Mesa 5i25+7i77 и фрезерный станок 6Р13ф3
SONIC300077
Re: Mesa 5i25+7i77 и фрезерный станок 6Р13ф3
Сообщение SONIC300077 »
Если я правильно понял вас, то я сделал так заменил файл butt.clp файлом button6.clp и изменил хал! вот выдает ошибку ?
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.3
Machine configuration directory is '/home/test/linuxcnc/configs/6P13F3'
Machine configuration file is '6P13F3.ini'
INIFILE=/home/test/linuxcnc/configs/6P13F3/6P13F3.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting HAL User Interface program: halui
Running HAL shutdown script
Killing task linuxcncsvr, PID=3121
ERROR CLASSICLADDER-   Error intializing classicladder user module.
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
custom.hal:82: Signal 'feed-hold' can not add OUT pin 'classicladder.0.out-00', it already has OUT pin 'hm2_5i25.0.7i77.0.0.input-26'
3121
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
ULAPI: WARNING: module 'HAL_classicladder' failed to delete shmem 03
Kernel message information:
[  900.076283] I-pipe: Domain RTAI registered.
[  900.076301] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[  900.076308] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[  900.076428] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  900.076435] PIPELINE layers:
[  900.076442] fc42ce20 9ac15d93 RTAI 200
[  900.076448] c085cb20 0 Linux 100
[  900.121560] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  900.122363] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[  900.122380] RTAI[sched]: hard timer type/freq = APIC/12499668(Hz); default timing: periodic; linear timed lists.
[  900.122390] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1800059000 hz.
[  900.122398] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[  900.122529] RTAI[usi]: enabled.
[  900.192559] RTAI[math]: loaded.
[  900.320586] hm2: loading Mesa HostMot2 driver version 0.15
[  900.326294] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[  900.326355] hm2_pci 0000:03:00.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[  900.326362] hm2_pci: discovered 5i25 at 0000:03:00.0
[  900.327362] hm2/hm2_5i25.0: Smart Serial Firmware Version 42
[  900.423658] hm2/hm2_5i25.0: 34 I/O Pins used:
[  900.423667] hm2/hm2_5i25.0:     IO Pin 000 (P3-01): IOPort
[  900.423674] hm2/hm2_5i25.0:     IO Pin 001 (P3-14): IOPort
[  900.423680] hm2/hm2_5i25.0:     IO Pin 002 (P3-02): IOPort
[  900.423687] hm2/hm2_5i25.0:     IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[  900.423695] hm2/hm2_5i25.0:     IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[  900.423703] hm2/hm2_5i25.0:     IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[  900.423710] hm2/hm2_5i25.0:     IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[  900.423718] hm2/hm2_5i25.0:     IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[  900.423726] hm2/hm2_5i25.0:     IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[  900.423733] hm2/hm2_5i25.0:     IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[  900.423741] hm2/hm2_5i25.0:     IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[  900.423748] hm2/hm2_5i25.0:     IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[  900.423756] hm2/hm2_5i25.0:     IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[  900.423763] hm2/hm2_5i25.0:     IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[  900.423770] hm2/hm2_5i25.0:     IO Pin 014 (P3-11): IOPort
[  900.423775] hm2/hm2_5i25.0:     IO Pin 015 (P3-12): IOPort
[  900.423781] hm2/hm2_5i25.0:     IO Pin 016 (P3-13): IOPort
[  900.423787] hm2/hm2_5i25.0:     IO Pin 017 (P2-01): IOPort
[  900.423792] hm2/hm2_5i25.0:     IO Pin 018 (P2-14): IOPort
[  900.423798] hm2/hm2_5i25.0:     IO Pin 019 (P2-02): IOPort
[  900.423804] hm2/hm2_5i25.0:     IO Pin 020 (P2-15): IOPort
[  900.423810] hm2/hm2_5i25.0:     IO Pin 021 (P2-03): IOPort
[  900.423815] hm2/hm2_5i25.0:     IO Pin 022 (P2-16): IOPort
[  900.423821] hm2/hm2_5i25.0:     IO Pin 023 (P2-04): IOPort
[  900.423827] hm2/hm2_5i25.0:     IO Pin 024 (P2-17): IOPort
[  900.423832] hm2/hm2_5i25.0:     IO Pin 025 (P2-05): IOPort
[  900.423838] hm2/hm2_5i25.0:     IO Pin 026 (P2-06): IOPort
[  900.423844] hm2/hm2_5i25.0:     IO Pin 027 (P2-07): IOPort
[  900.423849] hm2/hm2_5i25.0:     IO Pin 028 (P2-08): IOPort
[  900.423855] hm2/hm2_5i25.0:     IO Pin 029 (P2-09): IOPort
[  900.423861] hm2/hm2_5i25.0:     IO Pin 030 (P2-10): IOPort
[  900.423866] hm2/hm2_5i25.0:     IO Pin 031 (P2-11): IOPort
[  900.423872] hm2/hm2_5i25.0:     IO Pin 032 (P2-12): IOPort
[  900.423878] hm2/hm2_5i25.0:     IO Pin 033 (P2-13): IOPort
[  900.424033] hm2/hm2_5i25.0: registered
[  900.424038] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[  900.591390] creating ladder-state
[  901.620008] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[  901.620022] hm2/hm2_5i25.0: unregistered
[  901.620062] hm2_pci 0000:03:00.0: PCI INT A disabled
[  901.620351] hm2_pci: driver unloaded
[  901.626476] hm2: unloading
[  901.930578] RTAI[math]: unloaded.
[  901.970051] SCHED releases registered named ALIEN RTGLBH
[  902.037657] RTAI[malloc]: unloaded.
[  902.136039] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  902.140533] I-pipe: Domain RTAI unregistered.
[  902.140675] RTAI[hal]: unmounted.
custom.hal
(3.3 КБ) 1317 скачиваний
Сообщение nkp »
ага - стоп подачи в хал уже прописано...
ну пока (для попробовать ) можно две строки :
# стоп подачи
#net feed-hold <= hm2_5i25.0.7i77.0.0.input-26
#net feed-hold => motion.feed-hold
и проверить блокировку кнопок - если работать будут как надо - разрулить до конца это дело...
SONIC300077
Да все работает как надо ! :D
Сообщение nkp »
тогда надо "вернуть активность" кнопке net feed-hold <= hm2_5i25.0.7i77.0.0.input-26
сейчас подключим ее через какой нибудь логический компонент...
Сообщение nkp »
здесь кнопка feed-hold и выход с ладдера скоммутированы через xor :
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
# Ручное управление
net manual-mode     <=  hm2_5i25.0.7i77.0.0.input-25
net manual-mode     =>  halui.mode.manual
loadrt xor2
addf  xor2.0  servo-thread
net xorin0  xor2.0.in0  hm2_5i25.0.7i77.0.0.input-26
# стоп подачи
# отключаем сигнал от halui.jog-speed, хрен знает зачем его в pncconf назначают
    # unlinkp halui.jog-speed
    # выставляем нужную скорость
    # отключаем mux16, который был загружен ранее для feed-override
    # unloadrt mux16
    loadrt mux16
    addf mux16.0 servo-thread
    net gal-0 => mux16.0.sel0
    net gal-1 => mux16.0.sel1
    net gal-2 => mux16.0.sel2
    net gal-3 => mux16.0.sel3
    setp mux16.0.suppress-no-input true
    setp mux16.0.in01 3
    setp mux16.0.in02 30
    setp mux16.0.in04 280
    setp mux16.0.in08 1500
    net jog-speed <=  mux16.0.out-f => halui.jog-speed
    # Выделим кнопку в отдельный сигнал - кнопка нажата = любой из контактов галетника замкнут, т.е. or для всех контактов.
    loadrt or2 count=3
    addf or2.0 servo-thread
    addf or2.1 servo-thread
    addf or2.2 servo-thread
    net gal-0 => or2.0.in0 <= hm2_5i25.0.7i77.0.0.input-28
    net gal-1 => or2.0.in1 <= hm2_5i25.0.7i77.0.0.input-29
    net gal-2 => or2.1.in0 <= hm2_5i25.0.7i77.0.0.input-30
    net gal-3 => or2.1.in1 <= hm2_5i25.0.7i77.0.0.input-31
    net or-01 => or2.2.in0 <= or2.0.out
    net or-02 => or2.2.in1 <= or2.1.out
    net jog   <= or2.2.out
    # Это по переключателям xyz - фактически делаем and2 кнопки и каждого пина переключателя, и вывод на перемещение оси.
    loadrt and2 count=6
    addf and2.0 servo-thread
    addf and2.1 servo-thread
    addf and2.2 servo-thread
    addf and2.3 servo-thread
    addf and2.4 servo-thread
    addf and2.5 servo-thread
    net jog => and2.0.in1
    net jog => and2.1.in1
    net jog => and2.2.in1
    net jog => and2.3.in1
    net jog => and2.4.in1
    net jog => and2.5.in1
loadrt classicladder_rt numPhysInputs=15 numPhysOutputs=15 numS32in=10 numS32out=10 numFloatIn=10 numFloatOut=10 numTimersIec=20
loadusr classicladder   button6.clp
addf classicladder.0.refresh servo-thread
net and2-0-in0 => and2.0.in0 <= classicladder.0.in-00   hm2_5i25.0.7i77.0.0.input-19
net and2-1-in0 => and2.1.in0 <= classicladder.0.in-01   hm2_5i25.0.7i77.0.0.input-20
net and2-2-in0 => and2.2.in0 <= classicladder.0.in-02   hm2_5i25.0.7i77.0.0.input-21
net and2-3-in0 => and2.3.in0 <= classicladder.0.in-03   hm2_5i25.0.7i77.0.0.input-22
net and2-4-in0 => and2.4.in0 <= classicladder.0.in-04   hm2_5i25.0.7i77.0.0.input-23
net and2-5-in0 => and2.5.in0 <= classicladder.0.in-05   hm2_5i25.0.7i77.0.0.input-24
net and2-0-out <= and2.0.out => halui.jog.0.minus
net and2-1-out <= and2.1.out => halui.jog.0.plus
net and2-2-out <= and2.2.out => halui.jog.1.minus
net and2-3-out <= and2.3.out => halui.jog.1.plus
net and2-4-out <= and2.4.out => halui.jog.2.minus
net and2-5-out <= and2.5.out => halui.jog.2.plus
net xorin1  xor2.0.in1  classicladder.0.out-00
net xorout  xor2.0.out  motion.feed-hold
SONIC300077
Работает все в лучшем виде, спасибо всем и отдельное спасибо от оператора :good:
Говорит что в диком восторге от системы :o
и интернируется, так сказать для полного счастья ему не хватает тумблерочка который выполнял бы " стоп программа " как и клавиша ESC только вот чтобы без выключения шпинделя?
Возможно что нить в этом плане придумать :thinking:
SONIC300077
SONIC300077 писал(а):Работает все в лучшем виде, спасибо всем и отдельное спасибо от оператора :good:
Или может какой файл подправить чтоб при нажатии ESC (стоп программа) программа останавливалась а шпиндель нет ?
Сообщение nkp »
а чем пауза не подходит?
или во время этой паузы хотите работать в ручном режиме??
SONIC300077
Наверно наш оператор не совсем разобрался с интерфейсом, или я напутал, может он хотел просто чтоб под рукой на пульте был переключатель, просто у него на старой системе был такой тумблер. В понедельник думаю все проясниться!
А feedhold не оно? По русски "стоп подачи"...
de-signer
Сообщение de-signer »
Привет всем.
Смотрю тема свежая. Чтобы новую тему не создавать скажите. Можно ли прикрутить к linuxcnc две карты 5i25 и, соответственно 2 дочерние. Переварит ли hostmot сразу 2 карты или как-то нужно по-другому конфиг править.
В первспективе хотелось бы собрать пятикоординатный фрезер возможно с роботом на 1-2 коодинаты, т.е. нужно контролировать 6-7 координат. Может есть другое решение данного вопроса?
Порылся на сайте MESA таких карт не встретил: чтобы и управление шестью приводами и получение импульсов с шести датчиков для более точного контроля (повышения точности обработки).
Спасибо.
de-signer писал(а):Можно ли прикрутить к linuxcnc две карты 5i25
В теории должно работать.
de-signer писал(а):и, соответственно 2 дочерние
К одной 5i25 можно подключить 2 дочерние 7i77 и получить 12 осей + 64 входа + 32 выхода.
de-signer писал(а):Можно ли прикрутить к linuxcnc две карты 5i25 и, соответственно 2 дочерние. Переварит ли hostmot сразу 2 карты или как-то нужно по-другому конфиг править.
Хммм 7i77 держит до 6 серво осей.
Можно и несколько 5i25. в hal они сразу будут как hm2_5i25.0 и hm2_5i25.1
К каждой 5i25 можно до двух 7i77. Ну или там комбинации разные.
А вот кто реально пробовал 5i25+2x7i77? Оно нормально запускается с 12 энкодерами и аналоговыми выходами?
А то мне 15 надо... Изображение
UAVpilot писал(а):А вот кто реально пробовал 5i25+2x7i77? Оно нормально запускается с 12 энкодерами и аналоговыми выходами?
А чего ему будет-то?
на 15 надо 2х5i25 + 3x7i77 :).
Да эт понятно. Но вдруг у какого-нибудь компонента крыша поедет от 15 осей из 9 возможных... :idiot:
Так оси с энкодерами никак не связаны.
Там была штука с ограничением количества stepgen - но это все были программыне stepgen и лечилось правкой пары констант в самом stepgen.
А все месовское крутится на месе, наружу торчат только пины.
Nick писал(а):Так оси с энкодерами никак не связаны.
Это понятно, и исходники подправить не проблема, но хочется до начала трат на железо оценить "масштаб бедствия".
P.S. Ещё надо будет научиться рулить приводами, которым осей не досталось... :thinking: Но это уже наверно будет отдельная тема, если я за это возьмусь и хозяева монстрика разрешат про него тут писать.
А на что хоть примерно столько осей?
управлять можно через M62-66 или, в новых версиях, через прямую утсановку пинов hal из gкода. Все зависит от задачи :).
Nick писал(а):А на что хоть примерно столько осей?
подождите недельку - я сначала сам определюсь возьмусь я за это или нет. Потом спрошу разрешения рассказать про станок, ну или хозяин сам расскажет. :)
Приводов получается 14 (+шпиндель), из них 2 на одну ось и для простоты ещё 4 можно объеденить в одну ось. Но всё равно 9 осей не хватает.
Nick писал(а):управлять можно через M62-66 или, в новых версиях, через прямую утсановку пинов hal из gкода.
Так и планируется, но нужно ещё и синхронное движение нескольких таких осей.
Вернуться в «MESA»
