Сохранение координат после выключения.
- Loituma
Помню, что где то в ини прописать надо, а где и что не помню, подскажите Уважаемые.
Re: Сохранение координат после выключения.
POSITION_FILE = position.txt - If set to a non-empty value, the joint positions are stored between runs in this file. This allows the machine to start with the same coordinates it had on shutdown. This assumes there was no movement of the machine while powered off. If unset, joint positions are not stored and will begin at 0 each time LinuxCNC is started. This can help on smaller machines without home switches.
http://linuxcnc.org/docs/2.7/html/confi ... aj_section
- Loituma
спасибо таки
