Gcodetools in Inkscape Graffiti Problem
Добавлено: 18 май 2020, 00:34
karboskitos
Рабочее поле:
Обрабатываемые материалы:
Чертежи, фото, видео станка:
Примеры изделий (фото):
Вопросы:
Что пробовал:
Что плучилось:
Что не получилось:
Ориентировочный бюджет:
Hello I'm just make the "Polargragh" Project
so when I tried to get a gcode to drive the machine, a problem has appeared
I used Graffiti from the menu extensions and put all points
first I put graffiti points (x,y) and then the 0 offset point
but after that a massege has appeard after hit on apply
the massege :
Cutting tool has not been defined! A default tool has been automatically added.
File "gcodetools.py", line 6751, in <module>
gcodetools.affect()
File "inkex.py", line 289, in affect
self.effect()
File "gcodetools.py", line 6691, in effect
self.graffiti()
File "gcodetools.py", line 6579, in graffiti
draw_csp(self.transform_csp([csp],layer,reverse=True), color = "#00cc00;" if polyline_[0]=='draw' else "#ff5555;")
TypeError: draw_csp() got an unexpected keyword argument 'color'
do you have a solution please try to respond me as soon as you can
thanks in advance
