Problem with dimensions
Добавлено: 13 дек 2014, 03:30
narvf
I have a problem with dimensions after cutting something from linuxcnc. Let's say i have a shape 40x25mm, with 3.175 tool diameter. So in inkscape i draw shape 43.175 x 26.3175. After cutting it one time is 0.2mm smaller in longer side and almost 1mm smaller in shorter side, but each pass in depth is the same, in meaning that path is covered by before path when cutting in depth. I don't know what to do now. Object is always smaller. It's like a lottery... I checked my machine, i think it is ok, everythig is straight and correctly mounted. Week ago it was all ok, it started suddenly few days ago. I didn install any updates in linuxnc (debian).
Step in driver board changed from 1/5 to 1/16 and in config also.
