Редактирование интерфейса KmotionCNC
fishman
Re: Редактирование интерфейса KmotionCNC
Сообщение fishman »
а как примерно может выглядеть ее значение? и это другое место находится в этом же файле ScintillaCtrl.cpp ?
Ну, ты ведь увидел название переменной, теперь ищи, где ей присвоено значение через =
fishman
Сообщение fishman »
дык с самого утра этим и занимаюсь...
Module : ScintillaCtrl.CPP
Purpose: Defines the implementation for an MFC wrapper class for the Scintilla edit control (www.scintilla.org)
Created: PJN / 19-03-2004
History: PJN / 19-03-2004 1. Initial implementation synchronized to the v1.59 release of Scintilla
PJN / 19-03-2004 1. Updated the sample app's Find Next and Find Previous marker functions. Now correctly
goes to the next and previous markers when a marker is on the current line.
2. Updated the sample app's passing of messages to Scintilla from the top level
CMainFrame window
PJN / 06-06-2004 1. Updated class to work with Scintilla v1.61
PJN / 20-12-2004 1. Updated class to work with Scintilla v1.62.
2. Sample app now includes a common control 6 manifest
3. Sample app now includes an example of scintilla autocompletion. When you type
"scintilla is " case insensitively a autocompletion list is displayed which allows
"very cool", "easy" or "way cool!!" to be entered.
4. Sample app now includes an example of scintilla calltips. Whenever you hover
over text which is "author " case insensitively, a call tip with the text
"PJ Naughter" is displayed.
PJN / 10-07-2005 1. Updated class to work with Scintilla v1.64.
2. Fixed a number of warnings when the code is compiled using Visual Studio .NET 2003.
PJN / 03-01-2006.1. Updated class to work with Scintilla v1.67. New messages wrapped include:
SCI_MARKERADDSET, SCI_SETPASTECONVERTENDINGS, SCI_GETPASTECONVERTENDINGS,
SCI_SELECTIONDUPLICATE and SCI_GETSTYLEBITSNEEDED.
2. Updated copyright messages
PJN / 14-03-2006 1. Updated class to work with Scintilla v1.68. New messages wrapped include:
SCI_CALLTIPUSESTYLE, SCI_SETCARETLINEBACKALPHA and SCI_GETCARETLINEBACKALPHA.
PJN / 05-06-2006 1. Updated class to work with Scintilla v1.69. New messages wrapped include:
SCI_MARKERSETALPHA, SCI_GETSELALPHA and SCI_SETSELALPHA.
PJN / 06-06-2006 1. Updated the wrapper class to work correctly when compiled for Unicode.
PJN / 29-06-2006 1. Code now uses new C++ style casts rather than old style C casts where necessary.
2. Optimized CScintillaCtrl constructor code
3. Updated the code to clean compile in VC 2005
4. Fixed a bug in the sample program when you invoke Print Preview when compiled
using VC 2005
PJN / 27-07-2006 1. Minor update to the sample app to fix an ASSERT related to the formatting of the
IDR_SCINTITYPE string resource. Thanks to Matt Spear for reporting this issue.
PJN / 17-09-2006 1. Fixed a bug in UTF82W (and W2UTF8) where if GetLine is called in a Unicode build
for the end of the file (i.e. a line having a length of 0), the UTF82W function would
allocate no buffer, but still erroneously write a one character terminating null. In
addition, the caller (GetLine) will try to deallocate the buffer that was never
allocated. Thanks to Scott Kelley for spotting this nasty bug.
2. Added of a GetLineEx method which explicitly sets the first WORD value in the text
string to the maximum size. This avoids client code from having to deal with the
weird semantics of the EM_GETLINE message. Thanks to Scott Kelley for providing this
nice addition.
3. Verified code implements all the functionality of Scintilla v1.71
PJN / 11-06-2007 1. Updated copyright details.
2. CScintillaCtrl::GetSelText now uses CString::GetBufferSetLength to avoid having to
allocate an intermediate buffer. Thanks to Jochen Neubeck for reporting this
optimization
3. Addition of a SCINTILLACTRL_EXT_CLASS preprocessor macro to allow the classes to be
more easily used in an extension DLL.
4. Updated class to work with Scintilla v1.73. New messages wrapped include:
SCI_STYLEGETFORE, SCI_STYLEGETBACK, SCI_STYLEGETBOLD, SCI_STYLEGETITALIC, SCI_STYLEGETSIZE,
SCI_STYLEGETFONT, SCI_STYLEGETEOLFILLED, SCI_STYLEGETUNDERLINE, SCI_STYLEGETCASE,
SCI_STYLEGETCHARACTERSET, SCI_STYLEGETVISIBLE, SCI_STYLEGETCHANGEABLE, SCI_STYLEGETHOTSPOT,
SCI_GETSELEOLFILLED, SCI_SETSELEOLFILLED, SCI_GETHOTSPOTACTIVEFORE, SCI_GETHOTSPOTACTIVEBACK,
SCI_GETHOTSPOTACTIVEUNDERLINE & SCI_GETHOTSPOTSINGLELINE
PJN / 28-11-2007 1. Updated class to work with Scintilla v1.75. New messages wrapped include: SCI_INDICSETUNDER,
SCI_INDICGETUNDER, new behavior for SCI_SETINDENTATIONGUIDES & SCI_GETINDENTATIONGUIDES,
SCI_SETSCROLLWIDTHTRACKING, SCI_GETSCROLLWIDTHTRACKING, SCI_DELWORDRIGHTEND, SCI_SETCARETSTYLE,
SCI_GETCARETSTYLE, SCI_SETINDICATORCURRENT, SCI_SETINDICATORVALUE, SCI_INDICATORFILLRANGE,
SCI_INDICATORCLEARRANGE, SCI_INDICATORALLONFOR, SCI_INDICATORVALUEAT, SCI_INDICATORSTART,
SCI_INDICATOREND, SCI_SETPOSITIONCACHE & SCI_GETPOSITIONCACHE.
2. The auto completion sample in CScintillaDemoView::OnCharAdded has been extended to show
another style of auto completion. Thanks to alessandro limonta for suggesting this update.
PJN / 19-03-2008 1. Updated class to work with Scintilla v1.76. New messages wrapped include: SCI_COPYALLOWLINE.
2. Updated copyright details.
3. Updated code to clean compile on VC 2008.
4. Removed VC 6 style classwizard comments from the code.
5. Updated the sample apps document icon.
6. Fixed a level 4 warning when the code is compiled on VC 6.
PJN / 15-06-2008 1. Code now compiles cleanly using Code Analysis (/analyze)
2. Updated code to compile correctly using _ATL_CSTRING_EXPLICIT_CONSTRUCTORS define
3. The code now only supports VC 2005 or later.
PJN / 01-11-2008 1. Updated class to work with Scintilla v1.77. New messages wrapped include:
SCI_GETCHARACTERPOINTER, SCI_SETKEYSUNICODE & SCI_GETKEYSUNICODE
2. Reworked all the key Unicode functions which expose string length management and
reimplemented them to use CStringW output parameters. Equivalent ASCII versions have also been
provided. This new approach helps to raise the level of abstraction provided by the wrapper
class. In the process the need for the GetLineEx function has been removed. Thanks to Alexei
Letov for prompting this update.
PJN / 20-01-2009 1. Updated copyright details.
Copyright (c) 2004 - 2009 by PJ Naughter (Web: http://www.naughter.com, Email: pjna@naughter.com)
All rights reserved.
Copyright / Usage Details:
You are allowed to include the source code in any product (commercial, shareware, freeware or otherwise)
when your product is released in binary form. You are allowed to modify the source code in any way you want
except you cannot modify the copyright details at the top of each module. If you want to distribute source
code with your application, then you are only allowed to distribute versions released by the author. This is
to maintain a single distribution point for the source code.
///////////////////////////////// Includes //////////////////////////////////
#include "stdafx.h"
#include "ScintillaCtrl.h"
//////////////////////////////// Statics / Macros /////////////////////////////
#ifdef _DEBUG
#define new DEBUG_NEW
#endif
////////////////////////////////// Implementation /////////////////////////////
IMPLEMENT_DYNAMIC(CScintillaCtrl, CWnd)
CScintillaCtrl::CScintillaCtrl() : m_DirectFunction(0),
m_DirectPointer(0)
BOOL CScintillaCtrl::Create(DWORD dwStyle, const RECT& rect, CWnd* pParentWnd, UINT nID, DWORD dwExStyle, LPVOID lpParam)
//Call our base class implementation of CWnd::CreateEx
BOOL bSuccess = CreateEx(dwExStyle, _T("scintilla"), NULL, dwStyle, rect, pParentWnd, nID, lpParam);
//Setup the direct access data
if (bSuccess)
SetupDirectAccess();
//If we are running as Unicode, then use the UTF8 codepage
#ifdef _UNICODE
SetCodePage(SC_CP_UTF8);
#endif
return bSuccess;
void CScintillaCtrl::SetupDirectAccess()
m_DirectFunction = GetDirectFunction();
m_DirectPointer = GetDirectPointer();
CScintillaCtrl::~CScintillaCtrl()
DestroyWindow();
inline LRESULT CScintillaCtrl::Call(UINT message, WPARAM wParam, LPARAM lParam, BOOL bDirect)
ASSERT(::IsWindow(m_hWnd)); //Window must be valid
if (bDirect)
ASSERT(m_DirectFunction); //Direct function must be valid
return (reinterpret_cast<SciFnDirect>(m_DirectFunction))(m_DirectPointer, message, wParam, lParam);
else
return SendMessage(message, wParam, lParam);
LRESULT CScintillaCtrl::GetDirectFunction()
return SendMessage(SCI_GETDIRECTFUNCTION, 0, 0);
LRESULT CScintillaCtrl::GetDirectPointer()
return SendMessage(SCI_GETDIRECTPOINTER, 0, 0);
#ifdef _UNICODE
CStringA CScintillaCtrl::W2UTF8(const wchar_t* pszText, int nLength)
//First call the function to determine how much space we need to allocate
int nUTF8Length = WideCharToMultiByte(CP_UTF8, 0, pszText, nLength, NULL, 0, NULL, NULL);
//If the calculated length is zero, then ensure we have at least room for a NULL terminator
if (nUTF8Length == 0)
nUTF8Length = 1;
//Now recall with the buffer to get the converted text
CStringA sUTF;
char* pszUTF8Text = sUTF.GetBuffer(nUTF8Length + 1); //include an extra byte because we may be null terminating the string ourselves
int nCharsWritten = WideCharToMultiByte(CP_UTF8, 0, pszText, nLength, pszUTF8Text, nUTF8Length, NULL, NULL);
//Ensure we NULL terminate the text if WideCharToMultiByte doesn't do it for us
if (nLength != -1)
AFXASSUME(nCharsWritten <= nUTF8Length);
pszUTF8Text[nCharsWritten] = '\0';
sUTF.ReleaseBuffer();
return sUTF;
CStringW CScintillaCtrl::UTF82W(const char* pszText, int nLength)
int nWideLength = MultiByteToWideChar(CP_UTF8, 0, pszText, nLength, NULL, 0);
if (nWideLength == 0)
nWideLength = 1;
CStringW sWideString;
wchar_t* pszWText = sWideString.GetBuffer(nWideLength + 1); //include an extra byte because we may be null terminating the string ourselves
int nCharsWritten = MultiByteToWideChar(CP_UTF8, 0, pszText, nLength, pszWText, nWideLength);
//Ensure we NULL terminate the text if MultiByteToWideChar doesn't do it for us
if (nLength != -1)
AFXASSUME(nCharsWritten <= nWideLength);
pszWText[nCharsWritten] = '\0';
sWideString.ReleaseBuffer();
return sWideString;
void CScintillaCtrl::AddText(int length, const wchar_t* text, BOOL bDirect)
//Convert the unicode text to UTF8
CStringA sUTF8(W2UTF8(text, length));
//Call the native scintilla version of the function with the UTF8 text
AddText(sUTF8.GetLength(), sUTF8, bDirect);
void CScintillaCtrl::InsertText(long pos, const wchar_t* text, BOOL bDirect)
CStringA sUTF8(W2UTF8(text, -1));
InsertText(pos, sUTF8, bDirect);
CStringW CScintillaCtrl::GetSelText(BOOL bDirect)
//Work out the length of string to allocate
int nUTF8Length = GetSelectionEnd() - GetSelectionStart();
//Call the function which does the work
CStringA sUTF8;
GetSelText(sUTF8.GetBufferSetLength(nUTF8Length), bDirect);
sUTF8.ReleaseBuffer();
//Now convert the UTF8 text back to Unicode
return UTF82W(sUTF8, -1);
CStringW CScintillaCtrl::GetCurLine(BOOL bDirect)
int nUTF8Length = GetCurLine(0, NULL, bDirect);
CStringA sUTF8;
GetCurLine(nUTF8Length, sUTF8.GetBufferSetLength(nUTF8Length), bDirect);
void CScintillaCtrl::StyleSetFont(int style, const wchar_t* fontName, BOOL bDirect)
CStringA sUTF8(W2UTF8(fontName, -1));
StyleSetFont(style, sUTF8, bDirect);
void CScintillaCtrl::SetWordChars(const wchar_t* characters, BOOL bDirect)
CStringA sUTF8(W2UTF8(characters, -1));
SetWordChars(sUTF8, bDirect);
void CScintillaCtrl::AutoCShow(int lenEntered, const wchar_t* itemList, BOOL bDirect)
CStringA sUTF8(W2UTF8(itemList, -1));
AutoCShow(lenEntered, sUTF8, bDirect);
void CScintillaCtrl::AutoCStops(const wchar_t* characterSet, BOOL bDirect)
CStringA sUTF8(W2UTF8(characterSet, -1));
AutoCStops(sUTF8, bDirect);
void CScintillaCtrl::AutoCSelect(const wchar_t* text, BOOL bDirect)
AutoCSelect(sUTF8, bDirect);
void CScintillaCtrl::AutoCSetFillUps(const wchar_t* characterSet, BOOL bDirect)
AutoCSetFillUps(sUTF8, bDirect);
void CScintillaCtrl::UserListShow(int listType, const wchar_t* itemList, BOOL bDirect)
UserListShow(listType, sUTF8, bDirect);
CStringW CScintillaCtrl::GetLine(int line, BOOL bDirect)
int nUTF8Length = LineLength(line, bDirect);
CStringA sUTF8;
GetLine(line, sUTF8.GetBufferSetLength(nUTF8Length), bDirect);
void CScintillaCtrl::ReplaceSel(const wchar_t* text, BOOL bDirect)
ReplaceSel(sUTF8, bDirect);
void CScintillaCtrl::SetText(const wchar_t* text, BOOL bDirect)
SetText(sUTF8, bDirect);
CStringW CScintillaCtrl::GetText(int length, BOOL bDirect)
int nUTF8Length = length*4; //A Unicode character can take up to 4 octets when expressed as UTF8
CStringA sUTF8;
GetText(nUTF8Length, sUTF8.GetBufferSetLength(nUTF8Length), bDirect);
CStringW sWideText(UTF82W(sUTF8, -1));
return sWideText.Left(length-1);
int CScintillaCtrl::ReplaceTarget(int length, const wchar_t* text, BOOL bDirect)
return ReplaceTarget(sUTF8.GetLength(), sUTF8, bDirect);
int CScintillaCtrl::ReplaceTargetRE(int length, const wchar_t* text, BOOL bDirect)
return ReplaceTargetRE(sUTF8.GetLength(), sUTF8, bDirect);
int CScintillaCtrl::SearchInTarget(int length, const wchar_t* text, BOOL bDirect)
return SearchInTarget(sUTF8.GetLength(), sUTF8, bDirect);
void CScintillaCtrl::CallTipShow(long pos, const wchar_t* definition, BOOL bDirect)
CStringA sUTF8(W2UTF8(definition, -1));
CallTipShow(pos, sUTF8, bDirect);
int CScintillaCtrl::TextWidth(int style, const wchar_t* text, BOOL bDirect)
return TextWidth(style, sUTF8, bDirect);
void CScintillaCtrl::AppendText(int length, const wchar_t* text, BOOL bDirect)
AppendText(sUTF8.GetLength(), sUTF8, bDirect);
int CScintillaCtrl::SearchNext(int flags, const wchar_t* text, BOOL bDirect)
return SearchNext(flags, sUTF8, bDirect);
int CScintillaCtrl::SearchPrev(int flags, const wchar_t* text, BOOL bDirect)
return SearchPrev(flags, sUTF8, bDirect);
void CScintillaCtrl::CopyText(int length, const wchar_t* text, BOOL bDirect)
CopyText(sUTF8.GetLength(), sUTF8, bDirect);
void CScintillaCtrl::SetWhitespaceChars(const wchar_t* characters, BOOL bDirect)
SetWhitespaceChars(sUTF8, bDirect);
void CScintillaCtrl::SetProperty(const wchar_t* key, const wchar_t* value, BOOL bDirect)
//Convert the unicode texts to UTF8
CStringA sUTF8Key(W2UTF8(key, -1));
CStringA sUTF8Value(W2UTF8(value, -1));
SetProperty(sUTF8Key, sUTF8Value, bDirect);
void CScintillaCtrl::SetKeyWords(int keywordSet, const wchar_t* keyWords, BOOL bDirect)
CStringA sUTF8(W2UTF8(keyWords, -1));
SetKeyWords(keywordSet, sUTF8, bDirect);
void CScintillaCtrl::SetLexerLanguage(const wchar_t* language, BOOL bDirect)
CStringA sUTF8(W2UTF8(language, -1));
SetLexerLanguage(sUTF8, bDirect);
void CScintillaCtrl::LoadLexerLibrary(const wchar_t* path, BOOL bDirect)
CStringA sUTF8(W2UTF8(path, -1));
LoadLexerLibrary(sUTF8, bDirect);
CStringW CScintillaCtrl::GetProperty(const wchar_t* key, BOOL bDirect)
//Validate our parameters
ASSERT(key);
//Convert the Key value to UTF8
int nUTF8ValueLength = GetProperty(sUTF8Key, 0, bDirect);
CStringA sUTF8Value;
GetProperty(sUTF8Key, sUTF8Value.GetBufferSetLength(nUTF8ValueLength), bDirect);
sUTF8Value.ReleaseBuffer();
return UTF82W(sUTF8Value, -1);
CStringW CScintillaCtrl::GetPropertyExpanded(const wchar_t* key, BOOL bDirect)
ASSERT(key);
int nUTF8ValueLength = GetPropertyExpanded(sUTF8Key, 0, bDirect);
GetPropertyExpanded(sUTF8Key, sUTF8Value.GetBufferSetLength(nUTF8ValueLength), bDirect);
int CScintillaCtrl::GetPropertyInt(const wchar_t* key, BOOL bDirect)
CStringA sUTF8(W2UTF8(key, -1));
return GetPropertyInt(sUTF8, bDirect);
CStringW CScintillaCtrl::StyleGetFont(int style, BOOL bDirect)
//Allocate a UTF8 buffer to contain the font name. See the notes for
//SCI_STYLEGETFONT / SCI_STYLESETFONT on the reasons why we can use
//a statically sized buffer of 32 characters in size. Note it is 33 below
//to include space for the NULL terminator
char szUTF8FontName[33*4]; //A Unicode character can take up to 4 octets when expressed as UTF8
szUTF8FontName[0] = '\0';
//Call the native scintilla version of the function with a UTF8 text buffer
StyleGetFont(style, szUTF8FontName, bDirect);
return UTF82W(szUTF8FontName, -1);
#else
CStringA CScintillaCtrl::GetSelText(BOOL bDirect)
int nLength = GetSelectionEnd() - GetSelectionStart();
CStringA sSelText;
GetSelText(sSelText.GetBufferSetLength(nLength), bDirect);
sSelText.ReleaseBuffer();
return sSelText;
CStringA CScintillaCtrl::GetCurLine(BOOL bDirect)
CStringA sCurLine;
int nLength = GetCurLine(0, NULL, bDirect);
char* pszCurLine = sCurLine.GetBufferSetLength(nLength);
GetCurLine(nLength, pszCurLine, bDirect);
sCurLine.ReleaseBuffer();
return sCurLine;
CStringA CScintillaCtrl::GetLine(int line, BOOL bDirect)
CStringA sLine;
int nLength = LineLength(line, bDirect);
char* pszLine = sLine.GetBufferSetLength(nLength);
GetLine(line, pszLine, bDirect);
sLine.ReleaseBuffer();
return sLine;
CStringA CScintillaCtrl::GetProperty(const char* key, BOOL bDirect)
ASSERT(key);
int nValueLength = GetProperty(key, 0, bDirect);
CStringA sValue;
GetProperty(key, sValue.GetBufferSetLength(nValueLength), bDirect);
sValue.ReleaseBuffer();
return sValue;
CStringA CScintillaCtrl::GetText(int length, BOOL bDirect)
CString sText;
GetText(length, sText.GetBufferSetLength(length), bDirect);
sText.ReleaseBuffer();
return sText;
CStringA CScintillaCtrl::GetPropertyExpanded(const char* key, BOOL bDirect)
ASSERT(key);
int nValueLength = GetPropertyExpanded(key, 0, bDirect);
CStringA sValue;
GetPropertyExpanded(key, sValue.GetBufferSetLength(nValueLength), bDirect);
return sValue;
CStringA CScintillaCtrl::StyleGetFont(int style, BOOL bDirect)
//Allocate a buffer to contain the font name. See the notes for
char szFontName[33];
szFontName[0] = '\0';
//Call the native scintilla version of the function with a text buffer
StyleGetFont(style, szFontName, bDirect);
return szFontName;
#endif //#ifdef _UNICODE
//Everything else after this point was auto generated using the "ConvertScintillaiface.js" script
void CScintillaCtrl::AddText(int length, const char* text, BOOL bDirect)
Call(SCI_ADDTEXT, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(text), bDirect);
void CScintillaCtrl::AddStyledText(int length, char* c, BOOL bDirect)
Call(SCI_ADDSTYLEDTEXT, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(c), bDirect);
void CScintillaCtrl::InsertText(long pos, const char* text, BOOL bDirect)
Call(SCI_INSERTTEXT, static_cast<WPARAM>(pos), reinterpret_cast<LPARAM>(text), bDirect);
void CScintillaCtrl::ClearAll(BOOL bDirect)
Call(SCI_CLEARALL, 0, 0, bDirect);
void CScintillaCtrl::ClearDocumentStyle(BOOL bDirect)
Call(SCI_CLEARDOCUMENTSTYLE, 0, 0, bDirect);
int CScintillaCtrl::GetLength(BOOL bDirect)
return Call(SCI_GETLENGTH, 0, 0, bDirect);
int CScintillaCtrl::GetCharAt(long pos, BOOL bDirect)
return Call(SCI_GETCHARAT, static_cast<WPARAM>(pos), 0, bDirect);
long CScintillaCtrl::GetCurrentPos(BOOL bDirect)
return Call(SCI_GETCURRENTPOS, 0, 0, bDirect);
long CScintillaCtrl::GetAnchor(BOOL bDirect)
return Call(SCI_GETANCHOR, 0, 0, bDirect);
int CScintillaCtrl::GetStyleAt(long pos, BOOL bDirect)
return Call(SCI_GETSTYLEAT, static_cast<WPARAM>(pos), 0, bDirect);
void CScintillaCtrl::Redo(BOOL bDirect)
Call(SCI_REDO, 0, 0, bDirect);
void CScintillaCtrl::SetUndoCollection(BOOL collectUndo, BOOL bDirect)
Call(SCI_SETUNDOCOLLECTION, static_cast<WPARAM>(collectUndo), 0, bDirect);
void CScintillaCtrl::SelectAll(BOOL bDirect)
Call(SCI_SELECTALL, 0, 0, bDirect);
void CScintillaCtrl::SetSavePoint(BOOL bDirect)
Call(SCI_SETSAVEPOINT, 0, 0, bDirect);
int CScintillaCtrl::GetStyledText(TextRange* tr, BOOL bDirect)
return Call(SCI_GETSTYLEDTEXT, 0, reinterpret_cast<LPARAM>(tr), bDirect);
BOOL CScintillaCtrl::CanRedo(BOOL bDirect)
return Call(SCI_CANREDO, 0, 0, bDirect);
int CScintillaCtrl::MarkerLineFromHandle(int handle, BOOL bDirect)
return Call(SCI_MARKERLINEFROMHANDLE, static_cast<WPARAM>(handle), 0, bDirect);
void CScintillaCtrl::MarkerDeleteHandle(int handle, BOOL bDirect)
Call(SCI_MARKERDELETEHANDLE, static_cast<WPARAM>(handle), 0, bDirect);
BOOL CScintillaCtrl::GetUndoCollection(BOOL bDirect)
return Call(SCI_GETUNDOCOLLECTION, 0, 0, bDirect);
int CScintillaCtrl::GetViewWS(BOOL bDirect)
return Call(SCI_GETVIEWWS, 0, 0, bDirect);
void CScintillaCtrl::SetViewWS(int viewWS, BOOL bDirect)
Call(SCI_SETVIEWWS, static_cast<WPARAM>(viewWS), 0, bDirect);
long CScintillaCtrl::PositionFromPoint(int x, int y, BOOL bDirect)
return Call(SCI_POSITIONFROMPOINT, static_cast<WPARAM>(x), static_cast<LPARAM>(y), bDirect);
long CScintillaCtrl::PositionFromPointClose(int x, int y, BOOL bDirect)
return Call(SCI_POSITIONFROMPOINTCLOSE, static_cast<WPARAM>(x), static_cast<LPARAM>(y), bDirect);
void CScintillaCtrl::GotoLine(int line, BOOL bDirect)
Call(SCI_GOTOLINE, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::GotoPos(long pos, BOOL bDirect)
Call(SCI_GOTOPOS, static_cast<WPARAM>(pos), 0, bDirect);
void CScintillaCtrl::SetAnchor(long posAnchor, BOOL bDirect)
Call(SCI_SETANCHOR, static_cast<WPARAM>(posAnchor), 0, bDirect);
int CScintillaCtrl::GetCurLine(int length, char* text, BOOL bDirect)
return Call(SCI_GETCURLINE, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(text), bDirect);
long CScintillaCtrl::GetEndStyled(BOOL bDirect)
return Call(SCI_GETENDSTYLED, 0, 0, bDirect);
void CScintillaCtrl::ConvertEOLs(int eolMode, BOOL bDirect)
Call(SCI_CONVERTEOLS, static_cast<WPARAM>(eolMode), 0, bDirect);
int CScintillaCtrl::GetEOLMode(BOOL bDirect)
return Call(SCI_GETEOLMODE, 0, 0, bDirect);
void CScintillaCtrl::SetEOLMode(int eolMode, BOOL bDirect)
Call(SCI_SETEOLMODE, static_cast<WPARAM>(eolMode), 0, bDirect);
void CScintillaCtrl::StartStyling(long pos, int mask, BOOL bDirect)
Call(SCI_STARTSTYLING, static_cast<WPARAM>(pos), static_cast<LPARAM>(mask), bDirect);
void CScintillaCtrl::SetStyling(int length, int style, BOOL bDirect)
Call(SCI_SETSTYLING, static_cast<WPARAM>(length), static_cast<LPARAM>(style), bDirect);
BOOL CScintillaCtrl::GetBufferedDraw(BOOL bDirect)
return Call(SCI_GETBUFFEREDDRAW, 0, 0, bDirect);
void CScintillaCtrl::SetBufferedDraw(BOOL buffered, BOOL bDirect)
Call(SCI_SETBUFFEREDDRAW, static_cast<WPARAM>(buffered), 0, bDirect);
void CScintillaCtrl::SetTabWidth(int tabWidth, BOOL bDirect)
Call(SCI_SETTABWIDTH, static_cast<WPARAM>(tabWidth), 0, bDirect);
int CScintillaCtrl::GetTabWidth(BOOL bDirect)
return Call(SCI_GETTABWIDTH, 0, 0, bDirect);
void CScintillaCtrl::SetCodePage(int codePage, BOOL bDirect)
Call(SCI_SETCODEPAGE, static_cast<WPARAM>(codePage), 0, bDirect);
void CScintillaCtrl::SetUsePalette(BOOL usePalette, BOOL bDirect)
Call(SCI_SETUSEPALETTE, static_cast<WPARAM>(usePalette), 0, bDirect);
void CScintillaCtrl::MarkerDefine(int markerNumber, int markerSymbol, BOOL bDirect)
Call(SCI_MARKERDEFINE, static_cast<WPARAM>(markerNumber), static_cast<LPARAM>(markerSymbol), bDirect);
void CScintillaCtrl::MarkerSetFore(int markerNumber, COLORREF fore, BOOL bDirect)
Call(SCI_MARKERSETFORE, static_cast<WPARAM>(markerNumber), static_cast<LPARAM>(fore), bDirect);
void CScintillaCtrl::MarkerSetBack(int markerNumber, COLORREF back, BOOL bDirect)
Call(SCI_MARKERSETBACK, static_cast<WPARAM>(markerNumber), static_cast<LPARAM>(back), bDirect);
int CScintillaCtrl::MarkerAdd(int line, int markerNumber, BOOL bDirect)
return Call(SCI_MARKERADD, static_cast<WPARAM>(line), static_cast<LPARAM>(markerNumber), bDirect);
void CScintillaCtrl::MarkerDelete(int line, int markerNumber, BOOL bDirect)
Call(SCI_MARKERDELETE, static_cast<WPARAM>(line), static_cast<LPARAM>(markerNumber), bDirect);
void CScintillaCtrl::MarkerDeleteAll(int markerNumber, BOOL bDirect)
Call(SCI_MARKERDELETEALL, static_cast<WPARAM>(markerNumber), 0, bDirect);
int CScintillaCtrl::MarkerGet(int line, BOOL bDirect)
return Call(SCI_MARKERGET, static_cast<WPARAM>(line), 0, bDirect);
int CScintillaCtrl::MarkerNext(int lineStart, int markerMask, BOOL bDirect)
return Call(SCI_MARKERNEXT, static_cast<WPARAM>(lineStart), static_cast<LPARAM>(markerMask), bDirect);
int CScintillaCtrl::MarkerPrevious(int lineStart, int markerMask, BOOL bDirect)
return Call(SCI_MARKERPREVIOUS, static_cast<WPARAM>(lineStart), static_cast<LPARAM>(markerMask), bDirect);
void CScintillaCtrl::MarkerDefinePixmap(int markerNumber, const char* pixmap, BOOL bDirect)
Call(SCI_MARKERDEFINEPIXMAP, static_cast<WPARAM>(markerNumber), reinterpret_cast<LPARAM>(pixmap), bDirect);
void CScintillaCtrl::MarkerAddSet(int line, int set, BOOL bDirect)
Call(SCI_MARKERADDSET, static_cast<WPARAM>(line), static_cast<LPARAM>(set), bDirect);
void CScintillaCtrl::MarkerSetAlpha(int markerNumber, int alpha, BOOL bDirect)
Call(SCI_MARKERSETALPHA, static_cast<WPARAM>(markerNumber), static_cast<LPARAM>(alpha), bDirect);
void CScintillaCtrl::SetMarginTypeN(int margin, int marginType, BOOL bDirect)
Call(SCI_SETMARGINTYPEN, static_cast<WPARAM>(margin), static_cast<LPARAM>(marginType), bDirect);
int CScintillaCtrl::GetMarginTypeN(int margin, BOOL bDirect)
return Call(SCI_GETMARGINTYPEN, static_cast<WPARAM>(margin), 0, bDirect);
void CScintillaCtrl::SetMarginWidthN(int margin, int pixelWidth, BOOL bDirect)
Call(SCI_SETMARGINWIDTHN, static_cast<WPARAM>(margin), static_cast<LPARAM>(pixelWidth), bDirect);
int CScintillaCtrl::GetMarginWidthN(int margin, BOOL bDirect)
return Call(SCI_GETMARGINWIDTHN, static_cast<WPARAM>(margin), 0, bDirect);
void CScintillaCtrl::SetMarginMaskN(int margin, int mask, BOOL bDirect)
Call(SCI_SETMARGINMASKN, static_cast<WPARAM>(margin), static_cast<LPARAM>(mask), bDirect);
int CScintillaCtrl::GetMarginMaskN(int margin, BOOL bDirect)
return Call(SCI_GETMARGINMASKN, static_cast<WPARAM>(margin), 0, bDirect);
void CScintillaCtrl::SetMarginSensitiveN(int margin, BOOL sensitive, BOOL bDirect)
Call(SCI_SETMARGINSENSITIVEN, static_cast<WPARAM>(margin), static_cast<LPARAM>(sensitive), bDirect);
BOOL CScintillaCtrl::GetMarginSensitiveN(int margin, BOOL bDirect)
return Call(SCI_GETMARGINSENSITIVEN, static_cast<WPARAM>(margin), 0, bDirect);
void CScintillaCtrl::StyleClearAll(BOOL bDirect)
Call(SCI_STYLECLEARALL, 0, 0, bDirect);
void CScintillaCtrl::StyleSetFore(int style, COLORREF fore, BOOL bDirect)
Call(SCI_STYLESETFORE, static_cast<WPARAM>(style), static_cast<LPARAM>(fore), bDirect);
void CScintillaCtrl::StyleSetBack(int style, COLORREF back, BOOL bDirect)
Call(SCI_STYLESETBACK, static_cast<WPARAM>(style), static_cast<LPARAM>(back), bDirect);
void CScintillaCtrl::StyleSetBold(int style, BOOL bold, BOOL bDirect)
Call(SCI_STYLESETBOLD, static_cast<WPARAM>(style), static_cast<LPARAM>(bold), bDirect);
void CScintillaCtrl::StyleSetItalic(int style, BOOL italic, BOOL bDirect)
Call(SCI_STYLESETITALIC, static_cast<WPARAM>(style), static_cast<LPARAM>(italic), bDirect);
void CScintillaCtrl::StyleSetSize(int style, int sizePoints, BOOL bDirect)
Call(SCI_STYLESETSIZE, static_cast<WPARAM>(style), static_cast<LPARAM>(sizePoints), bDirect;)
void CScintillaCtrl::StyleSetFont(int style, const char* fontName, BOOL bDirect)
Call(SCI_STYLESETFONT, static_cast<WPARAM>(style), reinterpret_cast<LPARAM>(fontName), bDirect);
void CScintillaCtrl::StyleSetEOLFilled(int style, BOOL filled, BOOL bDirect)
Call(SCI_STYLESETEOLFILLED, static_cast<WPARAM>(style), static_cast<LPARAM>(filled), bDirect);
void CScintillaCtrl::StyleResetDefault(BOOL bDirect)
Call(SCI_STYLERESETDEFAULT, 0, 0, bDirect);
void CScintillaCtrl::StyleSetUnderline(int style, BOOL underline, BOOL bDirect)
Call(SCI_STYLESETUNDERLINE, static_cast<WPARAM>(style), static_cast<LPARAM>(underline), bDirect);
COLORREF CScintillaCtrl::StyleGetFore(int style, BOOL bDirect)
return Call(SCI_STYLEGETFORE, static_cast<WPARAM>(style), 0, bDirect);
COLORREF CScintillaCtrl::StyleGetBack(int style, BOOL bDirect)
return Call(SCI_STYLEGETBACK, static_cast<WPARAM>(style), 0, bDirect);
BOOL CScintillaCtrl::StyleGetBold(int style, BOOL bDirect)
return Call(SCI_STYLEGETBOLD, static_cast<WPARAM>(style), 0, bDirect);
BOOL CScintillaCtrl::StyleGetItalic(int style, BOOL bDirect)
return Call(SCI_STYLEGETITALIC, static_cast<WPARAM>(style), 0, bDirect);
int CScintillaCtrl::StyleGetSize(int style, BOOL bDirect)
return Call(SCI_STYLEGETSIZE, static_cast<WPARAM>(style), 8, bDirect);
int CScintillaCtrl::StyleGetFont(int style, char* fontName, BOOL bDirect)
return Call(SCI_STYLEGETFONT, static_cast<WPARAM>(style), reinterpret_cast<LPARAM>(fontName), bDirect);
BOOL CScintillaCtrl::StyleGetEOLFilled(int style, BOOL bDirect)
return Call(SCI_STYLEGETEOLFILLED, static_cast<WPARAM>(style), 0, bDirect);
BOOL CScintillaCtrl::StyleGetUnderline(int style, BOOL bDirect)
return Call(SCI_STYLEGETUNDERLINE, static_cast<WPARAM>(style), 0, bDirect);
int CScintillaCtrl::StyleGetCase(int style, BOOL bDirect)
return Call(SCI_STYLEGETCASE, static_cast<WPARAM>(style), 0, bDirect);
int CScintillaCtrl::StyleGetCharacterSet(int style, BOOL bDirect)
return Call(SCI_STYLEGETCHARACTERSET, static_cast<WPARAM>(style), 0, bDirect);
BOOL CScintillaCtrl::StyleGetVisible(int style, BOOL bDirect)
return Call(SCI_STYLEGETVISIBLE, static_cast<WPARAM>(style), 0, bDirect);
BOOL CScintillaCtrl::StyleGetChangeable(int style, BOOL bDirect)
return Call(SCI_STYLEGETCHANGEABLE, static_cast<WPARAM>(style), 0, bDirect);
BOOL CScintillaCtrl::StyleGetHotSpot(int style, BOOL bDirect)
return Call(SCI_STYLEGETHOTSPOT, static_cast<WPARAM>(style), 0, bDirect);
void CScintillaCtrl::StyleSetCase(int style, int caseForce, BOOL bDirect)
Call(SCI_STYLESETCASE, static_cast<WPARAM>(style), static_cast<LPARAM>(caseForce), bDirect);
void CScintillaCtrl::StyleSetCharacterSet(int style, int characterSet, BOOL bDirect)
Call(SCI_STYLESETCHARACTERSET, static_cast<WPARAM>(style), static_cast<LPARAM>(characterSet), bDirect);
void CScintillaCtrl::StyleSetHotSpot(int style, BOOL hotspot, BOOL bDirect)
Call(SCI_STYLESETHOTSPOT, static_cast<WPARAM>(style), static_cast<LPARAM>(hotspot), bDirect);
void CScintillaCtrl::SetSelFore(BOOL useSetting, COLORREF fore, BOOL bDirect)
Call(SCI_SETSELFORE, static_cast<WPARAM>(useSetting), static_cast<LPARAM>(fore), bDirect);
void CScintillaCtrl::SetSelBack(BOOL useSetting, COLORREF back, BOOL bDirect)
Call(SCI_SETSELBACK, static_cast<WPARAM>(useSetting), static_cast<LPARAM>(back), bDirect);
int CScintillaCtrl::GetSelAlpha(BOOL bDirect)
return Call(SCI_GETSELALPHA, 0, 0, bDirect);
void CScintillaCtrl::SetSelAlpha(int alpha, BOOL bDirect)
Call(SCI_SETSELALPHA, static_cast<WPARAM>(alpha), 0, bDirect);
BOOL CScintillaCtrl::GetSelEOLFilled(BOOL bDirect)
return Call(SCI_GETSELEOLFILLED, 0, 0, bDirect);
void CScintillaCtrl::SetSelEOLFilled(BOOL filled, BOOL bDirect)
Call(SCI_SETSELEOLFILLED, static_cast<WPARAM>(filled), 0, bDirect);
void CScintillaCtrl::SetCaretFore(COLORREF fore, BOOL bDirect)
Call(SCI_SETCARETFORE, static_cast<WPARAM>(fore), 0, bDirect);
void CScintillaCtrl::AssignCmdKey(DWORD km, int msg, BOOL bDirect)
Call(SCI_ASSIGNCMDKEY, static_cast<WPARAM>(km), static_cast<LPARAM>(msg), bDirect);
void CScintillaCtrl::ClearCmdKey(DWORD km, BOOL bDirect)
Call(SCI_CLEARCMDKEY, static_cast<WPARAM>(km), 0, bDirect);
void CScintillaCtrl::ClearAllCmdKeys(BOOL bDirect)
Call(SCI_CLEARALLCMDKEYS, 0, 0, bDirect);
void CScintillaCtrl::SetStylingEx(int length, const char* styles, BOOL bDirect)
Call(SCI_SETSTYLINGEX, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(styles), bDirect);
void CScintillaCtrl::StyleSetVisible(int style, BOOL visible, BOOL bDirect)
Call(SCI_STYLESETVISIBLE, static_cast<WPARAM>(style), static_cast<LPARAM>(visible), bDirect);
int CScintillaCtrl::GetCaretPeriod(BOOL bDirect)
return Call(SCI_GETCARETPERIOD, 0, 0, bDirect);
void CScintillaCtrl::SetCaretPeriod(int periodMilliseconds, BOOL bDirect)
Call(SCI_SETCARETPERIOD, static_cast<WPARAM>(periodMilliseconds), 0, bDirect);
void CScintillaCtrl::SetWordChars(const char* characters, BOOL bDirect)
Call(SCI_SETWORDCHARS, 0, reinterpret_cast<LPARAM>(characters), bDirect);
void CScintillaCtrl::BeginUndoAction(BOOL bDirect)
Call(SCI_BEGINUNDOACTION, 0, 0, bDirect);
void CScintillaCtrl::EndUndoAction(BOOL bDirect)
Call(SCI_ENDUNDOACTION, 0, 0, bDirect);
void CScintillaCtrl::IndicSetStyle(int indic, int style, BOOL bDirect)
Call(SCI_INDICSETSTYLE, static_cast<WPARAM>(indic), static_cast<LPARAM>(style), bDirect);
int CScintillaCtrl::IndicGetStyle(int indic, BOOL bDirect)
return Call(SCI_INDICGETSTYLE, static_cast<WPARAM>(indic), 0, bDirect);
void CScintillaCtrl::IndicSetFore(int indic, COLORREF fore, BOOL bDirect)
Call(SCI_INDICSETFORE, static_cast<WPARAM>(indic), static_cast<LPARAM>(fore), bDirect);
COLORREF CScintillaCtrl::IndicGetFore(int indic, BOOL bDirect)
return Call(SCI_INDICGETFORE, static_cast<WPARAM>(indic), 0, bDirect);
void CScintillaCtrl::IndicSetUnder(int indic, BOOL under, BOOL bDirect)
Call(SCI_INDICSETUNDER, static_cast<WPARAM>(indic), static_cast<LPARAM>(under), bDirect);
BOOL CScintillaCtrl::IndicGetUnder(int indic, BOOL bDirect)
return Call(SCI_INDICGETUNDER, static_cast<WPARAM>(indic), 0, bDirect);
void CScintillaCtrl::SetWhitespaceFore(BOOL useSetting, COLORREF fore, BOOL bDirect)
Call(SCI_SETWHITESPACEFORE, static_cast<WPARAM>(useSetting), static_cast<LPARAM>(fore), bDirect);
void CScintillaCtrl::SetWhitespaceBack(BOOL useSetting, COLORREF back, BOOL bDirect)
Call(SCI_SETWHITESPACEBACK, static_cast<WPARAM>(useSetting), static_cast<LPARAM>(back), bDirect);
void CScintillaCtrl::SetStyleBits(int bits, BOOL bDirect)
Call(SCI_SETSTYLEBITS, static_cast<WPARAM>(bits), 0, bDirect);
int CScintillaCtrl::GetStyleBits(BOOL bDirect)
return Call(SCI_GETSTYLEBITS, 0, 0, bDirect);
void CScintillaCtrl::SetLineState(int line, int state, BOOL bDirect)
Call(SCI_SETLINESTATE, static_cast<WPARAM>(line), static_cast<LPARAM>(state), bDirect);
int CScintillaCtrl::GetLineState(int line, BOOL bDirect)
return Call(SCI_GETLINESTATE, static_cast<WPARAM>(line), 0, bDirect);
int CScintillaCtrl::GetMaxLineState(BOOL bDirect)
return Call(SCI_GETMAXLINESTATE, 0, 0, bDirect);
BOOL CScintillaCtrl::GetCaretLineVisible(BOOL bDirect)
return Call(SCI_GETCARETLINEVISIBLE, 0, 0, bDirect);
void CScintillaCtrl::SetCaretLineVisible(BOOL show, BOOL bDirect)
Call(SCI_SETCARETLINEVISIBLE, static_cast<WPARAM>(show), 0, bDirect);
COLORREF CScintillaCtrl::GetCaretLineBack(BOOL bDirect)
return Call(SCI_GETCARETLINEBACK, 0, 0, bDirect);
void CScintillaCtrl::SetCaretLineBack(COLORREF back, BOOL bDirect)
Call(SCI_SETCARETLINEBACK, static_cast<WPARAM>(back), 0, bDirect);
void CScintillaCtrl::StyleSetChangeable(int style, BOOL changeable, BOOL bDirect)
Call(SCI_STYLESETCHANGEABLE, static_cast<WPARAM>(style), static_cast<LPARAM>(changeable), bDirect);
void CScintillaCtrl::AutoCShow(int lenEntered, const char* itemList, BOOL bDirect)
Call(SCI_AUTOCSHOW, static_cast<WPARAM>(lenEntered), reinterpret_cast<LPARAM>(itemList), bDirect);
void CScintillaCtrl::AutoCCancel(BOOL bDirect)
Call(SCI_AUTOCCANCEL, 0, 0, bDirect);
BOOL CScintillaCtrl::AutoCActive(BOOL bDirect)
return Call(SCI_AUTOCACTIVE, 0, 0, bDirect);
long CScintillaCtrl::AutoCPosStart(BOOL bDirect)
return Call(SCI_AUTOCPOSSTART, 0, 0, bDirect);
void CScintillaCtrl::AutoCComplete(BOOL bDirect)
Call(SCI_AUTOCCOMPLETE, 0, 0, bDirect);
void CScintillaCtrl::AutoCStops(const char* characterSet, BOOL bDirect)
Call(SCI_AUTOCSTOPS, 0, reinterpret_cast<LPARAM>(characterSet), bDirect);
void CScintillaCtrl::AutoCSetSeparator(int separatorCharacter, BOOL bDirect)
Call(SCI_AUTOCSETSEPARATOR, static_cast<WPARAM>(separatorCharacter), 0, bDirect);
int CScintillaCtrl::AutoCGetSeparator(BOOL bDirect)
return Call(SCI_AUTOCGETSEPARATOR, 0, 0, bDirect);
void CScintillaCtrl::AutoCSelect(const char* text, BOOL bDirect)
Call(SCI_AUTOCSELECT, 0, reinterpret_cast<LPARAM>(text), bDirect);
void CScintillaCtrl::AutoCSetCancelAtStart(BOOL cancel, BOOL bDirect)
Call(SCI_AUTOCSETCANCELATSTART, static_cast<WPARAM>(cancel), 0, bDirect);
BOOL CScintillaCtrl::AutoCGetCancelAtStart(BOOL bDirect)
return Call(SCI_AUTOCGETCANCELATSTART, 0, 0, bDirect);
void CScintillaCtrl::AutoCSetFillUps(const char* characterSet, BOOL bDirect)
Call(SCI_AUTOCSETFILLUPS, 0, reinterpret_cast<LPARAM>(characterSet), bDirect);
void CScintillaCtrl::AutoCSetChooseSingle(BOOL chooseSingle, BOOL bDirect)
Call(SCI_AUTOCSETCHOOSESINGLE, static_cast<WPARAM>(chooseSingle), 0, bDirect);
BOOL CScintillaCtrl::AutoCGetChooseSingle(BOOL bDirect)
return Call(SCI_AUTOCGETCHOOSESINGLE, 0, 0, bDirect);
void CScintillaCtrl::AutoCSetIgnoreCase(BOOL ignoreCase, BOOL bDirect)
Call(SCI_AUTOCSETIGNORECASE, static_cast<WPARAM>(ignoreCase), 0, bDirect);
BOOL CScintillaCtrl::AutoCGetIgnoreCase(BOOL bDirect)
return Call(SCI_AUTOCGETIGNORECASE, 0, 0, bDirect);
void CScintillaCtrl::UserListShow(int listType, const char* itemList, BOOL bDirect)
Call(SCI_USERLISTSHOW, static_cast<WPARAM>(listType), reinterpret_cast<LPARAM>(itemList), bDirect);
void CScintillaCtrl::AutoCSetAutoHide(BOOL autoHide, BOOL bDirect)
Call(SCI_AUTOCSETAUTOHIDE, static_cast<WPARAM>(autoHide), 0, bDirect);
BOOL CScintillaCtrl::AutoCGetAutoHide(BOOL bDirect)
return Call(SCI_AUTOCGETAUTOHIDE, 0, 0, bDirect);
void CScintillaCtrl::AutoCSetDropRestOfWord(BOOL dropRestOfWord, BOOL bDirect)
Call(SCI_AUTOCSETDROPRESTOFWORD, static_cast<WPARAM>(dropRestOfWord), 0, bDirect);
BOOL CScintillaCtrl::AutoCGetDropRestOfWord(BOOL bDirect)
return Call(SCI_AUTOCGETDROPRESTOFWORD, 0, 0, bDirect);
void CScintillaCtrl::RegisterImage(int type, const char* xpmData, BOOL bDirect)
Call(SCI_REGISTERIMAGE, static_cast<WPARAM>(type), reinterpret_cast<LPARAM>(xpmData), bDirect);
void CScintillaCtrl::ClearRegisteredImages(BOOL bDirect)
Call(SCI_CLEARREGISTEREDIMAGES, 0, 0, bDirect);
int CScintillaCtrl::AutoCGetTypeSeparator(BOOL bDirect)
return Call(SCI_AUTOCGETTYPESEPARATOR, 0, 0, bDirect);
void CScintillaCtrl::AutoCSetTypeSeparator(int separatorCharacter, BOOL bDirect)
Call(SCI_AUTOCSETTYPESEPARATOR, static_cast<WPARAM>(separatorCharacter), 0, bDirect);
void CScintillaCtrl::AutoCSetMaxWidth(int characterCount, BOOL bDirect)
Call(SCI_AUTOCSETMAXWIDTH, static_cast<WPARAM>(characterCount), 0, bDirect);
int CScintillaCtrl::AutoCGetMaxWidth(BOOL bDirect)
return Call(SCI_AUTOCGETMAXWIDTH, 0, 0, bDirect);
void CScintillaCtrl::AutoCSetMaxHeight(int rowCount, BOOL bDirect)
Call(SCI_AUTOCSETMAXHEIGHT, static_cast<WPARAM>(rowCount), 0, bDirect);
int CScintillaCtrl::AutoCGetMaxHeight(BOOL bDirect)
return Call(SCI_AUTOCGETMAXHEIGHT, 0, 0, bDirect);
void CScintillaCtrl::SetIndent(int indentSize, BOOL bDirect)
Call(SCI_SETINDENT, static_cast<WPARAM>(indentSize), 0, bDirect);
int CScintillaCtrl::GetIndent(BOOL bDirect)
return Call(SCI_GETINDENT, 0, 0, bDirect);
void CScintillaCtrl::SetUseTabs(BOOL useTabs, BOOL bDirect)
Call(SCI_SETUSETABS, static_cast<WPARAM>(useTabs), 0, bDirect);
BOOL CScintillaCtrl::GetUseTabs(BOOL bDirect)
return Call(SCI_GETUSETABS, 0, 0, bDirect);
void CScintillaCtrl::SetLineIndentation(int line, int indentSize, BOOL bDirect)
Call(SCI_SETLINEINDENTATION, static_cast<WPARAM>(line), static_cast<LPARAM>(indentSize), bDirect);
int CScintillaCtrl::GetLineIndentation(int line, BOOL bDirect)
return Call(SCI_GETLINEINDENTATION, static_cast<WPARAM>(line), 0, bDirect);
long CScintillaCtrl::GetLineIndentPosition(int line, BOOL bDirect)
return Call(SCI_GETLINEINDENTPOSITION, static_cast<WPARAM>(line), 0, bDirect);
int CScintillaCtrl::GetColumn(long pos, BOOL bDirect)
return Call(SCI_GETCOLUMN, static_cast<WPARAM>(pos), 0, bDirect);
void CScintillaCtrl::SetHScrollBar(BOOL show, BOOL bDirect)
Call(SCI_SETHSCROLLBAR, static_cast<WPARAM>(show), 0, bDirect);
BOOL CScintillaCtrl::GetHScrollBar(BOOL bDirect)
return Call(SCI_GETHSCROLLBAR, 0, 0, bDirect);
void CScintillaCtrl::SetIndentationGuides(int indentView, BOOL bDirect)
Call(SCI_SETINDENTATIONGUIDES, static_cast<WPARAM>(indentView), 0, bDirect);
int CScintillaCtrl::GetIndentationGuides(BOOL bDirect)
return Call(SCI_GETINDENTATIONGUIDES, 0, 0, bDirect);
void CScintillaCtrl::SetHighlightGuide(int column, BOOL bDirect)
Call(SCI_SETHIGHLIGHTGUIDE, static_cast<WPARAM>(column), 0, bDirect);
int CScintillaCtrl::GetHighlightGuide(BOOL bDirect)
return Call(SCI_GETHIGHLIGHTGUIDE, 0, 0, bDirect);
int CScintillaCtrl::GetLineEndPosition(int line, BOOL bDirect)
return Call(SCI_GETLINEENDPOSITION, static_cast<WPARAM>(line), 0, bDirect);
int CScintillaCtrl::GetCodePage(BOOL bDirect)
return Call(SCI_GETCODEPAGE, 0, 0, bDirect);
COLORREF CScintillaCtrl::GetCaretFore(BOOL bDirect)
return Call(SCI_GETCARETFORE, 0, 0, bDirect);
BOOL CScintillaCtrl::GetUsePalette(BOOL bDirect)
return Call(SCI_GETUSEPALETTE, 0, 0, bDirect);
BOOL CScintillaCtrl::GetReadOnly(BOOL bDirect)
return Call(SCI_GETREADONLY, 0, 0, bDirect);
void CScintillaCtrl::SetCurrentPos(long pos, BOOL bDirect)
Call(SCI_SETCURRENTPOS, static_cast<WPARAM>(pos), 0, bDirect);
void CScintillaCtrl::SetSelectionStart(long pos, BOOL bDirect)
Call(SCI_SETSELECTIONSTART, static_cast<WPARAM>(pos), 0, bDirect);
long CScintillaCtrl::GetSelectionStart(BOOL bDirect)
return Call(SCI_GETSELECTIONSTART, 0, 0, bDirect);
void CScintillaCtrl::SetSelectionEnd(long pos, BOOL bDirect)
Call(SCI_SETSELECTIONEND, static_cast<WPARAM>(pos), 0, bDirect);
long CScintillaCtrl::GetSelectionEnd(BOOL bDirect)
return Call(SCI_GETSELECTIONEND, 0, 0, bDirect);
void CScintillaCtrl::SetPrintMagnification(int magnification, BOOL bDirect)
Call(SCI_SETPRINTMAGNIFICATION, static_cast<WPARAM>(magnification), 0, bDirect);
int CScintillaCtrl::GetPrintMagnification(BOOL bDirect)
return Call(SCI_GETPRINTMAGNIFICATION, 0, 0, bDirect);
void CScintillaCtrl::SetPrintColourMode(int mode, BOOL bDirect)
Call(SCI_SETPRINTCOLOURMODE, static_cast<WPARAM>(mode), 0, bDirect);
int CScintillaCtrl::GetPrintColourMode(BOOL bDirect)
return Call(SCI_GETPRINTCOLOURMODE, 0, 0, bDirect);
long CScintillaCtrl::FindText(int flags, TextToFind* ft, BOOL bDirect)
return Call(SCI_FINDTEXT, static_cast<WPARAM>(flags), reinterpret_cast<LPARAM>(ft), bDirect);
long CScintillaCtrl::FormatRange(BOOL draw, RangeToFormat* fr, BOOL bDirect)
return Call(SCI_FORMATRANGE, static_cast<WPARAM>(draw), reinterpret_cast<LPARAM>(fr), bDirect);
int CScintillaCtrl::GetFirstVisibleLine(BOOL bDirect)
return Call(SCI_GETFIRSTVISIBLELINE, 0, 0, bDirect);
int CScintillaCtrl::GetLine(int line, char* text, BOOL bDirect)
return Call(SCI_GETLINE, static_cast<WPARAM>(line), reinterpret_cast<LPARAM>(text), bDirect);
int CScintillaCtrl::GetLineCount(BOOL bDirect)
return Call(SCI_GETLINECOUNT, 0, 0, bDirect);
void CScintillaCtrl::SetMarginLeft(int pixelWidth, BOOL bDirect)
Call(SCI_SETMARGINLEFT, 0, static_cast<LPARAM>(pixelWidth), bDirect);
int CScintillaCtrl::GetMarginLeft(BOOL bDirect)
return Call(SCI_GETMARGINLEFT, 0, 0, bDirect);
void CScintillaCtrl::SetMarginRight(int pixelWidth, BOOL bDirect)
Call(SCI_SETMARGINRIGHT, 0, static_cast<LPARAM>(pixelWidth), bDirect);
int CScintillaCtrl::GetMarginRight(BOOL bDirect)
return Call(SCI_GETMARGINRIGHT, 0, 0, bDirect);
BOOL CScintillaCtrl::GetModify(BOOL bDirect)
return Call(SCI_GETMODIFY, 0, 0, bDirect);
void CScintillaCtrl::SetSel(long start, long end, BOOL bDirect)
Call(SCI_SETSEL, static_cast<WPARAM>(start), static_cast<LPARAM>(end), bDirect);
int CScintillaCtrl::GetSelText(char* text, BOOL bDirect)
return Call(SCI_GETSELTEXT, 0, reinterpret_cast<LPARAM>(text), bDirect);
int CScintillaCtrl::GetTextRange(TextRange* tr, BOOL bDirect)
return Call(SCI_GETTEXTRANGE, 0, reinterpret_cast<LPARAM>(tr), bDirect);
void CScintillaCtrl::HideSelection(BOOL normal, BOOL bDirect)
Call(SCI_HIDESELECTION, static_cast<WPARAM>(normal), 0, bDirect);
int CScintillaCtrl::PointXFromPosition(long pos, BOOL bDirect)
return Call(SCI_POINTXFROMPOSITION, 0, static_cast<LPARAM>(pos), bDirect);
int CScintillaCtrl::PointYFromPosition(long pos, BOOL bDirect)
return Call(SCI_POINTYFROMPOSITION, 0, static_cast<LPARAM>(pos), bDirect);
int CScintillaCtrl::LineFromPosition(long pos, BOOL bDirect)
return Call(SCI_LINEFROMPOSITION, static_cast<WPARAM>(pos), 0, bDirect);
long CScintillaCtrl::PositionFromLine(int line, BOOL bDirect)
return Call(SCI_POSITIONFROMLINE, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::LineScroll(int columns, int lines, BOOL bDirect)
Call(SCI_LINESCROLL, static_cast<WPARAM>(columns), static_cast<LPARAM>(lines), bDirect);
void CScintillaCtrl::ScrollCaret(BOOL bDirect)
Call(SCI_SCROLLCARET, 0, 0, bDirect);
void CScintillaCtrl::ReplaceSel(const char* text, BOOL bDirect)
Call(SCI_REPLACESEL, 0, reinterpret_cast<LPARAM>(text), bDirect);
void CScintillaCtrl::SetReadOnly(BOOL readOnly, BOOL bDirect)
Call(SCI_SETREADONLY, static_cast<WPARAM>(readOnly), 0, bDirect);
void CScintillaCtrl::Null(BOOL bDirect)
Call(SCI_NULL, 0, 0, bDirect);
BOOL CScintillaCtrl::CanPaste(BOOL bDirect)
return Call(SCI_CANPASTE, 0, 0, bDirect);
BOOL CScintillaCtrl::CanUndo(BOOL bDirect)
return Call(SCI_CANUNDO, 0, 0, bDirect);
void CScintillaCtrl::EmptyUndoBuffer(BOOL bDirect)
Call(SCI_EMPTYUNDOBUFFER, 0, 0, bDirect);
void CScintillaCtrl::Undo(BOOL bDirect)
Call(SCI_UNDO, 0, 0, bDirect);
void CScintillaCtrl::Cut(BOOL bDirect)
Call(SCI_CUT, 0, 0, bDirect);
void CScintillaCtrl::Copy(BOOL bDirect)
Call(SCI_COPY, 0, 0, bDirect);
void CScintillaCtrl::Paste(BOOL bDirect)
Call(SCI_PASTE, 0, 0, bDirect);
void CScintillaCtrl::Clear(BOOL bDirect)
Call(SCI_CLEAR, 0, 0, bDirect);
void CScintillaCtrl::SetText(const char* text, BOOL bDirect)
Call(SCI_SETTEXT, 0, reinterpret_cast<LPARAM>(text), bDirect);
int CScintillaCtrl::GetText(int length, char* text, BOOL bDirect)
return Call(SCI_GETTEXT, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(text), bDirect);
int CScintillaCtrl::GetTextLength(BOOL bDirect)
return Call(SCI_GETTEXTLENGTH, 0, 0, bDirect);
void CScintillaCtrl::SetOvertype(BOOL overtype, BOOL bDirect)
Call(SCI_SETOVERTYPE, static_cast<WPARAM>(overtype), 0, bDirect);
BOOL CScintillaCtrl::GetOvertype(BOOL bDirect)
return Call(SCI_GETOVERTYPE, 0, 0, bDirect);
void CScintillaCtrl::SetCaretWidth(int pixelWidth, BOOL bDirect)
Call(SCI_SETCARETWIDTH, static_cast<WPARAM>(pixelWidth), 0, bDirect);
int CScintillaCtrl::GetCaretWidth(BOOL bDirect)
return Call(SCI_GETCARETWIDTH, 0, 0, bDirect);
void CScintillaCtrl::SetTargetStart(long pos, BOOL bDirect)
Call(SCI_SETTARGETSTART, static_cast<WPARAM>(pos), 0, bDirect);
long CScintillaCtrl::GetTargetStart(BOOL bDirect)
return Call(SCI_GETTARGETSTART, 0, 0, bDirect);
void CScintillaCtrl::SetTargetEnd(long pos, BOOL bDirect)
Call(SCI_SETTARGETEND, static_cast<WPARAM>(pos), 0, bDirect);
long CScintillaCtrl::GetTargetEnd(BOOL bDirect)
return Call(SCI_GETTARGETEND, 0, 0, bDirect);
int CScintillaCtrl::ReplaceTarget(int length, const char* text, BOOL bDirect)
return Call(SCI_REPLACETARGET, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(text), bDirect);
int CScintillaCtrl::ReplaceTargetRE(int length, const char* text, BOOL bDirect)
return Call(SCI_REPLACETARGETRE, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(text), bDirect);
int CScintillaCtrl::SearchInTarget(int length, const char* text, BOOL bDirect)
return Call(SCI_SEARCHINTARGET, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(text), bDirect);
void CScintillaCtrl::SetSearchFlags(int flags, BOOL bDirect)
Call(SCI_SETSEARCHFLAGS, static_cast<WPARAM>(flags), 0, bDirect);
int CScintillaCtrl::GetSearchFlags(BOOL bDirect)
return Call(SCI_GETSEARCHFLAGS, 0, 0, bDirect);
void CScintillaCtrl::CallTipShow(long pos, const char* definition, BOOL bDirect)
Call(SCI_CALLTIPSHOW, static_cast<WPARAM>(pos), reinterpret_cast<LPARAM>(definition), bDirect);
void CScintillaCtrl::CallTipCancel(BOOL bDirect)
Call(SCI_CALLTIPCANCEL, 0, 0, bDirect);
BOOL CScintillaCtrl::CallTipActive(BOOL bDirect)
return Call(SCI_CALLTIPACTIVE, 0, 0, bDirect);
long CScintillaCtrl::CallTipPosStart(BOOL bDirect)
return Call(SCI_CALLTIPPOSSTART, 0, 0, bDirect);
void CScintillaCtrl::CallTipSetHlt(int start, int end, BOOL bDirect)
Call(SCI_CALLTIPSETHLT, static_cast<WPARAM>(start), static_cast<LPARAM>(end), bDirect);
void CScintillaCtrl::CallTipSetBack(COLORREF back, BOOL bDirect)
Call(SCI_CALLTIPSETBACK, static_cast<WPARAM>(back), 0, bDirect);
void CScintillaCtrl::CallTipSetFore(COLORREF fore, BOOL bDirect)
Call(SCI_CALLTIPSETFORE, static_cast<WPARAM>(fore), 0, bDirect);
void CScintillaCtrl::CallTipSetForeHlt(COLORREF fore, BOOL bDirect)
Call(SCI_CALLTIPSETFOREHLT, static_cast<WPARAM>(fore), 0, bDirect);
void CScintillaCtrl::CallTipUseStyle(int tabSize, BOOL bDirect)
Call(SCI_CALLTIPUSESTYLE, static_cast<WPARAM>(tabSize), 0, bDirect);
int CScintillaCtrl::VisibleFromDocLine(int line, BOOL bDirect)
return Call(SCI_VISIBLEFROMDOCLINE, static_cast<WPARAM>(line), 0, bDirect);
int CScintillaCtrl::DocLineFromVisible(int lineDisplay, BOOL bDirect)
return Call(SCI_DOCLINEFROMVISIBLE, static_cast<WPARAM>(lineDisplay), 0, bDirect);
int CScintillaCtrl::WrapCount(int line, BOOL bDirect)
return Call(SCI_WRAPCOUNT, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::SetFoldLevel(int line, int level, BOOL bDirect)
Call(SCI_SETFOLDLEVEL, static_cast<WPARAM>(line), static_cast<LPARAM>(level), bDirect);
int CScintillaCtrl::GetFoldLevel(int line, BOOL bDirect)
return Call(SCI_GETFOLDLEVEL, static_cast<WPARAM>(line), 0, bDirect);
int CScintillaCtrl::GetLastChild(int line, int level, BOOL bDirect)
return Call(SCI_GETLASTCHILD, static_cast<WPARAM>(line), static_cast<LPARAM>(level), bDirect);
int CScintillaCtrl::GetFoldParent(int line, BOOL bDirect)
return Call(SCI_GETFOLDPARENT, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::ShowLines(int lineStart, int lineEnd, BOOL bDirect)
Call(SCI_SHOWLINES, static_cast<WPARAM>(lineStart), static_cast<LPARAM>(lineEnd), bDirect);
void CScintillaCtrl::HideLines(int lineStart, int lineEnd, BOOL bDirect)
Call(SCI_HIDELINES, static_cast<WPARAM>(lineStart), static_cast<LPARAM>(lineEnd), bDirect);
BOOL CScintillaCtrl::GetLineVisible(int line, BOOL bDirect)
return Call(SCI_GETLINEVISIBLE, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::SetFoldExpanded(int line, BOOL expanded, BOOL bDirect)
Call(SCI_SETFOLDEXPANDED, static_cast<WPARAM>(line), static_cast<LPARAM>(expanded), bDirect);
BOOL CScintillaCtrl::GetFoldExpanded(int line, BOOL bDirect)
return Call(SCI_GETFOLDEXPANDED, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::ToggleFold(int line, BOOL bDirect)
Call(SCI_TOGGLEFOLD, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::EnsureVisible(int line, BOOL bDirect)
Call(SCI_ENSUREVISIBLE, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::SetFoldFlags(int flags, BOOL bDirect)
Call(SCI_SETFOLDFLAGS, static_cast<WPARAM>(flags), 0, bDirect);
void CScintillaCtrl::EnsureVisibleEnforcePolicy(int line, BOOL bDirect)
Call(SCI_ENSUREVISIBLEENFORCEPOLICY, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::SetTabIndents(BOOL tabIndents, BOOL bDirect)
Call(SCI_SETTABINDENTS, static_cast<WPARAM>(tabIndents), 0, bDirect);
BOOL CScintillaCtrl::GetTabIndents(BOOL bDirect)
return Call(SCI_GETTABINDENTS, 0, 0, bDirect);
void CScintillaCtrl::SetBackSpaceUnIndents(BOOL bsUnIndents, BOOL bDirect)
Call(SCI_SETBACKSPACEUNINDENTS, static_cast<WPARAM>(bsUnIndents), 0, bDirect);
BOOL CScintillaCtrl::GetBackSpaceUnIndents(BOOL bDirect)
return Call(SCI_GETBACKSPACEUNINDENTS, 0, 0, bDirect);
void CScintillaCtrl::SetMouseDwellTime(int periodMilliseconds, BOOL bDirect)
Call(SCI_SETMOUSEDWELLTIME, static_cast<WPARAM>(periodMilliseconds), 0, bDirect);
int CScintillaCtrl::GetMouseDwellTime(BOOL bDirect)
return Call(SCI_GETMOUSEDWELLTIME, 0, 0, bDirect);
int CScintillaCtrl::WordStartPosition(long pos, BOOL onlyWordCharacters, BOOL bDirect)
return Call(SCI_WORDSTARTPOSITION, static_cast<WPARAM>(pos), static_cast<LPARAM>(onlyWordCharacters), bDirect);
int CScintillaCtrl::WordEndPosition(long pos, BOOL onlyWordCharacters, BOOL bDirect)
return Call(SCI_WORDENDPOSITION, static_cast<WPARAM>(pos), static_cast<LPARAM>(onlyWordCharacters), bDirect);
void CScintillaCtrl::SetWrapMode(int mode, BOOL bDirect)
Call(SCI_SETWRAPMODE, static_cast<WPARAM>(mode), 0, bDirect);
int CScintillaCtrl::GetWrapMode(BOOL bDirect)
return Call(SCI_GETWRAPMODE, 0, 0, bDirect);
void CScintillaCtrl::SetWrapVisualFlags(int wrapVisualFlags, BOOL bDirect)
Call(SCI_SETWRAPVISUALFLAGS, static_cast<WPARAM>(wrapVisualFlags), 0, bDirect);
int CScintillaCtrl::GetWrapVisualFlags(BOOL bDirect)
return Call(SCI_GETWRAPVISUALFLAGS, 0, 0, bDirect);
void CScintillaCtrl::SetWrapVisualFlagsLocation(int wrapVisualFlagsLocation, BOOL bDirect)
Call(SCI_SETWRAPVISUALFLAGSLOCATION, static_cast<WPARAM>(wrapVisualFlagsLocation), 0, bDirect);
int CScintillaCtrl::GetWrapVisualFlagsLocation(BOOL bDirect)
return Call(SCI_GETWRAPVISUALFLAGSLOCATION, 0, 0, bDirect);
void CScintillaCtrl::SetWrapStartIndent(int indent, BOOL bDirect)
Call(SCI_SETWRAPSTARTINDENT, static_cast<WPARAM>(indent), 0, bDirect);
int CScintillaCtrl::GetWrapStartIndent(BOOL bDirect)
return Call(SCI_GETWRAPSTARTINDENT, 0, 0, bDirect);
void CScintillaCtrl::SetLayoutCache(int mode, BOOL bDirect)
Call(SCI_SETLAYOUTCACHE, static_cast<WPARAM>(mode), 0, bDirect);
int CScintillaCtrl::GetLayoutCache(BOOL bDirect)
return Call(SCI_GETLAYOUTCACHE, 0, 0, bDirect);
void CScintillaCtrl::SetScrollWidth(int pixelWidth, BOOL bDirect)
Call(SCI_SETSCROLLWIDTH, static_cast<WPARAM>(pixelWidth), 0, bDirect);
int CScintillaCtrl::GetScrollWidth(BOOL bDirect)
return Call(SCI_GETSCROLLWIDTH, 0, 0, bDirect);
void CScintillaCtrl::SetScrollWidthTracking(BOOL tracking, BOOL bDirect)
Call(SCI_SETSCROLLWIDTHTRACKING, static_cast<WPARAM>(tracking), 0, bDirect);
BOOL CScintillaCtrl::GetScrollWidthTracking(BOOL bDirect)
return Call(SCI_GETSCROLLWIDTHTRACKING, 0, 0, bDirect);
int CScintillaCtrl::TextWidth(int style, const char* text, BOOL bDirect)
return Call(SCI_TEXTWIDTH, static_cast<WPARAM>(style), reinterpret_cast<LPARAM>(text), bDirect);
void CScintillaCtrl::SetEndAtLastLine(BOOL endAtLastLine, BOOL bDirect)
Call(SCI_SETENDATLASTLINE, static_cast<WPARAM>(endAtLastLine), 0, bDirect);
BOOL CScintillaCtrl::GetEndAtLastLine(BOOL bDirect)
return Call(SCI_GETENDATLASTLINE, 0, 0, bDirect);
int CScintillaCtrl::TextHeight(int line, BOOL bDirect)
return Call(SCI_TEXTHEIGHT, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::SetVScrollBar(BOOL show, BOOL bDirect)
Call(SCI_SETVSCROLLBAR, static_cast<WPARAM>(show), 0, bDirect);
BOOL CScintillaCtrl::GetVScrollBar(BOOL bDirect)
return Call(SCI_GETVSCROLLBAR, 0, 0, bDirect);
void CScintillaCtrl::AppendText(int length, const char* text, BOOL bDirect)
Call(SCI_APPENDTEXT, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(text), bDirect);
BOOL CScintillaCtrl::GetTwoPhaseDraw(BOOL bDirect)
return Call(SCI_GETTWOPHASEDRAW, 0, 0, bDirect);
void CScintillaCtrl::SetTwoPhaseDraw(BOOL twoPhase, BOOL bDirect)
Call(SCI_SETTWOPHASEDRAW, static_cast<WPARAM>(twoPhase), 0, bDirect);
void CScintillaCtrl::TargetFromSelection(BOOL bDirect)
Call(SCI_TARGETFROMSELECTION, 0, 0, bDirect);
void CScintillaCtrl::LinesJoin(BOOL bDirect)
Call(SCI_LINESJOIN, 0, 0, bDirect);
void CScintillaCtrl::LinesSplit(int pixelWidth, BOOL bDirect)
Call(SCI_LINESSPLIT, static_cast<WPARAM>(pixelWidth), 0, bDirect);
void CScintillaCtrl::SetFoldMarginColour(BOOL useSetting, COLORREF back, BOOL bDirect)
Call(SCI_SETFOLDMARGINCOLOUR, static_cast<WPARAM>(useSetting), static_cast<LPARAM>(back), bDirect);
void CScintillaCtrl::SetFoldMarginHiColour(BOOL useSetting, COLORREF fore, BOOL bDirect)
Call(SCI_SETFOLDMARGINHICOLOUR, static_cast<WPARAM>(useSetting), static_cast<LPARAM>(fore), bDirect);
void CScintillaCtrl::LineDown(BOOL bDirect)
Call(SCI_LINEDOWN, 0, 0, bDirect);
void CScintillaCtrl::LineDownExtend(BOOL bDirect)
Call(SCI_LINEDOWNEXTEND, 0, 0, bDirect);
void CScintillaCtrl::LineUp(BOOL bDirect)
Call(SCI_LINEUP, 0, 0, bDirect);
void CScintillaCtrl::LineUpExtend(BOOL bDirect)
Call(SCI_LINEUPEXTEND, 0, 0, bDirect);
void CScintillaCtrl::CharLeft(BOOL bDirect)
Call(SCI_CHARLEFT, 0, 0, bDirect);
void CScintillaCtrl::CharLeftExtend(BOOL bDirect)
Call(SCI_CHARLEFTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::CharRight(BOOL bDirect)
Call(SCI_CHARRIGHT, 0, 0, bDirect);
void CScintillaCtrl::CharRightExtend(BOOL bDirect)
Call(SCI_CHARRIGHTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::WordLeft(BOOL bDirect)
Call(SCI_WORDLEFT, 0, 0, bDirect);
void CScintillaCtrl::WordLeftExtend(BOOL bDirect)
Call(SCI_WORDLEFTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::WordRight(BOOL bDirect)
Call(SCI_WORDRIGHT, 0, 0, bDirect);
void CScintillaCtrl::WordRightExtend(BOOL bDirect)
Call(SCI_WORDRIGHTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::Home(BOOL bDirect)
Call(SCI_HOME, 0, 0, bDirect);
void CScintillaCtrl::HomeExtend(BOOL bDirect)
Call(SCI_HOMEEXTEND, 0, 0, bDirect);
void CScintillaCtrl::LineEnd(BOOL bDirect)
Call(SCI_LINEEND, 0, 0, bDirect);
void CScintillaCtrl::LineEndExtend(BOOL bDirect)
Call(SCI_LINEENDEXTEND, 0, 0, bDirect);
void CScintillaCtrl::DocumentStart(BOOL bDirect)
Call(SCI_DOCUMENTSTART, 0, 0, bDirect);
void CScintillaCtrl::DocumentStartExtend(BOOL bDirect)
Call(SCI_DOCUMENTSTARTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::DocumentEnd(BOOL bDirect)
Call(SCI_DOCUMENTEND, 0, 0, bDirect);
void CScintillaCtrl::DocumentEndExtend(BOOL bDirect)
Call(SCI_DOCUMENTENDEXTEND, 0, 0, bDirect);
void CScintillaCtrl::PageUp(BOOL bDirect)
Call(SCI_PAGEUP, 0, 0, bDirect);
void CScintillaCtrl::PageUpExtend(BOOL bDirect)
Call(SCI_PAGEUPEXTEND, 0, 0, bDirect);
void CScintillaCtrl::PageDown(BOOL bDirect)
Call(SCI_PAGEDOWN, 0, 0, bDirect);
void CScintillaCtrl::PageDownExtend(BOOL bDirect)
Call(SCI_PAGEDOWNEXTEND, 0, 0, bDirect);
void CScintillaCtrl::EditToggleOvertype(BOOL bDirect)
Call(SCI_EDITTOGGLEOVERTYPE, 0, 0, bDirect);
void CScintillaCtrl::Cancel(BOOL bDirect)
Call(SCI_CANCEL, 0, 0, bDirect);
void CScintillaCtrl::DeleteBack(BOOL bDirect)
Call(SCI_DELETEBACK, 0, 0, bDirect);
void CScintillaCtrl::Tab(BOOL bDirect)
Call(SCI_TAB, 0, 0, bDirect);
void CScintillaCtrl::BackTab(BOOL bDirect)
Call(SCI_BACKTAB, 0, 0, bDirect);
void CScintillaCtrl::NewLine(BOOL bDirect)
Call(SCI_NEWLINE, 0, 0, bDirect);
void CScintillaCtrl::FormFeed(BOOL bDirect)
Call(SCI_FORMFEED, 0, 0, bDirect);
void CScintillaCtrl::VCHome(BOOL bDirect)
Call(SCI_VCHOME, 0, 0, bDirect);
void CScintillaCtrl::VCHomeExtend(BOOL bDirect)
Call(SCI_VCHOMEEXTEND, 0, 0, bDirect);
void CScintillaCtrl::ZoomIn(BOOL bDirect)
Call(SCI_ZOOMIN, 0, 0, bDirect);
void CScintillaCtrl::ZoomOut(BOOL bDirect)
Call(SCI_ZOOMOUT, 0, 0, bDirect);
void CScintillaCtrl::DelWordLeft(BOOL bDirect)
Call(SCI_DELWORDLEFT, 0, 0, bDirect);
void CScintillaCtrl::DelWordRight(BOOL bDirect)
Call(SCI_DELWORDRIGHT, 0, 0, bDirect);
void CScintillaCtrl::DelWordRightEnd(BOOL bDirect)
Call(SCI_DELWORDRIGHTEND, 0, 0, bDirect);
void CScintillaCtrl::LineCut(BOOL bDirect)
Call(SCI_LINECUT, 0, 0, bDirect);
void CScintillaCtrl::LineDelete(BOOL bDirect)
Call(SCI_LINEDELETE, 0, 0, bDirect);
void CScintillaCtrl::LineTranspose(BOOL bDirect)
Call(SCI_LINETRANSPOSE, 0, 0, bDirect);
void CScintillaCtrl::LineDuplicate(BOOL bDirect)
Call(SCI_LINEDUPLICATE, 0, 0, bDirect);
void CScintillaCtrl::LowerCase(BOOL bDirect)
Call(SCI_LOWERCASE, 0, 0, bDirect);
void CScintillaCtrl::UpperCase(BOOL bDirect)
Call(SCI_UPPERCASE, 0, 0, bDirect);
void CScintillaCtrl::LineScrollDown(BOOL bDirect)
Call(SCI_LINESCROLLDOWN, 0, 0, bDirect);
void CScintillaCtrl::LineScrollUp(BOOL bDirect)
Call(SCI_LINESCROLLUP, 0, 0, bDirect);
void CScintillaCtrl::DeleteBackNotLine(BOOL bDirect)
Call(SCI_DELETEBACKNOTLINE, 0, 0, bDirect);
void CScintillaCtrl::HomeDisplay(BOOL bDirect)
Call(SCI_HOMEDISPLAY, 0, 0, bDirect);
void CScintillaCtrl::HomeDisplayExtend(BOOL bDirect)
Call(SCI_HOMEDISPLAYEXTEND, 0, 0, bDirect);
void CScintillaCtrl::LineEndDisplay(BOOL bDirect)
Call(SCI_LINEENDDISPLAY, 0, 0, bDirect);
void CScintillaCtrl::LineEndDisplayExtend(BOOL bDirect)
Call(SCI_LINEENDDISPLAYEXTEND, 0, 0, bDirect);
void CScintillaCtrl::HomeWrap(BOOL bDirect)
Call(SCI_HOMEWRAP, 0, 0, bDirect);
void CScintillaCtrl::HomeWrapExtend(BOOL bDirect)
Call(SCI_HOMEWRAPEXTEND, 0, 0, bDirect);
void CScintillaCtrl::LineEndWrap(BOOL bDirect)
Call(SCI_LINEENDWRAP, 0, 0, bDirect);
void CScintillaCtrl::LineEndWrapExtend(BOOL bDirect)
Call(SCI_LINEENDWRAPEXTEND, 0, 0, bDirect);
void CScintillaCtrl::VCHomeWrap(BOOL bDirect)
Call(SCI_VCHOMEWRAP, 0, 0, bDirect);
void CScintillaCtrl::VCHomeWrapExtend(BOOL bDirect)
Call(SCI_VCHOMEWRAPEXTEND, 0, 0, bDirect);
void CScintillaCtrl::LineCopy(BOOL bDirect)
Call(SCI_LINECOPY, 0, 0, bDirect);
void CScintillaCtrl::MoveCaretInsideView(BOOL bDirect)
Call(SCI_MOVECARETINSIDEVIEW, 0, 0, bDirect);
int CScintillaCtrl::LineLength(int line, BOOL bDirect)
return Call(SCI_LINELENGTH, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::BraceHighlight(long pos1, long pos2, BOOL bDirect)
Call(SCI_BRACEHIGHLIGHT, static_cast<WPARAM>(pos1), static_cast<LPARAM>(pos2), bDirect);
void CScintillaCtrl::BraceBadLight(long pos, BOOL bDirect)
Call(SCI_BRACEBADLIGHT, static_cast<WPARAM>(pos), 0, bDirect);
long CScintillaCtrl::BraceMatch(long pos, BOOL bDirect)
return Call(SCI_BRACEMATCH, static_cast<WPARAM>(pos), 0, bDirect);
BOOL CScintillaCtrl::GetViewEOL(BOOL bDirect)
return Call(SCI_GETVIEWEOL, 0, 0, bDirect);
void CScintillaCtrl::SetViewEOL(BOOL visible, BOOL bDirect)
Call(SCI_SETVIEWEOL, static_cast<WPARAM>(visible), 0, bDirect);
int CScintillaCtrl::GetDocPointer(BOOL bDirect)
return Call(SCI_GETDOCPOINTER, 0, 0, bDirect);
void CScintillaCtrl::SetDocPointer(int pointer, BOOL bDirect)
Call(SCI_SETDOCPOINTER, 0, static_cast<LPARAM>(pointer), bDirect);
void CScintillaCtrl::SetModEventMask(int mask, BOOL bDirect)
Call(SCI_SETMODEVENTMASK, static_cast<WPARAM>(mask), 0, bDirect);
int CScintillaCtrl::GetEdgeColumn(BOOL bDirect)
return Call(SCI_GETEDGECOLUMN, 0, 0, bDirect);
void CScintillaCtrl::SetEdgeColumn(int column, BOOL bDirect)
Call(SCI_SETEDGECOLUMN, static_cast<WPARAM>(column), 0, bDirect);
int CScintillaCtrl::GetEdgeMode(BOOL bDirect)
return Call(SCI_GETEDGEMODE, 0, 0, bDirect);
void CScintillaCtrl::SetEdgeMode(int mode, BOOL bDirect)
Call(SCI_SETEDGEMODE, static_cast<WPARAM>(mode), 0, bDirect);
COLORREF CScintillaCtrl::GetEdgeColour(BOOL bDirect)
return Call(SCI_GETEDGECOLOUR, 0, 0, bDirect);
void CScintillaCtrl::SetEdgeColour(COLORREF edgeColour, BOOL bDirect)
Call(SCI_SETEDGECOLOUR, static_cast<WPARAM>(edgeColour), 0, bDirect);
void CScintillaCtrl::SearchAnchor(BOOL bDirect)
Call(SCI_SEARCHANCHOR, 0, 0, bDirect);
int CScintillaCtrl::SearchNext(int flags, const char* text, BOOL bDirect)
return Call(SCI_SEARCHNEXT, static_cast<WPARAM>(flags), reinterpret_cast<LPARAM>(text), bDirect);
int CScintillaCtrl::SearchPrev(int flags, const char* text, BOOL bDirect)
return Call(SCI_SEARCHPREV, static_cast<WPARAM>(flags), reinterpret_cast<LPARAM>(text), bDirect);
int CScintillaCtrl::LinesOnScreen(BOOL bDirect)
return Call(SCI_LINESONSCREEN, 0, 0, bDirect);
void CScintillaCtrl::UsePopUp(BOOL allowPopUp, BOOL bDirect)
Call(SCI_USEPOPUP, static_cast<WPARAM>(allowPopUp), 0, bDirect);
BOOL CScintillaCtrl::SelectionIsRectangle(BOOL bDirect)
return Call(SCI_SELECTIONISRECTANGLE, 0, 0, bDirect);
void CScintillaCtrl::SetZoom(int zoom, BOOL bDirect)
Call(SCI_SETZOOM, static_cast<WPARAM>(zoom), 0, bDirect);
int CScintillaCtrl::GetZoom(BOOL bDirect)
return Call(SCI_GETZOOM, 0, 0, bDirect);
int CScintillaCtrl::CreateDocument(BOOL bDirect)
return Call(SCI_CREATEDOCUMENT, 0, 0, bDirect);
void CScintillaCtrl::AddRefDocument(int doc, BOOL bDirect)
Call(SCI_ADDREFDOCUMENT, 0, static_cast<LPARAM>(doc), bDirect);
void CScintillaCtrl::ReleaseDocument(int doc, BOOL bDirect)
Call(SCI_RELEASEDOCUMENT, 0, static_cast<LPARAM>(doc), bDirect);
int CScintillaCtrl::GetModEventMask(BOOL bDirect)
return Call(SCI_GETMODEVENTMASK, 0, 0, bDirect);
void CScintillaCtrl::SCISetFocus(BOOL focus, BOOL bDirect)
Call(SCI_SETFOCUS, static_cast<WPARAM>(focus), 0, bDirect);
BOOL CScintillaCtrl::GetFocus(BOOL bDirect)
return Call(SCI_GETFOCUS, 0, 0, bDirect);
void CScintillaCtrl::SetStatus(int statusCode, BOOL bDirect)
Call(SCI_SETSTATUS, static_cast<WPARAM>(statusCode), 0, bDirect);
int CScintillaCtrl::GetStatus(BOOL bDirect)
return Call(SCI_GETSTATUS, 0, 0, bDirect);
void CScintillaCtrl::SetMouseDownCaptures(BOOL captures, BOOL bDirect)
Call(SCI_SETMOUSEDOWNCAPTURES, static_cast<WPARAM>(captures), 0, bDirect);
BOOL CScintillaCtrl::GetMouseDownCaptures(BOOL bDirect)
return Call(SCI_GETMOUSEDOWNCAPTURES, 0, 0, bDirect);
void CScintillaCtrl::SetCursor(int cursorType, BOOL bDirect)
Call(SCI_SETCURSOR, static_cast<WPARAM>(cursorType), 0, bDirect);
int CScintillaCtrl::GetCursor(BOOL bDirect)
return Call(SCI_GETCURSOR, 0, 0, bDirect);
void CScintillaCtrl::SetControlCharSymbol(int symbol, BOOL bDirect)
Call(SCI_SETCONTROLCHARSYMBOL, static_cast<WPARAM>(symbol), 0, bDirect);
int CScintillaCtrl::GetControlCharSymbol(BOOL bDirect)
return Call(SCI_GETCONTROLCHARSYMBOL, 0, 0, bDirect);
void CScintillaCtrl::WordPartLeft(BOOL bDirect)
Call(SCI_WORDPARTLEFT, 0, 0, bDirect);
void CScintillaCtrl::WordPartLeftExtend(BOOL bDirect)
Call(SCI_WORDPARTLEFTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::WordPartRight(BOOL bDirect)
Call(SCI_WORDPARTRIGHT, 0, 0, bDirect);
void CScintillaCtrl::WordPartRightExtend(BOOL bDirect)
Call(SCI_WORDPARTRIGHTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::SetVisiblePolicy(int visiblePolicy, int visibleSlop, BOOL bDirect)
Call(SCI_SETVISIBLEPOLICY, static_cast<WPARAM>(visiblePolicy), static_cast<LPARAM>(visibleSlop), bDirect);
void CScintillaCtrl::DelLineLeft(BOOL bDirect)
Call(SCI_DELLINELEFT, 0, 0, bDirect);
void CScintillaCtrl::DelLineRight(BOOL bDirect)
Call(SCI_DELLINERIGHT, 0, 0, bDirect);
void CScintillaCtrl::SetXOffset(int newOffset, BOOL bDirect)
Call(SCI_SETXOFFSET, static_cast<WPARAM>(newOffset), 0, bDirect);
int CScintillaCtrl::GetXOffset(BOOL bDirect)
return Call(SCI_GETXOFFSET, 0, 0, bDirect);
void CScintillaCtrl::ChooseCaretX(BOOL bDirect)
Call(SCI_CHOOSECARETX, 0, 0, bDirect);
void CScintillaCtrl::GrabFocus(BOOL bDirect)
Call(SCI_GRABFOCUS, 0, 0, bDirect);
void CScintillaCtrl::SetXCaretPolicy(int caretPolicy, int caretSlop, BOOL bDirect)
Call(SCI_SETXCARETPOLICY, static_cast<WPARAM>(caretPolicy), static_cast<LPARAM>(caretSlop), bDirect);
void CScintillaCtrl::SetYCaretPolicy(int caretPolicy, int caretSlop, BOOL bDirect)
Call(SCI_SETYCARETPOLICY, static_cast<WPARAM>(caretPolicy), static_cast<LPARAM>(caretSlop), bDirect);
void CScintillaCtrl::SetPrintWrapMode(int mode, BOOL bDirect)
Call(SCI_SETPRINTWRAPMODE, static_cast<WPARAM>(mode), 0, bDirect);
int CScintillaCtrl::GetPrintWrapMode(BOOL bDirect)
return Call(SCI_GETPRINTWRAPMODE, 0, 0, bDirect);
void CScintillaCtrl::SetHotspotActiveFore(BOOL useSetting, COLORREF fore, BOOL bDirect)
Call(SCI_SETHOTSPOTACTIVEFORE, static_cast<WPARAM>(useSetting), static_cast<LPARAM>(fore), bDirect);
COLORREF CScintillaCtrl::GetHotspotActiveFore(BOOL bDirect)
return Call(SCI_GETHOTSPOTACTIVEFORE, 0, 0, bDirect);
void CScintillaCtrl::SetHotspotActiveBack(BOOL useSetting, COLORREF back, BOOL bDirect)
Call(SCI_SETHOTSPOTACTIVEBACK, static_cast<WPARAM>(useSetting), static_cast<LPARAM>(back), bDirect);
COLORREF CScintillaCtrl::GetHotspotActiveBack(BOOL bDirect)
return Call(SCI_GETHOTSPOTACTIVEBACK, 0, 0, bDirect);
void CScintillaCtrl::SetHotspotActiveUnderline(BOOL underline, BOOL bDirect)
Call(SCI_SETHOTSPOTACTIVEUNDERLINE, static_cast<WPARAM>(underline), 0, bDirect);
BOOL CScintillaCtrl::GetHotspotActiveUnderline(BOOL bDirect)
return Call(SCI_GETHOTSPOTACTIVEUNDERLINE, 0, 0, bDirect);
void CScintillaCtrl::SetHotspotSingleLine(BOOL singleLine, BOOL bDirect)
Call(SCI_SETHOTSPOTSINGLELINE, static_cast<WPARAM>(singleLine), 0, bDirect);
BOOL CScintillaCtrl::GetHotspotSingleLine(BOOL bDirect)
return Call(SCI_GETHOTSPOTSINGLELINE, 0, 0, bDirect);
void CScintillaCtrl::ParaDown(BOOL bDirect)
Call(SCI_PARADOWN, 0, 0, bDirect);
void CScintillaCtrl::ParaDownExtend(BOOL bDirect)
Call(SCI_PARADOWNEXTEND, 0, 0, bDirect);
void CScintillaCtrl::ParaUp(BOOL bDirect)
Call(SCI_PARAUP, 0, 0, bDirect);
void CScintillaCtrl::ParaUpExtend(BOOL bDirect)
Call(SCI_PARAUPEXTEND, 0, 0, bDirect);
long CScintillaCtrl::PositionBefore(long pos, BOOL bDirect)
return Call(SCI_POSITIONBEFORE, static_cast<WPARAM>(pos), 0, bDirect);
long CScintillaCtrl::PositionAfter(long pos, BOOL bDirect)
return Call(SCI_POSITIONAFTER, static_cast<WPARAM>(pos), 0, bDirect);
void CScintillaCtrl::CopyRange(long start, long end, BOOL bDirect)
Call(SCI_COPYRANGE, static_cast<WPARAM>(start), static_cast<LPARAM>(end), bDirect);
void CScintillaCtrl::CopyText(int length, const char* text, BOOL bDirect)
Call(SCI_COPYTEXT, static_cast<WPARAM>(length), reinterpret_cast<LPARAM>(text), bDirect);
void CScintillaCtrl::SetSelectionMode(int mode, BOOL bDirect)
Call(SCI_SETSELECTIONMODE, static_cast<WPARAM>(mode), 0, bDirect);
int CScintillaCtrl::GetSelectionMode(BOOL bDirect)
return Call(SCI_GETSELECTIONMODE, 0, 0, bDirect);
long CScintillaCtrl::GetLineSelStartPosition(int line, BOOL bDirect)
return Call(SCI_GETLINESELSTARTPOSITION, static_cast<WPARAM>(line), 0, bDirect);
long CScintillaCtrl::GetLineSelEndPosition(int line, BOOL bDirect)
return Call(SCI_GETLINESELENDPOSITION, static_cast<WPARAM>(line), 0, bDirect);
void CScintillaCtrl::LineDownRectExtend(BOOL bDirect)
Call(SCI_LINEDOWNRECTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::LineUpRectExtend(BOOL bDirect)
Call(SCI_LINEUPRECTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::CharLeftRectExtend(BOOL bDirect)
Call(SCI_CHARLEFTRECTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::CharRightRectExtend(BOOL bDirect)
Call(SCI_CHARRIGHTRECTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::HomeRectExtend(BOOL bDirect)
Call(SCI_HOMERECTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::VCHomeRectExtend(BOOL bDirect)
Call(SCI_VCHOMERECTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::LineEndRectExtend(BOOL bDirect)
Call(SCI_LINEENDRECTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::PageUpRectExtend(BOOL bDirect)
Call(SCI_PAGEUPRECTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::PageDownRectExtend(BOOL bDirect)
Call(SCI_PAGEDOWNRECTEXTEND, 0, 0, bDirect);
void CScintillaCtrl::StutteredPageUp(BOOL bDirect)
Call(SCI_STUTTEREDPAGEUP, 0, 0, bDirect);
void CScintillaCtrl::StutteredPageUpExtend(BOOL bDirect)
Call(SCI_STUTTEREDPAGEUPEXTEND, 0, 0, bDirect);
void CScintillaCtrl::StutteredPageDown(BOOL bDirect)
Call(SCI_STUTTEREDPAGEDOWN, 0, 0, bDirect);
void CScintillaCtrl::StutteredPageDownExtend(BOOL bDirect)
Call(SCI_STUTTEREDPAGEDOWNEXTEND, 0, 0, bDirect);
void CScintillaCtrl::WordLeftEnd(BOOL bDirect)
Call(SCI_WORDLEFTEND, 0, 0, bDirect);
void CScintillaCtrl::WordLeftEndExtend(BOOL bDirect)
Call(SCI_WORDLEFTENDEXTEND, 0, 0, bDirect);
void CScintillaCtrl::WordRightEnd(BOOL bDirect)
Call(SCI_WORDRIGHTEND, 0, 0, bDirect);
void CScintillaCtrl::WordRightEndExtend(BOOL bDirect)
Call(SCI_WORDRIGHTENDEXTEND, 0, 0, bDirect);
void CScintillaCtrl::SetWhitespaceChars(const char* characters, BOOL bDirect)
Call(SCI_SETWHITESPACECHARS, 0, reinterpret_cast<LPARAM>(characters), bDirect);
void CScintillaCtrl::SetCharsDefault(BOOL bDirect)
Call(SCI_SETCHARSDEFAULT, 0, 0, bDirect);
int CScintillaCtrl::AutoCGetCurrent(BOOL bDirect)
return Call(SCI_AUTOCGETCURRENT, 0, 0, bDirect);
void CScintillaCtrl::Allocate(int bytes, BOOL bDirect)
Call(SCI_ALLOCATE, static_cast<WPARAM>(bytes), 0, bDirect);
int CScintillaCtrl::TargetAsUTF8(char* s, BOOL bDirect)
return Call(SCI_TARGETASUTF8, 0, reinterpret_cast<LPARAM>(s), bDirect);
void CScintillaCtrl::SetLengthForEncode(int bytes, BOOL bDirect)
Call(SCI_SETLENGTHFORENCODE, static_cast<WPARAM>(bytes), 0, bDirect);
int CScintillaCtrl::EncodedFromUTF8(const char* utf8, char* encoded, BOOL bDirect)
return Call(SCI_ENCODEDFROMUTF8, reinterpret_cast<WPARAM>(utf8), reinterpret_cast<LPARAM>(encoded), bDirect);
int CScintillaCtrl::FindColumn(int line, int column, BOOL bDirect)
return Call(SCI_FINDCOLUMN, static_cast<WPARAM>(line), static_cast<LPARAM>(column), bDirect);
BOOL CScintillaCtrl::GetCaretSticky(BOOL bDirect)
return Call(SCI_GETCARETSTICKY, 0, 0, bDirect);
void CScintillaCtrl::SetCaretSticky(BOOL useCaretStickyBehaviour, BOOL bDirect)
Call(SCI_SETCARETSTICKY, static_cast<WPARAM>(useCaretStickyBehaviour), 0, bDirect);
void CScintillaCtrl::ToggleCaretSticky(BOOL bDirect)
Call(SCI_TOGGLECARETSTICKY, 0, 0, bDirect);
void CScintillaCtrl::SetPasteConvertEndings(BOOL convert, BOOL bDirect)
Call(SCI_SETPASTECONVERTENDINGS, static_cast<WPARAM>(convert), 0, bDirect);
BOOL CScintillaCtrl::GetPasteConvertEndings(BOOL bDirect)
return Call(SCI_GETPASTECONVERTENDINGS, 0, 0, bDirect);
void CScintillaCtrl::SelectionDuplicate(BOOL bDirect)
Call(SCI_SELECTIONDUPLICATE, 0, 0, bDirect);
void CScintillaCtrl::SetCaretLineBackAlpha(int alpha, BOOL bDirect)
Call(SCI_SETCARETLINEBACKALPHA, static_cast<WPARAM>(alpha), 0, bDirect);
int CScintillaCtrl::GetCaretLineBackAlpha(BOOL bDirect)
return Call(SCI_GETCARETLINEBACKALPHA, 0, 0, bDirect);
void CScintillaCtrl::SetCaretStyle(int caretStyle, BOOL bDirect)
Call(SCI_SETCARETSTYLE, static_cast<WPARAM>(caretStyle), 0, bDirect);
int CScintillaCtrl::GetCaretStyle(BOOL bDirect)
return Call(SCI_GETCARETSTYLE, 0, 0, bDirect);
void CScintillaCtrl::SetIndicatorCurrent(int indicator, BOOL bDirect)
Call(SCI_SETINDICATORCURRENT, static_cast<WPARAM>(indicator), 0, bDirect);
int CScintillaCtrl::GetIndicatorCurrent(BOOL bDirect)
return Call(SCI_GETINDICATORCURRENT, 0, 0, bDirect);
void CScintillaCtrl::SetIndicatorValue(int value, BOOL bDirect)
Call(SCI_SETINDICATORVALUE, static_cast<WPARAM>(value), 0, bDirect);
int CScintillaCtrl::GetIndicatorValue(BOOL bDirect)
return Call(SCI_GETINDICATORVALUE, 0, 0, bDirect);
void CScintillaCtrl::IndicatorFillRange(int position, int fillLength, BOOL bDirect)
Call(SCI_INDICATORFILLRANGE, static_cast<WPARAM>(position), static_cast<LPARAM>(fillLength), bDirect);
void CScintillaCtrl::IndicatorClearRange(int position, int clearLength, BOOL bDirect)
Call(SCI_INDICATORCLEARRANGE, static_cast<WPARAM>(position), static_cast<LPARAM>(clearLength), bDirect);
int CScintillaCtrl::IndicatorAllOnFor(int position, BOOL bDirect)
return Call(SCI_INDICATORALLONFOR, static_cast<WPARAM>(position), 0, bDirect);
int CScintillaCtrl::IndicatorValueAt(int indicator, int position, BOOL bDirect)
return Call(SCI_INDICATORVALUEAT, static_cast<WPARAM>(indicator), static_cast<LPARAM>(position), bDirect);
int CScintillaCtrl::IndicatorStart(int indicator, int position, BOOL bDirect)
return Call(SCI_INDICATORSTART, static_cast<WPARAM>(indicator), static_cast<LPARAM>(position), bDirect);
int CScintillaCtrl::IndicatorEnd(int indicator, int position, BOOL bDirect)
return Call(SCI_INDICATOREND, static_cast<WPARAM>(indicator), static_cast<LPARAM>(position), bDirect);
void CScintillaCtrl::SetPositionCache(int size, BOOL bDirect)
Call(SCI_SETPOSITIONCACHE, static_cast<WPARAM>(size), 0, bDirect);
int CScintillaCtrl::GetPositionCache(BOOL bDirect)
return Call(SCI_GETPOSITIONCACHE, 0, 0, bDirect);
void CScintillaCtrl::CopyAllowLine(BOOL bDirect)
Call(SCI_COPYALLOWLINE, 0, 0, bDirect);
//LRESULT CScintillaCtrl::GetCharacterPointer(BOOL bDirect)
// return Call(SCI_GETCHARACTERPOINTER, 0, 0, bDirect);
//void CScintillaCtrl::SetKeysUnicode(BOOL keysUnicode, BOOL bDirect)
// Call(SCI_SETKEYSUNICODE, static_cast<WPARAM>(keysUnicode), 0, bDirect);
//BOOL CScintillaCtrl::GetKeysUnicode(BOOL bDirect)
// return Call(SCI_GETKEYSUNICODE, 0, 0, bDirect);
void CScintillaCtrl::StartRecord(BOOL bDirect)
Call(SCI_STARTRECORD, 0, 0, bDirect);
void CScintillaCtrl::StopRecord(BOOL bDirect)
Call(SCI_STOPRECORD, 0, 0, bDirect);
void CScintillaCtrl::SetLexer(int lexer, BOOL bDirect)
Call(SCI_SETLEXER, static_cast<WPARAM>(lexer), 0, bDirect);
int CScintillaCtrl::GetLexer(BOOL bDirect)
return Call(SCI_GETLEXER, 0, 0, bDirect);
void CScintillaCtrl::Colourise(long start, long end, BOOL bDirect)
Call(SCI_COLOURISE, static_cast<WPARAM>(start), static_cast<LPARAM>(end), bDirect);
void CScintillaCtrl::SetProperty(const char* key, const char* value, BOOL bDirect)
Call(SCI_SETPROPERTY, reinterpret_cast<WPARAM>(key), reinterpret_cast<LPARAM>(value), bDirect);
void CScintillaCtrl::SetKeyWords(int keywordSet, const char* keyWords, BOOL bDirect)
Call(SCI_SETKEYWORDS, static_cast<WPARAM>(keywordSet), reinterpret_cast<LPARAM>(keyWords), bDirect);
void CScintillaCtrl::SetLexerLanguage(const char* language, BOOL bDirect)
Call(SCI_SETLEXERLANGUAGE, 0, reinterpret_cast<LPARAM>(language), bDirect);
void CScintillaCtrl::LoadLexerLibrary(const char* path, BOOL bDirect)
Call(SCI_LOADLEXERLIBRARY, 0, reinterpret_cast<LPARAM>(path), bDirect);
int CScintillaCtrl::GetProperty(const char* key, char* buf, BOOL bDirect)
return Call(SCI_GETPROPERTY, reinterpret_cast<WPARAM>(key), reinterpret_cast<LPARAM>(buf), bDirect);
int CScintillaCtrl::GetPropertyExpanded(const char* key, char* buf, BOOL bDirect)
return Call(SCI_GETPROPERTYEXPANDED, reinterpret_cast<WPARAM>(key), reinterpret_cast<LPARAM>(buf), bDirect);
int CScintillaCtrl::GetPropertyInt(const char* key, BOOL bDirect)
return Call(SCI_GETPROPERTYINT, reinterpret_cast<WPARAM>(key), 0, bDirect);
int CScintillaCtrl::GetStyleBitsNeeded(BOOL bDirect)
return Call(SCI_GETSTYLEBITSNEEDED, 0, 0, bDirect);
fishman
Re: Редактирование интерфейса KmotionCNC
Сообщение fishman »
В общем домучал я Тома )))
Вот что он предложил :
1.JPG (17113 просмотров) <a class='original' href='./download/file.php?id=78259&mode=view' target=_blank>Загрузить оригинал (70.26 КБ)</a>
2.JPG (17113 просмотров) <a class='original' href='./download/file.php?id=78260&mode=view' target=_blank>Загрузить оригинал (90.48 КБ)</a>
единственный файл в котором я нашел такие строчки лежит в
C:\KMotion432\PC VC Examples\KMotionCNC
и называется RichEditCtrlEx.cpp
эта строка встречается там три раза.. в первый раз там что то про G код , предположительно то что нужно , однако после сохранения изменений у меня не получился нужный результат.
менял значение 10 на 40 и во всех строках , реакции ноль... вообще не догоняю как это работает
опыт общения с visual studio 3 дня )))
просьба к более опытным пользователям проверить этот вариант у себя и отписаться о результатах.
Ну или объяснить что делаю не так...
NikolayUa24
Настоящее имя: Николай
Сообщение NikolayUa24 »
А как лечится 3 оси во весь экран, а 4 оси невозможно весь экран .
fishman
Сообщение fishman »
NikolayUa24 писал(а):А как лечится 3 оси во весь экран, а 4 оси невозможно весь экран .
и три невозможно. это вкладка назывется resizeble 3 axes и на ходится в самом низу выпадающего списка
Безымянный.png (16874 просмотра) <a class='original' href='./download/file.php?id=83120&mode=view' target=_blank>Загрузить оригинал (125.27 КБ)</a>
если вы хотите чтобы там отображалась четвертая ось , то в Resourse Hacker открываете екзешник KmotionCNC , который лежит по адресу C:\KMotion433\KMotion\Release
далее , в левой части папка диалог , затем строка 443:1043 , отмечено на картинке)
1.JPG (16874 просмотра) <a class='original' href='./download/file.php?id=83122&mode=view' target=_blank>Загрузить оригинал (362.11 КБ)</a>
теперь вам нужно сдвинуть окно G кода , чтобы увидеть скрытые кнопки и названия остальных осей...
и сделать видимыми нужные вам кнопки и обозначения осей, для этого правой кнопкой щелкаете на нужной кнопке , выбираете edit control и в появившемся меню выбираете строку где написано wisible, после этого она станет желтого цвета , то есть активна
2.JPG (16874 просмотра) <a class='original' href='./download/file.php?id=83127&mode=view' target=_blank>Загрузить оригинал (303.14 КБ)</a>
затем расположите кнопки которые вы сделали видимыми в нужном месте , и не забудьте вернуть окно g кода на место ))
потом скомпилировать скрbпт "F5" , сохранить и выйти...
да , кстати , там же простым перетаскиванием можно изменить размеры самого окна
Bes
Сообщение Bes »
Такой вот интерфейс сделал. Сам раньше работал на NC210. Привык что бы значения координат были КРУПНО написаны. Размеры полей увеличил, а сами значения не могу найти где(( Если кто знает подскажите пожалуйста.
Так же и значения оборотов шпинделя и подачи тоже не найду где увеличить :wik:
Интерфейс.JPG (15802 просмотра) <a class='original' href='./download/file.php?id=115414&mode=view' target=_blank>Загрузить оригинал (116.97 КБ)</a>
Цель оправдывает средства.
Anton_S
Настоящее имя: Антон
Сообщение Anton_S »
Bes писал(а):Такой вот интерфейс сделал. Сам раньше работал на NC210. Привык что бы значения координат были КРУПНО написаны. Размеры полей увеличил, а сами значения не могу найти где(( Если кто знает подскажите пожалуйста.
Подскажите как так сделать ?
Bes
Сообщение Bes »
Программа Resourse Hacker, очень простая но довольно не удобная. Так же можно открыть exe файл в любой Visual Studio (сложнее, удобнее, но долго устанавливается :hehehe: ) и менять размер и положение кнопок, но не размер шрифта опять таки. Вроде как разработчики Kmotion в последней версии добавили "KmotionCNC screen editor" где есть такая возможность, но на станке стоит ХР и туда не поставилось, попробую на выходных поставить дома на 10ке.
Duhas
Сообщение Duhas »
там если штантная фича для настройки интерфейса начиная с 5 чтоли верии
Раньше можно было поменять всё, что нужно и собрать из исходников.
Но это, конечно, более рискованно.
Bes
Сообщение Bes »
SVP писал(а):поменять всё, что нужно и собрать из исходников.
Не подскажешь как найти эту штуку? Или ты как раз про тот же "KmotionCNC srcreen editor"???
Какую штуку ?
Исходники раньше лежали у автора, насколько я помню.
Собирал я все это какой-то visual studio довольно древней, толи 6й, толи чуть позже того.
Давно всё это было порядком.
Вернуться в «KFlop»
