CNC 2417 проблема с возвращением в нулевую позицию.
Добавлено: 03 май 2019, 00:21
Здравствуйте.
Помогите пожалуйста со станком cnc 2417 , станок не возвращается в нулевую позицию.
При при обнулении позиции X,Y, программа Candle в консоль выводит:
G92X0Y0 < ok
$# < [G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:14.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
После перемещения по этим осям и нажатии кнопки домой, программа выводит в консоль :
$H < error: Setting disabled
S0 < ok
Естественно станок остается в исходном положении и не возвращается в нулевую позицию.
Вот настройки $$:
$0=10 (step pulse, usec)
$1=255 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=4 (dir port invert mask:00000100)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=1 (status report mask:00000001)
$11=0.010 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$24=25.000 (homing feed, mm/min)
$25=500.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$100=800.000 (x, step/mm)
$101=400.000 (y, step/mm)
$102=400.000 (z, step/mm)
$110=1200.000 (x max rate, mm/min)
$111=1200.000 (y max rate, mm/min)
$112=600.000 (z max rate, mm/min)
$120=50.000 (x accel, mm/sec^2)
$121=50.000 (y accel, mm/sec^2)
$122=50.000 (z accel, mm/sec^2)
$130=400.000 (x max travel, mm)
$131=400.000 (y max travel, mm)
$132=400.000 (z max travel, mm)
ok
Версия GRBL 09J.
Буду очень признателен за помощь.
G92X0Y0 < ok
[TLO:0.000]
ok
S0 < ok
Вот настройки $$:
ok
Версия GRBL 09J.
