Страница 2 из 2
Re: PyVCP Цифровая индикация
Добавлено: 08 сен 2014, 19:02
Валерий
А где можно скачать Tcl/Tk,он платный или бесплатный ?
Добавлено: 08 сен 2014, 19:22
Валерий
Валерий писал(а):А где можно скачать Tcl/Tk,он платный или бесплатный ?
Скачал,а кто поможет установить?
Tcl и Tk это надо вместе ставить?
Добавлено: 08 сен 2014, 20:10
Валерий писал(а):Скачал,а кто поможет установить?
не помню уже - убунта может уже идет с тиклем...
если нет - можно попробовать просто в терминале
sudo apt-get install tcl
или следуя инструкции по установке в прикрепленном архиве:
How To Compile And Install Tcl:
(a) If you have already compiled Tcl once in this directory and are now
    preparing to compile again in the same directory but for a different
    platform, or if you have applied patches, type "make distclean" to discard
    all the configuration information computed previously.
(b) If you need to reconfigure because you changed any of the .in or .m4
    files, you will need to run autoconf to create a new ./configure script.
    Most users will NOT need to do this since a configure script is already
    provided.
    (in the tcl/unix directory)
    autoconf
(c) Type "./configure". This runs a configuration script created by GNU
    autoconf, which configures Tcl for your system and creates a Makefile. The
    configure script allows you to customize the Tcl configuration for your
    site; for details on how you can do this, type "./configure --help" or
    refer to the autoconf documentation (not included here). Tcl's "configure"
    supports the following special switches in addition to the standard ones:
	--enable-threads	If this switch is set, Tcl will compile itself
				with multithreading support.
	--disable-load		If this switch is specified then Tcl will
				configure itself not to allow dynamic loading,
				even if your system appears to support it.
				Normally you can leave this switch out and Tcl
				will build itself for dynamic loading if your
				system supports it.
	--disable-dll-unloading	Disables support for the [unload] command even
				on platforms that can support it. Meaningless
				when Tcl is compiled with --disable-load.
	--enable-shared		If this switch is specified, Tcl will compile
				itself as a shared library if it can figure
				out how to do that on this platform. This is
				the default on platforms where we know how to
				build shared libraries.
	--disable-shared	If this switch is specified, Tcl will compile
				itself as a static library.
	--enable-symbols	Build with debugging symbols. By default
				standard debugging symbols are used. You can
				specify the value "mem" to include
				TCL_MEM_DEBUG memory debugging, "compile" to
				include TCL_COMPILE_DEBUG debugging, or "all"
				to enable all internal debugging.
	--disable-symbols	Build without debugging symbols
	--enable-64bit		Enable 64bit support (where applicable)
	--disable-64bit		Disable 64bit support (where applicable)
	--enable-64bit-vis	Enable 64bit Sparc VIS support
	--disable-64bit-vis	Disable 64bit Sparc VIS support
	--enable-langinfo	Allows use of modern nl_langinfo check for
				better localization support. This is on by
				default on platforms where nl_langinfo is
				found.
	--disable-langinfo	Specifically disables use of nl_langinfo.
	--enable-man-symlinks	Use symlinks for linking the manpages that
				should be reachable under several names.
	--enable-man-suffix[=STRING]
				Append STRING to the names of installed manual
				pages (prior to applying compression, if that
				is also enabled). If STRING is omitted,
				defaults to 'tcl'.
	--enable-man-compression=PROG
				Compress the manpages using PROG.
	--enable-dtrace		Enable tcl DTrace provider (if DTrace is
				available on the platform), c.f. tclDTrace.d
				for descriptions of the probes made available,
				see http://wiki.tcl.tk/DTrace for more details
	--with-encoding=ENCODING Specifies the encoding for compile-time
				configuration values. Defaults to iso8859-1,
				which is also sufficient for ASCII.
	--with-tzdata=FLAG	Specifies whether to install timezone data. By
				default, the configure script tries to detect
				whether a usable timezone database is present
				on the system already.
    Mac OS X only (i.e. completely unsupported on other platforms):
	--enable-framework	Package Tcl as a framework.
	--disable-corefoundation Disable use of CoreFoundation API and revert
				to standard select based notifier, required
				when using naked fork (i.e. not followed by
				execve).
    Note: by default gcc will be used if it can be located on the PATH. If you
    want to use cc instead of gcc, set the CC environment variable to "cc"
    before running configure. It is not safe to edit the Makefile to use gcc
    after configure is run. Also note that you should use the same compiler
    when building extensions.
    Note: be sure to use only absolute path names (those starting with "/") in
    the --prefix and --exec-prefix options.
(d) Type "make". This will create a library archive called "libtcl<version>.a"
    or "libtcl<version>.so" and an interpreter application called "tclsh" that
    allows you to type Tcl commands interactively or execute script files. It
    will also create a stub library archive "libtclstub<version>.a" that
    developers may link against other C code to produce loadable extensions
    for Tcl.
(e) If the make fails then you'll have to personalize the Makefile for your
    site or possibly modify the distribution in other ways. First check the
    porting Web page above to see if there are hints for compiling on your
    system. If you need to modify Makefile, there are comments at the
    beginning of it that describe the things you might want to change and how
    to change them.
(f) Type "make install" to install Tcl binaries and script files in standard
    places. You'll need write permission on the installation directories to do
    this. The installation directories are determined by the "configure"
    script and may be specified with the standard --prefix and --exec-prefix
    options to "configure". See the Makefile for information on what
    directories were chosen; you can override these choices by modifying the
    "prefix" and "exec_prefix" variables in the Makefile. The installed
    binaries have embedded within them path values relative to the install
    directory. If you change your mind about where Tcl should be installed,
    start this procedure over again from step (a) so that the path embedded in
    the binaries agrees with the install location.
(g) At this point you can play with Tcl by running the installed "tclsh"
    executable, or via the "make shell" target, and typing Tcl commands at the
    interactive prompt.
If you have trouble compiling Tcl, see the URL noted above about working
platforms. It contains information that people have provided about changes
they had to make to compile Tcl in various environments. We're also interested
in hearing how to change the configuration setup so that Tcl compiles on
additional platforms "out of the box".
Добавлено: 08 сен 2014, 22:36
Не надо ничего скачивать, уже всё что надо установлено.
Ищите книжки по нему, есть и русском...
Добавлено: 09 сен 2014, 00:55
Валерий, жесть!!! это метал такой... тонкий...
1) Тут обрисовалось пору вопросов... как у Вас Линукс?
2) на чем есть навыки программирования?
Вас спрашивают а Вы упорно игнорируете вопрос......
я Вам дал ссылку на ИСТОЧНИК этого языка, а Вы спрашиваете КАК его установить.... это не жесть.... это фанера!
я не злой... просто Вам не повезло.. извиняюсь.......
пошел других виновных искать........
Добавлено: 09 сен 2014, 11:18
А какая конечная задача? Чем управляешь?
Может, это можно сделать стандартными методами...
Добавлено: 09 сен 2014, 17:49
Валерий
Просто цифровая индикация,на расточной станок.
Что бы можно было вводить и нажимать кнопки без мышки.
Добавлено: 09 сен 2014, 18:08
Тогда похоже придётся полностью свой интерфейс ваять. Проще наверно будет сделать как gscreen/gmoccapy.
Добавлено: 09 сен 2014, 18:17
Валерий
Вот я уже просматриваю gscreen/gmoccapy
