7I92+7I77
Techno
7I92+7I77
Сообщение Techno »
Доброго времени суток.
НЕ могу настроить данную связку 7I92+7I77.
заранее спасибо
Kernel
cnc@lathe:~$ uname -a
Linux lathe 3.2.0-6-rt-686-pae #1 SMP PREEMPT RT Debian 3.2.102-1 i686 GNU/Linux
cnc@lathe:~$ mesaflash --device 7i92 --verbose
ETH device 7I92 at ip=192.168.1.121
Communication:
transport layer: ethernet IPv4 UDP
ip address: 192.168.1.121
mac address: 00:60:1B:13:04:01
protocol: LBP16 version 3
Board info:
Flash size: 16Mb (id: 0x14)
Connectors count: 2
Pins per connector: 17
Connectors names: P2 P1
FPGA type: xc6slx9
Number of leds: 4
Board firmware info:
memory spaces:
0: HostMot2 (registers, RW, 32-bit) [size=64K]
1: KSZ8851 (registers, RW, 16-bit)
2: EtherEEP (EEPROM, RW, 16-bit) , page size: 1, erase size: 1
3: FPGAFlsh (flash, RW, 32-bit) [size=16M], page size: 256, erase size: 65536
4: Timers (memory, RW, 16-bit)
6: LBP16RW (memory, RW, 16-bit)
7: LBP16RO (memory, RO, 16-bit)
[space 0] HostMot2
[space 2] Ethernet eeprom:
ip address: 10.10.10.10
board name: 7I92
user leds: eth debug
[space 3] FPGA flash eeprom:
flash size: 16Mb (id: 0x14)
[space 4] timers:
uSTimeStampReg: 0xC7AB
WaituSReg: 0x0000
HM2Timeout: 0x0000
[space 6] LBP16 control/status:
packets received: all 311, UDP 49, bad 0
packets sended: all 52, UDP 49, bad 0
parse errors: 0, mem errors 0, write errors 0
error flags: 0x0000
debug LED ptr: 0x0008
scratch: 0x0000
[space 7] LBP16 info:
board name: 7I92
LBP16 protocol version 3
board firmware version 15
IP address jumpers at boot: fixed 192.168.1.121
Linux Cnc errors
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/cnc/linuxcnc/configs/4'
Machine configuration file is '4.ini'
INIFILE=/home/cnc/linuxcnc/configs/4/4.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting HAL User Interface program: halui
Found file(REL): ./4.hal
hm2: loading Mesa HostMot2 driver version 0.15
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:13:04:01
hm2_eth: discovered 7I92
board fails HM2 registration
Running HAL shutdown script
Killing task linuxcncsvr, PID=3960
hm2: unloading
Debug file information:
Note: Using POSIX realtime
iptables: No chain/target/match by that name.
hm2/hm2_7i92.0: error reading Module Descriptor 3 (at 0x0464)
hm2_eth: rtapi_app_main: Input/output error (-5)
./4.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth
./4.hal:8: /usr/bin/rtapi_app exited without becoming ready
./4.hal:8: insmod for hm2_eth failed, returned -1
3960
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.2.0-6-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 4.9.2 (Debian 4.9.2-10+deb7u1) ) #1 SMP PREEMPT RT Debian 3.2.102-1
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[    0.000000]  BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 000000003f790000 (usable)
[    0.000000]  BIOS-e820: 000000003f790000 - 000000003f79e000 (ACPI data)
[    0.000000]  BIOS-e820: 000000003f79e000 - 000000003f7e0000 (ACPI NVS)
[    0.000000]  BIOS-e820: 000000003f7e0000 - 000000003f800000 (reserved)
[    0.000000]  BIOS-e820: 00000000ffb80000 - 0000000100000000 (reserved)
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.3 present.
[    0.000000] DMI: ASUSTek Computer INC. P5GZ-MX/P5GZ-MX, BIOS 0707    07/09/2007
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[    0.000000] last_pfn = 0x3f790 max_arch_pfn = 0x1000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-DFFFF uncachable
[    0.000000]   E0000-EFFFF write-through
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask FC0000000 write-back
[    0.000000]   1 base 03F800000 mask FFF800000 uncachable
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] found SMP MP-table at [c00ff780] ff780
[    0.000000] initial memory mapped : 0 - 01a00000
[    0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[    0.000000] init_memory_mapping: 0000000000000000-00000000379fe000
[    0.000000]  0000000000 - 0000200000 page 4k
[    0.000000]  0000200000 - 0037800000 page 2M
[    0.000000]  0037800000 - 00379fe000 page 4k
[    0.000000] kernel direct mapping tables up to 379fe000 @ 19f9000-1a00000
[    0.000000] RAMDISK: 365ac000 - 372ce000
[    0.000000] ACPI: RSDP 0x00000000000FAFE0 00014 (v00 ACPIAM)
[    0.000000] ACPI: RSDT 0x000000003F790000 00038 (v01 A_M_I_ OEMRSDT  07000709 MSFT 00000097)
[    0.000000] ACPI: FACP 0x000000003F790200 00081 (v01 A_M_I_ OEMFACP  07000709 MSFT 00000097)
[    0.000000] ACPI: DSDT 0x000000003F790590 0574C (v01 A0643  A0643000 00000000 INTL 20060113)
[    0.000000] ACPI: FACS 0x000000003F79E000 00040
[    0.000000] ACPI: APIC 0x000000003F790390 00080 (v01 A_M_I_ OEMAPIC  07000709 MSFT 00000097)
[    0.000000] ACPI: OEMB 0x000000003F79E040 00066 (v01 A_M_I_ AMI_OEM  07000709 MSFT 00000097)
[    0.000000] ACPI: HPET 0x000000003F795CE0 00038 (v01 A_M_I_ OEMHPET  07000709 MSFT 00000097)
[    0.000000] ACPI: MCFG 0x000000003F795D20 0003C (v01 A_M_I_ OEMMCFG  07000709 MSFT 00000097)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 125MB HIGHMEM available.
[    0.000000] 889MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 379fe000
[    0.000000]   low ram: 0 - 379fe000
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x000379fe
[    0.000000]   HighMem  0x000379fe -> 0x0003f790
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[2] active PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009f
[    0.000000]     0: 0x00000100 -> 0x0003f790
[    0.000000] On node 0 totalpages: 259871
[    0.000000] free_area_init_node: node 0, pgdat c1423940, node_mem_map f5dbc200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3951 pages, LIFO batch:0
[    0.000000]   Normal zone: 1748 pages used for memmap
[    0.000000]   Normal zone: 221994 pages, LIFO batch:31
[    0.000000]   HighMem zone: 252 pages used for memmap
[    0.000000]   HighMem zone: 31894 pages, LIFO batch:7
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x81] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[    0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[    0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[    0.000000] Allocating PCI resources starting at 3f800000 (gap: 3f800000:c0380000)
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 94 pages/cpu @f7879000 s362240 r0 d22784 u385024
[    0.000000] pcpu-alloc: s362240 r0 d22784 u385024 alloc=94*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 257839
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-6-rt-686-pae root=UUID=e5f40a2f-78fc-44f0-93c2-9b1445a1d70f ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] Initializing HighMem for node 0 (000379fe:0003f790)
[    0.000000] Memory: 1009400k/1039936k available (2875k kernel code, 30084k reserved, 1395k data, 744k init, 128584k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xffd36000 - 0xfffff000   (2852 kB)
[    0.000000]     pkmap   : 0xffa00000 - 0xffc00000   (2048 kB)
[    0.000000]     vmalloc : 0xf81fe000 - 0xff9fe000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf79fe000   ( 889 MB)
[    0.000000]       .init : 0xc142c000 - 0xc14e6000   ( 744 kB)
[    0.000000]       .data : 0xc12cefb0 - 0xc142bc80   (1395 kB)
[    0.000000]       .text : 0xc1000000 - 0xc12cefb0   (2875 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:2304 nr_irqs:712 16
[    0.000000] CPU 0 irqstacks, hard=f580a000 soft=f580c000
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] hpet clockevent registered
[    0.000000] Fast TSC calibration using PIT
[    0.000000] Detected 3466.628 MHz processor.
[    0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 6933.25 BogoMIPS (lpj=13866512)
[    0.004008] pid_max: default: 32768 minimum: 301
[    0.004074] Security Framework initialized
[    0.004081] AppArmor: AppArmor disabled by boot time parameter
[    0.004106] Mount-cache hash table entries: 512
[    0.004286] Initializing cgroup subsys cpuacct
[    0.004292] Initializing cgroup subsys memory
[    0.004306] Initializing cgroup subsys devices
[    0.004309] Initializing cgroup subsys freezer
[    0.004311] Initializing cgroup subsys net_cls
[    0.004313] Initializing cgroup subsys blkio
[    0.004322] Initializing cgroup subsys perf_event
[    0.004372] CPU0: Hyper-Threading is disabled
[    0.004376] mce: CPU supports 4 MCE banks
[    0.004389] CPU0: Thermal monitoring enabled (TM1)
[    0.004396] using mwait in idle threads.
[    0.004408] Spectre V2 : Mitigation: Full generic retpoline
[    0.004411] Spectre V2 : Filling RSB on context switch
[    0.008465] ACPI: Core revision 20110623
[    0.012086] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.012475] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.055446] CPU0: Intel(R) Celeron(R) D CPU 3.46GHz stepping 05
[    0.056003] APIC calibration not consistent with PM-Timer: 115ms instead of 100ms
[    0.056003] APIC delta adjusted to PM-Timer: 833304 (966622)
[    0.056003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[    0.056003] ... version:                0
[    0.056003] ... bit width:              40
[    0.056003] ... generic registers:      18
[    0.056003] ... value mask:             000000ffffffffff
[    0.056003] ... max period:             0000007fffffffff
[    0.056003] ... fixed-purpose events:   0
[    0.056003] ... event mask:             000000000003ffff
[    0.072259] NMI watchdog enabled, takes one hw-pmu counter.
[    0.076023] Brought up 1 CPUs
[    0.076029] Total of 1 processors activated (6933.25 BogoMIPS).
[    0.076805] devtmpfs: initialized
[    0.077181] PM: Registering ACPI NVS region at 3f79e000 (270336 bytes)
[    0.077529] print_constraints: dummy:
[    0.077646] NET: Registered protocol family 16
[    0.077892] ACPI: bus type pci registered
[    0.078019] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xf0000000-0xffffffff] (base 0xf0000000)
[    0.078023] PCI: not using MMCONFIG
[    0.078225] PCI : PCI BIOS aera is rw and x. Use pci=nobios if you want it NX.
[    0.078469] PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=2
[    0.078472] PCI: Using configuration type 1 for base access
[    0.079871] bio: create slab <bio-0> at 0
[    0.080103] ACPI: Added _OSI(Module Device)
[    0.080108] ACPI: Added _OSI(Processor Device)
[    0.080113] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.080117] ACPI: Added _OSI(Processor Aggregator Device)
[    0.081578] ACPI: EC: Look up EC in DSDT
[    0.083656] ACPI: Executed 1 blocks of module-level executable AML code
[    0.090035] ACPI: Interpreter enabled
[    0.090054] ACPI: (supports S0 S1 S3 S4 S5)
[    0.090110] ACPI: Using IOAPIC for interrupt routing
[    0.090163] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xf0000000-0xffffffff] (base 0xf0000000)
[    0.097103] PCI: MMCONFIG at [mem 0xf0000000-0xffffffff] reserved in ACPI motherboard resources
[    0.097110] PCI: MMCONFIG for 0000 [bus00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) (size reduced!)
[    0.097113] PCI: Using MMCONFIG for extended config space
[    0.109816] ACPI: No dock devices found.
[    0.109821] HEST: Table not found.
[    0.109829] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[    0.109957] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.110221] pci_root PNP0A08:00: host bridge window [io  0x0000-0x0cf7] (ignored)
[    0.110227] pci_root PNP0A08:00: host bridge window [io  0x0d00-0xffff] (ignored)
[    0.110231] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[    0.110235] pci_root PNP0A08:00: host bridge window [mem 0x3f810000-0xffffffff] (ignored)
[    0.110259] pci 0000:00:00.0: [8086:2770] type 0 class 0x000600
[    0.110331] pci 0000:00:02.0: [8086:2772] type 0 class 0x000300
[    0.110349] pci 0000:00:02.0: reg 10: [mem 0xdfe00000-0xdfe7ffff]
[    0.110358] pci 0000:00:02.0: reg 14: [io  0x9800-0x9807]
[    0.110368] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff pref]
[    0.110377] pci 0000:00:02.0: reg 1c: [mem 0xdfe80000-0xdfebffff]
[    0.110476] pci 0000:00:1b.0: [8086:27d8] type 0 class 0x000403
[    0.110498] pci 0000:00:1b.0: reg 10: [mem 0xdfef8000-0xdfefbfff 64bit]
[    0.110586] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.110618] pci 0000:00:1c.0: [8086:27d0] type 1 class 0x000604
[    0.110710] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.110749] pci 0000:00:1d.0: [8086:27c8] type 0 class 0x000c03
[    0.110801] pci 0000:00:1d.0: reg 20: [io  0xa000-0xa01f]
[    0.110844] pci 0000:00:1d.1: [8086:27c9] type 0 class 0x000c03
[    0.110895] pci 0000:00:1d.1: reg 20: [io  0xa400-0xa41f]
[    0.110940] pci 0000:00:1d.2: [8086:27ca] type 0 class 0x000c03
[    0.110992] pci 0000:00:1d.2: reg 20: [io  0xa800-0xa81f]
[    0.111034] pci 0000:00:1d.3: [8086:27cb] type 0 class 0x000c03
[    0.111086] pci 0000:00:1d.3: reg 20: [io  0xb000-0xb01f]
[    0.111142] pci 0000:00:1d.7: [8086:27cc] type 0 class 0x000c03
[    0.111167] pci 0000:00:1d.7: reg 10: [mem 0xdfeffc00-0xdfefffff]
[    0.111269] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.111296] pci 0000:00:1e.0: [8086:244e] type 1 class 0x000604
[    0.111385] pci 0000:00:1f.0: [8086:27b8] type 0 class 0x000601
[    0.111489] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0290 (mask 0007)
[    0.111542] pci 0000:00:1f.1: [8086:27df] type 0 class 0x000101
[    0.111560] pci 0000:00:1f.1: reg 10: [io  0x0000-0x0007]
[    0.111572] pci 0000:00:1f.1: reg 14: [io  0x0000-0x0003]
[    0.111584] pci 0000:00:1f.1: reg 18: [io  0x0000-0x0007]
[    0.111596] pci 0000:00:1f.1: reg 1c: [io  0x0000-0x0003]
[    0.111609] pci 0000:00:1f.1: reg 20: [io  0xffa0-0xffaf]
[    0.111658] pci 0000:00:1f.2: [8086:27c0] type 0 class 0x000101
[    0.111678] pci 0000:00:1f.2: reg 10: [io  0xc800-0xc807]
[    0.111689] pci 0000:00:1f.2: reg 14: [io  0xc400-0xc403]
[    0.111700] pci 0000:00:1f.2: reg 18: [io  0xc000-0xc007]
[    0.111711] pci 0000:00:1f.2: reg 1c: [io  0xb800-0xb803]
[    0.111722] pci 0000:00:1f.2: reg 20: [io  0xb400-0xb40f]
[    0.111769] pci 0000:00:1f.2: PME# supported from D3hot
[    0.111790] pci 0000:00:1f.3: [8086:27da] type 0 class 0x000c05
[    0.111852] pci 0000:00:1f.3: reg 20: [io  0x0400-0x041f]
[    0.111945] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[    0.111951] pci 0000:00:1c.0:   bridge window [io  0xe000-0xefff]
[    0.112051] pci 0000:01:04.0: [11ab:4320] type 0 class 0x000200
[    0.112078] pci 0000:01:04.0: reg 10: [mem 0xdfffc000-0xdfffffff]
[    0.112091] pci 0000:01:04.0: reg 14: [io  0xd800-0xd8ff]
[    0.112143] pci 0000:01:04.0: reg 30: [mem 0xdffc0000-0xdffdffff pref]
[    0.112191] pci 0000:01:04.0: supports D1 D2
[    0.112194] pci 0000:01:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.112248] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)
[    0.112254] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
[    0.112260] pci 0000:00:1e.0:   bridge window [mem 0xdff00000-0xdfffffff]
[    0.112271] pci 0000:00:1e.0:   bridge window [io  0x0000-0xffff] (subtractive decode)
[    0.112275] pci 0000:00:1e.0:   bridge window [mem 0x00000000-0xfffffffff] (subtractive decode)
[    0.112291] pci_bus 0000:00: on NUMA node 0
[    0.112298] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.112656] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
[    0.112849] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
[    0.113041]  pci0000:00: Requesting ACPI _OSC control (0x1d)
[    0.113047]  pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[    0.113050] ACPI _OSC control for PCIe not granted, disabling ASPM
[    0.120841] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[    0.120957] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.121069] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 10 11 12 14 15)
[    0.121179] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.121290] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[    0.121401] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.121515] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.121627] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.121823] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.121845] vgaarb: loaded
[    0.121848] vgaarb: bridge control possible 0000:00:02.0
[    0.121941] PCI: Using ACPI for IRQ routing
[    0.121947] PCI: pci_cache_line_size set to 64 bytes
[    0.122039] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[    0.122044] reserve RAM buffer: 000000003f790000 - 000000003fffffff
[    0.122262] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[    0.122270] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.122278] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[    0.132052] AMD NB: Cannot enumerate AMD northbridges.
[    0.132057] Switching to clocksource hpet
[    0.135828] pnp: PnP ACPI init
[    0.135863] ACPI: bus type pnp registered
[    0.136069] pnp 00:00: [bus 00-ff]
[    0.136074] pnp 00:00: [io  0x0cf8-0x0cff]
[    0.136078] pnp 00:00: [io  0x0000-0x0cf7 window]
[    0.136082] pnp 00:00: [io  0x0d00-0xffff window]
[    0.136086] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[    0.136090] pnp 00:00: [mem 0x3f810000-0xffffffff window]
[    0.136194] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[    0.136218] pnp 00:01: [mem 0xfed13000-0xfed19fff]
[    0.136305] system 00:01: [mem 0xfed13000-0xfed19fff] has been reserved
[    0.136312] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.136370] pnp 00:02: [dma 4]
[    0.136374] pnp 00:02: [io  0x0000-0x000f]
[    0.136378] pnp 00:02: [io  0x0081-0x0083]
[    0.136381] pnp 00:02: [io  0x0087]
[    0.136384] pnp 00:02: [io  0x0089-0x008b]
[    0.136387] pnp 00:02: [io  0x008f]
[    0.136390] pnp 00:02: [io  0x00c0-0x00df]
[    0.136445] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.136473] pnp 00:03: [io  0x0070-0x0071]
[    0.136488] pnp 00:03: [irq 8]
[    0.136542] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.136562] pnp 00:04: [io  0x0061]
[    0.136617] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[    0.136642] pnp 00:05: [io  0x00f0-0x00ff]
[    0.136650] pnp 00:05: [irq 13]
[    0.136706] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.137501] pnp 00:06: [irq 6]
[    0.137506] pnp 00:06: [dma 2]
[    0.137510] pnp 00:06: [io  0x03f0-0x03f5]
[    0.137513] pnp 00:06: [io  0x03f7]
[    0.137626] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[    0.138610] pnp 00:07: [irq 7]
[    0.138614] pnp 00:07: [dma 3]
[    0.138618] pnp 00:07: [io  0x0378-0x037f]
[    0.138621] pnp 00:07: [io  0x0778-0x077f]
[    0.138971] pnp 00:07: Plug and Play ACPI device, IDs PNP0401 (active)
[    0.139042] pnp 00:08: [io  0x0000-0xffffffffffffffff disabled]
[    0.139047] pnp 00:08: [io  0x0000-0xffffffffffffffff disabled]
[    0.139051] pnp 00:08: [io  0x0290-0x0297]
[    0.139141] system 00:08: [io  0x0290-0x0297] has been reserved
[    0.139147] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.139333] pnp 00:09: [io  0x0010-0x001f]
[    0.139338] pnp 00:09: [io  0x0022-0x003f]
[    0.139341] pnp 00:09: [io  0x0044-0x005f]
[    0.139344] pnp 00:09: [io  0x0062-0x0063]
[    0.139347] pnp 00:09: [io  0x0065-0x006f]
[    0.139350] pnp 00:09: [io  0x0072-0x007f]
[    0.139354] pnp 00:09: [io  0x0080]
[    0.139357] pnp 00:09: [io  0x0084-0x0086]
[    0.139360] pnp 00:09: [io  0x0088]
[    0.139363] pnp 00:09: [io  0x008c-0x008e]
[    0.139366] pnp 00:09: [io  0x0090-0x009f]
[    0.139369] pnp 00:09: [io  0x00a2-0x00bf]
[    0.139372] pnp 00:09: [io  0x00e0-0x00ef]
[    0.139376] pnp 00:09: [io  0x04d0-0x04d1]
[    0.139379] pnp 00:09: [io  0x0800-0x087f]
[    0.139382] pnp 00:09: [io  0x0000-0xffffffffffffffff disabled]
[    0.139386] pnp 00:09: [io  0x0480-0x04bf]
[    0.139389] pnp 00:09: [io  0x0400-0x041f]
[    0.139393] pnp 00:09: [mem 0xfed1c000-0xfed1ffff]
[    0.139396] pnp 00:09: [mem 0xfed20000-0xfed8ffff]
[    0.139400] pnp 00:09: [mem 0xffb00000-0xffbfffff]
[    0.139403] pnp 00:09: [mem 0xfff00000-0xfffffffe]
[    0.139510] system 00:09: [io  0x04d0-0x04d1] has been reserved
[    0.139516] system 00:09: [io  0x0800-0x087f] could not be reserved
[    0.139520] system 00:09: [io  0x0480-0x04bf] has been reserved
[    0.139525] system 00:09: [io  0x0400-0x041f] has been reserved
[    0.139530] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.139535] system 00:09: [mem 0xfed20000-0xfed8ffff] has been reserved
[    0.139543] system 00:09: [mem 0xffb00000-0xffbfffff] could not be reserved
[    0.139548] system 00:09: [mem 0xfff00000-0xfffffffe] has been reserved
[    0.139554] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.139710] pnp 00:0a: [mem 0xfed00000-0xfed003ff]
[    0.139770] pnp 00:0a: Plug and Play ACPI device, IDs PNP0103 (active)
[    0.139976] pnp 00:0b: [mem 0xfec00000-0xfec00fff]
[    0.139980] pnp 00:0b: [mem 0xfee00000-0xfee00fff]
[    0.140123] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.140128] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.140134] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.140825] pnp 00:0c: [irq 4]
[    0.140830] pnp 00:0c: [dma 0 disabled]
[    0.140834] pnp 00:0c: [io  0x03f8-0x03ff]
[    0.140977] pnp 00:0c: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.141103] pnp 00:0d: [mem 0xffb80000-0xffbfffff]
[    0.141108] pnp 00:0d: [mem 0xfff80000-0xffffffff]
[    0.141167] pnp 00:0d: Plug and Play ACPI device, IDs INT0800 (active)
[    0.141272] pnp 00:0e: [mem 0xffc00000-0xfff7ffff]
[    0.141369] system 00:0e: [mem 0xffc00000-0xfff7ffff] could not be reserved
[    0.141375] system 00:0e: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.141457] pnp 00:0f: [mem 0xf0000000-0xf3ffffff]
[    0.141548] system 00:0f: [mem 0xf0000000-0xf3ffffff] has been reserved
[    0.141554] system 00:0f: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.141921] pnp 00:10: [mem 0x00000000-0x0009ffff]
[    0.141926] pnp 00:10: [mem 0x000c0000-0x000dffff]
[    0.141929] pnp 00:10: [mem 0x000e0000-0x000fffff]
[    0.141933] pnp 00:10: [mem 0x00100000-0x3f7fffff]
[    0.141937] pnp 00:10: [mem 0x00000000-0xffffffffffffffff disabled]
[    0.142041] system 00:10: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.142047] system 00:10: [mem 0x000c0000-0x000dffff] could not be reserved
[    0.142052] system 00:10: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.142057] system 00:10: [mem 0x00100000-0x3f7fffff] could not be reserved
[    0.142062] system 00:10: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.142385] pnp: PnP ACPI: found 17 devices
[    0.142389] ACPI: ACPI bus type pnp unregistered
[    0.142394] PnPBIOS: Disabled by ACPI PNP
[    0.181055] PCI: max bus depth: 1 pci_try_num: 2
[    0.181096] pci 0000:00:1c.0: BAR 14: assigned [mem 0x40000000-0x401fffff]
[    0.181104] pci 0000:00:1c.0: BAR 15: assigned [mem 0x40200000-0x403fffff 64bit pref]
[    0.181109] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[    0.181114] pci 0000:00:1c.0:   bridge window [io  0xe000-0xefff]
[    0.181121] pci 0000:00:1c.0:   bridge window [mem 0x40000000-0x401fffff]
[    0.181127] pci 0000:00:1c.0:   bridge window [mem 0x40200000-0x403fffff 64bit pref]
[    0.181136] pci 0000:00:1e.0: PCI bridge to [bus 01-01]
[    0.181140] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
[    0.181147] pci 0000:00:1e.0:   bridge window [mem 0xdff00000-0xdfffffff]
[    0.181189] pci 0000:00:1c.0: setting latency timer to 64
[    0.181201] pci 0000:00:1e.0: setting latency timer to 64
[    0.181206] pci_bus 0000:00: resource 0 [io  0x0000-0xffff]
[    0.181210] pci_bus 0000:00: resource 1 [mem 0x00000000-0xfffffffff]
[    0.181214] pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
[    0.181217] pci_bus 0000:02: resource 1 [mem 0x40000000-0x401fffff]
[    0.181221] pci_bus 0000:02: resource 2 [mem 0x40200000-0x403fffff 64bit pref]
[    0.181224] pci_bus 0000:01: resource 0 [io  0xd000-0xdfff]
[    0.181228] pci_bus 0000:01: resource 1 [mem 0xdff00000-0xdfffffff]
[    0.181231] pci_bus 0000:01: resource 4 [io  0x0000-0xffff]
[    0.181234] pci_bus 0000:01: resource 5 [mem 0x00000000-0xfffffffff]
[    0.181345] NET: Registered protocol family 2
[    0.183922] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.184515] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.185185] TCP bind hash table entries: 65536 (order: 8, 1835008 bytes)
[    0.186377] TCP: Hash tables configured (established 131072 bind 65536)
[    0.186385] TCP reno registered
[    0.186398] UDP hash table entries: 512 (order: 3, 32768 bytes)
[    0.186424] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[    0.186637] NET: Registered protocol family 1
[    0.186669] pci 0000:00:02.0: Boot video device
[    0.186896] PCI: CLS 16 bytes, default 64
[    0.187011] Unpacking initramfs...
[    0.590550] Freeing initrd memory: 13448k freed
[    0.601612] audit: initializing netlink socket (disabled)
[    0.601637] type=2000 audit(1551044415.596:1): initialized
[    0.619956] highmem bounce pool size: 64 pages
[    0.619965] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.620267] VFS: Disk quotas dquot_6.5.2
[    0.620330] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.620452] msgmni has been set to 1746
[    0.620778] alg: No test for stdrng (krng)
[    0.620840] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.620846] io scheduler noop registered
[    0.620848] io scheduler deadline registered
[    0.620874] io scheduler cfq registered (default)
[    0.621023] pcieport 0000:00:1c.0: setting latency timer to 64
[    0.621082] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[    0.621247] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.621295] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.621298] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.621843] ERST: Table is not found!
[    0.621846] GHES: HEST is not enabled!
[    0.621875] isapnp: Scanning for PnP cards...
[    0.975174] isapnp: No Plug & Play device found
[    0.975301] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.995719] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.060636] 00:0c: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.072377] Linux agpgart interface v0.103
[    1.072575] agpgart-intel 0000:00:00.0: Intel 945G Chipset
[    1.072657] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[    1.072782] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[    1.072958] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[    1.073206] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    1.075778] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.075790] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.076091] mousedev: PS/2 mouse device common for all mice
[    1.076162] rtc_cmos 00:03: RTC can wake from S4
[    1.076351] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[    1.076433] rtc0: alarms up to one month, 114 bytes nvram, hpet irqs
[    1.076464] cpuidle: using governor ladder
[    1.076467] cpuidle: using governor menu
[    1.076983] TCP cubic registered
[    1.077057] NET: Registered protocol family 10
[    1.078308] Mobile IPv6
[    1.078314] NET: Registered protocol family 17
[    1.078323] Registering the dns_resolver key type
[    1.078364] Using IPI No-Shortcut mode
[    1.078575] PM: Hibernation image not present or could not be loaded.
[    1.078596] registered taskstats version 1
[    1.078986] rtc_cmos 00:03: setting system clock to 2019-02-24 21:40:16 UTC (1551044416)
[    1.079051] Initializing network drop monitor service
[    1.079277] Freeing unused kernel memory: 744k freed
[    1.079868] Write protecting the kernel text: 2876k
[    1.079921] Write protecting the kernel read-only data: 1100k
[    1.079924] NX-protecting the kernel data: 3268k
[    1.108420] udevd[57]: starting version 175
[    1.221946] usbcore: registered new interface driver usbfs
[    1.221993] usbcore: registered new interface driver hub
[    1.252838] usbcore: registered new device driver usb
[    1.270308] SCSI subsystem initialized
[    1.275351] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.275428] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[    1.275434] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[    1.275484] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[    1.275519] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[    1.275533] ehci_hcd 0000:00:1d.7: debug port 1
[    1.279420] ehci_hcd 0000:00:1d.7: cache line size of 16 is not supported
[    1.282178] skge: 1.14 addr 0xdfffc000 irq 20 chip Yukon-Lite rev 9
[    1.283243] skge 0000:01:04.0: eth0: addr 00:18:f3:0d:58:a5
[    1.289334] uhci_hcd: USB Universal Host Controller Interface driver
[    1.300461] ehci_hcd 0000:00:1d.7: irq 20, io mem 0xdfeffc00
[    1.332137] libata version 3.00 loaded.
[    1.340185] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    1.340308] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.340313] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.340317] usb usb1: Product: EHCI Host Controller
[    1.340320] usb usb1: Manufacturer: Linux 3.2.0-6-rt-686-pae ehci_hcd
[    1.340323] usb usb1: SerialNumber: 0000:00:1d.7
[    1.340625] hub 1-0:1.0: USB hub found
[    1.340645] hub 1-0:1.0: 8 ports detected
[    1.340895] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    1.340901] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    1.340921] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    1.366292] uhci_hcd 0000:00:1d.0: irq 20, io base 0x0000a000
[    1.366375] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.366380] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.366384] usb usb2: Product: UHCI Host Controller
[    1.366386] usb usb2: Manufacturer: Linux 3.2.0-6-rt-686-pae uhci_hcd
[    1.366389] usb usb2: SerialNumber: 0000:00:1d.0
[    1.366640] hub 2-0:1.0: USB hub found
[    1.366650] hub 2-0:1.0: 2 ports detected
[    1.366822] ata_piix 0000:00:1f.1: version 2.13
[    1.366920] ata_piix 0000:00:1f.1: setting latency timer to 64
[    1.387325] Floppy drive(s): fd0 is 1.44M
[    1.406123] scsi0 : ata_piix
[    1.411247] scsi1 : ata_piix
[    1.415777] FDC 0 is a post-1991 82077
[    1.418665] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[    1.418671] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[    1.419809] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    1.419816] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    1.419839] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[    1.423865] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000a400
[    1.423947] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.423952] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.423955] usb usb3: Product: UHCI Host Controller
[    1.423958] usb usb3: Manufacturer: Linux 3.2.0-6-rt-686-pae uhci_hcd
[    1.423961] usb usb3: SerialNumber: 0000:00:1d.1
[    1.424309] hub 3-0:1.0: USB hub found
[    1.424321] hub 3-0:1.0: 2 ports detected
[    1.424566] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    1.424639] ata_piix 0000:00:1f.2: setting latency timer to 64
[    1.434605] scsi2 : ata_piix
[    1.439553] scsi3 : ata_piix
[    1.443442] ata3: SATA max UDMA/133 cmd 0xc800 ctl 0xc400 bmdma 0xb400 irq 23
[    1.443448] ata4: SATA max UDMA/133 cmd 0xc000 ctl 0xb800 bmdma 0xb408 irq 23
[    1.445761] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[    1.445769] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    1.445792] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[    1.450351] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000a800
[    1.450427] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.450432] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.450436] usb usb4: Product: UHCI Host Controller
[    1.450439] usb usb4: Manufacturer: Linux 3.2.0-6-rt-686-pae uhci_hcd
[    1.450442] usb usb4: SerialNumber: 0000:00:1d.2
[    1.450687] hub 4-0:1.0: USB hub found
[    1.450698] hub 4-0:1.0: 2 ports detected
[    1.450883] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[    1.450888] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[    1.450906] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[    1.456294] uhci_hcd 0000:00:1d.3: irq 19, io base 0x0000b000
[    1.456378] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    1.456382] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.456386] usb usb5: Product: UHCI Host Controller
[    1.456389] usb usb5: Manufacturer: Linux 3.2.0-6-rt-686-pae uhci_hcd
[    1.456392] usb usb5: SerialNumber: 0000:00:1d.3
[    1.456644] hub 5-0:1.0: USB hub found
[    1.456655] hub 5-0:1.0: 2 ports detected
[    1.600022] Refined TSC clocksource calibration: 3466.554 MHz.
[    1.600032] Switching to clocksource tsc
[    1.623227] ata3.00: ATA-7: Hitachi HDS721680PLA380, P21OAB3A, max UDMA/133
[    1.623233] ata3.00: 160836480 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    1.636341] ata3.00: configured for UDMA/133
[    1.636521] scsi 2:0:0:0: Direct-Access     ATA      Hitachi HDS72168 P21O PQ: 0 ANSI: 5
[    1.654721] sd 2:0:0:0: [sda] 160836480 512-byte logical blocks: (82.3 GB/76.6 GiB)
[    1.654839] sd 2:0:0:0: [sda] Write Protect is off
[    1.654844] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.654893] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.689097]  sda: sda1 sda2 < sda5 >
[    1.690003] sd 2:0:0:0: [sda] Attached SCSI disk
[    1.693966] sd 2:0:0:0: Attached scsi generic sg0 type 0
[    1.764034] usb 1-3: new high-speed USB device number 4 using ehci_hcd
[    1.896928] usb 1-3: New USB device found, idVendor=2a45, idProduct=2004
[    1.896934] usb 1-3: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[    1.896938] usb 1-3: Product: M5c
[    1.896940] usb 1-3: Manufacturer: Meizu
[    1.896943] usb 1-3: SerialNumber: 710HVBR523L8L
[    2.136079] usb 2-1: new low-speed USB device number 2 using uhci_hcd
[    2.304393] usb 2-1: New USB device found, idVendor=1bcf, idProduct=0005
[    2.304398] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    2.304402] usb 2-1: Product: USB Optical Mouse
[    2.332862] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input0
[    2.333154] generic-usb 0003:1BCF:0005.0001: input,hidraw0: USB HID v1.10 Mouse [USB Optical Mouse] on usb-0000:00:1d.0-1/input0
[    2.333502] usbcore: registered new interface driver usbhid
[    2.333506] usbhid: USB HID core driver
[    2.548022] usb 2-2: new low-speed USB device number 3 using uhci_hcd
[    2.715406] usb 2-2: New USB device found, idVendor=2a7a, idProduct=6a08
[    2.715411] usb 2-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    2.715415] usb 2-2: Product: U
[    2.738791] input: U as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/input/input1
[    2.739004] generic-usb 0003:2A7A:6A08.0002: input,hidraw1: USB HID v1.10 Keyboard [U] on usb-0000:00:1d.0-2/input0
[    2.770620] input: U as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.1/input/input2
[    2.770794] generic-usb 0003:2A7A:6A08.0003: input,hidraw2: USB HID v1.10 Device [U] on usb-0000:00:1d.0-2/input1
[    6.951705] microcode: CPU0 sig=0xf65, pf=0x4, revision=0x9
[    6.958786] platform microcode: firmware: agent loaded intel-ucode/0f-06-05 into memory
[    6.959146] microcode: CPU0 updated to revision 0xb, date = 2007-05-10
[    6.959876] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    6.980707] PM: Starting manual resume from disk
[    6.980714] PM: Hibernation image partition 8:5 present
[    6.980716] PM: Looking for hibernation image.
[    6.981009] PM: Image not found (code -22)
[    6.981012] PM: Hibernation image not present or could not be loaded.
[    7.038887] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    8.730403] udevd[355]: starting version 175
[    8.996958] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[    8.996969] ACPI: Power Button [PWRB]
[    8.997073] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[    8.997080] ACPI: Power Button [PWRF]
[    9.175520] intel_rng: FWH not detected
[    9.349122] udevd[405]: renamed network interface eth0 to eth1
[    9.437025] [drm] Initialized drm 1.1.0 20060810
[    9.587464] input: PC Speaker as /devices/platform/pcspkr/input/input5
[    9.621521] parport_pc 00:07: reported by Plug and Play ACPI
[    9.621646] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[    9.710497] iTCO_vendor_support: vendor-support=0
[    9.735365] snd_hda_intel 0000:00:1b.0: irq 41 for MSI/MSI-X
[    9.735931] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[    9.744528] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[    9.744676] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860)
[    9.746256] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    9.851064] leds_ss4200: no LED devices found
[    9.917587] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
[    9.930916] i915 0000:00:02.0: setting latency timer to 64
[    9.969570] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    9.969575] [drm] Driver supports precise vblank timestamp query.
[    9.970227] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   10.007656] [drm] initialized overlay support
[   10.014673] usbcore: registered new interface driver cdc_ether
[   10.022682] rndis_host 1-3:1.0: usb0: register 'rndis_host' at usb-0000:00:1d.7-3, RNDIS device, b2:bc:32:04:cc:84
[   10.022731] usbcore: registered new interface driver rndis_host
[   10.071713] fbcon: inteldrmfb (fb0) is primary device
[   10.122922] Console: switching to colour frame buffer device 240x67
[   10.142848] fb0: inteldrmfb frame buffer device
[   10.142853] drm: registered panic notifier
[   10.142867] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[   11.963895] Adding 3302396k swap on /dev/sda5.  Priority:-1 extents:1 across:3302396k
[   11.991728] EXT4-fs (sda1): re-mounted. Opts: (null)
[   12.216521] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   12.458388] loop: module loaded
[   14.492715] RPC: Registered named UNIX socket transport module.
[   14.492720] RPC: Registered udp transport module.
[   14.492723] RPC: Registered tcp transport module.
[   14.492726] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   14.544066] FS-Cache: Loaded
[   14.591769] FS-Cache: Netfs 'nfs' registered for caching
[   14.626669] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   17.101620] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input7
[   18.159099] Bluetooth: Core ver 2.16
[   18.159556] NET: Registered protocol family 31
[   18.159561] Bluetooth: HCI device and connection manager initialized
[   18.159566] Bluetooth: HCI socket layer initialized
[   18.159570] Bluetooth: L2CAP socket layer initialized
[   18.159584] Bluetooth: SCO socket layer initialized
[   18.195354] Bluetooth: RFCOMM TTY layer initialized
[   18.195364] Bluetooth: RFCOMM socket layer initialized
[   18.195367] Bluetooth: RFCOMM ver 1.11
[   18.270067] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   18.270073] Bluetooth: BNEP filters: protocol multicast
[   18.326067] lp0: using parport0 (interrupt-driven).
[   18.338301] ppdev: user-space parallel port driver
[   21.175314] skge 0000:01:04.0: eth1: enabling interface
[   22.863115] skge 0000:01:04.0: eth1: Link is up at 100 Mbps, full duplex, flow control both
[   31.776018] eth1: no IPv6 routers present
[   32.440016] usb0: no IPv6 routers present
[  254.068941] ip_tables: (C) 2000-2006 Netfilter Core Team
Re: 7I92+7I77
сетевой интерфейс настроен как сказано в доках?
Techno
Re: 7I92+7I77
Сообщение Techno »
Вы могли бы скинуть ссылку где почитать подробнее
Re: 7I92+7I77
Сообщение nkp »
Techno писал(а):ссылку где почитать подробнее
http://www.cnc-club.ru/forum/viewtopic. ... 20#p408790
Techno
Re: 7I92+7I77
Сообщение Techno »
cnc@lathe:~$ sudo ifconfig
eth1      Link encap:Ethernet  HWaddr 00:18:f3:0d:58:a5
          inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::218:f3ff:fe0d:58a5/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:384 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2707 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:24654 (24.0 KiB)  TX bytes:180343 (176.1 KiB)
          Interrupt:20
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:782 errors:0 dropped:0 overruns:0 frame:0
          TX packets:782 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:46952 (45.8 KiB)  TX bytes:46952 (45.8 KiB)
Communication:
Board info:
  Connectors count: 2
  FPGA type: xc6slx9
  Number of leds: 4
  memory spaces:
    1: KSZ8851 (registers, RW, 16-bit) [size=256]
    2: EtherEEP (EEPROM, RW, 16-bit) [size=128], page size: 1, erase size: 1
    4: Timers (memory, RW, 16-bit) [size=16]
    6: LBP16RW (memory, RW, 16-bit) [size=16]
    7: LBP16RO (memory, RO, 16-bit) [size=16]
  [space 0] HostMot2
    board name: 7I92
  [space 4] timers:
    uSTimeStampReg: 0x9B72
    WaituSReg: 0x0000
    HM2Timeout: 0x0000
    packets received: all 1200, UDP 187, bad 0
    packets sended: all 188, UDP 187, bad 0
    error flags: 0x0000
    scratch: 0x0000
    board name: 7I92
cnc@lathe:~$ mesaflash --device 7i92 --readhmid
Configuration Name: HOSTMOT2
General configuration information:
  BoardName : MESA7I92
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 2
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 2 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: MuxedQCount
  There are 12 of MuxedQCount in configuration
  Version: 3
  Registers: 5
  BaseAddress: 3600
  Module: MuxedQCountSel
  There are 1 of MuxedQCountSel in configuration
  Version: 0
  Registers: 0
  BaseAddress: 0000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       SSerial          0        TXEn3           (Out)
14      1   IOPort       SSerial          0        TXData3         (Out)
 2      2   IOPort       SSerial          0        RXData3         (In)
15      3   IOPort       SSerial          0        TXData2         (Out)
 3      4   IOPort       SSerial          0        RXData2         (In)
16      5   IOPort       SSerial          0        TXData1         (Out)
 4      6   IOPort       SSerial          0        RXData1         (In)
17      7   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
 5      8   IOPort       MuxedQCount      0        MuxQ-A          (In)
 6      9   IOPort       MuxedQCount      0        MuxQ-B          (In)
 7     10   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
 8     11   IOPort       MuxedQCount      1        MuxQ-A          (In)
 9     12   IOPort       MuxedQCount      1        MuxQ-B          (In)
10     13   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
11     14   IOPort       MuxedQCount      2        MuxQ-A          (In)
12     15   IOPort       MuxedQCount      2        MuxQ-B          (In)
13     16   IOPort       MuxedQCount      2        MuxQ-IDX        (In)
IO Connections for P1
 1     17   IOPort       SSerial          0        TXEn6           (Out)
14     18   IOPort       SSerial          0        TXData6         (Out)
 2     19   IOPort       SSerial          0        RXData6         (In)
15     20   IOPort       SSerial          0        TXData5         (Out)
 3     21   IOPort       SSerial          0        RXData5         (In)
16     22   IOPort       SSerial          0        TXData4         (Out)
 4     23   IOPort       SSerial          0        RXData4         (In)
17     24   IOPort       MuxedQCountSel   6        MuxSel0         (Out)
 5     25   IOPort       MuxedQCount      3        MuxQ-A          (In)
 6     26   IOPort       MuxedQCount      3        MuxQ-B          (In)
 7     27   IOPort       MuxedQCount      3        MuxQ-IDX        (In)
 8     28   IOPort       MuxedQCount      4        MuxQ-A          (In)
 9     29   IOPort       MuxedQCount      4        MuxQ-B          (In)
10     30   IOPort       MuxedQCount      4        MuxQ-IDX        (In)
11     31   IOPort       MuxedQCount      5        MuxQ-A          (In)
12     32   IOPort       MuxedQCount      5        MuxQ-B          (In)
13     33   IOPort       MuxedQCount      5        MuxQ-IDX        (In)
Re: 7I92+7I77
"ping 192.168.1.121" что говорит?
И как джамперы на плате стоят?
Techno
Re: 7I92+7I77
Сообщение Techno »
Спасибо за подсказку по пингу. Поставил сетевую старый добрый realtek, завелось с пол пинка.
MGG
Re: 7I92+7I77
Сообщение MGG »
Господа, подаскжите. Увидел по сети 7и92, в ней 7и77, залил прошивку. На последней не горит зеленый и постоянно горит красный. Вроде все делал по множественным инстукциям, пингуется и так далее.
Прошивка
mgg@mgg-desktop ~ $ mesaflash --device 7i92  --readhmid
  FPGA Size: 9 KGates
  FPGA Pins: 144
  IDROM Type: 3
  Module: WatchDog
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: MuxedQCount
  Version: 3
  Registers: 5
  BaseAddress: 3500
  Version: 0
  Registers: 0
  BaseAddress: 0000
  Module: SSerial
  Version: 0
  Registers: 6
  BaseAddress: 5A00
  Module: LED
  Version: 0
  Registers: 1
  BaseAddress: 0200
Инфа
[codemgg@mgg-desktop ~ $ mesaflash --device 7i92 --verbose
Communication:
  mac address: 00:60:1B:13:04:05
Board info:
  Connectors count: 2
  FPGA type: 6slx9tqg144
  Number of leds: 4
  memory spaces:
  [space 0] HostMot2
    board name: 7I92
  [space 4] timers:
    uSTimeStampReg: 0xAF8C
    WaituSReg: 0x0000
    HM2Timeout: 0x0000
    packets received: all 7952, UDP 7690, bad 0
    packets sended: all 4692, UDP 4690, bad 0
    error flags: 0x0020
    scratch: 0x0000
    board name: 7I92
сетка
mgg@mgg-desktop ~ $ sudo ifconfig
enp1s0    Link encap:Ethernet  HWaddr 00:1c:c0:e2:6e:f6
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          RX packets:5110 errors:0 dropped:0 overruns:0 frame:0
          TX packets:11642 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:307606 (307.6 KB)  TX bytes:546525 (546.5 KB)
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:2492 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2492 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:230506 (230.5 KB)  TX bytes:230506 (230.5 KB)
Система минт18.3, ибо на изобретение сатаны интел атом330 (откуда он взялся, загадка) больше ничего не встает. Пишешь текст, иногда нормально, иногда надо покурить, посмотреть, как буковки набиваются :)
Скажите хотя бы где что читать.
Re: 7I92+7I77
Какой из? Их там полно. :)
Небось питание 24в не подал, или сколько там у тебя...
MGG
Re: 7I92+7I77
Сообщение MGG »
UAVpilot писал(а):Какой из? Их там полно. :)
Подал, даже прозвонил, но дружить они не хотят.
MGG
Re: 7I92+7I77
Сообщение MGG »
mgg@mgg-desktop ~ $ halrun
halcmd: loadrt hostmot2
Waiting for component 'hostmot2' to become ready.......Note: Using POSIX realtime
halcmd: loadrt hm2_eth board_ip="192.168.1.121"
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:13:04:05
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
Board hm2_7i92.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_7i92.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_7i92.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Waiting for component 'hm2_eth' to become ready..Board hm2_7i92.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.1 Software Mode 0 = analogout_enables
.....hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0:     IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0:     IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0:     IO Pin 002 (P2-02): IOPort
hm2/hm2_7i92.0:     IO Pin 003 (P2-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_7i92.0:     IO Pin 004 (P2-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_7i92.0:     IO Pin 005 (P2-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i92.0:     IO Pin 006 (P2-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i92.0:     IO Pin 007 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i92.0:     IO Pin 008 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 009 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 010 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 011 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 012 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 013 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 014 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 015 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 016 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 017 (P1-01): IOPort
hm2/hm2_7i92.0:     IO Pin 018 (P1-14): IOPort
hm2/hm2_7i92.0:     IO Pin 019 (P1-02): IOPort
hm2/hm2_7i92.0:     IO Pin 020 (P1-15): IOPort
hm2/hm2_7i92.0:     IO Pin 021 (P1-03): IOPort
hm2/hm2_7i92.0:     IO Pin 022 (P1-16): IOPort
hm2/hm2_7i92.0:     IO Pin 023 (P1-04): IOPort
hm2/hm2_7i92.0:     IO Pin 024 (P1-17): Muxed Encoder Select #6, pin Mux Select 0 (Output)
hm2/hm2_7i92.0:     IO Pin 025 (P1-05): Muxed Encoder #3, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 026 (P1-06): Muxed Encoder #3, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 027 (P1-07): Muxed Encoder #3, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 028 (P1-08): Muxed Encoder #4, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 029 (P1-09): Muxed Encoder #4, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 030 (P1-10): Muxed Encoder #4, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 031 (P1-11): Muxed Encoder #5, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 032 (P1-12): Muxed Encoder #5, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 033 (P1-13): Muxed Encoder #5, pin Muxed Index (Input)
hm2/hm2_7i92.0: registered
halcmd:
все видит, 24в есть, но ведет себя так, как будто питания нет :thinking:
Axis еще вот такое выдает hm2/hm2_7i92.0:erroe finishing read! iter=6
Может все это быть из за диких задержек ?
MGG
Re: 7I92+7I77
Сообщение MGG »
Нашёл другую мать, вопрос отпал
MGG
Re: 7I92+7I77
Сообщение MGG »
Вопрос снялся сам собой при смене материнской платы
Re: 7I92+7I77
MGG писал(а):все видит, 24в есть, но ведет себя так, как будто питания нет :thinking:
В логе halrun не видно подтверждения поданному питанию... :) Виновата-ли в этом матплата или твои 2 точки в конце мне неведомо. :)
MGG писал(а):Axis еще вот такое выдает hm2/hm2_7i92.0:erroe finishing read! iter=6
О как! А зачем скрывал от общественности "дикие задержки"?.. :)
MGG
Re: 7I92+7I77
Сообщение MGG »
UAVpilot писал(а):О как! А зачем скрывал от общественности "дикие задержки"?.. :)
Чуть меньше ста тысяч было, но при этом латенси тест вешал систему сильно. И вроде как задержки мешали законектится, и ватчдог был красный от злости =)
Чот с ночи вожусь с такой мелочью как енейбл. У меня на серве ком+ сон -, соответственно полярности завел в 7и77 и на ена+ завел 24 вольта от бп, и ничего не происходит :(
При принудительном включении мотора, даже оську погонял, страшно :hehehe:
Re: 7I92+7I77
В whatsapp твой вопрос увидел в пути и забыл ответить. :)
ENA+/ENA- - это по сути просто контакт, который замыкается при активном analogena, только полярность надо соблюдать.
MGG
Re: 7I92+7I77
Сообщение MGG »
UAVpilot писал(а):В whatsapp твой вопрос увидел в пути и забыл ответить. :)
Получается где плюс сервы туда бп, а ена +- сигнал сервы и бп землю? :)
Спасибо
Re: 7I92+7I77
ENA+ на 7 сервы, ENA- на -24v.
Вернуться в «MESA»
