Brother TC 228.
john1987887
Re: Brother TC 228.
Сообщение john1987887 »
Servo drivers and spindle driver are from SZGH company?
zars
Настоящее имя: Andris
Re: Brother TC 228.
Сообщение zars »
Yes, 2600$ shipped.
zars
Re: Brother TC 228.
Сообщение zars »
https://www.youtube.com/watch?v=kvtY-77TSvA зажужала машинка...
zars
Re: Brother TC 228.
Сообщение zars »
Waiting for a controller.
20190624_161344.jpg (12680 просмотров) <a class='original' href='./download/file.php?id=165258&mode=view' target=_blank>Загрузить оригинал (6.64 МБ)</a>
john1987887
Re: Brother TC 228.
White VFD under spindle driver for what purpose?
Dimka
Настоящее имя: Дима
Re: Brother TC 228.
Сообщение Dimka »
On last video machine controlled with CSMIO by Mach3 or simCNC? What the new controller?
zars
Re: Brother TC 228.
Сообщение zars »
Little VFD ir for coolant pump. 3 Phase 200v.
Controller will be Adtech ADT-CNC9640.
zars
Re: Brother TC 228.
Сообщение zars »
Dimka писал(а):On last video machine controlled with CSMIO by Mach3 or simCNC? What the new controller?
Mach4
zars
Re: Brother TC 228.
Сообщение zars »
Getting closer to finish.
20190805_132230.jpg (11733 просмотра) <a class='original' href='./download/file.php?id=167264&mode=view' target=_blank>Загрузить оригинал (4.84 МБ)</a>
john1987887
Re: Brother TC 228.
Nice! ATC macro for the controller is made by you?
zars
Re: Brother TC 228.
Сообщение zars »
ATC is not done yet, that will be done by http://www.adtechcnc.co.uk/ guy. Just finished most of the wiring, soft limits, etc. Will try to machine round pocket later, to see how good or bad it is. So far controller looks not the easiest to set up, but good overall. Definitely far better than CSMIO.
zars
Re: Brother TC 228.
Сообщение zars »
zars
Re: Brother TC 228.
Сообщение zars »
Finally! Arduino doing the actual tool change. Adtech I/O action was too slow to deal with tool changer speed.
https://www.youtube.com/watch?v=4vYsvYj79pQ
john1987887
Re: Brother TC 228.
As i can see, you add raiser between spindle motor and the head. I just cut motor shaft with angle grinder, it was easier :)
zars
Re: Brother TC 228.
Сообщение zars »
We where trying to keep parts as stock as possible. Unfortunately had to open motor holes, as it is smaller than original one.
zars
Re: Brother TC 228.
Сообщение zars »
I need some help in finding, why holes are not coming out round. They are oval between X+ Y+ and X- Y- . The backlash is whitin 0.05mm on both axis, but 25mm comes out min.size 24.7mm, max size 25.1mm. Can it be controller, servo drive settings or anything else?
20191008_083255.jpg (9956 просмотров) <a class='original' href='./download/file.php?id=170127&mode=view' target=_blank>Загрузить оригинал (4.4 МБ)</a>
20191008_083233.jpg (9956 просмотров) <a class='original' href='./download/file.php?id=170128&mode=view' target=_blank>Загрузить оригинал (4.76 МБ)</a>
zars
Re: Brother TC 228.
Сообщение zars »
Oh, 20mm square came out as 20.05x20.05mm
john1987887
Re: Brother TC 228.
zars писал(а):Can it be controller, servo drive settings or anything else?
Check servo drive settings, such as position loop gain or something that sounds like that. You should increase this parameter. Or post a link to the manual for your drives, i will take a look.
zars
Re: Brother TC 228.
Сообщение zars »
Yeah, that helps a lot! Thank you.
nizamus
Настоящее имя: руслан
Re: Brother TC 228.
Сообщение nizamus »
Куплен у Евгения шпиндельный сервопривод Sanyo Denki. Работать будет от частотника unidrive m700. Отмыт от слоя мазутообразного чего то :hehehe: , подобран трансформатор для питания вентилятора охлаждения, отловлены каналы энкодера.
IMG_20200810_145021.jpg (5987 просмотров) <a class='original' href='./download/file.php?id=184824&mode=view' target=_blank>Загрузить оригинал (4.76 МБ)</a>
IMG_20200810_143957.jpg (5987 просмотров) <a class='original' href='./download/file.php?id=184823&mode=view' target=_blank>Загрузить оригинал (4.19 МБ)</a>
Все пока идет своим чередом.
Вопрос к знатокам синхронных машин
IMG-20200810-WA0014.jpg (5987 просмотров) <a class='original' href='./download/file.php?id=184825&mode=view' target=_blank>Загрузить оригинал (74.68 КБ)</a>
При вращении вала на одной фазе два полных периода. Метки в начале и конце - индексная метка энкодера. Можно ли сделать вывод на основании этих данных о том, что количество полюсов - шесть?
