Страница 2 из 4
Re: delta robot emc2
Добавлено: 08 июн 2012, 17:31
z-vr
Nick писал(а):Надо его сравнить с trikins... в смысле исходник, посмотреть чем они еще отличаются...
Имеется в виду файл другой какой-то кинематики и сравнить его с моим файлом?
Добавлено: 08 июн 2012, 17:38
* Description: trivkins.c
*   Trivial kinematics for 3 axis Cartesian machine
*   Derived from a work by Fred Proctor & Will Shackleford
* Author:
* License: GPL Version 2
* System: Linux
* Copyright (c) 2004 All rights reserved.
* Last change:
#include "kinematics.h"		/* these decls */
int kinematicsForward(const double *joints,
		      EmcPose * pos,
		      const KINEMATICS_FORWARD_FLAGS * fflags,
		      KINEMATICS_INVERSE_FLAGS * iflags)
    pos->tran.x = joints[0];
    pos->tran.y = joints[1];
    pos->tran.z = joints[2];
    pos->a = joints[3];
    pos->b = joints[4];
    pos->c = joints[5];
    pos->u = joints[6];
    pos->v = joints[7];
    pos->w = joints[8];
    return 0;
int kinematicsInverse(const EmcPose * pos,
		      double *joints,
		      const KINEMATICS_INVERSE_FLAGS * iflags,
		      KINEMATICS_FORWARD_FLAGS * fflags)
    joints[0] = pos->tran.x;
    joints[1] = pos->tran.y;
    joints[2] = pos->tran.z;
    joints[3] = pos->a;
    joints[4] = pos->b;
    joints[5] = pos->c;
    joints[6] = pos->u;
    joints[7] = pos->v;
    joints[8] = pos->w;
    return 0;
/* implemented for these kinematics as giving joints preference */
int kinematicsHome(EmcPose * world,
		   double *joint,
    *fflags = 0;
    *iflags = 0;
    return kinematicsForward(joint, world, fflags, iflags);
KINEMATICS_TYPE kinematicsType()
    return KINEMATICS_IDENTITY;
#include "rtapi.h"		/* RTAPI realtime OS API */
#include "rtapi_app.h"		/* RTAPI realtime module decls */
#include "hal.h"
EXPORT_SYMBOL(kinematicsType);
EXPORT_SYMBOL(kinematicsForward);
EXPORT_SYMBOL(kinematicsInverse);
MODULE_LICENSE("GPL");
int comp_id;
int rtapi_app_main(void) {
    comp_id = hal_init("trivkins");
    if(comp_id > 0) {
	hal_ready(comp_id);
	return 0;
    return comp_id;
void rtapi_app_exit(void) { hal_exit(comp_id); }
http://git.linuxcnc.org/gitweb?p=linuxc ... 2d458ac5d7
Добавлено: 08 июн 2012, 17:45
z-vr
s3301 писал(а):
Nick писал(а): В общем надо HAL_SUCCESS заменить на 0.
Несколько надёжней будет вот так:
#ifndef HAL_SUCCESS
#define HAL_SUCCESS 0
#endif
Если я просто ноль прописал это не могло повлиять или надо как тут?
Добавлено: 08 июн 2012, 18:09
z-vr
Этот tripodkins.c больше похож на мой, но наверное мне это не поможет.
Что мой, что тот, что этот темный лес для меня.
Добавлено: 08 июн 2012, 18:16
если это работало у других- значит заработает и у нас!
все дело только во времени.
для меня си - это тоже иероглифы.Но есть коллективный разум-он поможет.
Добавлено: 08 июн 2012, 20:20
nkp писал(а):insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko': -1 Invalid module format
может быть ошибка в самом модуле
Не, похоже модуль неправильно скомпилился.
Что говорят
file /usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko
и
modinfo /usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko
Добавлено: 08 июн 2012, 20:22
PKM
я бы не надеялся на comp
в таких случаях скачиваю исходники и редактирую одну из готовых кинематик, потом полностью компилирую linuxcnc для run-in-place
правда, компилировать приходится очень много раз, пока не заработает... :hehehe:
Добавлено: 08 июн 2012, 20:26
z-vr писал(а): Если я просто ноль прописал это не могло повлиять или надо как тут?
В данном случае эта запись и замена на 0 развнозначны, но при заменах можно что-нибудь пропустить, а эта запись, особенно если расположить её в правильном месте сама "поменяет" везде.
Можно было ещё поменять добавив в опции компилятору "-DHAL_SUCCESS=0", например в Makefile в переменную CFLAGS.
Добавлено: 08 июн 2012, 22:29
попробовал я проделать все эти действия:
Файл:
deltakins.c.tar.gz
(2.09 КБ) 1188 скачиваний
файл положил /usr/src/linux-headers-2.6.32-122-rtai/deltakins.c
сделал comp --install deltakins.c
(все под рутом)
s3301 писал(а):Что говорят file /usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko и modinfo /usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko
не знаю что это значит,но:
root@nkp-desktop:/usr/src/linux-headers-2.6.32-122-rtai# file /usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko
/usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko: ELF 32-bit LSB relocatable, Intel 80386, version 1 (SYSV), not stripped
и:
root@nkp-desktop:/usr/src/linux-headers-2.6.32-122-rtai# modinfo /usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko
filename:       /usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko
license:        GPL
srcversion:     87EF434EF176B8BE61DAA0F
depends:        hal_lib
vermagic:       2.6.32-122-rtai SMP mod_unload 586TSC
после записи в хал:
loadrt deltakins
результат:
Выделение(001).png (3169 просмотров) <a class='original' href='./download/file.php?id=5798&mode=view' target=_blank>Загрузить оригинал (19.69 КБ)</a>
Добавлено: 08 июн 2012, 22:41
Я тоже в сях не силен...
Меня вот это смущает , что за "error:" ?!? (4-я строчка снизу)
    int res = 0;
    comp_id = hal_init("deltakins");
    if(comp_id < 0) return comp_id;
    haldata = hal_malloc(sizeof(struct haldata));
    if(!haldata) goto error;
    if((res = hal_pin_float_new("deltakins.e", HAL_IO, &(haldata->e), comp_id)) != HAL_SUCCESS) goto error;
    if((res = hal_pin_float_new("deltakins.f", HAL_IO, &(haldata->f), comp_id)) != HAL_SUCCESS) goto error;
    if((res = hal_pin_float_new("deltakins.re", HAL_IO, &(haldata->re), comp_id)) != HAL_SUCCESS) goto error;
    if((res = hal_pin_float_new("deltakins.rf", HAL_IO, &(haldata->rf), comp_id)) != HAL_SUCCESS) goto error;
    delta_e = delta_f = delta_re = delta_rf = 1.0;
    hal_ready(comp_id);
    return 0;
error:
    hal_exit(comp_id);
    return res;
s3301 писал(а):Не, похоже модуль неправильно скомпилился.Что говорят
вроде ошибок при компилировании не было...
А что они должны говорить?
Т.е. заработало???
А что ты сделал не так?
Добавлено: 08 июн 2012, 22:45
Nick писал(а):Т.е. заработало??? А что ты сделал не так?
В исходниках раскомментировал
e = 115.0;
f = 457.3;
re = 232.0;
rf = 112.0;
Добавлено: 09 июн 2012, 01:14
nkp писал(а):не знаю что это значит,но:
file - по содержимому определят тип файла, не расширение после имени, а текст это, картинка или ещё что.
modinfo - как можно догдаться показывает специфическую информацию о модуле.
Вобщем с этим всё в порядке.
nkp писал(а):В исходниках раскомментировал
я пока не силён в этом API, но мне показалось, что параметры должны передаваться как-то с помощью пинов, в имени которых есть буквы типа "deltakins.e"
Кстати, если пробуете раскоментировать, то лучше так:
double e = 115.0;
Nick писал(а):Меня вот это смущает , что за "error:" ?!? (4-я строчка снизу)
Это метка, на которую происходит переход при выполнении "goto error".
Добавлено: 09 июн 2012, 01:25
xentaur
s3301 писал(а):я пока не силён в этом API, но мне показалось, что параметры должны передаваться как-то с помощью пинов, в имени которых есть буквы типа "deltakins.e"
Это не для всех. Некоторые кинематики только во время компиляции параметры принимают.
Добавлено: 09 июн 2012, 13:16
z-vr
nkp писал(а):#29 nkp » Вчера, 23:29
Файл:
Повторил все, у меня при компиляции такие предупреждения:
root@cnc-desktop:/usr/src/linux-headers-2.6.32-122-rtai# comp --install deltakins.c
make -C /usr/src/linux-headers-2.6.32-122-rtai SUBDIRS=`pwd` CC=gcc V=0 -o /Module.symvers modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-122-rtai'
CC [M] /tmp/tmp790I3i/deltakins.o
/tmp/tmp790I3i/deltakins.c:7: warning: data definition has no type or storage class
/tmp/tmp790I3i/deltakins.c:7: warning: type defaults to ‘int’ in declaration of ‘e’
/tmp/tmp790I3i/deltakins.c:8: warning: data definition has no type or storage class
/tmp/tmp790I3i/deltakins.c:8: warning: type defaults to ‘int’ in declaration of ‘f’
/tmp/tmp790I3i/deltakins.c:9: warning: data definition has no type or storage class
/tmp/tmp790I3i/deltakins.c:9: warning: type defaults to ‘int’ in declaration of ‘re’
/tmp/tmp790I3i/deltakins.c:10: warning: data definition has no type or storage class
/tmp/tmp790I3i/deltakins.c:10: warning: type defaults to ‘int’ in declaration of ‘rf’
/tmp/tmp790I3i/deltakins.c: In function ‘delta_calcAngleYZ’:
/tmp/tmp790I3i/deltakins.c:119: warning: ISO C90 forbids mixed declarations and code
/tmp/tmp790I3i/deltakins.c:124: warning: ISO C90 forbids mixed declarations and code
/tmp/tmp790I3i/deltakins.c: In function ‘kinematicsInverse’:
/tmp/tmp790I3i/deltakins.c:147: warning: ISO C90 forbids mixed declarations and code
Building modules, stage 2.
MODPOST 1 modules
WARNING: "hal_init" [/tmp/tmp790I3i/deltakins.ko] undefined!
WARNING: "hal_exit" [/tmp/tmp790I3i/deltakins.ko] undefined!
WARNING: "hal_malloc" [/tmp/tmp790I3i/deltakins.ko] undefined!
WARNING: "hal_pin_float_new" [/tmp/tmp790I3i/deltakins.ko] undefined!
WARNING: "hal_ready" [/tmp/tmp790I3i/deltakins.ko] undefined!
CC /tmp/tmp790I3i/deltakins.mod.o
LD [M] /tmp/tmp790I3i/deltakins.ko
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
Сделал modinfo:
root@cnc-desktop:/usr/src/linux-headers-2.6.32-122-rtai# modinfo /usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko
license: GPL
depends:
У меня нет depends?
в примере depends: hal_lib
и EMC2 выдает:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/cnc/emc2/configs/мой-станок'
Machine configuration file is 'мой-станок.ini'
INIFILE=/home/cnc/emc2/configs/мой-станок/мой-станок.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting EMC2 IO program: io
Starting HAL User Interface program: halui
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=2014
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
'/usr/realtime-2.6.32-122-rtai/modules/emc2/deltakins.ko': -1 Unknown
symbol in module
мой-станок.hal:10: exit value: 1
мой-станок.hal:10: insmod failed, returned -1
See the output of 'dmesg' for more information.
2014
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 879.230015] I-pipe: Domain RTAI registered.
[ 879.230031] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 879.230035] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu
4.4.3-4ubuntu5) .
[ 879.230046] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL
IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 879.230050] PIPELINE layers:
[ 879.230055] f85b4e20 9ac15d93 RTAI 200
[ 879.230059] c085cb20 0 Linux 100
[ 879.273496] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 879.273739] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI
OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 879.273750] RTAI[sched]: hard timer type/freq = APIC/8311990(Hz);
default timing: periodic; linear timed lists.
[ 879.273755] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq =
2394121000 hz.
[ 879.273759] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 879.273908] RTAI[usi]: enabled.
[ 879.428590] RTAI[math]: loaded.
[ 879.598716] config string '0x378 out '
[ 879.605126] deltakins: Unknown parameter `e'
[ 880.385404] RTAI[math]: unloaded.
[ 880.506549] SCHED releases registered named ALIEN RTGLBH
[ 880.521379] RTAI[malloc]: unloaded.
[ 880.620033] RTAI[sched]: unloaded (forced hard/soft/hard transitions:
traps 0, syscalls 0).
[ 880.627128] I-pipe: Domain RTAI unregistered.
[ 880.627144] RTAI[hal]: unmounted.
Может я EMC2 установил c LiveCD, а надо было из  SRC?
Добавлено: 09 июн 2012, 13:23
у меня убунта 10.04 емс 2.5 установлена с CD
а может ругается на наниаши переменные
попробовать как советовали:
double e = 115.0;
Добавлено: 09 июн 2012, 13:29
z-vr
У меня 10.04 и 2.4.6
сеючас обновлю EMC
Добавлено: 09 июн 2012, 14:11
z-vr писал(а):type defaults to ‘int’ in declaration of ‘e’
Нужно в объявлении переменных написать вот так:
UAVpilot писал(а):double e = 115.0;
Ошибка говорит, что не задан тип переменной по этому по дефолту он ставится в int, т.е. в целое число. А он должен быть действительным числом, т.к. потом с этими параметрами производятся различные хитрые вычисления.
Добавлено: 09 июн 2012, 14:59
z-vr
Пока добился этого:
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-2.6.32-122-rtai SUBDIRS=`pwd` CC=gcc V=0 modules
CC [M] /tmp/tmpoiqJBq/deltakins.o
/tmp/tmpoiqJBq/deltakins.c: In function ‘delta_calcAngleYZ’:
/tmp/tmpoiqJBq/deltakins.c:119: warning: ISO C90 forbids mixed declarations and code
/tmp/tmpoiqJBq/deltakins.c:124: warning: ISO C90 forbids mixed declarations and code
/tmp/tmpoiqJBq/deltakins.c: In function ‘kinematicsInverse’:
/tmp/tmpoiqJBq/deltakins.c:147: warning: ISO C90 forbids mixed declarations and code
MODPOST 1 modules
CC /tmp/tmpoiqJBq/deltakins.mod.o
LD [M] /tmp/tmpoiqJBq/deltakins.ko
cp deltakins.ko /usr/realtime-2.6.32-122-rtai/modules/linuxcnc/
root@cnc-desktop:/usr/src/linux-headers-2.6.32-122-rtai# modinfo /usr/realtime-2.6.32-122-rtai/modules/linuxcnc/deltakins.ko
filename: /usr/realtime-2.6.32-122-rtai/modules/linuxcnc/deltakins.ko
license: GPL
srcversion: CD4663657E9DC151030172C
depends: hal_lib
Добавлено: 09 июн 2012, 15:21
И LinuxCNC все еще не запускается? Покажи ошибку...
Вообще, на сколько я понимаю:
z-vr писал(а):/tmp/tmpoiqJBq/deltakins.c:124: warning: ISO C90 forbids mixed declarations and code
Это старый стандарт, который говорит, что все объявления переменных должны быть только в начале блоков {...}, но имхо это пережиток...
Добавлено: 09 июн 2012, 15:32
По поводу "depends: hal_lib", теперь уже просто как ликбез:
Это говорит о том, что для работы модуля нужен модуль hal_lib.
z-vr, у вас по какой-то причине при сборке модуля компилятор/линкер не увидел hal_lib и не постоил соотв. связь, решив, что это будет сделано на этапе выполнения самим модулем. А т.к. модуль этого не делает, то получили "Unknown symbol in module", т.е. модуль использует некую функцию, но никто не знает где её взять.
Ну а чтоб при компиляции совсем не ругалось надо в в функциях delta_calcAngleYZ и kinematicsInverse сначала сделать все объявления переменных, а потом их использовать:
double y1, a, b, d, yj, zj;
y1 = ...
y0 -= ...
a = ...
b = ...
double x0 = pos->tran.x;
double y0 = pos->tran.y;
double z0 = pos->tran.z;
double theta1;
double theta2;
double theta3;
int status;
theta1 = theta2 = theta3 = 0;
status = delta_calcAngleYZ(x0, y0, z0, &theta1);
if (status == 0) joints[0] = theta1;
