UAVpilot писал(а):в конфиге самбы включи отладку
гдеж ты раньше был
во чего пишет (для просмотра содержимого нажмите на ссылку)[2012/08/01 18:38:49.492815, 5] auth/auth_util.c:211(make_user_info_map)
Mapping user []\[] from workstation [MARINA]
[2012/08/01 18:38:49.492855, 5] auth/auth_util.c:232(make_user_info_map)
Mapped domain from [] to [NAS] for user [] from workstation [MARINA]
[2012/08/01 18:38:49.492873, 5] auth/auth_util.c:122(make_user_info)
attempting to make a user_info for ()
[2012/08/01 18:38:49.492889, 5] auth/auth_util.c:132(make_user_info)
making strings for 's user_info struct
[2012/08/01 18:38:49.492905, 5] auth/auth_util.c:164(make_user_info)
making blobs for 's user_info struct
[2012/08/01 18:38:49.492921, 10] auth/auth_util.c:182(make_user_info)
made an encrypted user_info for ()
[2012/08/01 18:38:49.492938, 3] auth/auth.c:216(check_ntlm_password)
check_ntlm_password: Checking password for unmapped user []\[]@[MARINA] with the new password interface
[2012/08/01 18:38:49.492956, 3] auth/auth.c:219(check_ntlm_password)
check_ntlm_password: mapped user is: [NAS]\[]@[MARINA]
[2012/08/01 18:38:49.492972, 10] auth/auth.c:228(check_ntlm_password)
check_ntlm_password: auth_context challenge created by random
[2012/08/01 18:38:49.492988, 10] auth/auth.c:230(check_ntlm_password)
challenge is:
[2012/08/01 18:38:49.493191, 3] auth/auth.c:265(check_ntlm_password)
check_ntlm_password: guest authentication for user [] succeeded
[2012/08/01 18:38:49.493212, 5] auth/auth.c:304(check_ntlm_password)
check_ntlm_password: guest authentication for user [] -> [] -> [nobody] succeeded
[2012/08/01 18:38:49.493229, 5] auth/auth_util.c:2119(free_user_info)
attempting to free (and zero) a user_info structure
[2012/08/01 18:38:49.493245, 10] auth/auth_util.c:2123(free_user_info)
structure was created for
[2012/08/01 18:38:49.493757, 10] auth/auth_util.c:753(create_local_token)
Could not convert SID S-1-1-0 to gid, ignoring it
[2012/08/01 18:38:49.493829, 10] auth/auth_util.c:753(create_local_token)
Could not convert SID S-1-5-2 to gid, ignoring it
[2012/08/01 18:38:49.493901, 10] auth/auth_util.c:753(create_local_token)
Could not convert SID S-1-5-32-546 to gid, ignoring it
[2012/08/01 18:38:49.493923, 10] auth/token_util.c:531(debug_nt_user_token)
NT user token of user S-1-5-21-1734920027-3087388298-3064130432-501
contains 5 SIDs
SID[ 0]: S-1-5-21-1734920027-3087388298-3064130432-501
SID[ 1]: S-1-1-0
SID[ 2]: S-1-5-2
SID[ 3]: S-1-5-32-546
SID[ 4]: S-1-22-1-65534
SE_PRIV 0x0 0x0 0x0 0x0
[2012/08/01 18:38:49.493989, 10] auth/token_util.c:551(debug_unix_user_token)
UNIX token of user 65534
Primary group is 65534 and contains 0 supplementary groups
NAS - сервер
MARINA - комп с XP
раньше писало как всегда - unknown ror
изменил smbpasswd на такой-же как на винде - стало пускать в паблик папку, но в секрепную - никак
вижу что меня мапит на гостя.
