Страница 8 из 32
Inkscape Gcodetools plug-in English support forum
Добавлено: 10 дек 2009, 10:28
- Generated Gcode in EMC2
| Type | Extension of vector
graphics editor Inkscape |
| Developer | Gcodetools develop team |
| Written in | Python |
| OS | Cross-Platform (Windows, Linux, MacOS) |
| Version | 1.6.03 |
| License | GNU GPL |
| Downloads | 7800+ |
Gcodetools
Gcodetools is a plug-in for Inkscape. It prepares and converts paths from Inkscape to Gcode, using biarc interpolation.
This article is unfinished. You can help cnc-club expanding it.
Screenshots and photos are needed. Please post them at this thread.
Features (для просмотра содержимого нажмите на ссылку)Features
- Preview of the generated Gcode in EMC
- Gcodetools area pocketing
- Gcodetools lathe
- Gcodetools engraving by Rene
- Bears by Durachko
Export to Gcode- Export paths to Gcode
- Using circular (biarc approximation) or straight line interpolation
- Automatic path subdivision to reach defined tolerance
- Multiply tool processing
- Export Gcode in parametric of flat form
- Including personal headers and footers
- Choosing units
- Multi-pass processing
- Numeric suffix is added to generated files to avoid overwriting
Lathe Gcode- Compute trajectories for lathe
- Fine cut
- Define fine cut's depth
- Define fine rounds
- Two different computation functions for fine cut
- Standard axis remapping
Path's area processing- Building area paths
- Area paths could be modified
Engraving- Building trajectory according to the cutter's shape
- Defining different cutter's shapes
Tool's library- Defining different tool's parameters (diameter, feed, depth step, penetration feed, personal Gcode before/after each path, cutters shape, personal tool's changing Gcode)
- Tools can be managed by Inkscape's standard procedures (copy, delete, assigned to different layer)
- Multiply tools processing
Orientation system- Applying scale along any axis
- Apply rotate in the ХY plane
- Apply translation along any axis
- Apply transforms according to arbitrary points
Post-processor- You can create custom post-processor by writing down the commands or choose from the list of default post-processors
- Scale and offset Gcode
- Gcode commands remapping
- Parameterize Gcode
- Round floating point values to specified precision
Verifying tools for the scene- Select and remove small paths (area artefacts)
- Tool's alignment check
- Cutting order check
Plotter cutting- Export to Gcode for plotter with tangential knife. Forth axis A is knife's rotation.
Install (для просмотра содержимого нажмите на ссылку)Install
Windows
Unpack and copy all the files to the following directory Program Files\Inkscape\share\extensions\ and restart inkscape
Linux
Unpack and copy all the files to the following directory /usr/share/inkscape/extensions/ and restart inkscape
Get latest version (для просмотра содержимого нажмите на ссылку)Get latest versions
Latest stable version
Gcodetools 1.7
Older versions(ver 1.5)
(ver 1.5)
(ver 1.4)
(ver 1.2)
Dev-version
You can try the newest development version by getting it from github repository
https://github.com/cnc-club/gcodetools via web interface or using
git clone git@github.com:cnc-club/gcodetools.git .
You'll need to run
python create_inx.py to create inx files. After that install procedure is the same with the stable version.
Translations
Gcodetools is included into Inkscape v 0.49 so it will have native translations as other Inkscape's extensions. Until it is released you can use some self made translation packs:
Develop (для просмотра содержимого нажмите на ссылку)Develop
At the moment following features are being developed:
- Plasma cutter extension
- Turning lathe extension
- Plotter extension
You can help us improve Gcodetools in several ways
- Writing a report / bug report
- Improve help and manuals
- Publish G-codes / SVGs / other code
- Publish photos / videos
- Make a bug report
- Help develop new features
- Suggest a new feature
Tested on (для просмотра содержимого нажмите на ссылку)Tested on
Linux
Ubuntu 9.10 14.04 + inkscape 0.48 (older Gcodetools versions also work with 0.46, 0.47)
Windows
Windows XP, Windows Vista, Windows 7 + inkscape 0.46, inkscape 0.47
MacOS
There are some reports on successful work on MacOs.
Re: Inkscape Gcodetools plug-in English support forum
Добавлено: 21 дек 2010, 03:03
otto_pjm
Great stuff,
I've been using Vectric's Cut2D and Cut3D with my CNC Router, which I've now moved to a common
maker space and have been searching for open and accessible tools that we can put on the resident Ubuntu machines, or that users can run on any OS they happen to have. Your Gcodetools plug-in looks great. I've spent a few days with the tutorials, and have managed to get the area tool to create the paths I expect, but I have a question, well two actually.
1)
Can I specify a step over or overlap parameter somewhere? So for instance if my tool is 10mm wide and I want a 60% step over, then the path's are only 4mm apart.
I'm not sure if this feature exists, and I'm missing it because it's named something else, or if it hasn't been developed, or needs to be manually produced by running the tool again after offsetting the size of the object I wish to cut out by some factor for smooth pocketing.
Let me know if this is unclear and I attach images of what I'm talking about.
2)
In the tutorials you mention that the area width is always in pixels, and the units setting (in or mm) does not matter. My question is, is this the only parameter that is not based on Inkscape's units setting? I use inches and set the tool diameter as such and it seems to work as expected, but wanted to know if there would be other non-inch based parameters.
Thanks again for the great tool.
Pete
Добавлено: 21 дек 2010, 10:15
1. Yes there's such feature, but it's in the development version...
See 5 posts above :^)
http://www.cnc-club.ru/forum/viewtopic. ... =120#p1327
2. As long as Orientation points system was implemented you can use any units you want. Just make sure, that orientation points are in place.
So if you create create area curves with Area tab from gcodetools you wont have to do any unit conversations.
By the way check out our new Area fill function which fills the path with straight lines, so there no need to do any difficult path offsets:
http://www.cnc-club.ru/forum/viewtopic. ... =164#p1959
Добавлено: 22 дек 2010, 06:29
otto_pjm
Excellent, not sure how I missed the the offset feature, that is exactly what I was hoping for, the Area fill looks very promising too, I'll pull the development code and check it out, thanks. I'll likely be pulling some documentation together to give a tutorial to the members at my maker space. I'd be happy to contribute it. what's the best format and way to do so.
Добавлено: 22 дек 2010, 11:58
That will be great! You can do in any format that suitable to you. And you can place it wherever you want, either at your own site (and give me a link to link it from the main page) or here at the forum.
Inkscape Gcodetools in windows has no output
Добавлено: 04 янв 2011, 20:09
bolo
Hi folks! I'm trying to use g-code tools v1.4 in Windows, with Inkscape 0.48.0 r9654, but it seems that nothing happenes, unfortunately!
I tried c: with and without backslash, and "C:\Dokumente und Einstellungen\bo\" (my home dir), with activated logfile as you can see in the picture, but no file appeared there. Also on the screen nothing happened, no matter what values i set for tool diameter and area radius. I also tried version Gcodetools 1.6.04, where the 'what to do' section is missing, and it also didn't seem to work.
Has someone the same problem, or any idea?
Those are the tutorials I found:
http://www.cnc-club.ru/forum/viewtopic. ... t=82&p=993 from root
and other one from 10 Dec 2009, 10:28 and also this (
http://kalyaev.com/2010/20100402/tut01/tut01.html)
cheers;
(?) bolo
Edit OHUH think i found out, it must be a general problem because none of my extensions work! I was just reading
http://wiki.inkscape.org/wiki/index.php ... onsWorking but maybe I'll install all again.
servas!
Добавлено: 04 янв 2011, 20:58
You better use v1.6. we've split all the functions to different extensions/tabs (tab is a "page" in the extension's window).
So for example if you want co export path to
Gcode you should open
Path to Gcode extension from
Gcodetools, fill in filename and dir, chose the
Path to Gcode tab and press Apply.
Now "what to do" equals to active tab. So if you want area function - select Area tab, if you want Gcode select Path to Gcode tab.
If extensions do not work at all, try looking here
http://wiki.inkscape.org/wiki/index.php ... ft_Windows . Gcodetools is a ordinal python script so all you need to make it work is to have an Inkscape and Python. So check if Python have been installed. (It should have been installed when you've installed Inkscape but may be something went wrong
PS if something goes wrong Gcodetools usually raises an error so you should know what exactly goes wrong.
Добавлено: 13 янв 2011, 21:48
bolo
Ah ok, think I got it now, it's probably easy when it's running. I'll have a look in the future.
Anyway thank you for the reply and for sharing your work! cool!
Salü, Новичок B.
Добавлено: 20 янв 2011, 09:28
Bartelime
Dear all
I'm great fan of cnc-club and milled several projects so far. Yesterday I experienced a problem. The code seemed to be finde on EMC2 (Ubuntu 10.04). But when milling, it follows on a huge radius, when I understand the G-code, see picture and see what I mean. (I tried two fonts, Comics Sans / Tlwg Typist)
I tried several settings, even with Windows and on a Linux Computer with inkscape 0.48 and the stable Gcodeplugin 1.6 as well as the newest dev. revision from 17.01.2011.
I'm sure, I do not understand some parametric settings. But I have no idea where to adjust.
I'm really happy to every answer and hint where I need to fix that.
By the way, it's a fantastic tool! Congratulations to the developers!
Bartelime
Добавлено: 20 янв 2011, 10:25
Thanks for the report could you attach you svg file?
I'll try to find out what's wrong.
PS I've heard about same situation while using Engraving function...
Добавлено: 20 янв 2011, 17:15
Bartelime
Wow, ultra fast reply!
Thanks and find the file attached above!
Добавлено: 20 янв 2011, 17:52
I've made a test of the "Reinigung" word and it was fine, probably it's because of different parameters...
Could you attach an ngc file to
PS I've posted a question about same bug from another user at the LinuxCNC.org - EMC2 developers site. And now waiting for their answer to ...
http://www.linuxcnc.org/component/optio ... 2/lang,ru/
Добавлено: 20 янв 2011, 19:13
alfcnc
Hi !
Ill try to test new dev release of gcodetools , first the lathe extension but nothing work.
And after just the path to gcode and same problem ??? Inkscape 0.48 on Debian.
The svg is just a spriral , Two orientation point set with gcotools dev 1.6 last rev 173.
And standard tool... and i have nothing done and no errors...if I'll set the option direct viewing and then I have :
File "gcodetools-dev.py", line 5396, in <module>
e.affect()
File "/usr/local/share/inkscape/extensions/inkex.py", line 211, in affect
self.parse()
File "/usr/local/share/inkscape/extensions/inkex.py", line 139, in parse
self.document = etree.parse(stream)
File "lxml.etree.pyx", line 2706, in lxml.etree.parse (src/lxml/lxml.etree.c:49958)
File "parser.pxi", line 1522, in lxml.etree._parseDocument (src/lxml/lxml.etree.c:72015)
File "parser.pxi", line 1552, in lxml.etree._parseFilelikeDocument (src/lxml/lxml.etree.c:72325)
File "parser.pxi", line 1435, in lxml.etree._parseDocFromFilelike (src/lxml/lxml.etree.c:71240)
File "parser.pxi", line 997, in lxml.etree._BaseParser._parseDocFromFilelike (src/lxml/lxml.etree.c:68381)
File "parser.pxi", line 539, in lxml.etree._ParserContext._handleParseResultDoc (src/lxml/lxml.etree.c:64257)
File "parser.pxi", line 625, in lxml.etree._handleParseResult (src/lxml/lxml.etree.c:65178)
File "parser.pxi", line 565, in lxml.etree._raiseParseError (src/lxml/lxml.etree.c:64521)
lxml.etree.XMLSyntaxError: Document is empty, line 1, column 1
Thanks !
Добавлено: 21 янв 2011, 00:20
Hmmm sounds strange.
I've just checked the Lathe function. And it works fine. May be you have defined wrong lathe width parameter...
And what's the "direct viewing"? Is it a kind of "Preview" check box at the bottom of the dialog window? If yes - it does not work
! It is needed only for enabling editing the scene while extension's window is opened.
PS here's the screenshot of lathe:
By the way in the development version there's a new function: modify path, to prepare the path for cutting with straight rectangular cutter:
Red path is the trajectory, black one is needed cut.
And a simple test path made with gcodetools:
- lathe gcode path preprocessing.png (8.59 КБ) 7989 просмотров
Добавлено: 21 янв 2011, 00:51
Гость
Yes very curious !
I have update my inkscape 0.48 to last trunk recompile it but always the same nothing is generate ???
I have also try on inkscape on ubuntu that's the same problem ???? curious curious... i haven't have this problem before ???
I have try to change all the parameter...nothing work ? I've load some previous file that's was working before and try to reprocessing ...this do nothing ???
For lathe with etc...thank's but I know i have done many test for debugging....
the lathe function...
I'll try to find.
Wich version of inkscape do you use... ? win ? linux ? dev ? 0.47, 0.48 ?
Добавлено: 21 янв 2011, 00:54
alfcnc
Yes very strange !
I have ever test with changing all the parameters... I'll have done so many test when debugging lathe function...
But with other function it's the same ???
I have test on ubuntu same problem ???
I'll try to find...
Which version of inkscape do you use ? 0.47,0.48 ? dev ? on win or Linux ?
Добавлено: 21 янв 2011, 01:00
admin
There should not be any difference what version to use, 0.46-0.48 windows/linux.
Attach your svg, and I'll try to find out what is wrong...
Добавлено: 21 янв 2011, 01:18
alfcnc
Добавлено: 21 янв 2011, 01:32
Hmm... Works "fine" at my side.
"fine" as fine as could be cutting such spiral on lathe
But I've tested it at home on dev version at one of the latest revisions but not the last one, I'll try it on the last revision tomorrow at work.
Do other extensions (not Lathe or not Gcodetools) work fine, or not?
Добавлено: 21 янв 2011, 01:36
alfcnc
I'll come to test on Debian same version but Inkscape 0.47 that's ok....
It's my Inkscape 0.48 on this computer who make things out of order...Excuse me !
Thank's a lot for speedy reply.
have a nice day.
Добавлено: 21 янв 2011, 12:32
Probably there's a problem with Python or smf...
