Hi,
now that I got my first test project done I'd like to get a bit more ambitious, also concerning to material. Therefore, i'd like not to mill the whole thing at once but in several layers. Is there any way to do this with gcodetools?
engraving multiple layers
narvf
- Кандидат
Re: engraving multiple layers
Can you explain more what would you like to do?
Example file with two layers is here:
http://e-rr.pl/cnc/files/wyciecie_oraz_grawer.svg
Is this what you were asking?
tecdroid
- Новичок
I just don't want to mill 6mm depth at once but maybe going over my path three times, 2mm depth each..
narvf
- Кандидат
So if you set for example z-Depth (when adding orientation points) to -6mm, now you have to set "depth step" to "2" in tool options i.e. in this greeen recatangle on tool that you added. This will make 3 passess each for 2 mm. Hope that helps
