имам проблем с подкарването на въпросния контролер .
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.5
Machine configuration directory is '/home/cnc/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/cnc/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./my_LinuxCNC_machine.hal
Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=7527
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
./my_LinuxCNC_machine.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth
./my_LinuxCNC_machine.hal:8: /usr/bin/rtapi_app exited without becoming ready
./my_LinuxCNC_machine.hal:8: insmod for hm2_eth failed, returned -1
7527
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT RT Debian 3.2.81-1
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003f690000 (usable)
[ 0.000000] BIOS-e820: 000000003f690000 - 000000003f69e000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003f69e000 - 000000003f6d0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003f6d0000 - 000000003f6de000 (reserved)
[ 0.000000] BIOS-e820: 000000003f6e0000 - 000000003f700000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: System manufacturer System Product Name/P5KPL-AM EPU, BIOS 0415 02/04/2010
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3f690 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-DFFFF write-protect
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 03F700000 mask FFFF00000 uncachable
[ 0.000000] 2 base 03F800000 mask FFF800000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00ff780] ff780
[ 0.000000] initial memory mapped : 0 - 01a00000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000379fe000
[ 0.000000] 0000000000 - 0000200000 page 4k
[ 0.000000] 0000200000 - 0037800000 page 2M
[ 0.000000] 0037800000 - 00379fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 379fe000 @ 19f9000-1a00000
[ 0.000000] RAMDISK: 365c2000 - 372d9000
[ 0.000000] ACPI: RSDP 0x00000000000FB7F0 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 0x000000003F690000 0003C (v01 A_M_I_ OEMRSDT 02001004 MSFT 00000097)
[ 0.000000] ACPI: FACP 0x000000003F690200 00084 (v02 A_M_I_ OEMFACP 02001004 MSFT 00000097)
[ 0.000000] ACPI: DSDT 0x000000003F6905C0 08A54 (v01 A1350 A1350000 00000000 INTL 20060113)
[ 0.000000] ACPI: FACS 0x000000003F69E000 00040
[ 0.000000] ACPI: APIC 0x000000003F690390 0006C (v01 A_M_I_ OEMAPIC 02001004 MSFT 00000097)
[ 0.000000] ACPI: MCFG 0x000000003F690400 0003C (v01 A_M_I_ OEMMCFG 02001004 MSFT 00000097)
[ 0.000000] ACPI: OEMB 0x000000003F69E040 00080 (v01 A_M_I_ AMI_OEM 02001004 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x000000003F699020 00038 (v01 A_M_I_ OEMHPET 02001004 MSFT 00000097)
[ 0.000000] ACPI: GSCI 0x000000003F69E0C0 02024 (v01 A_M_I_ GMCHSCI 02001004 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 124MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000379fe
[ 0.000000] HighMem 0x000379fe -> 0x0003f690
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003f690
[ 0.000000] On node 0 totalpages: 259615
[ 0.000000] free_area_init_node: node 0, pgdat c1415400, node_mem_map f5dd2200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1748 pages used for memmap
[ 0.000000] Normal zone: 221994 pages, LIFO batch:31
[ 0.000000] HighMem zone: 250 pages used for memmap
[ 0.000000] HighMem zone: 31640 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 3f700000 (gap: 3f700000:bf700000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 93 pages/cpu @f787d000 s360128 r0 d20800 u380928
[ 0.000000] pcpu-alloc: s360128 r0 d20800 u380928 alloc=93*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257585
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-rt-686-pae root=UUID=d6ffc506-5658-435b-bf6e-5f5a7754e150 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x3, cntxt size 0x240
[ 0.000000] Initializing HighMem for node 0 (000379fe:0003f690)
[ 0.000000] Memory: 1008520k/1038912k available (2864k kernel code, 29940k reserved, 1346k data, 728k init, 127560k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
[ 0.000000] pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
[ 0.000000] vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
[ 0.000000] .init : 0xc141d000 - 0xc14d3000 ( 728 kB)
[ 0.000000] .data : 0xc12cc220 - 0xc141ca80 (1346 kB)
[ 0.000000] .text : 0xc1000000 - 0xc12cc220 (2864 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f5808000 soft=f580a000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 3066.394 MHz processor.
[ 0.004001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6132.78 BogoMIPS (lpj=12265576)
[ 0.004004] pid_max: default: 32768 minimum: 301
[ 0.004045] Security Framework initialized
[ 0.004049] AppArmor: AppArmor disabled by boot time parameter
[ 0.004064] Mount-cache hash table entries: 512
[ 0.004170] Initializing cgroup subsys cpuacct
[ 0.004175] Initializing cgroup subsys memory
[ 0.004181] Initializing cgroup subsys devices
[ 0.004183] Initializing cgroup subsys freezer
[ 0.004184] Initializing cgroup subsys net_cls
[ 0.004186] Initializing cgroup subsys blkio
[ 0.004191] Initializing cgroup subsys perf_event
[ 0.004217] CPU: Physical Processor ID: 0
[ 0.004218] CPU: Processor Core ID: 0
[ 0.004220] mce: CPU supports 6 MCE banks
[ 0.004225] CPU0: Thermal monitoring enabled (TM2)
[ 0.004228] using mwait in idle threads.
[ 0.004493] ACPI: Core revision 20110623
[ 0.012040] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.012390] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.052856] CPU0: Intel(R) Core(TM)2 Duo CPU E7600 @ 3.06GHz stepping 0a
[ 0.056003] APIC calibration not consistent with PM-Timer: 115ms instead of 100ms
[ 0.056003] APIC delta adjusted to PM-Timer: 1666663 (1933308)
[ 0.056003] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[ 0.056003] ... version: 2
[ 0.056003] ... bit width: 40
[ 0.056003] ... generic registers: 2
[ 0.056003] ... value mask: 000000ffffffffff
[ 0.056003] ... max period: 000000007fffffff
[ 0.056003] ... fixed-purpose events: 3
[ 0.056003] ... event mask: 0000000700000003
[ 0.072254] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.092040] CPU 1 irqstacks, hard=f5910000 soft=f5912000
[ 0.092043] Booting Node 0, Processors #1
[ 0.092047] smpboot cpu 1: start_ip = 9b000
[ 0.008000] Initializing CPU#1
[ 0.184047] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.188024] Brought up 2 CPUs
[ 0.188029] Total of 2 processors activated (12266.10 BogoMIPS).
[ 0.189796] devtmpfs: initialized
[ 0.189796] PM: Registering ACPI NVS region at 3f69e000 (204800 bytes)
[ 0.189796] print_constraints: dummy:
[ 0.189796] NET: Registered protocol family 16
[ 0.189796] ACPI: bus type pci registered
[ 0.189796] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000)
[ 0.189796] PCI: not using MMCONFIG
[ 0.189796] PCI : PCI BIOS aera is rw and x. Use pci=nobios if you want it NX.
[ 0.189796] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=3
[ 0.189796] PCI: Using configuration type 1 for base access
[ 0.189796] bio: create slab <bio-0> at 0
[ 0.189796] ACPI: Added _OSI(Module Device)
[ 0.189796] ACPI: Added _OSI(Processor Device)
[ 0.189796] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.189796] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.192927] ACPI: EC: Look up EC in DSDT
[ 0.193469] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.212920] ACPI: SSDT 0x000000003F6A00F0 00214 (v01 AMI CPU1PM 00000001 INTL 20060113)
[ 0.213207] ACPI: Dynamic OEM Table Load:
[ 0.213210] ACPI: SSDT 0x0000000000000000 00214 (v01 AMI CPU1PM 00000001 INTL 20060113)
[ 0.213484] ACPI: SSDT 0x000000003F6A0310 00143 (v01 AMI CPU2PM 00000001 INTL 20060113)
[ 0.213760] ACPI: Dynamic OEM Table Load:
[ 0.213763] ACPI: SSDT 0x0000000000000000 00143 (v01 AMI CPU2PM 00000001 INTL 20060113)
[ 0.214139] ACPI: Interpreter enabled
[ 0.214150] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.214184] ACPI: Using IOAPIC for interrupt routing
[ 0.214210] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000)
[ 0.215711] PCI: MMCONFIG at [mem 0xf0000000-0xf3ffffff] reserved in ACPI motherboard resources
[ 0.215713] PCI: Using MMCONFIG for extended config space
[ 0.223397] ACPI: No dock devices found.
[ 0.223399] HEST: Table not found.
[ 0.223403] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.223486] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.223670] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.223672] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.223674] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.223677] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff]
[ 0.223679] pci_root PNP0A08:00: host bridge window [mem 0x3f700000-0xffffffff]
[ 0.223692] pci 0000:00:00.0: [8086:29c0] type 0 class 0x000600
[ 0.223730] pci 0000:00:02.0: [8086:29c2] type 0 class 0x000300
[ 0.223738] pci 0000:00:02.0: reg 10: [mem 0xfea80000-0xfeafffff]
[ 0.223743] pci 0000:00:02.0: reg 14: [io 0xdc00-0xdc07]
[ 0.223748] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff pref]
[ 0.223753] pci 0000:00:02.0: reg 1c: [mem 0xfe900000-0xfe9fffff]
[ 0.223810] pci 0000:00:1b.0: [8086:27d8] type 0 class 0x000403
[ 0.223823] pci 0000:00:1b.0: reg 10: [mem 0xfea78000-0xfea7bfff 64bit]
[ 0.223882] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.223902] pci 0000:00:1c.0: [8086:27d0] type 1 class 0x000604
[ 0.223962] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.223984] pci 0000:00:1c.1: [8086:27d2] type 1 class 0x000604
[ 0.224062] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.224084] pci 0000:00:1d.0: [8086:27c8] type 0 class 0x000c03
[ 0.224119] pci 0000:00:1d.0: reg 20: [io 0xd400-0xd41f]
[ 0.224147] pci 0000:00:1d.1: [8086:27c9] type 0 class 0x000c03
[ 0.224181] pci 0000:00:1d.1: reg 20: [io 0xd480-0xd49f]
[ 0.224208] pci 0000:00:1d.2: [8086:27ca] type 0 class 0x000c03
[ 0.224243] pci 0000:00:1d.2: reg 20: [io 0xd800-0xd81f]
[ 0.224272] pci 0000:00:1d.3: [8086:27cb] type 0 class 0x000c03
[ 0.224306] pci 0000:00:1d.3: reg 20: [io 0xd880-0xd89f]
[ 0.224341] pci 0000:00:1d.7: [8086:27cc] type 0 class 0x000c03
[ 0.224357] pci 0000:00:1d.7: reg 10: [mem 0xfea77c00-0xfea77fff]
[ 0.224428] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.224447] pci 0000:00:1e.0: [8086:244e] type 1 class 0x000604
[ 0.224501] pci 0000:00:1f.0: [8086:27b8] type 0 class 0x000601
[ 0.224573] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003)
[ 0.224613] pci 0000:00:1f.1: [8086:27df] type 0 class 0x000101
[ 0.224624] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007]
[ 0.224632] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003]
[ 0.224640] pci 0000:00:1f.1: reg 18: [io 0x08f0-0x08f7]
[ 0.224648] pci 0000:00:1f.1: reg 1c: [io 0x08f8-0x08fb]
[ 0.224656] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf]
[ 0.224687] pci 0000:00:1f.2: [8086:27c0] type 0 class 0x000101
[ 0.224698] pci 0000:00:1f.2: reg 10: [io 0xd080-0xd087]
[ 0.224705] pci 0000:00:1f.2: reg 14: [io 0xd000-0xd003]
[ 0.224712] pci 0000:00:1f.2: reg 18: [io 0xcc00-0xcc07]
[ 0.224719] pci 0000:00:1f.2: reg 1c: [io 0xc880-0xc883]
[ 0.224726] pci 0000:00:1f.2: reg 20: [io 0xc800-0xc80f]
[ 0.224756] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.224770] pci 0000:00:1f.3: [8086:27da] type 0 class 0x000c05
[ 0.224815] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f]
[ 0.224880] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.224936] pci 0000:01:00.0: [1969:1026] type 0 class 0x000200
[ 0.224958] pci 0000:01:00.0: reg 10: [mem 0xfebc0000-0xfebfffff 64bit]
[ 0.224969] pci 0000:01:00.0: reg 18: [io 0xec00-0xec7f]
[ 0.225058] pci 0000:01:00.0: PME# supported from D3hot D3cold
[ 0.225078] pci 0000:01:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.225087] pci 0000:00:1c.1: PCI bridge to [bus 01-01]
[ 0.225090] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.225094] pci 0000:00:1c.1: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.225151] pci 0000:00:1e.0: PCI bridge to [bus 03-03] (subtractive decode)
[ 0.225159] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.225161] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.225164] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.225166] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode)
[ 0.225168] pci 0000:00:1e.0: bridge window [mem 0x3f700000-0xffffffff] (subtractive decode)
[ 0.225180] pci_bus 0000:00: on NUMA node 0
[ 0.225184] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.225391] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.225515] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
[ 0.225577] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT]
[ 0.225648] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.225651] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.225653] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.234417] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.234481] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.234542] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.234604] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.234666] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.234728] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.234790] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.234853] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.234920] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.234920] vgaarb: loaded
[ 0.234920] vgaarb: bridge control possible 0000:00:02.0
[ 0.234920] PCI: Using ACPI for IRQ routing
[ 0.234920] PCI: pci_cache_line_size set to 64 bytes
[ 0.234920] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.234920] reserve RAM buffer: 000000003f690000 - 000000003fffffff
[ 0.234920] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.234920] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.234920] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.244047] Switching to clocksource hpet
[ 0.246749] pnp: PnP ACPI init
[ 0.246762] ACPI: bus type pnp registered
[ 0.246851] pnp 00:00: [bus 00-ff]
[ 0.246853] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.246856] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.246858] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.246862] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.246865] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.246867] pnp 00:00: [mem 0x3f700000-0xffffffff window]
[ 0.246914] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.246925] pnp 00:01: [mem 0xfed14000-0xfed19fff]
[ 0.246974] system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.246978] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.247016] pnp 00:02: [dma 4]
[ 0.247018] pnp 00:02: [io 0x0000-0x000f]
[ 0.247020] pnp 00:02: [io 0x0081-0x0083]
[ 0.247022] pnp 00:02: [io 0x0087]
[ 0.247023] pnp 00:02: [io 0x0089-0x008b]
[ 0.247025] pnp 00:02: [io 0x008f]
[ 0.247027] pnp 00:02: [io 0x00c0-0x00df]
[ 0.247055] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.247070] pnp 00:03: [io 0x0070-0x0071]
[ 0.247077] pnp 00:03: [irq 8]
[ 0.247107] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.247118] pnp 00:04: [io 0x0061]
[ 0.247149] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.247160] pnp 00:05: [io 0x00f0-0x00ff]
[ 0.247164] pnp 00:05: [irq 13]
[ 0.247194] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.247805] pnp 00:06: [irq 7]
[ 0.247807] pnp 00:06: [dma 3]
[ 0.247809] pnp 00:06: [io 0x0378-0x037f]
[ 0.247811] pnp 00:06: [io 0x0778-0x077f]
[ 0.247996] pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.248045] pnp 00:07: [io 0x0000-0xffffffffffffffff disabled]
[ 0.248048] pnp 00:07: [io 0x0000-0xffffffffffffffff disabled]
[ 0.248050] pnp 00:07: [io 0x0290-0x0297]
[ 0.248101] system 00:07: [io 0x0290-0x0297] has been reserved
[ 0.248104] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.248243] pnp 00:08: [io 0x0010-0x001f]
[ 0.248245] pnp 00:08: [io 0x0022-0x003f]
[ 0.248247] pnp 00:08: [io 0x0044-0x005f]
[ 0.248248] pnp 00:08: [io 0x0062-0x0063]
[ 0.248250] pnp 00:08: [io 0x0065-0x006f]
[ 0.248252] pnp 00:08: [io 0x0072-0x007f]
[ 0.248253] pnp 00:08: [io 0x0080]
[ 0.248255] pnp 00:08: [io 0x0084-0x0086]
[ 0.248257] pnp 00:08: [io 0x0088]
[ 0.248259] pnp 00:08: [io 0x008c-0x008e]
[ 0.248260] pnp 00:08: [io 0x0090-0x009f]
[ 0.248262] pnp 00:08: [io 0x00a2-0x00bf]
[ 0.248264] pnp 00:08: [io 0x00e0-0x00ef]
[ 0.248266] pnp 00:08: [io 0x04d0-0x04d1]
[ 0.248267] pnp 00:08: [io 0x0800-0x087f]
[ 0.248269] pnp 00:08: [io 0x0400-0x03ff disabled]
[ 0.248273] pnp 00:08: [io 0x0480-0x04bf]
[ 0.248275] pnp 00:08: [mem 0xfed1c000-0xfed1ffff]
[ 0.248277] pnp 00:08: [mem 0xfed20000-0xfed8ffff]
[ 0.248339] system 00:08: [io 0x04d0-0x04d1] has been reserved
[ 0.248342] system 00:08: [io 0x0800-0x087f] could not be reserved
[ 0.248344] system 00:08: [io 0x0480-0x04bf] has been reserved
[ 0.248347] system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.248350] system 00:08: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.248353] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.248441] pnp 00:09: [mem 0xfed00000-0xfed003ff]
[ 0.248473] pnp 00:09: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.248545] pnp 00:0a: [mem 0xffb00000-0xffbfffff]
[ 0.248548] pnp 00:0a: [mem 0xfff00000-0xffffffff]
[ 0.248580] pnp 00:0a: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.248640] pnp 00:0b: [mem 0xffc00000-0xffefffff]
[ 0.248694] system 00:0b: [mem 0xffc00000-0xffefffff] has been reserved
[ 0.248697] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.248762] pnp 00:0c: [mem 0xfec00000-0xfec00fff]
[ 0.248764] pnp 00:0c: [mem 0xfee00000-0xfee00fff]
[ 0.248816] system 00:0c: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.248819] system 00:0c: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.248822] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.249283] pnp 00:0d: [irq 4]
[ 0.249285] pnp 00:0d: [dma 0 disabled]
[ 0.249287] pnp 00:0d: [io 0x03f8-0x03ff]
[ 0.249364] pnp 00:0d: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.249408] pnp 00:0e: [mem 0xf0000000-0xf3ffffff]
[ 0.249462] system 00:0e: [mem 0xf0000000-0xf3ffffff] has been reserved
[ 0.249465] system 00:0e: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.249697] pnp 00:0f: [mem 0x00000000-0x0009ffff]
[ 0.249699] pnp 00:0f: [mem 0x000c0000-0x000cffff]
[ 0.249701] pnp 00:0f: [mem 0x000e0000-0x000fffff]
[ 0.249703] pnp 00:0f: [mem 0x00100000-0x3f6fffff]
[ 0.249705] pnp 00:0f: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.249769] system 00:0f: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.249772] system 00:0f: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.249775] system 00:0f: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.249778] system 00:0f: [mem 0x00100000-0x3f6fffff] could not be reserved
[ 0.249781] system 00:0f: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.249961] pnp: PnP ACPI: found 16 devices
[ 0.249962] ACPI: ACPI bus type pnp unregistered
[ 0.249965] PnPBIOS: Disabled by ACPI PNP
[ 0.287035] PCI: max bus depth: 1 pci_try_num: 2
[ 0.287061] pci 0000:00:1c.1: BAR 15: assigned [mem 0x3f700000-0x3f8fffff 64bit pref]
[ 0.287065] pci 0000:00:1c.0: BAR 14: assigned [mem 0x3f900000-0x3fafffff]
[ 0.287068] pci 0000:00:1c.0: BAR 15: assigned [mem 0x3fb00000-0x3fcfffff 64bit pref]
[ 0.287072] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.287076] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.287079] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.287083] pci 0000:00:1c.0: bridge window [mem 0x3f900000-0x3fafffff]
[ 0.287086] pci 0000:00:1c.0: bridge window [mem 0x3fb00000-0x3fcfffff 64bit pref]
[ 0.287091] pci 0000:00:1c.1: PCI bridge to [bus 01-01]
[ 0.287094] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.287098] pci 0000:00:1c.1: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.287101] pci 0000:00:1c.1: bridge window [mem 0x3f700000-0x3f8fffff 64bit pref]
[ 0.287107] pci 0000:00:1e.0: PCI bridge to [bus 03-03]
[ 0.287119] pci 0000:00:1c.0: enabling device (0104 -> 0107)
[ 0.287131] pci 0000:00:1c.0: setting latency timer to 64
[ 0.287142] pci 0000:00:1c.1: setting latency timer to 64
[ 0.287148] pci 0000:00:1e.0: setting latency timer to 64
[ 0.287151] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.287153] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.287155] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.287157] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.287159] pci_bus 0000:00: resource 8 [mem 0x3f700000-0xffffffff]
[ 0.287161] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 0.287163] pci_bus 0000:02: resource 1 [mem 0x3f900000-0x3fafffff]
[ 0.287165] pci_bus 0000:02: resource 2 [mem 0x3fb00000-0x3fcfffff 64bit pref]
[ 0.287167] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.287169] pci_bus 0000:01: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.287171] pci_bus 0000:01: resource 2 [mem 0x3f700000-0x3f8fffff 64bit pref]
[ 0.287173] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
[ 0.287175] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
[ 0.287177] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.287179] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.287181] pci_bus 0000:03: resource 8 [mem 0x3f700000-0xffffffff]
[ 0.287231] NET: Registered protocol family 2
[ 0.288810] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.289105] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.289502] TCP bind hash table entries: 65536 (order: 8, 1835008 bytes)
[ 0.290323] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.290326] TCP reno registered
[ 0.290329] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.290346] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.290482] NET: Registered protocol family 1
[ 0.290501] pci 0000:00:02.0: Boot video device
[ 0.290662] PCI: CLS 32 bytes, default 64
[ 0.290730] Unpacking initramfs...
[ 0.538498] Freeing initrd memory: 13404k freed
[ 0.545429] audit: initializing netlink socket (disabled)
[ 0.545447] type=2000 audit(1469988581.540:1): initialized
[ 0.554240] highmem bounce pool size: 64 pages
[ 0.554246] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.554386] VFS: Disk quotas dquot_6.5.2
[ 0.554426] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.554510] msgmni has been set to 1746
[ 0.554675] alg: No test for stdrng (krng)
[ 0.554699] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.554703] io scheduler noop registered
[ 0.554705] io scheduler deadline registered
[ 0.554718] io scheduler cfq registered (default)
[ 0.554817] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.554855] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[ 0.554916] pcieport 0000:00:1c.1: setting latency timer to 64
[ 0.554946] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
[ 0.555037] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.555063] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.555065] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.555386] intel_idle: does not run on family 6 model 23
[ 0.555414] ERST: Table is not found!
[ 0.555415] GHES: HEST is not enabled!
[ 0.555430] isapnp: Scanning for PnP cards...
[ 0.908203] isapnp: No Plug & Play device found
[ 0.908267] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.928581] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.092569] 00:0d: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.128300] Linux agpgart interface v0.103
[ 1.128448] agpgart-intel 0000:00:00.0: Intel G33 Chipset
[ 1.128491] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 1.129214] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.129347] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 1.129540] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.132273] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.132315] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.132434] mousedev: PS/2 mouse device common for all mice
[ 1.132491] rtc_cmos 00:03: RTC can wake from S4
[ 1.132597] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.132639] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.132654] cpuidle: using governor ladder
[ 1.132656] cpuidle: using governor menu
[ 1.132952] TCP cubic registered
[ 1.132990] NET: Registered protocol family 10
[ 1.133688] Mobile IPv6
[ 1.133692] NET: Registered protocol family 17
[ 1.133696] Registering the dns_resolver key type
[ 1.133721] Using IPI No-Shortcut mode
[ 1.133835] PM: Hibernation image not present or could not be loaded.
[ 1.133851] registered taskstats version 1
[ 1.134111] rtc_cmos 00:03: setting system clock to 2016-07-31 18:09:42 UTC (1469988582)
[ 1.134158] Initializing network drop monitor service
[ 1.134271] Freeing unused kernel memory: 728k freed
[ 1.134494] Write protecting the kernel text: 2868k
[ 1.134534] Write protecting the kernel read-only data: 1076k
[ 1.134535] NX-protecting the kernel data: 3276k
[ 1.144548] udevd[63]: starting version 175
[ 1.183542] ATL1E 0000:01:00.0: setting latency timer to 64
[ 1.187905] SCSI subsystem initialized
[ 1.188113] usbcore: registered new interface driver usbfs
[ 1.188139] usbcore: registered new interface driver hub
[ 1.194060] usbcore: registered new device driver usb
[ 1.202273] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.202373] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.202377] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.202491] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.202505] libata version 3.00 loaded.
[ 1.202511] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.202522] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.206394] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 1.206623] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfea77c00
[ 1.220025] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.221474] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.221476] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.221478] usb usb1: Product: EHCI Host Controller
[ 1.221480] usb usb1: Manufacturer: Linux 3.2.0-4-rt-686-pae ehci_hcd
[ 1.221482] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.225162] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.227701] hub 1-0:1.0: USB hub found
[ 1.227709] hub 1-0:1.0: 8 ports detected
[ 1.229143] ata_piix 0000:00:1f.1: version 2.13
[ 1.229200] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.239108] scsi0 : ata_piix
[ 1.240493] scsi1 : ata_piix
[ 1.243851] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.243853] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.243946] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.243949] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.243991] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.244058] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000d400
[ 1.244109] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.244112] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.244114] usb usb2: Product: UHCI Host Controller
[ 1.244115] usb usb2: Manufacturer: Linux 3.2.0-4-rt-686-pae uhci_hcd
[ 1.244117] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.246417] hub 2-0:1.0: USB hub found
[ 1.246425] hub 2-0:1.0: 2 ports detected
[ 1.247664] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.247698] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.255192] scsi2 : ata_piix
[ 1.256283] scsi3 : ata_piix
[ 1.259829] ata3: SATA max UDMA/133 cmd 0xd080 ctl 0xd000 bmdma 0xc800 irq 23
[ 1.259832] ata4: SATA max UDMA/133 cmd 0xcc00 ctl 0xc880 bmdma 0xc808 irq 23
[ 1.259886] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.259890] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.259921] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.260108] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000d480
[ 1.260147] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.260149] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.260151] usb usb3: Product: UHCI Host Controller
[ 1.260153] usb usb3: Manufacturer: Linux 3.2.0-4-rt-686-pae uhci_hcd
[ 1.260155] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.261247] hub 3-0:1.0: USB hub found
[ 1.261255] hub 3-0:1.0: 2 ports detected
[ 1.261930] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.261933] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.261948] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.262653] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000d800
[ 1.262691] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.262694] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.262696] usb usb4: Product: UHCI Host Controller
[ 1.262697] usb usb4: Manufacturer: Linux 3.2.0-4-rt-686-pae uhci_hcd
[ 1.262699] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.262838] hub 4-0:1.0: USB hub found
[ 1.262843] hub 4-0:1.0: 2 ports detected
[ 1.262991] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.262994] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.263002] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.263967] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000d880
[ 1.264022] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.264024] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.264026] usb usb5: Product: UHCI Host Controller
[ 1.264028] usb usb5: Manufacturer: Linux 3.2.0-4-rt-686-pae uhci_hcd
[ 1.264030] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.264148] hub 5-0:1.0: USB hub found
[ 1.264154] hub 5-0:1.0: 2 ports detected
[ 1.454175] ata3.00: ATA-8: ST3320613AS, CC2J, max UDMA/133
[ 1.454180] ata3.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.511548] ata3.00: configured for UDMA/133
[ 1.511718] scsi 2:0:0:0: Direct-Access ATA ST3320613AS CC2J PQ: 0 ANSI: 5
[ 1.522471] sd 2:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 1.522531] sd 2:0:0:0: [sda] Write Protect is off
[ 1.522533] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.522558] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.536082] usb 1-2: new high-speed USB device number 2 using ehci_hcd
[ 1.544029] Refined TSC clocksource calibration: 3066.666 MHz.
[ 1.544037] Switching to clocksource tsc
[ 1.571127] sda: sda1 sda2 < sda5 sda6 >
[ 1.571574] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.573069] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.670063] usb 1-2: New USB device found, idVendor=3538, idProduct=0901
[ 1.670069] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.670073] usb 1-2: Product: PQI USB Flash Drive
[ 1.670076] usb 1-2: Manufacturer: PQI
[ 1.670079] usb 1-2: SerialNumber: 01AF00000000040A
[ 1.672615] Initializing USB Mass Storage driver...
[ 1.672769] scsi4 : usb-storage 1-2:1.0
[ 1.672847] usbcore: registered new interface driver usb-storage
[ 1.672849] USB Mass Storage support registered.
[ 2.128017] usb 3-1: new full-speed USB device number 2 using uhci_hcd
[ 2.297148] usb 3-1: New USB device found, idVendor=046d, idProduct=c52b
[ 2.297153] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.297157] usb 3-1: Product: USB Receiver
[ 2.297160] usb 3-1: Manufacturer: Logitech
[ 2.306645] usbcore: registered new interface driver usbhid
[ 2.306648] usbhid: USB HID core driver
[ 2.315402] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.1-1/input2
[ 2.320684] input: Logitech Unifying Device. Wireless PID:404d as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.2/0003:046D:C52B.0003/input/input0
[ 2.320781] logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:404d] on usb-0000:00:1d.1-1:1
[ 2.672608] scsi 4:0:0:0: Direct-Access Generic USB Flash Disk 0.00 PQ: 0 ANSI: 2
[ 2.673586] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 2.673817] sd 4:0:0:0: [sdb] 7892992 512-byte logical blocks: (4.04 GB/3.76 GiB)
[ 2.674314] sd 4:0:0:0: [sdb] Write Protect is off
[ 2.674316] sd 4:0:0:0: [sdb] Mode Sense: 00 00 00 00
[ 2.674820] sd 4:0:0:0: [sdb] Asking for cache data failed
[ 2.674855] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 2.678079] sd 4:0:0:0: [sdb] Asking for cache data failed
[ 2.678122] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 2.678973] sdb: sdb1
[ 2.695956] sd 4:0:0:0: [sdb] Asking for cache data failed
[ 2.695998] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 2.696065] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 7.174706] microcode: CPU0 sig=0x1067a, pf=0x1, revision=0xa07
[ 7.177123] platform microcode: firmware: agent loaded intel-ucode/06-17-0a into memory
[ 7.181095] microcode: CPU0 updated to revision 0xa0b, date = 2010-09-28
[ 7.181559] microcode: CPU1 sig=0x1067a, pf=0x1, revision=0xa07
[ 7.183763] platform microcode: firmware: agent loaded intel-ucode/06-17-0a into memory
[ 7.187734] microcode: CPU1 updated to revision 0xa0b, date = 2010-09-28
[ 7.188412] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 7.330047] PM: Starting manual resume from disk
[ 7.330050] PM: Hibernation image partition 8:6 present
[ 7.330051] PM: Looking for hibernation image.
[ 7.330586] PM: Image not found (code -22)
[ 7.330589] PM: Hibernation image not present or could not be loaded.
[ 7.356231] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.845407] udevd[375]: starting version 175
[ 9.229029] intel_rng: FWH not detected
[ 9.567557] snd_hda_intel 0000:00:1b.0: irq 42 for MSI/MSI-X
[ 9.567611] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 9.576941] input: PC Speaker as /devices/platform/pcspkr/input/input1
[ 9.641318] ACPI: resource 0000:00:1f.3 [io 0x0400-0x041f] conflicts with ACPI region SMRG [io 0x400-0x40f]
[ 9.641321] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.655723] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 9.655770] ACPI: Power Button [PWRB]
[ 9.655829] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 9.655865] ACPI: Power Button [PWRF]
[ 9.680303] iTCO_vendor_support: vendor-support=0
[ 9.682403] ACPI: Requesting acpi_cpufreq
[ 9.748718] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 9.748835] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860)
[ 9.748893] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 9.766063] leds_ss4200: no LED devices found
[ 9.860747] [drm] Initialized drm 1.1.0 20060810
[ 9.958227] i915 0000:00:02.0: setting latency timer to 64
[ 9.972510] i915 0000:00:02.0: irq 43 for MSI/MSI-X
[ 9.972520] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 9.972522] [drm] Driver supports precise vblank timestamp query.
[ 9.972560] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 9.986936] [drm] initialized overlay support
[ 10.031318] fbcon: inteldrmfb (fb0) is primary device
[ 10.037572] parport_pc 00:06: reported by Plug and Play ACPI
[ 10.037673] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[ 10.078797] Console: switching to colour frame buffer device 170x48
[ 10.083511] fb0: inteldrmfb frame buffer device
[ 10.083514] drm: registered panic notifier
[ 10.083527] No ACPI video bus found
[ 10.083580] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 11.636085] Adding 4882428k swap on /dev/sda6. Priority:-1 extents:1 across:4882428k
[ 11.657752] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 11.859689] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 11.953970] loop: module loaded
[ 13.155424] RPC: Registered named UNIX socket transport module.
[ 13.155427] RPC: Registered udp transport module.
[ 13.155429] RPC: Registered tcp transport module.
[ 13.155432] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 13.202145] FS-Cache: Loaded
[ 13.238753] FS-Cache: Netfs 'nfs' registered for caching
[ 13.248482] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 15.137150] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input4
[ 15.369986] Bluetooth: Core ver 2.16
[ 15.370132] NET: Registered protocol family 31
[ 15.370135] Bluetooth: HCI device and connection manager initialized
[ 15.370139] Bluetooth: HCI socket layer initialized
[ 15.370141] Bluetooth: L2CAP socket layer initialized
[ 15.370151] Bluetooth: SCO socket layer initialized
[ 15.398082] Bluetooth: RFCOMM TTY layer initialized
[ 15.398088] Bluetooth: RFCOMM socket layer initialized
[ 15.398090] Bluetooth: RFCOMM ver 1.11
[ 15.403423] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.403426] Bluetooth: BNEP filters: protocol multicast
[ 15.549034] lp0: using parport0 (interrupt-driven).
[ 15.679378] ppdev: user-space parallel port driver
[ 17.698688] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 17.698771] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.698857] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 28.512019] eth0: no IPv6 routers present
[ 76.336012] eth0: no IPv6 routers present
[ 124.112014] eth0: no IPv6 routers present
[ 172.608015] eth0: no IPv6 routers present
[ 518.072013] eth0: no IPv6 routers present
[ 565.032011] eth0: no IPv6 routers present
[ 613.328017] eth0: no IPv6 routers present
[ 661.392015] eth0: no IPv6 routers present
[ 1006.816016] eth0: no IPv6 routers present
[ 1054.536016] eth0: no IPv6 routers present
[ 1102.512017] eth0: no IPv6 routers present
[ 1150.848015] eth0: no IPv6 routers present
[ 1495.152012] eth0: no IPv6 routers present
[ 1543.920016] eth0: no IPv6 routers present
[ 1591.952014] eth0: no IPv6 routers present
[ 1639.760013] eth0: no IPv6 routers present
[ 1985.008010] eth0: no IPv6 routers present
[ 2032.352013] eth0: no IPv6 routers present
[ 2080.224014] eth0: no IPv6 routers present
[ 2128.032014] eth0: no IPv6 routers present
[ 2473.920019] eth0: no IPv6 routers present
[ 2521.968014] eth0: no IPv6 routers present
[ 2569.152012] eth0: no IPv6 routers present
[ 2617.024013] eth0: no IPv6 routers present
[ 2962.568012] eth0: no IPv6 routers present
[ 3010.176013] eth0: no IPv6 routers present
[ 3058.192015] eth0: no IPv6 routers present
[ 3106.512014] eth0: no IPv6 routers present
[ 3355.405960] ATL1E 0000:01:00.0: eth0: NIC Link is Down
[ 3365.936472] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 3376.096014] eth0: no IPv6 routers present
[ 3424.240015] eth0: no IPv6 routers present
[ 3472.528016] eth0: no IPv6 routers present
[ 3520.064012] eth0: no IPv6 routers present
[ 3568.744014] eth0: no IPv6 routers present
[ 3913.512016] eth0: no IPv6 routers present
[ 3961.312015] eth0: no IPv6 routers present
[ 4009.104018] eth0: no IPv6 routers present
[ 4027.610611] ATL1E 0000:01:00.0: eth0: NIC Link is Down
[ 4054.296980] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 4065.184018] eth0: no IPv6 routers present
[ 4113.632016] eth0: no IPv6 routers present
[ 4161.552013] eth0: no IPv6 routers present
[ 4209.488017] eth0: no IPv6 routers present
[ 4315.986009] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4554.112022] eth0: no IPv6 routers present
[ 4602.272018] eth0: no IPv6 routers present
[ 4650.208016] eth0: no IPv6 routers present
[ 4698.488019] eth0: no IPv6 routers present
[ 5043.936020] eth0: no IPv6 routers present
[ 5091.440013] eth0: no IPv6 routers present
[ 5139.496017] eth0: no IPv6 routers present
[ 5187.648015] eth0: no IPv6 routers present
[ 5532.352016] eth0: no IPv6 routers present
[ 5580.248014] eth0: no IPv6 routers present
[ 5628.544017] eth0: no IPv6 routers present
[ 5676.736016] eth0: no IPv6 routers present
[ 5689.330325] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 5689.330630] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5689.330808] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 5699.592015] eth0: no IPv6 routers present
[ 6021.536015] eth0: no IPv6 routers present
[ 6069.696016] eth0: no IPv6 routers present
[ 6117.952014] eth0: no IPv6 routers present
[ 6121.957786] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 6121.958100] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6121.958270] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6132.448014] eth0: no IPv6 routers present
[ 6303.158070] ATL1E 0000:01:00.0: eth0: NIC Link is Down
[ 6309.619095] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 6320.392018] eth0: no IPv6 routers present
[ 6334.626123] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 6334.626459] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6334.626622] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6344.784016] eth0: no IPv6 routers present
[ 6363.155397] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 6363.156324] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6363.156498] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6373.696015] eth0: no IPv6 routers present
[ 6374.688243] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 6374.688938] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6374.689162] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6385.696014] eth0: no IPv6 routers present
[ 6391.834621] ATL1E 0000:01:00.0: eth0: NIC Link is Up <100 Mbps Full Duplex>
[ 6391.834946] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6391.835108] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6402.432012] eth0: no IPv6 routers present
За първи път работя с Linux ( една седмица се мъчих докато инсталирам програмата и ОС
