Станок для гравировки ювелирки 2018
victornguyen
Настоящее имя: Victor Nguyen
Сообщение victornguyen »
How To Become A Complete Waldner Table Tennis Player In 5 Easy Steps
When you talk about Waldner Table tennis or Table tennis in general, you talk about Jan-Ove Waldner. The way that Michael Jordan synonymous with basketball is the way Jan-Ove Waldner plays table tennis. Jan-Ove Waldner was born in Stockholm in October 1965. He is very well known in China and is clearly in the Swedish homeland. The game's ping-pong style of Jave Waldner was impressed with table fans for more than three decades and this improved when he and some of his colleagues came to China to train. Read How to choice the best ping pong table outdoor on Amazon? to choose the best ping pong table for you.
To achieve becoming a leading and highly recognised Waldner Pong player is just not a only one step correction. But here's how to achieve that goal in 5 simple steps.
Step 1. You've got to become a complete ' All-Round ' Player. This can be really important because the title can be won, you have to master all the gameplay style. Therefore, you need to regularly exercise and compete with other players. Another important aspect is playing with the left-handed player. If you are going to succeed in this sport, you must learn how to play with both the right hand player. Now, this will require a well-developed technique and an extremely sturdy balance.. Unless you really do that step, you stand almost no chance against your opponent.
Step 2. Collect and develop skill points. It's probably a really crucial step that will need attention and your full focus. You need to do this way: work your Serves and track it with a different hand-handed arrangement. The main reason why you need this is because it is necessary to be in a position to win points easily and quickly. Choose table tennis racket pingpongstart.com is the best for you.
Step 3. Make sure you play a lot while you are young. The main reason why, simply because it's good to utilize the dexterity and coordination of a person's mobilization. Another important reason may be to continually try new strokes, in reality in the matches to sharpen and expand our imagination.
Step 4. Why not develop a relaxing technique. To build on that a little, being relaxed can increase your odds to be able to play calmly can even in tight conditions since the table tennis requires great practice.
Step 5. Make sure you learn good play. A further proposal, research and watch many video records as much as possible both themselves and other players, especially world-class players. Ping Pong as it is often known in the United States really requires you to study your true opponent.
Finally, if you want to benefit from increased speed of play, the agility is better, keeping better skills and improving the overall gameplay, then you need to act today. Follow the good tips and you will succeed and take advantage of the achievement of your success! Choose a table tennis robot to the best practice.
Последний раз редактировалось victornguyen 25 фев 2019, 18:08, всего редактировалось 2 раза.
inFamous
Re: Станок для гравировки ювелирки 2018
Сообщение inFamous »
victornguyen писал(а):Добрый день!
Прошу совета=) Нужен станок для гравировки ювелирки серебро, золото, может сталь (ножи). В основном текст "Я тебя люблю!" в различных вариациях.
Рабочее поле 100 на 100мм, по Z тоже не большой.
Можно построить на механике от струйных принтеров (направляющая 8мм и ШД) и строительной шпильке что-нибудь стоящее?
Денег пока только на контроллер Есть капролон, дремел, руки чуть мозга. Опыта нет.
Ну вот, хотите гравировать золото, а денег только на контроллер. Могу сказать только одно - те станки, что продают на территории СНГ под видом ювелирных - лютое говно в массе своей, не стоящее своих денег, даже не думайте брать, Стриж, например.
moscow
Настоящее имя: Олег Милантьев
Сообщение moscow »
cnc 1610 на али. Мне обошёлся в 8500р с доставкой.
Мой первый станок :)
Ежли очень не торопясь, отцарапает всё!
niksooon
Сообщение niksooon »
moscow писал(а):Ежли очень не торопясь, отцарапает всё!
вот в том-то и дело что отцарапает........ за такую работу можно слегка и по мордасам схлопотать от восторженного клиента........
moscow
Сообщение moscow »
niksooon писал(а):за такую работу можно слегка и по мордасам схлопотать от восторженного клиента........
Личный опыт?
2018_02_05_8573.jpg (2341 просмотр) <a class='original' href='./download/file.php?id=150217&mode=view' target=_blank>Загрузить оригинал (2.54 МБ)</a>
У меня был 1610, нормально он гравирует пластики и дюраль.
Медь гравирует отлично (платы на нём резал).
Золото не пробовал, заготовку не нашёл в шкафу :)
Ну как бы стоит соотносить оборудование для обычных металлов и драг. металлов. Конечно можно и на таком попробовать гравировать если есть лишние деньги. Ведь если испортил заготовку значит купил ее (по сути получается испортил заготовку - купил еще станок :) так как ценник немалый).
moscow
Сообщение moscow »
Я точно знаю, что есть предел вкуса конфет, которые можно слепить из г.
Так же я видел этот станок в деле и готов утверждать, что он не идеален, но с задачей медленной и неторопливой гравировки он справляется.
А главное, что он справляется с задачей учебно-образовательного стенда, полностью отвечающего на вопрос "что такое ЧПУ фрезерно-гравировальный станок". Вовсе не обязательно, не набив руку, сразу подставлять морду :)
Din
Настоящее имя: Саша
Сообщение Din »
moscow писал(а):Так же я видел этот станок в деле и готов утверждать, что он не идеален, но с задачей медленной и неторопливой гравировки он справляется.
Этого никто не оспаривает.Сделай макрофото и растяни потом снимок ну хотя бы на 19" мониторе,увидишь много чего интересного в плане чистоты обработки поверхности.
