Страница 2 из 2
Re: Модальные g-коды и конец программы.
Добавлено: 12 дек 2015, 01:17
Lexxa
Ларчик просто открывался.
Итак, чтобы на токарном станке заставить работать циклы Cannad Cycles (G81, G82,...) без дополнительных танцев с плоскостями и сохранением работоспособности фрезерной версии нужно к действиям в посте #12 , добавить следующее:
в файле src/emc/rs274ngc/interp_cycles.cc функцию
оригинал_convert_cycle (для просмотра содержимого нажмите на ссылку)
/*! convert_cycle
Returned Value: int
   If any of the specific functions called returns an error code,
   this returns that code.
   If any of the following errors occur, this returns the error code shown.
   Otherwise, it returns INTERP_OK.
   1. The r-value is not given the first time this code is called after
      some other motion mode has been in effect:
      NCE_R_CLEARANCE_PLANE_UNSPECIFIED_IN_CYCLE
   2. The l number is zero: NCE_CANNOT_DO_ZERO_REPEATS_OF_CYCLE
   3. The currently selected plane in not XY, YZ, or XZ.
      NCE_BUG_PLANE_NOT_XY_YZ_OR_XZ
Side effects:
   A number of moves are made to execute a canned cycle. The current
   position is reset. The values of the cycle attributes in the settings
   may be reset.
Called by: convert_motion
This function makes a couple checks and then calls one of three
functions, according to which plane is currently selected.
See the documentation of convert_cycle_xy for most of the details.
int Interp::convert_cycle(int motion,    //!< a g-code between G_81 and G_89, a canned cycle
                         block_pointer block,   //!< pointer to a block of RS274 instructions
                         setup_pointer settings)        //!< pointer to machine settings
  CANON_PLANE plane;
  CHKS((settings->feed_rate == 0.0), _("Cannot feed with zero feed rate"));
  CHKS((settings->feed_mode == INVERSE_TIME), _("Cannot use inverse time feed with canned cycles"));
  CHKS((settings->cutter_comp_side), _("Cannot use canned cycles with cutter compensation on"));
  plane = settings->plane;
  if (!block->r_flag) {
    if (settings->motion_mode == motion)
      block->r_number = settings->cycle_r;
    else
      ERS(NCE_R_CLEARANCE_PLANE_UNSPECIFIED_IN_CYCLE);
  CHKS((block->l_number == 0), NCE_CANNOT_DO_ZERO_REPEATS_OF_CYCLE);
  if (block->l_number == -1)
    block->l_number = 1;
  switch(plane) {
  case CANON_PLANE_XY:
  case CANON_PLANE_XZ:
  case CANON_PLANE_YZ:
    CHKS(block->u_flag, "Cannot put a U in a canned cycle in the %s plane",
	plane_name(settings->plane));
    CHKS(block->v_flag, "Cannot put a V in a canned cycle in the %s plane",
    CHKS(block->w_flag, "Cannot put a W in a canned cycle in the %s plane",
    break;
  case CANON_PLANE_UV:
  case CANON_PLANE_VW:
  case CANON_PLANE_UW:
    CHKS(block->x_flag, "Cannot put an X in a canned cycle in the %s plane",
    CHKS(block->y_flag, "Cannot put a Y in a canned cycle in the %s plane",
    CHKS(block->z_flag, "Cannot put a Z in a canned cycle in the %s plane",
  if (plane == CANON_PLANE_XY) {
    CHP(convert_cycle_xy(motion, block, settings));
  } else if (plane == CANON_PLANE_YZ) {
    CHP(convert_cycle_yz(motion, block, settings));
  } else if ((plane == CANON_PLANE_XZ) {
    CHP(convert_cycle_zx(motion, block, settings));
  } else if (plane == CANON_PLANE_UV) {
    CHP(convert_cycle_uv(motion, block, settings));
  } else if (plane == CANON_PLANE_VW) {
    CHP(convert_cycle_vw(motion, block, settings));
  } else if (plane == CANON_PLANE_UW) {
    CHP(convert_cycle_wu(motion, block, settings));
  } else
    ERS(NCE_BUG_PLANE_NOT_XY_YZ_OR_XZ);
  settings->cycle_l = block->l_number;
  settings->cycle_r = block->r_number;
  settings->motion_mode = motion;
  return INTERP_OK;
заменить на исправленную функцию
новая_convert_cycle (для просмотра содержимого нажмите на ссылку)
/*! convert_cycle
Returned Value: int
Side effects:
   may be reset.
  CANON_PLANE plane;
    else
  switch(plane) {
    break;
  if ((plane == CANON_PLANE_XY) or (_setup.lathe_mode == 1)) {
  } else if ((plane == CANON_PLANE_XZ)  and (_setup.lathe_mode == 0)) {
  } else
  return INTERP_OK;
функцию
оригинал_cycle_feed (для просмотра содержимого нажмите на ссылку)
/*! cycle_feed
Returned Value: int (INTERP_OK)
Side effects:
  STRAIGHT_FEED is called.
Called by:
  convert_cycle_g81
  convert_cycle_g82
  convert_cycle_g83
  convert_cycle_g84
  convert_cycle_g85
  convert_cycle_g86
  convert_cycle_g87
  convert_cycle_g88
  convert_cycle_g89
This writes a STRAIGHT_FEED command appropriate for a cycle move with
respect to the given plane. No rotary axis motion takes place.
int Interp::cycle_feed(block_pointer block,
                       CANON_PLANE plane,        //!< currently selected plane
                       double end1,      //!< first coordinate value
                       double end2,      //!< second coordinate value
                       double end3)      //!< third coordinate value
        STRAIGHT_FEED(block->line_number, end1, end2, end3,
                      _setup.AA_current, _setup.BB_current, _setup.CC_current,
                      _setup.u_current, _setup.v_current, _setup.w_current);
        STRAIGHT_FEED(block->line_number, end3, end1, end2,
    else if (plane == CANON_PLANE_XZ )
        STRAIGHT_FEED(block->line_number, end2, end3, end1,
        STRAIGHT_FEED(block->line_number, _setup.current_x, _setup.current_y, _setup.current_z,
                      end1, end2, end3);
                      end3, end1, end2);
    else // (plane == CANON_PLANE_UW)
                      end2, end3, end1);
    return INTERP_OK;
/*! cycle_feed
Side effects:
Called by:
  convert_cycle_g81
  convert_cycle_g82
  convert_cycle_g83
  convert_cycle_g84
  convert_cycle_g85
  convert_cycle_g86
  convert_cycle_g87
  convert_cycle_g88
  convert_cycle_g89
    else if ((plane == CANON_PLANE_XZ ) and (_setup.lathe_mode == 0))
                      end1, end2, end3);
                      end3, end1, end2);
                      end2, end3, end1);
    return INTERP_OK;
и функцию
оригинал_cycle_traverse (для просмотра содержимого нажмите на ссылку)
/*! cycle_traverse
Side effects:
  STRAIGHT_TRAVERSE is called.
Called by:
  convert_cycle
  convert_cycle_g81
  convert_cycle_g82
  convert_cycle_g83
  convert_cycle_g86
  convert_cycle_g87
  convert_cycle_xy (via CYCLE_MACRO)
  convert_cycle_yz (via CYCLE_MACRO)
  convert_cycle_zx (via CYCLE_MACRO)
This writes a STRAIGHT_TRAVERSE command appropriate for a cycle
move with respect to the given plane. No rotary axis motion takes place.
int Interp::cycle_traverse(block_pointer block,
        STRAIGHT_TRAVERSE(block->line_number, end1, end2, end3,
        STRAIGHT_TRAVERSE(block->line_number, end3, end1, end2,
    else if (plane == CANON_PLANE_XZ)
        STRAIGHT_TRAVERSE(block->line_number, end2, end3, end1,
        STRAIGHT_TRAVERSE(block->line_number, _setup.current_x, _setup.current_y, _setup.current_z,
                          end1, end2, end3);
                          end3, end1, end2);
                          end2, end3, end1);
    return INTERP_OK;
Заменить на исправленную
исправленная_cycle_traverse (для просмотра содержимого нажмите на ссылку)
/*! cycle_traverse
Side effects:
Called by:
  convert_cycle
  convert_cycle_g81
  convert_cycle_g82
  convert_cycle_g83
  convert_cycle_g86
  convert_cycle_g87
                          end1, end2, end3);
                          end3, end1, end2);
                          end2, end3, end1);
    return INTERP_OK;
Измениния смотрят на наличие "LATHE =1" в секции [DYSPLAY] и если это так то вызывается отработка цикла с подмененными осями.
Pfhf,jnfkb
Добавлено: 12 дек 2015, 01:51
Lexxa писал(а):Не ясно символ "_" перед setup.
Просто символ подчёркивания.
Lexxa писал(а):А вот и нет! Ибо конструкция описана в функции
Так ты про '?'...
Без знания основ C мы так и будем разговаривать на разных языках...
Это аналог 'if'.
Lexxa писал(а): G90 G81 G98 X4 Z1.5 R2.8 F100
ругается на отсутствие Y.
Попробовал в симуляторе - ничего не ругается, сверлит.
Снимок экрана от 2015-12-12 01-52-45.png (3772 просмотра) <a class='original' href='./download/file.php?id=65885&mode=view' target=_blank>Загрузить оригинал (86.12 КБ)</a>
Добавлено: 12 дек 2015, 08:47
Lexxa
Ругается с g18, ты сверлишь на g17.
У токарного станка без Y нет такой плоскости.
Поэтому нужно заставить его сверлить на g18 также как он это делает на g17. Эту задачу я решил.
С этими доработками токарная версия стала похожа на токпрную.
Спасибо за помощь.
Добавлено: 12 дек 2015, 08:50
Lexxa
Тему бы переименовать " LinuxCNC. допиливание токарной версии".
Добавлено: 12 дек 2015, 09:22
UAVpilot писал(а):Это аналог 'if'.
Так не только в С аналог if :)
Добавлено: 12 дек 2015, 10:03
Lexxa писал(а):Ругается с g18, ты сверлишь на g17.
Вообще-то на токарном сверлят в плоскости XY - сверло располагается перпендикулярно осям X и Y и параллельно оси Z...
Просто у токарного нет перемещений по координате Y, и координаты такой нет.
Добавлено: 12 дек 2015, 10:50
Lexxa
Чет я не встречал, чтоб на токарных фануках плоскости переключали
Добавлено: 12 дек 2015, 12:56
f.png (3745 просмотров) <a class='original' href='./download/file.php?id=65910&mode=view' target=_blank>Загрузить оригинал (116.44 КБ)</a>
Добавлено: 30 апр 2016, 22:28
Lexxa
Скачал с git.linuxcnc.org .tgz с исходниками.
Подправил нужные файлы.
далее по мануалу нужно
./autogen
./configure
make
make setuid
но, хотелось бы установить linuxcnc в директорию аналогично, как ставится linuxcnc из deb пакетов.
делаю
./autogen
./configure --prefix=/usr
make
make install
и получаю:
'make install' is only supported for building packages,
and it doesn't look like that is what is going on because
you have not set DESTDIR.
make: *** [install] Ошибка 99
как установить штатно?
Добавлено: 30 апр 2016, 23:03
torvn77
Lexxa писал(а):Знатоки, как сделать патч?
Регестрируешся на сайте github.com и после регистрации идёшь к странице с исходниками проекта.
https://github.com/LinuxCNC/linuxcnc
Дальше находишь нужные файлы, нажимаешь карандашик, вносишь изменения, и нажимаешь не то коммит, не то pool rekvest
так как репозитарий не твой и прав коммита у тебя нет, то процедура отправки будет несколько путанной.
Ну и ещё момент, я не знаю, смотрят сейчас разработчики за пулреквестами или нет, нокакая то жизнь там идёт.
На худой конец был ещё и собственный git проекта, но про него я вообще ничего не знаю.
В любом случае, закачиваете через git clone исходники, вногсите изменения и через git add . && git commit -m ggg && git pull отправляете измениния на сервер.
Сама работа выглядит примерно так, но вам ещё надо будет разобраться со всякими мелочами в организации работы git как программы.
Добавлено: 30 апр 2016, 23:09
Lexxa
мне не надо это все выкладывать на гитхаб итд, мне нужно эт установить себе! Чтоб было как будто я установил из deb.
как это сделать из исходников?
Добавлено: 30 апр 2016, 23:18
torvn77
Тогда на github регистрироваться не надо, берёте со страницы исходников ссылку для git для анонимного скачивания,
скачиваете исходники, вносите свои изменения, регестрируете у себя на компьютере через git add . && git commit -m ggg и даёте git команду сделать дифиринциальный патч.
Ну а дальше обычная процедура установки из исходников.
Причём пока не появятся конфликты исходники командой git pull можно подновлять, по крайней мере до тех пор пока не произойдёт их конфликта с вашими изменениями.
Но надо учесть, что такая работа с git намного сложнее и требует полного понимания этой системы контроля версий файлов.
Добавлено: 30 апр 2016, 23:26
Lexxa
еще раз.
Я уже отредактировал все что мне нужно, откомпилировал.
Мне нужно сделать make install по идее, но make install не выполняется, ругаясь на DESTDIR
Добавлено: 01 май 2016, 01:33
torvn77
Я отвечал на вопрос "как сделать патч", ну а по вашему вопросу всё просто,
берёте текст сообщения об ошибке, заходите на сайт https://translate.yandex.ru или https://translate.google.ru/
Там будет два поля, для левого поля выбираете английский, для правого поля русский.
Потом в левое поле помещаете текст сообщения об ошибке, после чего в правом автоматически появится перевод, либо в случае гугла надо нажать кнопку.
Screenshot.png (3590 просмотров) <a class='original' href='./download/file.php?id=78994&mode=view' target=_blank>Загрузить оригинал (74.96 КБ)</a>
Написанное означает то, что вы используете опцию install не для той цели, для которой она предназначена и вам надо делать так, как написано в мануальнике.
Во вторых, это уже лично от меня надо посмотреть в макефайле какое значение будет принимать переменная DESTDIR
может вы не указали опцию, из которой она берёт своё значение.
Но скорее всего ставить надо так, как написано в инструкции, потому что некоторые программисты делают установку при указании make без параметров.
А последня команда make setuid скорее всего нужна для того, чтобы установить для уже установленных файлов suid атрибут,
без которого программа не будет запрашивать требуемые для её работы административные права пользователя root (sks super user)
Добавлено: 03 май 2016, 17:22
Lexxa писал(а):как установить штатно?
make DESTDIR=/ install
