Страница 1 из 1
Top mini e-boards for electric skateboard lovers
Добавлено: 23 дек 2021, 17:51
dagmarsawayn
Are you looking for a mini electric skateboard? You are probably also interested in it because you are reading this blog post of mine. Mini electric skateboards are both convenient and compact, making them easy to carry anywhere. There are many types of quality, but today I have compiled only the top 5 e-boards. See which skateboard is right for you. I very much look forward to that. And now let's get started with the first esk8!
Exway Wave
This is one of those boards that are durable and easy to customize. With high application technology, it is very suitable for those who want to use it for safe driving purposes such as going to school, work, or walking around town.
With quality articles on electric skateboards over the years, Dario Yore deserves to be the top author of electric skateboards. Follow this author to read the best quality articles!
With a fairly light weight of only 15lbs / 6.9kg, you can easily take it with you or put it on the train. The special thing is that it has 2 separate types of motors 2x 800W (Hub) and 2x 1000W (Riot). You can choose the engine that suits you personally as it also does not affect the top speed of 23.6mph / 38kph. However, the maximum range with the slight difference is Hub 12.4 miles/20km, compared to Riot's 11 miles/18km.
Another point is that the deck has a recess with shock-absorbing tape, so your ride is extremely soft and smooth. Usually, this will not be available on cheaper e-boards. And its price is $749. A bit pricey but worth it for the features above.
Verreal Mini
Unlike the electric skateboard I just reviewed above, this is a very cheap type that is suitable for many budgets of many people as well as being much more compact and lighter in weight. For just $339, half the price of Exway Wave.
This e-board features dual 250W motors that can reach rates of up to 25mph/40kph and climb mountains up to 30 percent of the mountain height, so it's not for the faint of heart. What do you think when this esk8 has such an affordable price with such great features?
You can also choose the battery type that corresponds to the range you want to go: the standard 4.0Ah battery has a distance of up to 10 miles, whereas the 6.0Ah battery has a distance of up to 16 miles.
With a stylish fishtail design composed of super light and incredibly sturdy case material, the deck is not only strong and hard but also very unique and personal.-->>> many other articles about mini electric skateboard that you can refer to at eSkateBuddy, Refer to eskatebuddy's address: See eskatebuddy's address: 121 W Wacker Dr, Chicago, IL 60601, United States.
This type, as I just said, is that with cheap mini e-boards, there is usually no shock-absorbing tape and of course, it does not.
Maxfind Max Pro 2
For about $840, you can already own an e-board with a pretty and popular design. If it's too expensive for you, you can check it out at reputable sites that have that discount. This type I would recommend for newbies because the speed is moderate and not too fast.
Not that it is slow because the top speed is up to 24mph / 38kph and 15 miles / 24km. The 2x 600W hub motor is extremely powerful and the 90mm wheels don't shy away from any terrain.
The deck, which is of nylon and fiberglass and covers all of the electronics inside the deck, has a high hardness and durability. This reduces the risk of scratching or breaking components and decks.
The disadvantage is that, while it isn't cheap, it lacks a shock-absorbing grip tape.
Teamgee H20 Mini
This type is a cruiser so when surfing you will feel like you are surfing and suitable for the sea atmosphere. This one costs $599 - a price that's neither too expensive nor too cheap, isn't it?
With a fairly light weight of only 16lbs / 7.5kg, you can take it anywhere and it is not too cumbersome to leave this e-board.
Despite its small size, the board has a top speed of 24mph/38kph and achieves a range of up to 18 miles/30km. This speed is suitable even for those who are just starting to use electric boards. In addition, 2x 450W hub motors on a single charge with a battery capacity of 7.5Ah.
The deck is made from Canadian maple and the 80mm wheels make it suitable for riding on flatter terrain. Usually, cruiser boards focus on rear design, so they provide the rider with more control while driving, easier to ride than standard electric skateboards.
Ownboard Mini KT
This is one of the standard electric skateboards suitable for commuting trips.
Laminate flooring enjoys strong and stable 8 layers and 90mm 78A, even if you go in many holes or uneven road surfaces, this esk8 will not be difficult. And a top speed of 25mph/40kph and a range of up to 12 miles/18.5km give you a fast, smooth yet safe ride.
Picked For You >> best mini electric skateboard 2022
Alternatively, you can also choose a higher-end battery to increase the e-board's range up to 19 miles/30.5km. One thing to note is that for people over 220lbs, you need to consider when buying this esk8. Since it is mini, it is not suitable for this weight.
The design is quite simple but has a unique fishtail and is also suitable for traveling at sea. Its price is lower than the Teamgee H20 Mini at $409. You can consider one of these 2 esk8 cruisers.
Re: Ответ на вопрос: перекос осей/ разные размеры по осям.
Добавлено: 23 дек 2021, 18:04
rry
причин перекоса осей может быть миллион. сталкивался с самыми разными, от люфта в разных частях станка до люфта кривых рук оператора станка...
самой для меня сложноуловимый случай был в казалось бы идеально настроеном 3-х осевом фрезере, это ненастроеные моменты инерции серводрайверов, пока он стоит или руками катаешь - всё идеально, а как включешь привода - начинается перекос
