Problem:
felixbeck
Настоящее имя: Felix Beck
Problem:
Сообщение felixbeck »
Dear Nick,
unfortunately I get different results with Gcodetools concerning the geometry using the same CAD data in two different files:
- The first file covers an area of 1200x2200mm but generates Gcode aproxximately 114x2100mm (top right: rect3905). This is really strange!
- The second file contains a rectangle with the size of 1200x2200mm and the geometry is generated correctly!
- Third file: when the first file is imported into the second file which contains allready a rectangle with the size of 1200x2200mm the geometry is reduced to 114x2100mm!
Could you please be so kind as to help me with this Problem?
Thank you very much in advance,
with best regards,
Felix
file_1.svg
(325.3 КБ) 1196 скачиваний
file_2.svg
(50.67 КБ) 1080 скачиваний
file_3.svg
(595.04 КБ) 1128 скачиваний
output_0001.ngc
(41.84 КБ) 1577 скачиваний
output_0002.ngc
(685 байт) 1646 скачиваний
output_0003.ngc
(42.29 КБ) 1549 скачиваний
Вернуться в «English forum»
