registered protocol family 5
[ 3.916314] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 3.916459] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 3.916609] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 3.916751] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 3.916917] input: HDA Intel HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 4.065325] init: failsafe main process (705) killed by TERM signal
[ 4.129290] microcode: CPU1 sig=0x30661, pf=0x4, revision=0x109
[ 4.307362] microcode: CPU2 sig=0x30661, pf=0x4, revision=0x109
[ 4.313641] microcode: CPU3 sig=0x30661, pf=0x4, revision=0x109
[ 4.322894] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 4.475374] r8169 0000:02:00.0: eth1: link down
[ 4.475442] r8169 0000:02:00.0: eth1: link down
[ 4.475902] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 4.572648] init: udev-fallback-graphics main process (923) terminated with status 1
[ 6.027687] r8169 0000:02:00.0: eth1: link up
[ 6.028016] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 7.338554] fuse init (API version 7.18)
[ 16.588470] eth1: no IPv6 routers present
опят удалял
- Nick
- Заслуга: Developer
ну как NightV написал, гдавная ошибка:
М 141;142;143 а вот эти придется отдельно описывать.... Что они у тебя будут делать?
этот пин уже подключен к 'estop-ext'. Смотри в основном hal.dinkata писал(а):custom.hal:7: Pin 'hm2_5i25.0.7i64.0.2.input-00' was already linked to signal 'estop-ext'
Ты же уже вроде привязал кучу пинов...dinkata писал(а):подскажите пожалуйста как привязат входьй/вьйходьй к classicladder ,
М3;М4;М5 ;М19 ; М6;Тхх у этих есть стандартные пины в motion и iocontrol.dinkata писал(а):кроме ето там мне будут нужньйе
- dinkata
Переключение диапазонов коробка передач шпинделя .Nick писал(а):М 141;142;143 а вот эти придется отдельно описывать.... Что они у тебя будут делать?
я его убирал ,опят ошибка ,у меня сомнения что пиньй с motion и iocontrol некоректно ввел ...не знаю где копатNick писал(а):этот пин уже подключен к 'estop-ext'
- Nick
скинь еще раз все ini и hal файлы.dinkata писал(а):я его убирал ,опят ошибка ,у меня сомнения что пиньй с motion и iocontrol некоректно ввел ...не знаю где копат
Это можно сделать через reamap http://linuxcnc.org/docs/html/remap/str ... le_codes_adinkata писал(а):Переключение диапазонов коробка передач шпинделя .
или через custom mcode и там через консоль
(т.е. создаем исполняемые файлы M141 ... M143 в директории с ini)
halcmd setp .... 1
http://linuxcnc.org/docs/html/gcode/m-c ... 00-to-M199
или вообще исользовать M62-M65 и дергать пины через них...
http://linuxcnc.org/docs/html/gcode/m-c ... ec:M62-M65
- dinkata
Ну ,помогите пожалуйста запустит етот чертовой custom halNick писал(а):скинь еще раз все ini и hal файлы.
- Вложения
- RV50124_1.ini
- етот из pncconf
- (4.05 КБ) 1129 скачиваний
- RV50124_1.hal
- етот из pncconf
- (17.61 КБ) 1097 скачиваний
- Primercustom.hal
- етот я редактировал и хочу сделат его мой къстом хал
- (6.37 КБ) 1067 скачиваний
- Nick
Вот в основсном hal у тебя уже эти пины подключены, например, 7i64.0.2.input-00. Ты их через pncconf что ли настроил?
# --- ESTOP-EXT ---
net estop-ext <= hm2_5i25.0.7i64.0.2.input-00
разве так :Nick писал(а):Вот в основсном hal у тебя уже эти пины подключены, например, 7i64.0.2.input-00.
# --- ESTOP-EXT ---
net estop-ext => iocontrol.0.emc-enable-in
будет ошибка??
а именно так сейчас в конфиге прописано...
здесь наверно всё дело в каше из файлов ...))
(тех ,что в папке с конфигом ,и теми ,что прописаны в ини...
или я что то не доглядел...)
- Nick
так можно, но потом в Primercustom.hal у тебя есть тот же пин:
net extstp => classicladder.0.in-00 <= hm2_5i25.0.7i64.0.2.input-00
если хочешь его подключить и к classicladder.0.in-00 то надо использовать тот же сигнал, т.е. надо написать только
net estop-ext => classicladder.0.in-00
- dinkata
Да ,но я убирал и его и другие ,все равно ошибка ,was already linked to signalNick писал(а):Ты их через pncconf что ли настроил?
вот поставил в къстом хал только етие :
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
loadrt weighted_sum wsum_sizes=5
addf process_wsums servo-thread
net opref2 => classicladder.0.in-11 <= hm2_5i25.0.7i64.0.2.input-15
net nsthor => classicladder.0.in-12 <= hm2_5i25.0.7i64.0.2.input-16
net nstver => classicladder.0.in-13 <= hm2_5i25.0.7i64.0.2.input-17
net opdown => classicladder.0.in-14 <= hm2_5i25.0.7i64.0.2.input-18
net operup => classicladder.0.in-15 <= hm2_5i25.0.7i64.0.2.input-19
net btnsot => classicladder.0.in-16 <= hm2_5i25.0.7i77.0.0.input-11
net pgebox => classicladder.0.in-17 <= hm2_5i25.0.7i77.0.0.input-12
net phydrv => classicladder.0.in-18 <= hm2_5i25.0.7i77.0.0.input-13
net hllube => classicladder.0.in-19 <= hm2_5i25.0.7i77.0.0.input-14
net pllube => classicladder.0.in-20 <= hm2_5i25.0.7i77.0.0.input-15
и опят ошибка was already linked to signal
- dinkata
Nick ,а так можно прямо в основном хал записат ..:
# --- DIGITAL_IN_PHYDROK ---
net Digital_in_Phydrok <= hm2_5i25.0.7i77.0.0.input-13 => classicladder.0.in-18
# --- DIGITAL_IN_HLUBE ---
net Digital_in_Hlube <= hm2_5i25.0.7i77.0.0.input-14 => classicladder.0.in-19
- dinkata
НАКОНЕЦ ТО ВИДИТСЯ СВЕТ В ТУНЕЛЕ.
ВОТ что записал в хал ;
net Digital_out_Oper+60 hm2_5i25.0.7i64.0.2.output-12 <= classicladder.0.out-05
и протестировал он лайн ,светодиод на 7и64 загорел ,значит вьйход включен ,урааааааааааааа ,продолжаем
- Nick
Можно. Просто основной hal сотрется, если ты хоть что-то помнеяешь в pncconf, а custom.hal - нет.dinkata писал(а):Nick ,а так можно прямо в основном хал записат ..:
Луше не ставь + в названия сигналов... в принципе, если работает, то не критично, но лучше не ставь.dinkata писал(а):Digital_out_Oper+60
- dinkata
спасибоNick писал(а):Луше не ставь + в названия сигналов
- dinkata
значит те пиньй которьйе хочу пользоват в custom hal , в pncconf не привязават ,да ?Nick писал(а): основной hal сотрется, если ты хоть что-то помнеяешь в pncconf
Потом в custom hal привязьйвай как удобно ,да ?
- Nick
Нет. Их привязывать можно. Просто потом в своем custom.hal используй имя сигнала, которое в обычном hal указано.
Т.е. пин можно привязать только к 1 сигналу. Но этот сигнал можно использовать в любом hal.
