CC net/sunrpc/rpcb_clnt.o
drivers/usb/host/dwc_otg/dwc_otg_hcd.c: In function 'assign_and_init_hc':
19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
hc->xfer_buff = (uint8_t *) urb->dma + urb->actual_length;
21: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
hc->xfer_buff = (uint8_t *) urb->setup_dma;
hc->xfer_buff = (uint8_t *) hcd->status_buf_dma;
hc->xfer_buff = (uint8_t *) urb->dma;
drivers/usb/host/dwc_otg/dwc_otg_hcd.c: In function 'fiq_fsm_setup_periodic_dma':
10: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
blob = (struct fiq_dma_blob *) hcd->fiq_state->dma_base;
24: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
st->hcdma_copy.d32 = (dma_addr_t) blob->channel[hc->hc_num].index[0].buf;
11: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
drivers/usb/host/dwc_otg/dwc_otg_hcd.c: In function 'dwc_otg_hcd_disconnect_cb':
drivers/usb/host/dwc_otg/dwc_otg_hcd.c:292:16: warning: 'flags' may be used uninitialized in this function [-Wmaybe-uninitialized]
unsigned long flags;
CC net/sunrpc/timer.o
CC drivers/usb/host/dwc_otg/dwc_otg_hcd_linux.o
CC net/sunrpc/xdr.o
CC drivers/usb/host/dwc_otg/dwc_otg_hcd_intr.o
CC net/sunrpc/sunrpc_syms.o
CC net/sunrpc/cache.o
In file included from drivers/usb/host/dwc_otg/dwc_otg_core_if.h:36,
from drivers/usb/host/dwc_otg/dwc_otg_hcd_if.h:37,
from drivers/usb/host/dwc_otg/dwc_otg_hcd.h:39,
from drivers/usb/host/dwc_otg/dwc_otg_hcd_intr.c:35:
drivers/usb/host/dwc_otg/dwc_otg_hcd_intr.c: In function 'handle_hc_ahberr_intr':
15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
urb->buf, (void *)urb->dma);
drivers/usb/host/dwc_otg/../dwc_common_port/dwc_os.h:310:40: note: in definition of macro 'DWC_ERROR'
dwc_irq(), __func__, __LINE__, ## _args)
24: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
urb->setup_packet, (void *)urb->setup_dma);
CC drivers/usb/host/dwc_otg/dwc_otg_hcd_queue.o
CC drivers/usb/host/dwc_otg/dwc_otg_hcd_ddma.o
CC drivers/usb/host/dwc_otg/dwc_otg_adp.o
drivers/usb/host/dwc_otg/dwc_otg_hcd_ddma.c: In function 'init_non_isoc_dma_desc':
drivers/usb/host/dwc_otg/dwc_otg_hcd_ddma.c:623:20: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
hc->xfer_buff = (uint8_t *)qtd->urb->dma + qtd->urb->actual_length;
CC net/sunrpc/rpc_pipe.o
CC drivers/watchdog/watchdog_core.o
CC drivers/usb/host/dwc_otg/dwc_otg_fiq_fsm.o
CC net/sunrpc/svc_xprt.o
drivers/usb/host/dwc_otg/dwc_otg_fiq_fsm.c: In function 'fiq_increment_dma_buf':
drivers/usb/host/dwc_otg/dwc_otg_fiq_fsm.c:243:30: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
struct fiq_dma_blob *blob = (struct fiq_dma_blob *) st->dma_base;
drivers/usb/host/dwc_otg/dwc_otg_fiq_fsm.c:252:14: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
hcdma.d32 = (dma_addr_t) &blob->channel[n].index
.buf[0];
drivers/usb/host/dwc_otg/dwc_otg_fiq_fsm.c: In function 'fiq_iso_out_advance':
drivers/usb/host/dwc_otg/dwc_otg_fiq_fsm.c:292:30: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
drivers/usb/host/dwc_otg/dwc_otg_fiq_fsm.c:304:14: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
hcdma.d32 = (dma_addr_t) blob->channel[n].index.buf;
CC drivers/watchdog/watchdog_dev.o
