Inkscape Gcodetools plug-in English support forum
What function should we develope next?
Результаты голосования
Generated Gcode in EMC2 (1471543 просмотра) <a class='original' href='./download/file.php?id=508&mode=view' target=_blank>Загрузить оригинал (21.99 КБ)</a>
TypeExtension of vector
graphics editor Inkscape
DeveloperGcodetools develop team
Written inPython
OSCross-Platform (Windows, Linux, MacOS)
Version1.6.03
LicenseGNU GPL
Downloads7800+
Gcodetools
Gcodetools is a plug-in for Inkscape. It prepares and converts paths from Inkscape to Gcode, using biarc interpolation.
This article is unfinished. You can help cnc-club expanding it.
Screenshots and photos are needed. Please post them at this thread.
Features (для просмотра содержимого нажмите на ссылку)
Features
Preview of the generated Gcode in EMC (1474467 просмотров) <a class='original' href='./download/file.php?id=130&mode=view' target=_blank>Загрузить оригинал (154.76 КБ)</a>
Gcodetools area pocketing (1460570 просмотров) <a class='original' href='./download/file.php?id=772&mode=view' target=_blank>Загрузить оригинал (147.75 КБ)</a>
Gcodetools lathe (1466891 просмотр) <a class='original' href='./download/file.php?id=642&mode=view' target=_blank>Загрузить оригинал (21.98 КБ)</a>
Gcodetools lathe
Gcodetools engraving by Rene (1467056 просмотров) <a class='original' href='./download/file.php?id=631&mode=view' target=_blank>Загрузить оригинал (233.84 КБ)</a>
Bears by Durachko (1402514 просмотров) <a class='original' href='./download/file.php?id=5429&mode=view' target=_blank>Загрузить оригинал (89.93 КБ)</a>
Bears by Durachko
Export to Gcode
  • Export paths to Gcode
  • Using circular (biarc approximation) or straight line interpolation
  • Automatic path subdivision to reach defined tolerance
  • Multiply tool processing
  • Export Gcode in parametric of flat form
  • Including personal headers and footers
  • Choosing units
  • Multi-pass processing
  • Numeric suffix is added to generated files to avoid overwriting
Lathe Gcode
  • Compute trajectories for lathe
  • Fine cut
  • Define fine cut's depth
  • Define fine rounds
  • Two different computation functions for fine cut
  • Standard axis remapping
Path's area processing
  • Building area paths
  • Area paths could be modified
Engraving
  • Building trajectory according to the cutter's shape
  • Defining different cutter's shapes
Tool's library
  • Defining different tool's parameters (diameter, feed, depth step, penetration feed, personal Gcode before/after each path, cutters shape, personal tool's changing Gcode)
  • Tools can be managed by Inkscape's standard procedures (copy, delete, assigned to different layer)
  • Multiply tools processing
Orientation system
  • Applying scale along any axis
  • Apply rotate in the ХY plane
  • Apply translation along any axis
  • Apply transforms according to arbitrary points
Post-processor
  • You can create custom post-processor by writing down the commands or choose from the list of default post-processors
  • Scale and offset Gcode
  • Gcode commands remapping
  • Parameterize Gcode
  • Round floating point values to specified precision
Verifying tools for the scene
  • Select and remove small paths (area artefacts)
  • Tool's alignment check
  • Cutting order check
Plotter cutting
  • Export to Gcode for plotter with tangential knife. Forth axis A is knife's rotation.
Install (для просмотра содержимого нажмите на ссылку)
Install
Windows
Unpack and copy all the files to the following directory Program Files\Inkscape\share\extensions\ and restart inkscape
Linux
Unpack and copy all the files to the following directory /usr/share/inkscape/extensions/ and restart inkscape
Screenshots (для просмотра содержимого нажмите на ссылку)
Screenshots
Gcodetools plug-in tutorial (2600*1300 px png ~ 700Kb) (1474470 просмотров) <a class='original' href='./download/file.php?id=127&mode=view' target=_blank>Загрузить оригинал (752.7 КБ)</a>
Curve to Gcode result (1474476 просмотров) <a class='original' href='./download/file.php?id=103&mode=view' target=_blank>Загрузить оригинал (1023.52 КБ)</a>
Get latest version (для просмотра содержимого нажмите на ссылку)
Get latest versions
Latest stable version Gcodetools 1.7
gcodetools.tar.gz
Gcodetools 1.7
(75.25 КБ) 104330 скачиваний
Older versions(ver 1.5)
gcodetools-1.6.tar.gz
Gcodetools 1.6
(56.6 КБ) 16562 скачивания
(ver 1.5)
gcodetools.tar.gz
Gcodetools 1.5
(21.32 КБ) 12151 скачивание
(ver 1.4)
gcodetools.tar.gz
(14.72 КБ) 29044 скачивания
(ver 1.2)
extensions.tar.gz
(9.01 КБ) 11887 скачиваний
Dev-version
You can try the newest development version by getting it from github repository https://github.com/cnc-club/gcodetools via web interface or using git clone git@github.com:cnc-club/gcodetools.git .
You'll need to run python create_inx.py to create inx files. After that install procedure is the same with the stable version.
Translations
Gcodetools is included into Inkscape v 0.49 so it will have native translations as other Inkscape's extensions. Until it is released you can use some self made translation packs:
Credits (для просмотра содержимого нажмите на ссылку)
Credits
Developers:
  • Nick Drobchenko (Nick)
  • Vladimir Kalyaev (Dormouse)
  • Henry Nicolas (Alfcnc)
Translators:
  • John Brooker (greybeard from cnczone.com)
Develop (для просмотра содержимого нажмите на ссылку)
Develop
At the moment following features are being developed:
  • Plasma cutter extension
  • Turning lathe extension
  • Plotter extension
You can help us improve Gcodetools in several ways
  • Writing a report / bug report
  • Improve help and manuals
  • Publish G-codes / SVGs / other code
  • Publish photos / videos
  • Make a bug report
  • Help develop new features
  • Suggest a new feature
Tested on (для просмотра содержимого нажмите на ссылку)
Tested on
Linux
Ubuntu 9.10 14.04 + inkscape 0.48 (older Gcodetools versions also work with 0.46, 0.47)
Windows
Windows XP, Windows Vista, Windows 7 + inkscape 0.46, inkscape 0.47
MacOS
There are some reports on successful work on MacOs.
alfcnc
Заслуга: Tester
Re: Inkscape Gcodetools plug-in English support forum
Сообщение alfcnc »
For don't lose precision I've see that you put all the with to 0.00 when do offset or area trace..
So i put with of the original path to 0.00 before Stroke to path Ctrl+alt+c and Union and this give good result..
But always no solution to have just outside or inside without doing another boolean after this...
Sorry for not answering for 2 days, I was out of Russia so I was not able to check the forum.
As for the DXF import. I've faced the same problem some weeks ago. It happens because the path is imported divided into the segments. If you try to break it apart with Ctrl+Shift+K, you'll see a lot of small segments.
I've made a small extension to fix it.
But when I've announced it on the linuxgraphics.ru I was told a better solution.
1. Select all the paths.
2. Go to node editing mode F2. And select all the nodes Ctrl+A.
3. Press the button to all separate nodes into one node. This one:
join nodes inkscape dxf import.png (681 байт) 7280 просмотров
So my extension is pointless :lol:.
The latest version is in the first post of this thread. And gcodetools.py file should have this lines at the top:
###		Gcodetools v 1.6.04
gcodetools_current_version = "1.6.04"
Encoding problem:
Try to put these lines into gcodetools.py (at the top):
#!/usr/bin/env python
# -*- coding: utf-8 -*-
instead of
If it fixes the problem I'll add it to mainstream.
alfcnc
Заслуга: Tester
Сообщение alfcnc »
For the node joining ! I'll have ever test this method for that's don't work....
It's logical because the join node is just for terminal node ...and if I do select all , middle node are select too and the tool d'ont work....
For it work i must select terminal node manually one by one... very very long work...
I think your extension is not so pointless...
I've just tried it on your path. Select path, F2, Ctrl+A and join.
Works fine:
test_area.svg
(13.44 КБ) 996 скачиваний
What Inkscape version do you have?
Here's my extension if join nodes method does not work:
join_paths.tar.gz
(1.96 КБ) 1409 скачиваний
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Ok !
On inkscape 0.47 that's don't work but on 0.48 Yes works great... and I haven't test this method on 0.48...
very very sad for me ! I'll ve won many hours of works...
Thanks for the extension i'll test it on 0.47 , because it's good for those are always on 0.47
For the encoding !
I have done the change and this don't work... and finally I'm don't know if that come from that..
Because a the end of the error lxml.etree say Document is empty.... so the problem come before lxml work... I'll must set debug mode to find were this crash...
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Ok !
Your extension Joinpath work very well on 0.47.0-2+b1 on Debian...
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Could you give some indication how to debug to try to find were is the problem...
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Hi !
I'll ve path to gcode some path...i'll have a Z safe of 20mm and cuting depht of 5 with Z step of 1...
I path to gcode with ver 1.6.04...
testplunge.svg
(57.51 КБ) 1080 скачиваний
this give me :
testplunge_0001.ngc
(33.47 КБ) 1419 скачиваний
First problem... the plunge speed is set by the tool definition! it's ok.
But when the tools goes from 20mm high to the material the plunge speed must be G00 or it's
G01 all the plunge...
So it's must be go to speed G00 from Z Top rapid move position to Z cut position and then start Cut depth speed...
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Another problem his if put multiple path whit step plunge cut...
It do first pass of each path and the second one... logical will be make all the pass of one path and
all the cut pass of the others...
If setting all path with a different layer that's make with this order...but curious things... until all depth
cut path the tool return to the Z G00 safe position... interesting when doing drilling but not for milling...
I've see that in dev version you have set some option to choose different logic of cutting pass...well to see.
Hmmmm...
It goes from 20mm to Zcut position with the penetration speed. It's set so because it could be unsafe to go toward the surface at rapid speed.
You can reduce safe distance to reduce the time it takes to penetrate. Or make an replace
"G01 Z[0-9\-\.]+ F100.0" to "G00 Z0 \n \0" using regex.
Also you cat automate this procedure by using post-processor.
To debug what's wring with the lxml try to change inkex.py parse function from /usr/share/inkscape/extensions to something like:
   def parse(self,file=None):
        """Parse document in specified file or on stdin"""
    f = open("/home/user/out.txt",'w')
        try:
            try:
                stream = open(file,'r')
                f.write("File from func param %s"%file)
            except:
                stream = open(self.svg_file,'r')
                f.write("File from arg %s"%self.svg_file)
        except:
            stream = sys.stdin
            f.write("File from stdin ")
        f.write("\n\n")
		f.write(stream.readlines())
		f.close()
Replace /home/user to your home dir.
And then look in the out.txt for stream contents.
Yes dev version has some options to order the paths. But still it would go up and down each pass. You can get rid of it by the regex replace/
alfcnc
Заслуга: Tester
Сообщение alfcnc »
"It goes from 20mm to Zcut position with the penetration speed. It's set so because it could be unsafe to go toward the surface at rapid speed. "
Ok ! but i found this very very curious because the cnc is made for don't error on positionning even if go to G00 speed...So if you have take care of your material width accuracy you set the orientation point with a Z depth that take this security into account...and then you can go to G00 to the top of your material to be cutting...
Thank's for the solution regex and postprocessor...
By unsafe I mean there's could be something in the cutters way. Gcodetools does not know anything about the surface except it's path. And it knows that it can move at rapid speed at the safe distance above the surface. So anything below the safe distance should be assumed as "probably cutting" so it should be done with G01. And when it goes down from the safe distance it actually "probably penetrates", so this move should be done at the penetration speed.
That's how I see it.
alfcnc
Заслуга: Tester
Сообщение alfcnc »
root писал(а):Hmmmm...
        try:
            try:
            except:
        except:
            stream = sys.stdin
        f.write("\n\n")
		f.close()
Hum ! I don't understand i have indent error on line with the first " try: "
I have try to change indentation but no result ???
upsss add some spaces before f = open("/home/user/out.txt",'w') to match try.
Look at the /home/user/out.txt. Post it here.
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Yes ok ! some space here and some on others line...
After try a Pathtogcode the file output contain:
File from arg /tmp/ink_ext_XXXXXX.svg60FNRV
The gcodetools traceback in Inkscape:
File "/usr/share/inkscape/extensions/gcodetools.py", line 4602, in <module>
e.affect()
File "/usr/share/inkscape/extensions/inkex.py", line 221, in affect
self.parse()
File "/usr/share/inkscape/extensions/inkex.py", line 156, in parse
TypeError: argument 1 must be string or read-only character buffer, not list
And the file in tmp is the copy of the file svg i am using in inkscape...
Последний раз редактировалось alfcnc 28 фев 2011, 18:25, всего редактировалось 1 раз.
replace f.write(stream.readlines())
with:
for i in stream.readlines() :
f.write(i)
alfcnc
Заслуга: Tester
Сообщение alfcnc »
Done : Give traceback:
e.affect()
File "/usr/share/inkscape/extensions/inkex.py", line 223, in affect
self.getposinlayer()
File "/usr/share/inkscape/extensions/inkex.py", line 162, in getposinlayer
self.current_layer = self.document.getroot()
AttributeError: 'NoneType' object has no attribute 'getroot
And the output.txt i set in file because long...
debuggcodetools.txt
(12.71 КБ) 1395 скачиваний
alfcnc
Заслуга: Tester
Сообщение alfcnc »
I think start a post for the making of post processor...do you agree...?
Have you some start point to tell me for that ?
It's strange. Why lxml thinks that the tree is empty when it's not...
I'll got to think about it some more :think:
Post-processing theme was opened a while ago:
http://cnc-club.ru/forum/viewtopic.php?f=33&t=78
alfcnc
Заслуга: Tester
Сообщение alfcnc »
excuse me ! I'haven't see it ...
Вернуться в «English forum»
