Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/mgg/Рабочий стол/my-conf_1'
Machine configuration file is 'my.ini'
INIFILE=/home/mgg/Рабочий стол/my-conf_1/my.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Found file(REL): ./my.hal
Found file(REL): ./custom.hal
Starting TASK program: milltask
Starting DISPLAY program: axis
Shutting down and cleaning up LinuxCNC...
Xlib.protocol.request.QueryExtension
**** auto_tool_measurement GETINIINFO ****
Preference file path: /home/mgg/Рабочий стол/my-conf_1/to_pci.pref
gladevcp: trouble looking for handlers in 'auto_tool_measurement': Недопустимый аргумент
**** probe_screen GETINIINFO ****
Killing task linuxcncsvr, PID=4366
Killing task milltask, PID=4407
task: 197 cycles, min=0.000019, max=0.021857, avg=0.009202, 0 latency excursions (> 10x expected cycle time of 0.010000s)
spindle-vfd: device='/dev/ttyUSB0', baud=19200, bits=8, parity='none', stopbits=1, slave=1, verbose=0, debug=0
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
dirname: лишний операнд «стол/my-conf_1/my.ini»
Попробуйте «dirname --help» для получения более подробного описания.
/usr/bin/gladevcp:185: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
builder.add_from_file(xmlname)
HAL: ERROR: duplicate component name 'auto_tool_measurement'
File "/usr/bin/gladevcp", line 122, in load_handlers
objlist = h(halcomp,builder,useropts)
File "python/auto_tool_measurement.py", line 407, in get_handlers
return [HandlerClass(halcomp,builder,useropts)]
File "python/auto_tool_measurement.py", line 345, in __init__
self.halcomp = hal.component("auto_tool_measurement")
error: Недопустимый аргумент
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_tool_number_value_changed'
builder.connect_signals(handlers)
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_manual_change'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_set_z'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_set_y'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_set_x'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_touch_off_z_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_touch_off_y_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_touch_off_x_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_probe_workpiece'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_block_height_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_probe_vel_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_search_vel_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_probe_tool_setter'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_probe_height_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_chk_use_tool_measurement_toggled'
custom_postgui.hal:28: Pin 'auto_tool_measurment.toolchange-change' does not exist
/usr/bin/gladevcp:295: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width -5 and height 15
gtk.main()
/usr/bin/gladevcp:295: GtkWarning: GdkWindow 0x3600003 unexpectedly destroyed
gtk.main()
**** GLADE VCP ERROR: X Protocol Error: 3
gtk.main()
/usr/bin/gladevcp:295: GtkWarning: GdkWindow 0x3400003 unexpectedly destroyed
gtk.main()
/usr/bin/gladevcp:295: GtkWarning: GdkWindow 0x3200003 unexpectedly destroyed
gtk.main()
4366
PID TTY STAT TIME COMMAND
4407
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000009fee0000 (usable)
[ 0.000000] BIOS-e820: 000000009fee0000 - 000000009fee3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000009fee3000 - 000000009fef0000 (ACPI data)
[ 0.000000] BIOS-e820: 000000009fef0000 - 000000009ff00000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: System manufacturer System Product Name/P5VD2-MX, BIOS ASUS P5VD2-MX ACPI BIOS Revision 0401 06/16/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x9fee0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CCFFF write-protect
[ 0.000000] CD000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 080000000 mask FE0000000 write-back
[ 0.000000] 2 base 0C0000000 mask FF8000000 write-combining
[ 0.000000] 3 base 09FF00000 mask FFFF00000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f5920] f5920
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36528000 - 3728c000
[ 0.000000] ACPI: RSDP 000f7810 00014 (v00 AWARD )
[ 0.000000] ACPI: RSDT 9fee3040 00030 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 9fee30c0 00074 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 9fee3180 07137 (v01 AWARD AWRDACPI 00001000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 9fee0000 00040
[ 0.000000] ACPI: MCFG 9feea400 0003C (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: APIC 9feea300 00090 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1670MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0009fee0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0009fee0
[ 0.000000] On node 0 totalpages: 654959
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5128200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 3342 pages used for memmap
[ 0.000000] HighMem zone: 424404 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 3, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: IOAPIC (id[0x05] address[0xfecc0000] gsi_base[24])
[ 0.000000] IOAPIC[1]: apic_id 5, version 3, address 0xfecc0000, GSI 24-47
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 64
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 9ff00000 (gap: 9ff00000:40100000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77ad000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 649841
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=685f2945-ac33-4dc3-8e1f-e7b1b0a54ffd ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 5240448 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0009fee0)
[ 0.000000] Memory: 2573540k/2620288k available (3495k kernel code, 46296k reserved, 1237k data, 416k init, 1710984k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:1024 16
[ 0.000000] CPU 0 irqstacks, hard=f4806000 soft=f4808000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1861.889 MHz processor.
[ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 3723.77 BogoMIPS (lpj=7447556)
[ 0.004008] pid_max: default: 32768 minimum: 301
[ 0.004064] Security Framework initialized
[ 0.004070] AppArmor: AppArmor disabled by boot time parameter
[ 0.004093] Mount-cache hash table entries: 512
[ 0.004365] Initializing cgroup subsys cpuacct
[ 0.004368] Initializing cgroup subsys memory
[ 0.004378] Initializing cgroup subsys devices
[ 0.004381] Initializing cgroup subsys freezer
[ 0.004383] Initializing cgroup subsys net_cls
[ 0.004386] Initializing cgroup subsys blkio
[ 0.004394] Initializing cgroup subsys perf_event
[ 0.004428] CPU: Physical Processor ID: 0
[ 0.004430] CPU: Processor Core ID: 0
[ 0.004433] mce: CPU supports 6 MCE banks
[ 0.004441] CPU0: Thermal monitoring enabled (TM1)
[ 0.004503] ACPI: Core revision 20120320
[ 0.015172] Enabling APIC mode: Flat. Using 2 I/O APICs
[ 0.016711] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.056408] CPU0: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz stepping 06
[ 0.060003] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.060003] PEBS disabled due to CPU errata.
[ 0.060003] ... version: 2
[ 0.060003] ... bit width: 40
[ 0.060003] ... generic registers: 2
[ 0.060003] ... value mask: 000000ffffffffff
[ 0.060003] ... max period: 000000007fffffff
[ 0.060003] ... fixed-purpose events: 3
[ 0.060003] ... event mask: 0000000700000003
[ 0.068067] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.080026] CPU 1 irqstacks, hard=f48d4000 soft=f48d6000
[ 0.080030] Booting Node 0, Processors #1
[ 0.008000] Initializing CPU#1
[ 0.092045] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.092102] Brought up 2 CPUs
[ 0.092106] Total of 2 processors activated (7447.55 BogoMIPS).
[ 0.093537] devtmpfs: initialized
[ 0.093537] PM: Registering ACPI NVS region [mem 0x9fee0000-0x9fee2fff] (12288 bytes)
[ 0.093537] dummy:
[ 0.093537] NET: Registered protocol family 16
[ 0.093537] ACPI: bus type pci registered
[ 0.093537] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.093537] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.093537] PCI: Using MMCONFIG for extended config space
[ 0.093537] PCI: Using configuration type 1 for base access
[ 0.093537] mtrr: your CPUs had inconsistent fixed MTRR settings
[ 0.093537] mtrr: probably your BIOS does not setup all CPUs.
[ 0.093537] mtrr: corrected configuration.
[ 0.096420] bio: create slab <bio-0> at 0
[ 0.096420] ACPI: Added _OSI(Module Device)
[ 0.096420] ACPI: Added _OSI(Processor Device)
[ 0.096420] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.096420] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.098801] ACPI: EC: Look up EC in DSDT
[ 0.112543] ACPI: Interpreter enabled
[ 0.112563] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.112606] ACPI: Using IOAPIC for interrupt routing
[ 0.122085] ACPI: No dock devices found.
[ 0.122095] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.122183] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.122313] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.122317] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.122321] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.122325] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[ 0.122328] pci_root PNP0A08:00: host bridge window [mem 0x9ff00000-0xfebfffff] (ignored)
[ 0.122332] PCI: root bus 00: using default resources
[ 0.122388] PCI host bridge to bus 0000:00
[ 0.122392] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.122395] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.122417] pci 0000:00:00.0: [1106:0327] type 00 class 0x060000
[ 0.122432] pci 0000:00:00.0: reg 10: [mem 0xc0000000-0xc7ffffff pref]
[ 0.122522] pci 0000:00:00.1: [1106:1327] type 00 class 0x060000
[ 0.122589] pci 0000:00:00.2: [1106:2327] type 00 class 0x060000
[ 0.122656] pci 0000:00:00.3: [1106:3327] type 00 class 0x060000
[ 0.122721] pci 0000:00:00.4: [1106:4327] type 00 class 0x060000
[ 0.122788] pci 0000:00:00.5: [1106:5327] type 00 class 0x080020
[ 0.122884] pci 0000:00:00.6: [1106:6327] type 00 class 0x060000
[ 0.122951] pci 0000:00:00.7: [1106:7327] type 00 class 0x060000
[ 0.123019] pci 0000:00:01.0: [1106:b198] type 01 class 0x060400
[ 0.123095] pci 0000:00:02.0: [1106:a327] type 01 class 0x060400
[ 0.123176] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.123216] pci 0000:00:03.0: [1106:c327] type 01 class 0x060400
[ 0.123309] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.123378] pci 0000:00:0f.0: [1106:0591] type 00 class 0x01018f
[ 0.123401] pci 0000:00:0f.0: reg 10: [io 0xfc00-0xfc07]
[ 0.123414] pci 0000:00:0f.0: reg 14: [io 0xf800-0xf803]
[ 0.123427] pci 0000:00:0f.0: reg 18: [io 0xf400-0xf407]
[ 0.123441] pci 0000:00:0f.0: reg 1c: [io 0xf000-0xf003]
[ 0.123454] pci 0000:00:0f.0: reg 20: [io 0xec00-0xec0f]
[ 0.123467] pci 0000:00:0f.0: reg 24: [io 0xe800-0xe8ff]
[ 0.123522] pci 0000:00:0f.1: [1106:0571] type 00 class 0x01018a
[ 0.123584] pci 0000:00:0f.1: reg 20: [io 0xe400-0xe40f]
[ 0.123660] pci 0000:00:10.0: [1106:3038] type 00 class 0x0c0300
[ 0.123721] pci 0000:00:10.0: reg 20: [io 0xe000-0xe01f]
[ 0.123764] pci 0000:00:10.0: supports D1 D2
[ 0.123767] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.123791] pci 0000:00:10.1: [1106:3038] type 00 class 0x0c0300
[ 0.123852] pci 0000:00:10.1: reg 20: [io 0xdc00-0xdc1f]
[ 0.123896] pci 0000:00:10.1: supports D1 D2
[ 0.123899] pci 0000:00:10.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.123924] pci 0000:00:10.2: [1106:3038] type 00 class 0x0c0300
[ 0.123984] pci 0000:00:10.2: reg 20: [io 0xd800-0xd81f]
[ 0.124041] pci 0000:00:10.2: supports D1 D2
[ 0.124044] pci 0000:00:10.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.124068] pci 0000:00:10.3: [1106:3038] type 00 class 0x0c0300
[ 0.124129] pci 0000:00:10.3: reg 20: [io 0xd400-0xd41f]
[ 0.124173] pci 0000:00:10.3: supports D1 D2
[ 0.124175] pci 0000:00:10.3: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.124200] pci 0000:00:10.4: [1106:3104] type 00 class 0x0c0320
[ 0.124222] pci 0000:00:10.4: reg 10: [mem 0xdffff000-0xdffff0ff]
[ 0.124305] pci 0000:00:10.4: supports D1 D2
[ 0.124308] pci 0000:00:10.4: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.124338] pci 0000:00:11.0: [1106:3337] type 00 class 0x060100
[ 0.124470] pci 0000:00:11.7: [1106:287e] type 00 class 0x060000
[ 0.124548] pci 0000:00:12.0: [1106:3065] type 00 class 0x020000
[ 0.124570] pci 0000:00:12.0: reg 10: [io 0xd000-0xd0ff]
[ 0.124583] pci 0000:00:12.0: reg 14: [mem 0xdfffe000-0xdfffe0ff]
[ 0.124657] pci 0000:00:12.0: supports D1 D2
[ 0.124660] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.124687] pci 0000:00:13.0: [1106:337b] type 01 class 0x060400
[ 0.124780] pci 0000:00:13.1: [1106:337a] type 01 class 0x060401
[ 0.124959] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.125047] pci 0000:02:00.0: [10de:0de1] type 00 class 0x030000
[ 0.125064] pci 0000:02:00.0: reg 10: [mem 0xdd000000-0xddffffff]
[ 0.125082] pci 0000:02:00.0: reg 14: [mem 0xc8000000-0xcfffffff 64bit pref]
[ 0.125100] pci 0000:02:00.0: reg 1c: [mem 0xd6000000-0xd7ffffff 64bit pref]
[ 0.125113] pci 0000:02:00.0: reg 24: [io 0xcc00-0xcc7f]
[ 0.125125] pci 0000:02:00.0: reg 30: [mem 0xdef00000-0xdef7ffff pref]
[ 0.125198] pci 0000:02:00.1: [10de:0bea] type 00 class 0x040300
[ 0.125214] pci 0000:02:00.1: reg 10: [mem 0xdeffc000-0xdeffffff]
[ 0.132030] pci 0000:00:02.0: PCI bridge to [bus 02-02]
[ 0.132036] pci 0000:00:02.0: bridge window [io 0xc000-0xcfff]
[ 0.132042] pci 0000:00:02.0: bridge window [mem 0xdd000000-0xdeffffff]
[ 0.132051] pci 0000:00:02.0: bridge window [mem 0xc8000000-0xd7ffffff 64bit pref]
[ 0.132145] pci 0000:03:00.0: [197b:2363] type 00 class 0x010185
[ 0.132242] pci 0000:03:00.0: reg 24: [mem 0xdfefe000-0xdfefffff]
[ 0.132258] pci 0000:03:00.0: reg 30: [mem 0xdfee0000-0xdfeeffff pref]
[ 0.132294] pci 0000:03:00.0: PME# supported from D3hot
[ 0.132331] pci 0000:03:00.1: [197b:2363] type 00 class 0x010185
[ 0.132358] pci 0000:03:00.1: reg 10: [io 0xbc00-0xbc07]
[ 0.132374] pci 0000:03:00.1: reg 14: [io 0xb800-0xb803]
[ 0.132390] pci 0000:03:00.1: reg 18: [io 0xb400-0xb407]
[ 0.132405] pci 0000:03:00.1: reg 1c: [io 0xb000-0xb003]
[ 0.132421] pci 0000:03:00.1: reg 20: [io 0xac00-0xac0f]
[ 0.132499] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.132516] pci 0000:00:03.0: PCI bridge to [bus 03-03]
[ 0.132522] pci 0000:00:03.0: bridge window [io 0xa000-0xbfff]
[ 0.132528] pci 0000:00:03.0: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.132594] pci 0000:04:01.0: [1106:3288] type 00 class 0x040300
[ 0.132615] pci 0000:04:01.0: reg 10: [mem 0xdfdfc000-0xdfdfffff 64bit]
[ 0.132690] pci 0000:04:01.0: PME# supported from D0 D3hot D3cold
[ 0.132708] pci 0000:04:01.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.132758] pci 0000:00:13.0: PCI bridge to [bus 04-04]
[ 0.132766] pci 0000:00:13.0: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.132825] pci 0000:05:04.0: [2105:5555] type 00 class 0x110000
[ 0.132841] pci 0000:05:04.0: reg 10: [mem 0xdfcff000-0xdfcff01f]
[ 0.132953] pci 0000:00:13.1: PCI bridge to [bus 05-05] (subtractive decode)
[ 0.132961] pci 0000:00:13.1: bridge window [mem 0xdfc00000-0xdfcfffff]
[ 0.132970] pci 0000:00:13.1: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.132973] pci 0000:00:13.1: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.133005] pci_bus 0000:00: on NUMA node 0
[ 0.133010] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.133569] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEXG._PRT]
[ 0.133715] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 0.133860] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2PE._PRT]
[ 0.133992] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2PB._PRT]
[ 0.134152] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.192242] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12)
[ 0.192394] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 11 12) *5
[ 0.192552] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 6 7 10 11 12)
[ 0.192707] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12)
[ 0.192822] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.192933] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.193043] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.193175] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 10 *11 12)
[ 0.193254] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.193254] vgaarb: loaded
[ 0.193254] vgaarb: bridge control possible 0000:02:00.0
[ 0.193254] PCI: Using ACPI for IRQ routing
[ 0.203774] PCI: pci_cache_line_size set to 64 bytes
[ 0.203923] reserve RAM buffer: 000000000009f800 - 000000000009ffff
[ 0.203927] reserve RAM buffer: 000000009fee0000 - 000000009fffffff
[ 0.204226] pnp: PnP ACPI init
[ 0.204243] ACPI: bus type pnp registered
[ 0.204362] pnp 00:00: [bus 00-ff]
[ 0.204366] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.204370] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.204373] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.204377] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.204380] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.204383] pnp 00:00: [mem 0x9ff00000-0xfebfffff window]
[ 0.204453] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.204486] pnp 00:01: [io 0x0400-0x047f]
[ 0.204490] pnp 00:01: [io 0x0500-0x050f]
[ 0.204556] system 00:01: [io 0x0400-0x047f] has been reserved
[ 0.204561] system 00:01: [io 0x0500-0x050f] has been reserved
[ 0.204565] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.205332] pnp 00:02: [mem 0x10000000-0x10000fff]
[ 0.205421] system 00:02: [mem 0x10000000-0x10000fff] could not be reserved
[ 0.205426] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.205783] pnp 00:03: [io 0x0010-0x001f]
[ 0.205786] pnp 00:03: [io 0x0022-0x003f]
[ 0.205789] pnp 00:03: [io 0x0044-0x005f]
[ 0.205792] pnp 00:03: [io 0x0062-0x0063]
[ 0.205795] pnp 00:03: [io 0x0065-0x006f]
[ 0.205798] pnp 00:03: [io 0x0074-0x007f]
[ 0.205801] pnp 00:03: [io 0x0091-0x0093]
[ 0.205804] pnp 00:03: [io 0x00a2-0x00bf]
[ 0.205807] pnp 00:03: [io 0x00e0-0x00ef]
[ 0.205810] pnp 00:03: [io 0x04d0-0x04d1]
[ 0.205813] pnp 00:03: [io 0x0290-0x029f]
[ 0.205815] pnp 00:03: [io 0x0800-0x0805]
[ 0.205818] pnp 00:03: [io 0x0880-0x088f]
[ 0.205921] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.205925] system 00:03: [io 0x0290-0x029f] has been reserved
[ 0.205929] system 00:03: [io 0x0800-0x0805] has been reserved
[ 0.205933] system 00:03: [io 0x0880-0x088f] has been reserved
[ 0.205938] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.205961] pnp 00:04: [dma 4]
[ 0.205964] pnp 00:04: [io 0x0000-0x000f]
[ 0.205967] pnp 00:04: [io 0x0080-0x0090]
[ 0.205970] pnp 00:04: [io 0x0094-0x009f]
[ 0.205973] pnp 00:04: [io 0x00c0-0x00df]
[ 0.206033] pnp 00:04: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.206052] pnp 00:05: [io 0x0070-0x0073]
[ 0.206064] pnp 00:05: [irq 8]
[ 0.206127] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.206142] pnp 00:06: [io 0x0061]
[ 0.206203] pnp 00:06: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.206220] pnp 00:07: [io 0x00f0-0x00ff]
[ 0.206227] pnp 00:07: [irq 13]
[ 0.206290] pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.206503] pnp 00:08: [io 0x03f0-0x03f5]
[ 0.206507] pnp 00:08: [io 0x03f7]
[ 0.206514] pnp 00:08: [irq 6]
[ 0.206517] pnp 00:08: [dma 2]
[ 0.206598] pnp 00:08: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.206878] pnp 00:09: [io 0x03f8-0x03ff]
[ 0.206885] pnp 00:09: [irq 4]
[ 0.206985] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.207625] pnp 00:0a: [io 0x0378-0x037f]
[ 0.207629] pnp 00:0a: [io 0x0778-0x077b]
[ 0.207636] pnp 00:0a: [irq 7]
[ 0.207639] pnp 00:0a: [dma 3]
[ 0.207739] pnp 00:0a: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.207827] pnp 00:0b: [io 0x0060]
[ 0.207830] pnp 00:0b: [io 0x0064]
[ 0.207837] pnp 00:0b: [irq 12]
[ 0.207911] pnp 00:0b: Plug and Play ACPI device, IDs PNP0f13 (active)
[ 0.208024] pnp 00:0c: [mem 0xe0000000-0xefffffff]
[ 0.208123] system 00:0c: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.208128] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.208341] pnp 00:0d: [mem 0x000d2800-0x000d3fff]
[ 0.208345] pnp 00:0d: [mem 0x000f0000-0x000f7fff]
[ 0.208348] pnp 00:0d: [mem 0x000f8000-0x000fbfff]
[ 0.208351] pnp 00:0d: [mem 0x000fc000-0x000fffff]
[ 0.208354] pnp 00:0d: [mem 0x9fee0000-0x9fefffff]
[ 0.208357] pnp 00:0d: [mem 0xffff0000-0xffffffff]
[ 0.208360] pnp 00:0d: [mem 0x00000000-0x0009ffff]
[ 0.208363] pnp 00:0d: [mem 0x00100000-0x9fedffff]
[ 0.208366] pnp 00:0d: [mem 0xfec00000-0xfec00fff]
[ 0.208371] pnp 00:0d: [mem 0xfee00000-0xfee00fff]
[ 0.208375] pnp 00:0d: [mem 0xfff80000-0xfffeffff]
[ 0.208484] system 00:0d: [mem 0x000d2800-0x000d3fff] has been reserved
[ 0.208490] system 00:0d: [mem 0x000f0000-0x000f7fff] could not be reserved
[ 0.208494] system 00:0d: [mem 0x000f8000-0x000fbfff] could not be reserved
[ 0.208498] system 00:0d: [mem 0x000fc000-0x000fffff] could not be reserved
[ 0.208502] system 00:0d: [mem 0x9fee0000-0x9fefffff] could not be reserved
[ 0.208506] system 00:0d: [mem 0xffff0000-0xffffffff] has been reserved
[ 0.208510] system 00:0d: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.208515] system 00:0d: [mem 0x00100000-0x9fedffff] could not be reserved
[ 0.208519] system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.208523] system 00:0d: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.208527] system 00:0d: [mem 0xfff80000-0xfffeffff] has been reserved
[ 0.208532] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.208546] pnp: PnP ACPI: found 14 devices
[ 0.208549] ACPI: ACPI bus type pnp unregistered
[ 0.208553] PnPBIOS: Disabled by ACPI PNP
[ 0.245635] Switching to clocksource acpi_pm
[ 0.245703] pci 0000:00:03.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 0.245728] pci 0000:00:03.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.245735] pci 0000:00:03.0: BAR 15: assigned [mem 0xa0000000-0xa01fffff 64bit pref]
[ 0.245739] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.245754] pci 0000:00:02.0: PCI bridge to [bus 02-02]
[ 0.245758] pci 0000:00:02.0: bridge window [io 0xc000-0xcfff]
[ 0.245765] pci 0000:00:02.0: bridge window [mem 0xdd000000-0xdeffffff]
[ 0.245771] pci 0000:00:02.0: bridge window [mem 0xc8000000-0xd7ffffff 64bit pref]
[ 0.245780] pci 0000:00:03.0: PCI bridge to [bus 03-03]
[ 0.245784] pci 0000:00:03.0: bridge window [io 0xa000-0xbfff]
[ 0.245792] pci 0000:00:03.0: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.245798] pci 0000:00:03.0: bridge window [mem 0xa0000000-0xa01fffff 64bit pref]
[ 0.245808] pci 0000:00:13.0: PCI bridge to [bus 04-04]
[ 0.245814] pci 0000:00:13.0: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.245825] pci 0000:00:13.1: PCI bridge to [bus 05-05]
[ 0.245832] pci 0000:00:13.1: bridge window [mem 0xdfc00000-0xdfcfffff]
[ 0.245853] pci 0000:00:01.0: setting latency timer to 64
[ 0.245892] pci 0000:00:13.0: setting latency timer to 64
[ 0.245902] pci 0000:00:13.1: setting latency timer to 64
[ 0.245907] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.245910] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.245914] pci_bus 0000:02: resource 0 [io 0xc000-0xcfff]
[ 0.245917] pci_bus 0000:02: resource 1 [mem 0xdd000000-0xdeffffff]
[ 0.245921] pci_bus 0000:02: resource 2 [mem 0xc8000000-0xd7ffffff 64bit pref]
[ 0.245924] pci_bus 0000:03: resource 0 [io 0xa000-0xbfff]
[ 0.245928] pci_bus 0000:03: resource 1 [mem 0xdfe00000-0xdfefffff]
[ 0.245931] pci_bus 0000:03: resource 2 [mem 0xa0000000-0xa01fffff 64bit pref]
[ 0.245935] pci_bus 0000:04: resource 1 [mem 0xdfd00000-0xdfdfffff]
[ 0.245938] pci_bus 0000:05: resource 1 [mem 0xdfc00000-0xdfcfffff]
[ 0.245941] pci_bus 0000:05: resource 4 [io 0x0000-0xffff]
[ 0.245945] pci_bus 0000:05: resource 5 [mem 0x00000000-0xffffffff]
[ 0.246045] NET: Registered protocol family 2
[ 0.246129] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.246356] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.246870] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.247194] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.247197] TCP: reno registered
[ 0.247200] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.247211] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.247328] NET: Registered protocol family 1
[ 0.247373] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.247610] pci 0000:02:00.0: Boot video device
[ 0.247631] PCI: CLS 32 bytes, default 64
[ 0.247706] Unpacking initramfs...
[ 0.605638] Freeing initrd memory: 13712k freed
[ 0.613852] audit: initializing netlink socket (disabled)
[ 0.613888] type=2000 audit(1518248318.612:1): initialized
[ 0.628544] highmem bounce pool size: 64 pages
[ 0.628551] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.628812] VFS: Disk quotas dquot_6.5.2
[ 0.628849] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.628954] msgmni has been set to 1711
[ 0.629192] alg: No test for stdrng (krng)
[ 0.629229] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.629234] io scheduler noop registered
[ 0.629237] io scheduler deadline registered
[ 0.629262] io scheduler cfq registered (default)
[ 0.629608] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.629633] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.629636] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.630749] GHES: HEST is not enabled!
[ 0.630766] isapnp: Scanning for PnP cards...
[ 0.984899] isapnp: No Plug & Play device found
[ 0.984968] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.005329] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.026123] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.026354] Linux agpgart interface v0.103
[ 1.026515] agpgart: Detected VIA P4M890 chipset
[ 1.032114] agpgart-via 0000:00:00.0: AGP aperture is 128M @ 0xc0000000
[ 1.032251] i8042: PNP: PS/2 Controller [PNP0f13:PS2M] at 0x60,0x64 irq 12
[ 1.032255] i8042: PNP: PS/2 controller doesn't have KBD irq; using default 1
[ 1.032737] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.032755] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.032924] mousedev: PS/2 mouse device common for all mice
[ 1.032973] rtc_cmos 00:05: RTC can wake from S4
[ 1.033178] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 1.033232] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 1.033409] TCP: cubic registered
[ 1.033482] NET: Registered protocol family 10
[ 1.033779] Mobile IPv6
[ 1.033783] NET: Registered protocol family 17
[ 1.033789] Registering the dns_resolver key type
[ 1.033871] Using IPI No-Shortcut mode
[ 1.034017] PM: Hibernation image not present or could not be loaded.
[ 1.034032] registered taskstats version 1
[ 1.034641] rtc_cmos 00:05: setting system clock to 2018-02-10 07:38:39 UTC (1518248319)
[ 1.034749] Freeing unused kernel memory: 416k freed
[ 1.034954] Write protecting the kernel text: 3496k
[ 1.034985] Write protecting the kernel read-only data: 984k
[ 1.049402] udevd[49]: starting version 175
[ 1.079435] SCSI subsystem initialized
[ 1.088508] usbcore: registered new interface driver usbfs
[ 1.088544] usbcore: registered new interface driver hub
[ 1.098008] via_rhine: v1.10-LK1.5.0 2010-10-09 Written by Donald Becker
[ 1.098358] via-rhine 0000:00:12.0: eth0: VIA Rhine II at 0x1d000, 00:00:00:00:00:10, IRQ 23
[ 1.099149] via-rhine 0000:00:12.0: eth0: MII PHY found at address 1, status 0x7849 advertising 01e1 Link 0000
[ 1.111359] usbcore: registered new device driver usb
[ 1.111979] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.112710] libata version 3.00 loaded.
[ 1.113736] ehci_hcd 0000:00:10.4: EHCI Host Controller
[ 1.113773] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1
[ 1.113848] ehci_hcd 0000:00:10.4: irq 21, io mem 0xdffff000
[ 1.122235] ahci 0000:03:00.0: version 3.0
[ 1.122340] ahci 0000:03:00.0: PCI: Disallowing DAC for device
[ 1.124035] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00
[ 1.124115] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.124119] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.124123] usb usb1: Product: EHCI Host Controller
[ 1.124126] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.124129] usb usb1: SerialNumber: 0000:00:10.4
[ 1.124310] hub 1-0:1.0: USB hub found
[ 1.124320] hub 1-0:1.0: 8 ports detected
[ 1.124621] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.124689] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 1.124703] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 1.124760] uhci_hcd 0000:00:10.0: irq 20, io base 0x0000e000
[ 1.124804] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.124808] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.124811] usb usb2: Product: UHCI Host Controller
[ 1.124814] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.124817] usb usb2: SerialNumber: 0000:00:10.0
[ 1.125316] hub 2-0:1.0: USB hub found
[ 1.125324] hub 2-0:1.0: 2 ports detected
[ 1.125457] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 1.125468] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
[ 1.125523] uhci_hcd 0000:00:10.1: irq 22, io base 0x0000dc00
[ 1.125566] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.125570] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.125573] usb usb3: Product: UHCI Host Controller
[ 1.125576] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.125579] usb usb3: SerialNumber: 0000:00:10.1
[ 1.126066] hub 3-0:1.0: USB hub found
[ 1.126074] hub 3-0:1.0: 2 ports detected
[ 1.126196] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 1.126207] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
[ 1.126232] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d800
[ 1.126273] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.126277] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.126281] usb usb4: Product: UHCI Host Controller
[ 1.126284] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.126287] usb usb4: SerialNumber: 0000:00:10.2
[ 1.126426] hub 4-0:1.0: USB hub found
[ 1.126435] hub 4-0:1.0: 2 ports detected
[ 1.126552] uhci_hcd 0000:00:10.3: UHCI Host Controller
[ 1.126562] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5
[ 1.126616] uhci_hcd 0000:00:10.3: irq 23, io base 0x0000d400
[ 1.126657] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.126661] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.126664] usb usb5: Product: UHCI Host Controller
[ 1.126667] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.126670] usb usb5: SerialNumber: 0000:00:10.3
[ 1.126802] hub 5-0:1.0: USB hub found
[ 1.126808] hub 5-0:1.0: 2 ports detected
[ 1.126916] pata_via 0000:00:0f.1: version 0.3.4
[ 1.128808] scsi0 : pata_via
[ 1.129763] microcode: CPU0 sig=0x6f6, pf=0x1, revision=0x0
[ 1.129822] scsi1 : pata_via
[ 1.132511] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xe400 irq 14
[ 1.132516] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xe408 irq 15
[ 1.132584] sata_via 0000:00:0f.0: version 2.6
[ 1.132644] sata_via 0000:00:0f.0: routed to hard irq line 11
[ 1.133986] scsi2 : sata_via
[ 1.134237] scsi3 : sata_via
[ 1.136086] ahci 0000:03:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[ 1.136092] ahci 0000:03:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[ 1.138333] ata3: SATA max UDMA/133 cmd 0xfc00 ctl 0xf800 bmdma 0xec00 irq 21
[ 1.138339] ata4: SATA max UDMA/133 cmd 0xf400 ctl 0xf000 bmdma 0xec08 irq 21
[ 1.138397] scsi4 : ahci
[ 1.139036] scsi5 : ahci
[ 1.139122] ata5: SATA max UDMA/133 abar m8192@0xdfefe000 port 0xdfefe100 irq 28
[ 1.139128] ata6: SATA max UDMA/133 abar m8192@0xdfefe000 port 0xdfefe180 irq 28
[ 1.139167] pata_jmicron 0000:03:00.1: enabling device (0000 -> 0001)
[ 1.139256] pata_jmicron 0000:03:00.1: setting latency timer to 64
[ 1.140948] scsi6 : pata_jmicron
[ 1.141180] scsi7 : pata_jmicron
[ 1.141251] ata7: PATA max UDMA/100 cmd 0xbc00 ctl 0xb800 bmdma 0xac00 irq 29
[ 1.141255] ata8: PATA max UDMA/100 cmd 0xb400 ctl 0xb000 bmdma 0xac08 irq 29
[ 1.143550] Floppy drive(s): fd0 is 1.44M
[ 1.160393] FDC 0 is a post-1991 82077
[ 1.204524] microcode: CPU0 updated to revision 0xd0, date = 2010-09-30
[ 1.204538] microcode: CPU1 sig=0x6f6, pf=0x1, revision=0x0
[ 1.207668] microcode: CPU1 updated to revision 0xd0, date = 2010-09-30
[ 1.207730] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.340025] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.436019] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.456035] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.456063] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.509508] ata3.00: ATA-7: WDC WD1600AAJS-00PSA0, 05.06H05, max UDMA/133
[ 1.509512] ata3.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.524400] ata3.00: configured for UDMA/133
[ 1.524564] scsi 2:0:0:0: Direct-Access ATA WDC WD1600AAJS-0 05.0 PQ: 0 ANSI: 5
[ 1.571464] usb 1-1: New USB device found, idVendor=0930, idProduct=6545
[ 1.571469] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.571472] usb 1-1: Product: DT 101 G2
[ 1.571475] usb 1-1: Manufacturer: Kingston
[ 1.571478] usb 1-1: SerialNumber: 0019E06B70F9ECC0F75C0035
[ 1.574658] Initializing USB Mass Storage driver...
[ 1.574788] scsi8 : usb-storage 1-1:1.0
[ 1.574892] usbcore: registered new interface driver usb-storage
[ 1.574894] USB Mass Storage support registered.
[ 1.612026] Refined TSC clocksource calibration: 1861.999 MHz.
[ 1.612033] Switching to clocksource tsc
[ 1.728018] ata4: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[ 1.904496] ACPI: Fan [FAN] (on)
[ 1.912763] sd 2:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 1.912857] sd 2:0:0:0: [sda] Write Protect is off
[ 1.912862] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.912895] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.942504] sda: sda1 sda2 < sda5 >
[ 1.942950] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.945207] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 2.032028] usb 3-1: new full-speed USB device number 2 using uhci_hcd
[ 2.194615] usb 3-1: New USB device found, idVendor=046d, idProduct=c52b
[ 2.194620] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.194624] usb 3-1: Product: USB Receiver
[ 2.194627] usb 3-1: Manufacturer: Logitech
[ 2.205365] usbcore: registered new interface driver usbhid
[ 2.205369] usbhid: USB HID core driver
[ 2.215769] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:10.1-1/input2
[ 2.220820] input: Logitech Unifying Device. Wireless PID:400d as /devices/pci0000:00/0000:00:10.1/usb3/3-1/3-1:1.2/0003:046D:C52B.0003/input/input0
[ 2.220909] logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:400d] on usb-0000:00:10.1-1:2
[ 2.436019] usb 3-2: new full-speed USB device number 3 using uhci_hcd
[ 2.574161] scsi 8:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 4
[ 2.574937] sd 8:0:0:0: Attached scsi generic sg1 type 0
[ 2.576032] sd 8:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[ 2.576509] sd 8:0:0:0: [sdb] Write Protect is off
[ 2.576514] sd 8:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 2.577015] sd 8:0:0:0: [sdb] No Caching mode page present
[ 2.577087] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 2.580264] sd 8:0:0:0: [sdb] No Caching mode page present
[ 2.580332] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 2.581450] sdb: sdb1
[ 2.583757] sd 8:0:0:0: [sdb] No Caching mode page present
[ 2.583827] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 2.583894] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[ 2.622629] usb 3-2: New USB device found, idVendor=0403, idProduct=6001
[ 2.622634] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.622637] usb 3-2: Product: FT232R USB UART
[ 2.622640] usb 3-2: Manufacturer: FTDI
[ 2.622643] usb 3-2: SerialNumber: A9J8TN73
[ 7.619536] PM: Starting manual resume from disk
[ 7.619541] PM: Hibernation image partition 8:5 present
[ 7.619543] PM: Looking for hibernation image.
[ 7.619828] PM: Image not found (code -22)
[ 7.619832] PM: Hibernation image not present or could not be loaded.
[ 7.660634] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.424064] udevd[387]: starting version 175
[ 9.654091] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 9.654101] ACPI: Power Button [PWRB]
[ 9.654173] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 9.654179] ACPI: Sleep Button [SLPB]
[ 9.654289] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 9.654294] ACPI: Power Button [PWRF]
[ 9.707166] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 9.834416] parport_pc 00:0a: reported by Plug and Play ACPI
[ 9.834490] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 10.086347] hda_intel: Disabling MSI
[ 10.086395] snd_hda_intel 0000:02:00.1: PCI: Disallowing DAC for device
[ 10.100889] coretemp coretemp.0: Using relative temperature scale!
[ 10.100903] coretemp coretemp.0: Using relative temperature scale!
[ 10.175645] udevd[446]: renamed network interface eth0 to eth1
[ 10.272214] [drm] Initialized drm 1.1.0 20060810
[ 10.361351] wmi: Mapper loaded
[ 10.734683] usbcore: registered new interface driver usbserial
[ 10.734706] usbcore: registered new interface driver usbserial_generic
[ 10.734722] USB Serial support registered for generic
[ 10.734746] usbserial: USB Serial Driver core
[ 10.739009] usbcore: registered new interface driver ftdi_sio
[ 10.739170] USB Serial support registered for FTDI USB Serial Device
[ 10.739248] ftdi_sio 3-2:1.0: FTDI USB Serial Device converter detected
[ 10.739287] usb 3-2: Detected FT232RL
[ 10.739290] usb 3-2: Number of endpoints 2
[ 10.739294] usb 3-2: Endpoint 1 MaxPacketSize 64
[ 10.739297] usb 3-2: Endpoint 2 MaxPacketSize 64
[ 10.739300] usb 3-2: Setting MaxPacketSize 64
[ 10.741959] usb 3-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 10.741971] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 10.909162] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input4
[ 10.984115] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card0/input5
[ 10.984239] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card0/input6
[ 10.984601] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card0/input7
[ 10.985425] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card0/input8
[ 10.986149] hda_intel: position_fix set to 1 for device 1043:81b3
[ 10.986236] snd_hda_intel 0000:04:01.0: PCI: Disallowing DAC for device
[ 10.986688] [drm] nouveau 0000:02:00.0: Detected an NVc0 generation card (0x0c1080a1)
[ 10.993960] [drm] nouveau 0000:02:00.0: Checking PRAMIN for VBIOS
[ 11.054853] [drm] nouveau 0000:02:00.0: ... appears to be valid
[ 11.054858] [drm] nouveau 0000:02:00.0: Using VBIOS from PRAMIN
[ 11.054862] [drm] nouveau 0000:02:00.0: BIT BIOS found
[ 11.054866] [drm] nouveau 0000:02:00.0: Bios version 70.08.29.00
[ 11.054870] [drm] nouveau 0000:02:00.0: TMDS table version 2.0
[ 11.055256] [drm] nouveau 0000:02:00.0: MXM: no VBIOS data, nothing to do
[ 11.055260] [drm] nouveau 0000:02:00.0: DCB version 4.0
[ 11.055265] [drm] nouveau 0000:02:00.0: DCB outp 00: 01000302 00020030
[ 11.055268] [drm] nouveau 0000:02:00.0: DCB outp 01: 02000300 00000000
[ 11.055272] [drm] nouveau 0000:02:00.0: DCB outp 02: 08011392 00020020
[ 11.055275] [drm] nouveau 0000:02:00.0: DCB outp 03: 04022310 00000000
[ 11.055278] [drm] nouveau 0000:02:00.0: DCB conn 00: 00001030
[ 11.055282] [drm] nouveau 0000:02:00.0: DCB conn 01: 00002161
[ 11.055286] [drm] nouveau 0000:02:00.0: DCB conn 02: 00000200
[ 11.055291] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 0 at offset 0x6BB6
[ 11.075280] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 1 at offset 0x71FC
[ 11.082277] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 2 at offset 0x8391
[ 11.082280] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 3 at offset 0x8395
[ 11.082325] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 4 at offset 0x847D
[ 11.082328] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table at offset 0x84E2
[ 11.102176] [drm] nouveau 0000:02:00.0: 0x6B29: Condition still not met after 20ms, skipping following opcodes
[ 11.107077] nouveau 0000:02:00.0: PCI: Disallowing DAC for device
[ 11.107153] [TTM] Zone kernel: Available graphics memory: 438342 kiB
[ 11.107157] [TTM] Zone highmem: Available graphics memory: 1293834 kiB
[ 11.107160] [TTM] Initializing pool allocator
[ 11.107174] [drm] nouveau 0000:02:00.0: Detected 512MiB VRAM (DDR3)
[ 11.108240] [drm] nouveau 0000:02:00.0: 512 MiB GART (aperture)
[ 11.111967] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 11.111970] [drm] No driver support for vblank timestamp query.
[ 11.432245] [drm] nouveau 0000:02:00.0: 3 available performance level(s)
[ 11.432253] [drm] nouveau 0000:02:00.0: 0: core 50MHz shader 101MHz memory 135MHz voltage 880mV
[ 11.432258] [drm] nouveau 0000:02:00.0: 1: core 405MHz shader 810MHz memory 324MHz voltage 900mV
[ 11.432263] [drm] nouveau 0000:02:00.0: 3: core 700MHz shader 1400MHz memory 700MHz voltage 990mV
[ 11.432268] [drm] nouveau 0000:02:00.0: c: core 405MHz shader 810MHz memory 324MHz voltage 900mV fanspeed 35%
[ 11.453030] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:13.0/0000:04:01.0/input/input9
[ 11.579555] [drm] nouveau 0000:02:00.0: allocated 1680x1050 fb: 0x1a0000, bo f6818e00
[ 11.579655] fbcon: nouveaufb (fb0) is primary device
[ 11.601347] Console: switching to colour frame buffer device 210x65
[ 11.603520] fb0: nouveaufb frame buffer device
[ 11.603522] drm: registered panic notifier
[ 11.603529] [drm] Initialized nouveau 1.0.0 20120316 for 0000:02:00.0 on minor 0
[ 12.537132] Adding 6369276k swap on /dev/sda5. Priority:-1 extents:1 across:6369276k
[ 12.554756] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 12.748199] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 12.888238] loop: module loaded
[ 14.266606] RPC: Registered named UNIX socket transport module.
[ 14.266611] RPC: Registered udp transport module.
[ 14.266614] RPC: Registered tcp transport module.
[ 14.266616] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 14.316708] FS-Cache: Loaded
[ 14.348213] NFS: Registering the id_resolver key type
[ 14.348251] FS-Cache: Netfs 'nfs' registered for caching
[ 14.358361] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 16.252022] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input10
[ 17.236157] Bluetooth: Core ver 2.16
[ 17.236180] NET: Registered protocol family 31
[ 17.236183] Bluetooth: HCI device and connection manager initialized
[ 17.236187] Bluetooth: HCI socket layer initialized
[ 17.236190] Bluetooth: L2CAP socket layer initialized
[ 17.236197] Bluetooth: SCO socket layer initialized
[ 17.318225] Bluetooth: RFCOMM TTY layer initialized
[ 17.318233] Bluetooth: RFCOMM socket layer initialized
[ 17.318236] Bluetooth: RFCOMM ver 1.11
[ 17.440994] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.440999] Bluetooth: BNEP filters: protocol multicast
[ 17.739511] lp0: using parport0 (interrupt-driven).
[ 18.043574] ppdev: user-space parallel port driver
[ 151.261325] I-pipe: head domain RTAI registered.
[ 151.261332] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 151.261376] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 151.261381] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16624960, CLK_FREQ 1861889000, CPU_FREQ 1861889000
[ 151.261385] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 151.261389] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16624960, 16624960, 16580500
[ 151.304048] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 151.304087] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 151.304092] RTAI[sched]: hard timer type/freq = APIC/16624960(Hz); default timing: oneshot; linear timed lists.
[ 151.304097] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1861889000 hz.
[ 151.304100] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 151.325434] RTAI[math]: loaded.
[ 151.511400] to_pci: io_base: DFCFF000, mem_base: f80e6000
[ 151.511893] to_pci: installed driver for 1 card(s)
[ 151.551830] config string '0x378 out'
[ 156.348087] [drm] nouveau 0000:02:00.0: PMFB0_SUBP0: 0x037f0010
[ 156.348093] [drm] nouveau 0000:02:00.0: PMFB0_SUBP1: 0x037f0010
[ 8699.672186] to_pci: exit
[ 8701.833819] RTAI[math]: unloaded.
[ 8701.835985] SCHED releases registered named ALIEN PEDV$D
[ 8701.840639] RTAI[malloc]: unloaded.
[ 8701.940017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 8701.942277] I-pipe: head domain RTAI unregistered.
[ 8701.942344] RTAI[hal]: unmounted.
[ 8707.621505] I-pipe: head domain RTAI registered.
[ 8707.621512] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 8707.621579] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 8707.621583] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16624960, CLK_FREQ 1861889000, CPU_FREQ 1861889000
[ 8707.621587] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 8707.621591] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16624960, 16624960, 16546500
[ 8707.631843] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 8707.631884] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 8707.631890] RTAI[sched]: hard timer type/freq = APIC/16624960(Hz); default timing: oneshot; linear timed lists.
[ 8707.631894] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1861889000 hz.
[ 8707.631897] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 8707.638316] RTAI[math]: loaded.
[ 8707.788492] to_pci: io_base: DFCFF000, mem_base: f80e6000
[ 8707.788994] to_pci: installed driver for 1 card(s)
[ 8707.796127] config string '0x378 out'
[ 8709.914275] to_pci: exit
[ 8712.034795] RTAI[math]: unloaded.
[ 8712.037206] SCHED releases registered named ALIEN PEDV$D
[ 8712.042919] RTAI[malloc]: unloaded.
[ 8712.140013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 8712.142211] I-pipe: head domain RTAI unregistered.
[ 8712.142277] RTAI[hal]: unmounted.
[ 8765.973772] I-pipe: head domain RTAI registered.
[ 8765.973780] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 8765.973825] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 8765.973830] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16624960, CLK_FREQ 1861889000, CPU_FREQ 1861889000
[ 8765.973834] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 8765.973838] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16624960, 16624960, 16578500
[ 8765.984509] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 8765.984552] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 8765.984558] RTAI[sched]: hard timer type/freq = APIC/16624960(Hz); default timing: oneshot; linear timed lists.
[ 8765.984562] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1861889000 hz.
[ 8765.984565] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 8765.991174] RTAI[math]: loaded.
[ 8766.139493] to_pci: io_base: DFCFF000, mem_base: f80e6000
[ 8766.139988] to_pci: installed driver for 1 card(s)
[ 8766.146976] config string '0x378 out'
[ 8768.159605] to_pci: exit
[ 8770.272778] spurious APIC interrupt on CPU#0, should never happen.
[ 8770.277186] RTAI[math]: unloaded.
[ 8770.279402] SCHED releases registered named ALIEN PEDV$D
[ 8770.285386] RTAI[malloc]: unloaded.
[ 8770.384019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 8770.386368] I-pipe: head domain RTAI unregistered.
[ 8770.386437] RTAI[hal]: unmounted.
