Как сделать чтоб emc при стартапе поднимался на весь экран?
Добавлено: 12 дек 2011, 22:38
Т.е maximized. Честно гуглил, но не нашел.
Статьи, обзоры, цены на станки и комплектующие.
https://cnc-club.ru/forum/
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/zai4ik/emc2/configs/CNC01'
Machine configuration file is 'CNC01.ini'
INIFILE=/home/zai4ik/emc2/configs/CNC01/CNC01.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1236
Killing task milltask, PID=1395
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
File "/usr/bin/axis", line 113, in <module>
root_window.attributes("-zoomed,1")
File "/usr/lib/python2.6/lib-tk/Tkinter.py", line 1454, in wm_attributes
return self.tk.call(args)
_tkinter.TclError: bad attribute "-zoomed,1": must be -alpha, -topmost, -zoomed, or -fullscreen
1236
PID TTY STAT TIME COMMAND
1395
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 19.627971] I-pipe: Domain RTAI registered.
[ 19.627982] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 19.627985] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 19.628041] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 19.628044] PIPELINE layers:
[ 19.628047] f83c4e20 9ac15d93 RTAI 200
[ 19.628050] c085cb20 0 Linux 100
[ 19.867032] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 19.877193] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 19.877200] RTAI[sched]: hard timer type/freq = APIC/8312420(Hz); default timing: periodic; linear timed lists.
[ 19.877205] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3325308000 hz.
[ 19.877207] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 19.878814] RTAI[usi]: enabled.
[ 20.217992] RTAI[math]: loaded.
[ 20.860663] config string '0x378 out '
[ 25.460050] eth0: no IPv6 routers present
[ 29.200096] RTAI[math]: unloaded.
[ 29.328134] SCHED releases registered named ALIEN RTGLBH
[ 29.344355] RTAI[malloc]: unloaded.
[ 29.444022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 29.456118] I-pipe: Domain RTAI unregistered.
[ 29.456130] RTAI[hal]: unmounted.
Ты написалMorzhovich писал(а):Код: Выделить всё
Debug file information: Traceback (most recent call last): File "/usr/bin/axis", line 113, in <module> root_window.attributes("-zoomed,1") File "/usr/lib/python2.6/lib-tk/Tkinter.py", line 1454, in wm_attributes return self.tk.call(args) _tkinter.TclError: bad attribute "-zoomed,1": must be -alpha, -topmost, -zoomed, or -fullscreen 1236
Кто ж зналpsha писал(а):Эта, не трогайте /usr/bin/axis, а? Есть же ~/.axisrc
Угу, действительно можно просто сделать этот файл, записать туда что надо и эксис из него подгружает потом.psha писал(а):Эта, не трогайте /usr/bin/axis, а? Есть же ~/.axisrc
root_window = Tkinter.Tk(className="Axis")
root_window.attributes("-zoomed",1)
root_window.attributes("-zoomed",1)Код: Выделить всё
root_window.attributes("-zoomed",1)уже 2.7 в мастере? ну-ну, неделю назад ставил 2.6 ещеLexxa писал(а):ЕМС 2.7
из-за ошибке пишет что 2.6 фактически 2.7PKM писал(а):ну-ну, неделю назад ставил 2.6
