suggessting extension: inner/outer edge
Добавлено: 26 ноя 2014, 15:20
hi,
right after i wrote my post on crown gears i got the idea that one should write an extension which creates a milling edge around the inner or outer edge of an object depending on the tool width.
that plugin would create another object (just like it's done with the area) which surrounds the original object. this would give me the ability to work witch much more precision.
since i never wrote an inkscape extension i'd say i'm unable to do this
so.. can u?
