Страница 1 из 1
dxfpoint
Добавлено: 03 янв 2012, 17:56
alfcnc
Using Dxfpoint
Re: dxfpoint
Добавлено: 03 янв 2012, 18:03
alfcnc
I all !
I try to use dxfpoint dev version. All is ok.
Setting circle.
Putting them to path and execute set as dxfpoint and save shape.
After this run Path to gcode and the drilling gcode is process nice.
My exemple svg file:
dxf_point_center_of_object.svg
(32.92 КБ) 1402 скачивания
But I want to have the drilling done in the center of the path...
So if the path show a circle i want dxfpoint set in the center ! Or if it is a square or rectangle...set the dxfpoint to the center of the shape.
Have a you an idea ? or perhaps this will be a new good feature to add to dxfpoint ?
Happy new year ! and Have a nice day.
Re: dxfpoint
Добавлено: 03 янв 2012, 23:51
Hi! Happy new year!
We are going to improve dfx_points a little bit to be able to drill large holes with small mill bits. Probably they will look almost the same with orientation points. So it'll be an arrow with the text field. Just give us some time :)
Or may be you have some suggestions?
Re: dxfpoint
Добавлено: 04 янв 2012, 14:02
alfcnc
Ok ! I wait for :D !
Re: dxfpoint
Добавлено: 06 фев 2012, 19:43
CraftCadet
I too am looking forward to this update. I would like the ability to set the centre of circle to the DXF point.
Many thanks for this excellent Inkscape extention
Re: dxfpoint
Добавлено: 06 фев 2012, 20:33
As a quick fix, you can add snapping to the center of rotation and to the sharp angles, then you can easily place the circles exact at the points. You can find useful, to press SpaceBar while draggin the object - that will create a copy of it.
Re: dxfpoint
Добавлено: 06 фев 2012, 21:17
CraftCadet
thanks for the quick fix. worked well :)
