цена 25000р отправлю ТК по России
Пишите пожалуйста на почту здесь бываю редко 3dpaskal {} gmail.com
Диаметр шпинделя 52мм
Technical Parameters
1) Machine Dimensions: 540×410×320mm5 (not including the coupling and motor)
2) Table size: 525x320mm,Groove width: 7.5mm
3) Rack material:6061-T5,high strength, through the CNC machining center precision machining, all of the surface after anodic oxidation treatment.
4) 3Axis effective stroke: X290mm, Y390mm, X60mm
5) Z-axis Stroke:55mm,Engraving depth depends on the length of the tool edge
6) Max workpiece thickness:≤70mm
7) Rail type: Chromeplate shaft+Linear Bearings(Surface hardening 61HRC)
8) Transmission unit: X axis diameter 16mm chrome plated linear guide, TBI1204 ball screw;Y axis diameter 16mm chrome plated linear guide, TBI1204 ball screw;Z axis diameter 12mm chrome plated linear guide, TBI1204 ball screw;
9) Repeat positioning Accuracy: 0.05mm
10) Net weight: 17.5kg
