Страница 3 из 4
Re: Brother TC 228.
Добавлено: 07 май 2019, 11:40
john1987887
Servo drivers and spindle driver are from SZGH company?
Re: Brother TC 228.
Добавлено: 07 май 2019, 12:51
zars
Yes, 2600$ shipped.
Re: Brother TC 228.
Добавлено: 22 май 2019, 21:23
zars
https://www.youtube.com/watch?v=kvtY-77TSvA зажужала машинка...
Re: Brother TC 228.
Добавлено: 26 июн 2019, 14:48
zars
Waiting for a controller.
Re: Brother TC 228.
Добавлено: 26 июн 2019, 16:29
john1987887
White VFD under spindle driver for what purpose?
Re: Brother TC 228.
Добавлено: 26 июн 2019, 16:30
Dimka
On last video machine controlled with CSMIO by Mach3 or simCNC? What the new controller?
Re: Brother TC 228.
Добавлено: 26 июн 2019, 16:37
zars
Little VFD ir for coolant pump. 3 Phase 200v.
Controller will be Adtech ADT-CNC9640.
Re: Brother TC 228.
zars
Dimka писал(а):On last video machine controlled with CSMIO by Mach3 or simCNC? What the new controller?
Mach4
Re: Brother TC 228.
Добавлено: 05 авг 2019, 20:45
zars
Getting closer to finish.
Re: Brother TC 228.
Добавлено: 06 авг 2019, 05:30
john1987887
Nice! ATC macro for the controller is made by you?
Re: Brother TC 228.
Добавлено: 06 авг 2019, 12:12
zars
ATC is not done yet, that will be done by http://www.adtechcnc.co.uk/ guy. Just finished most of the wiring, soft limits, etc. Will try to machine round pocket later, to see how good or bad it is. So far controller looks not the easiest to set up, but good overall. Definitely far better than CSMIO.
Re: Brother TC 228.
Добавлено: 05 сен 2019, 15:51
zars
Re: Brother TC 228.
Добавлено: 30 сен 2019, 16:09
zars
Finally! Arduino doing the actual tool change. Adtech I/O action was too slow to deal with tool changer speed.
https://www.youtube.com/watch?v=4vYsvYj79pQ
Re: Brother TC 228.
Добавлено: 30 сен 2019, 17:48
john1987887
As i can see, you add raiser between spindle motor and the head. I just cut motor shaft with angle grinder, it was easier :)
Re: Brother TC 228.
Добавлено: 01 окт 2019, 13:42
zars
We where trying to keep parts as stock as possible. Unfortunately had to open motor holes, as it is smaller than original one.
Re: Brother TC 228.
Добавлено: 08 окт 2019, 12:54
zars
I need some help in finding, why holes are not coming out round. They are oval between X+ Y+ and X- Y- . The backlash is whitin 0.05mm on both axis, but 25mm comes out min.size 24.7mm, max size 25.1mm. Can it be controller, servo drive settings or anything else?
20191008_083255.jpg (9740 просмотров) <a class='original' href='./download/file.php?id=170127&mode=view' target=_blank>Загрузить оригинал (4.4 МБ)</a>
20191008_083233.jpg (9740 просмотров) <a class='original' href='./download/file.php?id=170128&mode=view' target=_blank>Загрузить оригинал (4.76 МБ)</a>
Re: Brother TC 228.
Добавлено: 08 окт 2019, 12:57
zars
Oh, 20mm square came out as 20.05x20.05mm
Re: Brother TC 228.
Добавлено: 08 окт 2019, 13:32
john1987887
zars писал(а):Can it be controller, servo drive settings or anything else?
Check servo drive settings, such as position loop gain or something that sounds like that. You should increase this parameter. Or post a link to the manual for your drives, i will take a look.
Re: Brother TC 228.
Добавлено: 08 окт 2019, 13:50
zars
Yeah, that helps a lot! Thank you.
Re: Brother TC 228.
Добавлено: 11 авг 2020, 00:16
nizamus
Куплен у Евгения шпиндельный сервопривод Sanyo Denki. Работать будет от частотника unidrive m700. Отмыт от слоя мазутообразного чего то :hehehe: , подобран трансформатор для питания вентилятора охлаждения, отловлены каналы энкодера.
IMG_20200810_145021.jpg (5771 просмотр) <a class='original' href='./download/file.php?id=184824&mode=view' target=_blank>Загрузить оригинал (4.76 МБ)</a>
IMG_20200810_143957.jpg (5771 просмотр) <a class='original' href='./download/file.php?id=184823&mode=view' target=_blank>Загрузить оригинал (4.19 МБ)</a>
Все пока идет своим чередом.
Вопрос к знатокам синхронных машин
IMG-20200810-WA0014.jpg (5771 просмотр) <a class='original' href='./download/file.php?id=184825&mode=view' target=_blank>Загрузить оригинал (74.68 КБ)</a>
При вращении вала на одной фазе два полных периода. Метки в начале и конце - индексная метка энкодера. Можно ли сделать вывод на основании этих данных о том, что количество полюсов - шесть?
