Постпроцессор Artcam
Добавлено: 11 ноя 2016, 11:16
Всем привет. Для самодельного лазерного гравера сделал свой постпроцессор, но не уверен что не без ошибок, поэтому прошу глянуть на код и указать на допущенные ошибки или недочеты.
И еще почему-то прямую линию он выжигает волнистой!
DESCRIPTION = "LaserGRBL (*.nc)"
FILE_EXTENSION = "nc"
UNITS = MM
END_OF_LINE = "[13][10]"
LINE_NUM_START = 0
LINE_NUM_INCREMENT = 10
LINE_NUM_MAXIMUM = 999999
FORMAT = [N|@|N|1.0]
FORMAT = [S|@|S|1.0]
FORMAT = [F|#|F|1.0]
FORMAT = [X|#| X|1.1]
FORMAT = [Y|#| Y|1.1]
FORMAT = [Z|#| Z|1.1]
FORMAT = [I|@| I|1.1]
FORMAT = [J|@| J|1.1]
FORMAT = [XH|@| X|1.1]
FORMAT = [YH|@| Y|1.1]
FORMAT = [ZH|@| Z|1.1]
FORMAT = [T|#||02.0]
; Set up program header
START = "[N] G17 E01"
START = "[N] M06 T[T] H[T] D[T]"
START = "[N] G00 [XH][YH]"
START = "[N] G00 [ZH]"
START = "[N] G49"
START = "[N] M3 S40"
; Program moves
FIRST_RAPID_RATE_MOVE = "[N] G0 [X] [Y] [Z]"
PLUNGE_RATE_MOVE = "[N] M3 S1000"
FIRST_FEED_RATE_MOVE = "[N] G1 [X] [Y] [F]"
FEED_RATE_MOVE = "[N] [X] [Y]"
RETRACT_MOVE = "[N] M3 S40"
; Setup Toolchange commands
TOOLCHANGE = "[N] G00 [ZH]"
TOOLCHANGE = "[N] M06 T[T] H[T] D[T]"
TOOLCHANGE = "[N] G00 [XH][YH]"
TOOLCHANGE = "[N] M11"
TOOLCHANGE = "[N] [S] M03 M08"
; End of file
END = "[N] G0[ZH]"
END = "[N] [XH][YH]"
END = "[N] M3 S40"
END = "[N] M5"
END = "%"
